I’m currently on vacation without ethernet access and want to reinstall manjaro. The issue is that my WiFi drivers need to be manually installed (always installed them with ethernet) and I currently have no option. Does anyone know a way to install the rtl8821ce drivers without having access the internet
Have an android phone that can do USB tethering?
My laptop has the same wifi chip and it does not require an external driver with kernel 5.13, so you could try installing the 21.1.0 RC, which ships with 5.13.
Thank you for your reply! Can this be tested on a live environment, because I can’t test it rn
Sounds good, I may try it!
Got home, tried it and it worked! Thank you
