I’ve used sudo yay rdiff-backup and yay -S rdiff-backup. I’m a newbie manjaro user so extremely unfamiliar with the package/install tools. During the install I keep choosing a, for A[All], as the option as I do not know what the other options do. Keeps getting stuck on the line:
diff --git /home/dad/.cache/yay/rdiff-backup/PKGBUILD /home/dad/.cache/yay/rdiff-backup/PKGBUILD
new file mode 100644
index 0000000…3180f69
Try building it using Manjaro’s package manager, Pamac, either via the GUI or by entering the following command in a terminal:
Note: do NOT use sudo for this command: pamac build rdiff-backup
You may have to enable AUR support in Pamac (via the GUI: Preferences => Third Party), and you may also have to install the base-devel package which provides a lot of the tools required to build packages from the AUR.
I just ran the pamac build command & it took a total of 34 seconds (including the delay it took for me to enter my password when prompted) to build & install rdiff-backup:
I’m getting the message:
WARNING: this command line interface is deprecated and will disappear, start using the new one as described with ‘–new --help’.
Apparently the installed version 2.2.6 is an alfa version. The version I have on my ubuntu machine is 2.0.5. Two questions please, how to uninstall and how to install a stable version?
