I had been working on a qt project which I have to deploy. I found cqtdeploy a good choice for deploying qt projects but the package is only available for x86 architectures. So I went to compile it my own but it required qt-installer-frame work for making which was another package not available for arm64 architecture. Then I tried to install qt-installer-framework from source and ended up in failure.
here are the step that I’ve followed.
git clone https://code.qt.io/cgit/installer-framework/install
er-framework.git
cd installer-framework
mkdir build
cd build
qmake ../*.pro (using qt installed from default repository)
make -j4
sudo make install
Although the source compiled and installed successfully, building the cqtdeploy after all of this thrown the same error saying QtInstallerFramework is not found. I think the installation didn’t took place in right folders that qmake could detect it. I am not much experienced in compiling packages. Am I doing anything wrong?
