"Installing pacman breaks dependency for pacman-contrib"?
Got this error when trying to run sudo pacman . . . . Any immediate fixes for this, or, just wait awhile and it will be resolved??
:: Replace bashrc-manjaro with core/bash? [Y/n] y
resolving dependencies...
:: installing pacman (6.0.2-18) breaks dependency 'pacman-contrib' required by bmenu
:: installing pacman (6.0.2-18) breaks dependency 'pacman-contrib' required by pacui
Read the update announcements.
sudo pacman -Syu pacman-contrib
Very, very busy with life stuff . . . no time to check announcements before running a pacman . . . for the most part Manjaro has been faultless or, with few faults or breakages . . . .
But I ran your suggested command and it went through for the 255 package upgrades.
Thanks for the hint.
I’m sorry to say, then that follows that you have no time for using Manjaro or any other rolling release distro. Every topic you’ve created here were asking questions that were already answered. I suggest using a fixed release distro like Linux Mint instead.
