Installing packages from the testing branch
Hello, everyone
is there a guide on how to install packages from the testing branch? I suspect that proton-vpn-gtk-app might not be working because of a deprecated version. I can see the AUR has the same version as the Manjaro testing branch, but I do not get pacman to offer me a choice.
I have uncommented verbosepkglists in /etc/pacman.conf and restarted my terminal, but to no avail.
Thanks in advance and thank you for being a great community throughout my 11 years as a Linux user thus far.
Switching to Testing branch is not difficult:
sudo pacman-mirrors --api --set-branch testing
sudo pacman-mirrors --continent && sudo pacman -Syu
If you want to return to Stable branch later, you can do so by running the following commands:
sudo pacman-mirrors --api --set-branch stable
sudo pacman-mirrors --continent && sudo pacman -Syuu
Note the extra ā€œuā€ in the second command, which will allow package downgrades when moving from Testing to Stable branch
Amazing. Thank you, @scotty65 <3
Snapshot and Backup before switching branches.
