Storm
25 August 2020 10:45
1
I get this error when trying to install the latest driver.
Waiting for user input...
Starting
> Installing video-nvidia-450xx...
Sourcing /etc/mhwd-x86_64.conf
Has lib32 support: true
Sourcing /var/lib/mhwd/db/pci/graphic_drivers/nvidia-450xx/MHWDCONFIG
Processing classid: 0300
Sourcing /var/lib/mhwd/scripts/include/0300
Processing classid: 0302
checking dependencies...
:: removing linux57-nvidia-440xx breaks dependency 'linux57-nvidia-440xx' required by linux-latest-nvidia-440xx
Error: pacman failed!
Error: script failed!
Done ...
Does it mean I have to uninstall driver 440 manually?
Takei
25 August 2020 10:46
2
No, but you will need to remove the metapackage linux-latest-nvidia-440xx
first, as it blocks the uninstall process.
You can remove it easily with pacman -R linux-latest-nvidia-440xx
There is a very good tutorial with all infos:
Difficulty: ★☆☆☆☆
If you are attempting to change driver selection through Manjaro Settings Manager or mhwd and you receive a message similar to
:: removing XXXXX breaks dependency 'xxxxx' required by nnnnn
then there are 2 things to keep in mind.
It is usually easier to install a new profile than attempting to remove one first.
(especially if is a related upgrade, such as nvi…
Storm
25 August 2020 10:50
4
Thanks to both of you. Installing the latest driver as I type.
system
Closed
28 August 2020 10:50
5
