Installing network-r8168 does not work (no internet)
mhwd --listinstalled
> Installed PCI configs:
           video-linux            2018.05.04                true            PCI
         network-r8168        2023.09.12                true            PCI
I have it listed, but once I do I can no longer access the internet. I’m now using r8169 driver and that one is working.
The reason I wanted to try '68 is because of some lag issues I had in one MMO game I wanted to try.
As I understand it, there is already a kernel driver/module baked into the default kernels which should already handle r8168/r8169 chipsets, without installing an additional driver.
Perhaps someone can clarify this further. @cscs
If I recall correctly this was a nicety when there was no in-kernel module.
Now there is a newer one that is in the kernel … and so this mhwd profile plays the reverse role of being a legacy some can choose if their hardware (or more likely/accurately the old kernel they are using) needs it.
If trying to enable it breaks your networking … then … I would say you dont want to use it.
