Hello, Manjaro isn’t detecting my mic, perhaps it’s a driver issue. The mic I want to use is Boya by-m1.
Here is my output info
Kernel: 5.15.65-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=4dc5b6f6-b6f5-433d-a996-e2cd19a01173 rw quiet
resume=UUID=e3fe5712-6311-4853-9cfd-65decc068d5d udev.log_priority=3
Console: pty pts/1 wm: kwin_x11 DM: SDDM Distro: Manjaro Linux
base: Arch Linux
Type: Desktop Mobo: Micro-Star model: X470 GAMING PRO CARBON (MS-7B78)
v: 1.0 serial: <filter> UEFI: American Megatrends v: 2.50 date: 12/28/2018
RAM: total: 13.6 GiB used: 2.87 GiB (21.1%)
Array-1: capacity: 256 GiB note: check slots: 4 EC: None
max-module-size: 64 GiB note: est.
Device-1: DIMM 0 type: no module installed
Device-2: DIMM 1 type: DDR4 detail: synchronous unbuffered (unregistered)
size: 8 GiB speed: spec: 2133 MT/s actual: 1067 MT/s volts: curr: 1.2
min: 1.2 max: 1.2 width (bits): data: 64 total: 64 manufacturer: Corsair
part-no: CMK8GX4M1D3000C16 serial: N/A
Device-3: DIMM 0 type: no module installed
Device-4: DIMM 1 type: DDR4 detail: synchronous unbuffered (unregistered)
Info: model: AMD Ryzen 3 2200G with Radeon Vega Graphics socket: AM4
bits: 64 type: MCP arch: Zen level: v3 built: 2017-19 process: GF 14nm
family: 0x17 (23) model-id: 0x11 (17) stepping: 0 microcode: 0x810100B
Topology: cpus: 1x cores: 4 smt: <unsupported> cache: L1: 384 KiB
desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
desc: 1x4 MiB
Speed (MHz): avg: 1600 min/max: 1600/3500 boost: enabled
base/boost: 3500/3700 scaling: driver: acpi-cpufreq governor: powersave
volts: 1.4 V ext-clock: 100 MHz cores: 1: 1600 2: 1600 3: 1600 4: 1600
bogomips: 28011
bmi2 bpext clflush clflushopt clzero cmov cmp_legacy constant_tsc cpb
cpuid cr8_legacy cx16 cx8 de decodeassists extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb irperf
lahf_lm lbrv lm mca mce misalignsse mmx mmxext monitor movbe msr mtrr
mwaitx nonstop_tsc nopl npt nrip_save nx osvw overflow_recov pae pat
pausefilter pclmulqdq pdpe1gb perfctr_core perfctr_llc perfctr_nb
pfthreshold pge pni popcnt pse pse36 rapl rdrand rdseed rdtscp rep_good
sep sev sev_es sha_ni skinit smap smca sme smep ssbd sse sse2 sse4_1
sse4_2 sse4a ssse3 succor svm svm_lock syscall tce topoext tsc tsc_scale
v_vmsave_vmload vgif vmcb_clean vme vmmcall wdt xgetbv1 xsave xsavec
xsaveerptr xsaveopt xsaves
prctl and seccomp
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
disabled, RSB filling, PBRSB-eIBRS: Not affected
Device-1: AMD Raven Ridge [Radeon Vega Series / Radeon Mobile Series]
vendor: Micro-Star MSI driver: amdgpu v: kernel arch: GCN-5 code: Vega
process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16
ports: active: HDMI-A-1 empty: DP-1,HDMI-A-2 bus-ID: 38:00.0
chip-ID: 1002:15dd class-ID: 0300
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.3
compositor: kwin_x11 driver: X: loaded: amdgpu unloaded: modesetting
alternate: fbdev,vesa gpu: amdgpu display-ID: :0 screens: 1
Screen-1: 0 s-res: 1280x720 s-dpi: 96 s-size: 337x190mm (13.27x7.48")
s-diag: 387mm (15.23")
Monitor-1: HDMI-A-1 mapped: HDMI-A-0 model: LG (GoldStar) MP59G
serial: <filter> built: 2019 res: 1280x720 dpi: 68 gamma: 1.2
size: 480x270mm (18.9x10.63") diag: 551mm (21.7") ratio: 16:9 modes:
max: 1920x1080 min: 720x400
OpenGL: renderer: AMD Radeon Vega 8 Graphics (raven LLVM 14.0.6 DRM 3.42
5.15.65-1-MANJARO) v: 4.6 Mesa 22.1.7 direct render: Yes
Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio driver: snd_hda_intel
v: kernel pcie: bus-ID: 1-13:7 chip-ID: 0d8c:0012 gen: 3 speed: 8 GT/s
class-ID: 0300 lanes: 16 bus-ID: 38:00.1 chip-ID: 1002:15de class-ID: 0403
Device-2: AMD Family 17h/19h HD Audio vendor: Micro-Star MSI
bus-ID: 38:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-3: C-Media USB Audio Device type: USB
driver: hid-generic,snd-usb-audio,usbhid
Sound Server-1: ALSA v: k5.15.65-1-MANJARO running: yes
Sound Server-3: JACK v: 1.9.21 running: no
Sound Server-4: PulseAudio v: 16.1 running: yes
Sound Server-5: PipeWire v: 0.3.57 running: yes
Device-1: Intel I211 Gigabit Network vendor: Micro-Star MSI driver: igb
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 18:00.0
IF: enp24s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Local Storage: total: 4.09 TiB used: 231.73 GiB (5.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST4000DM004-2CV104
family: BarraCuda 3.5 (SMR) size: 3.64 TiB block-size: physical: 4096 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s type: HDD rpm: 5425
serial: <filter> rev: 0001 temp: 27 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 5897h+07m+06.750s cycles: 680
read: 12.96 TiB written: 8.47 TiB Pre-Fail: attribute: Spin_Retry_Count
value: 100 worst: 100 threshold: 97
ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 860 EVO 500GB
family: based SSDs size: 465.76 GiB block-size: physical: 512 B
logical: 512 B sata: 3.1 speed: 6.0 Gb/s type: SSD serial: <filter>
rev: 2B6Q temp: 25 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 1y 182d 22h cycles: 1426
written: 25.84 TiB
ID-1: / raw-size: 110 GiB size: 107.72 GiB (97.92%) used: 36.19 GiB (33.6%)
fs: ext4 block-size: 4096 B dev: /dev/sdb2 maj-min: 8:18 label: N/A
uuid: 4dc5b6f6-b6f5-433d-a996-e2cd19a01173
ID-2: /boot/efi raw-size: 550 MiB size: 548.9 MiB (99.80%) used: 312 KiB
(0.1%) fs: vfat block-size: 512 B dev: /dev/sdb1 maj-min: 8:17
label: NO_LABEL uuid: 8554-F499
ID-3: /home raw-size: 345 GiB size: 338.52 GiB (98.12%) used: 159.57 GiB
(47.1%) fs: ext4 block-size: 4096 B dev: /dev/sdb3 maj-min: 8:19
label: N/A uuid: d3301e3c-645c-472c-960a-9a0548aa88c2
ID-4: /mnt/GINTORA raw-size: 2.19 TiB size: 2.16 TiB (98.38%) used: 35.97
GiB (1.6%) fs: ext4 block-size: 4096 B dev: /dev/sda1 maj-min: 8:1
label: N/A uuid: d63bc971-f3f6-4412-bd48-3cb2e4b47b27
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default)
ID-1: swap-1 type: partition size: 10.22 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sdb4 maj-min: 8:20 label: N/A
uuid: e3fe5712-6311-4853-9cfd-65decc068d5d
ID-1: /dev/sda2 maj-min: 8:2 size: 1.45 TiB fs: ntfs label: N/A
uuid: B44A084B4A080CB4
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 14 rev: 2.0
Device-1: 1-6:5 info: China Resource Semico Keyboard type: Keyboard,HID
power: 98mA chip-ID: 1a2c:2124 class-ID: 0300
Device-2: 1-12:6 info: [Maxxter] USB OPTICAL MOUSE type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 1.5 Mb/s
power: 100mA chip-ID: 18f8:1485 class-ID: 0301
Device-3: 1-13:7 info: C-Media USB Audio Device type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 0d8c:0012 class-ID: 0300
Hub-2: 2-0:1 info: Super-speed hub ports: 8 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-4: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-5: 5-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
Hub-6: 6-0:1 info: Super-speed hub ports: 1 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 26.5 C mobo: N/A gpu: amdgpu temp: 26.0 C
Processes: 252 Uptime: 16m wakeups: 0 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.2.0 clang: 14.0.6
Packages: 1772 pm: pacman pkgs: 1754 libs: 482 tools: pamac pm: flatpak
pkgs: 18 Shell: Zsh (sudo) v: 5.9 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.21
[(https://www.boya-mic.com/lavaliermicrophones/BY-M1.html)]
