I currently have 2 SSDs and 1 HDD in my PC using windows 10. What I would like to do is format my 2nd SSD and install manjaro on it. I have no DVD or USB drives. An acquaintance told me it may be possible to do the following:
Format 2nd SSD, make 2 partitions with the first partition being just large enough to hold the installer ISO.
Boot into the installer partition and install manjaro to the SSD.
I do have USB ports, just no thumbdrive or external hard drive available atm. I will most likely go purchase a thumbdrive tonight, but I wanted to see if that suggestion was possible. It makes sense in my head, one partition with the installer, boot into it and install the OS to the 2nd partition. I spent some time googling around and can’t find anything conclusive.
Possible would be installing tinycore or alpine on a little partition with grub and put the grub menu of the iso on it, problaly also a tiny efi partition and make it bootable.
Or install Manjaro on a VM, install ALMA and connect the VM to the physical SSD. Then install it there.
