Installing Manjaro on Lenovo IdeaPad Duet, CT-X636F
Hi all, has anyone managed to install Manjaro on a Lenovo Duet? I can’t get the computer to boot from the USB …
Only certain ARM SOCs are supported. From the Manjaro Download page, select ARM and see what is supported clicking on the dropdown under Device Options.
Would “generic” work?
Try efi, it might work to some extend if you have UEFi on the device.
with generic you can add startup.nsh file with the needed boot argument and devicetree as per your device.
Quick look at the device soc, it is MediaTek and I highly doubt it will work.
A kind soul was working on Mainlining it here
Its been stale for sometime plus it was never for the device in question.
