New to manjaro and trying to install on a new SSD in my 2009 MacBook Pro. I’m receiving this error on the GUI install and not sure where to go from here. I took out the SSD and put it in my Lenovo and installed Ubuntu fine so I know the SSD is good.
“Thank The installer failed to create partition on disk ‘Samsung 55D 870 EVO 500GB’.
Create a new partition (465.46 GiB, ext4) on /dev/sda
job: Create new partition on device /dev/sda
Command: mkfs.ext4-qF/dev/sda2 “
Any ideas?
But apple relies on what resides in the EFI partition, for the firmware stuff they have, since they don’t have a BIOS as other Laptops have … And apparently you tried to approach the install the same way as for another Laptop.
To properly install linux on it, check this Laptop/Apple - ArchWiki
Thank you for the info. I have also installed it on my 2012 MacBook Pro without any modifications, but I realize it is a different generation. I looked into the link and that guide says it’s for Model Mac 5, 2.
I looked into mine and it is a 5,5
MB991LL/A
Will this guide still be relevant?
