Per the discussion in the recent testing update thread, I’ve been trying to understand how to correctly install GRUB when required, instead of only updating it. However, I enabled full-disk encryption when I installed my system, using the option provided in the standard GUI installer.
I see in the docs that the install-grub script, which seems like the simplest way to accomplish this, does not support “fancy encryption.” Does the standard full-disk encryption count as “fancy”? If install-grub does not support it, what needs to be done differently to install GRUB when full-disk encryption is in use? I’m not seeing any mention of encryption in those docs to describe how to handle this case.
I’ve searched around but I cannot seem to find additional information about this, so any help would be appreciated!
