Hi, Iβm trying to install Flutter , is the 3 time I try, but I always end in some error, any one know a proven way to install it correctly ??
I need also Android-studio.
Thanks
Hi @paolol
What is the error?
last one was missing ANDOID_SDK_ROOT.
But at the moment I removed all and cleaned the system to start fresh again, when I can find a tutorial that is up to date
so itβs not a problem at the installation but a bad user var after install
After reboot, we have some env variables, for flutter i have ANDOID_SDK_ROOT, FLUTTER_ROOT and CHROME_EXECUTABLE(if chromium installed)
android-sdk is a dependency and write at install instructions for add this var
if all config is good, doctor return ok
$ flutter doctor
Doctor summary (to see all details, run flutter doctor -v):
[β] Flutter (Channel stable, 2.2.1, on Linux, locale fr_FR.UTF-8)
[β] Android toolchain - develop for Android devices (Android SDK version 30.0.3)
[β] Chrome - develop for the web
[β] Linux toolchain - develop for Linux desktop
[β] Android Studio (version 4.2)
[β] Connected device (2 available)
β’ No issues found!
I did a manual install in home and did not use aur - only aur Android-studio (flutter has built-in update notifications and an update command so pacman is no interest for me)
ββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββ
β A new version of Flutter is available! β
β To update to the latest version, run "flutter upgrade". β
$ flutter upgrade
Upgrading Flutter to 2.2.2 from 2.2.1 in /home/patrick/.local/bin/flutter...
Downloading Dart SDK from Flutter engine 91c9fc8fe011352879e3bb6660966eafc0847233...
% Total % Received % Xferd Average Speed Time Time Time Current
Downloading android-arm-release/linux-x64 tools...
Downloading android-x64-release/linux-x64 tools...
Downloading android-x86 tools...
Downloading android-x64 tools...
Downloading android-arm tools...
Downloading linux-x64 tools...
Thanks , so letβs recap.
First I have to install Android studio, then Flutter (aur or Direct ?)
Correct ??
Tahnks
Working thanks
