On Ubuntu I was using Duplicati and would like to continue doing so. However, after the graphical install on Manjaro there was no menu entry, and trying duplicati from terminal returned bash: duplicati: command not found. Terminal install to the rescue:
pamac build duplicati2-beta returns some info not provided by the graphical installer:
* UI can be accessed via following URL: http://localhost:8200
* Running duplicati user instance (using current user account)
- to reload user systemd modules: systemctl --user daemon-reload
- to start duplicati manually: systemctl --user start duplicati
- to autostart duplicati on user login: systemctl --user enable duplicati
Run those commands first (I assume you want Duplicati to autostart at login) before heading to the UI to configure.
End note: There are 2 AUR packages for Duplicati. I chose the beta as that’s the one I was using previously, but I don’t know the difference between it and duplicati-latest.
Hope this little “guide” will be useful to someone!
