I have installed Manjaro 20.1 and buy a wifi usb adapter “TL-WN823N V3” but cannot use it. Can you help me.
Hi!
Can you post the output of
inxi -N
Network: Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169
My usb wifi adapter is not showing.
But using USB Devices-Info center , I got this.
TL-WN823N v2/v3 [Realtek RTL8192EU]
I tried to install it from git clone https://github.com/Mange/rtl8192eu-linux-driver;
and tried to install it through dkms . but hot an error.
sudo dkms install rtl8192eu/1.0;
Error! echo
Your kernel headers for kernel 5.8.6-1-MANJARO cannot be found at
/usr/lib/modules/5.8.6-1-MANJARO/build or /usr/lib/modules/5.8.6-1-MANJARO/source.
You can use the --kernelsourcedir option to tell DKMS where it’s located.
Hi!
you need to install linux58-headers, then try to install the driver again
