I installed the minimum version of Manjaro for Raspberry Pi 4. It booted and installed everything went smoothly.
I tried to update Manjaro with: sudo pacman -Syu which returns a whole punch of 404 errors.
Then I tried to install Cinnamon Desktop Environment: sudo pacman -S cinnamon . It gets the package I hit [y] to install and then every single file returns a 404 error.
If I run: sudo ifconfig
Output: sudo: ifconfig: command not found
I’m connected with ethernet and my router isn’t blocking traffic. I can get SSH access.
I’m pretty sure I need to change PPA’s or configure the internet but I have no idea how to do that in Manjaro. I’m completely new to Manjaro. I’m learning linux but I’ve just used Ubuntu and Raspbian so far.
I got Manjaro here: Downloading File /rpi4/minimal/19.12 - Manjaro ARM - OSDN
I’m using these instructions for install: Install Desktop Environments - Manjaro Linux
