Trying to install catfish file search tool results in a warning that zeitgeist is required my midori, which it then wants to remove.
Not a current problem - I gave in and installed regexxer instead - but I thought someone should know.
The conflict has been added by Arch because of a bug between catfish and zeitgeist.
https://bugs.archlinux.org/task/65344
The last Major Update required me to remove Zeitgeist before I was allowed to apply said Update.
Never heard of Regexxer. OP There is a version of Midori that doesn’t require Zeitgeist. Look in the AUR.
Thanks. As long as someone knows about it.
Regexxer is, I think, somewhat better than catfish anyway - I was going for something I could remember the name of in a hurry but eventually found regexxer.
