Hello!
I am attempting to get the displayport (thunderbolt) port to output a signal to my external monitor. From my 13" macbook pro with only integrated Intel graphics this works fine.
From my main 15" macbook pro with Nvidia/Intel setup I am not getting any signal output to the external monitor. So I am guessing it is a driver issue.
I want to try to use the recommended bumblebee driver to hopefully remedy the displayport issue but when I try to install it it just freezes my computer after restart. What can I do to fix this? I have been trying the same install on Xfce, Gnome and Kde with the same result.
System info:
Kernel: 5.15.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=5b00aa74-4572-4c1b-883d-63755cb04e4e rw quiet
cryptdevice=UUID=7c5bb4e0-2f2e-42aa-966f-96aefda76d1b:luks-7c5bb4e0-2f2e-42aa-966f-96aefda76d1b
root=/dev/mapper/luks-7c5bb4e0-2f2e-42aa-966f-96aefda76d1b splash
apparmor=1 security=apparmor
resume=/dev/mapper/luks-e47fa923-04f4-4257-9db4-b14b68389573
udev.log_priority=3
Desktop: GNOME 41.3 tk: GTK 3.24.31 wm: gnome-shell dm: GDM 41.3
Type: Laptop System: Apple product: MacBookPro9,1 v: 1.0
serial: <superuser required> Chassis: type: 10 v: Mac-4B7AC7E43945597E
Mobo: Apple model: Mac-4B7AC7E43945597E v: MacBookPro9,1
serial: <superuser required> UEFI: Apple v: MBP91.88Z.00DA.B00.1804091930
date: 04/09/2018
ID-1: BAT0 charge: 41.0 Wh (80.4%) condition: 51.0/75.2 Wh (67.8%)
volts: 12.3 min: 10.9 model: SMP bq20z451 type: Li-ion serial: N/A
status: Charging cycles: 770
RAM: total: 7.7 GiB used: 1.24 GiB (16.1%)
RAM Report:
Info: model: Intel Core i7-3820QM bits: 64 type: MT MCP arch: Ivy Bridge
family: 6 model-id: 0x3A (58) stepping: 9 microcode: 0x21
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1512 high: 2815 min/max: 1200/3700 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1197 2: 1197 3: 1213
4: 1287 5: 1313 6: 1877 7: 2815 8: 1197 bogomips: 43112
Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept erms
est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs ida lahf_lm
lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx pae pat pbe
pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts rdrand
rdtscp rep_good sep smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
syscall tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid x2apic
xsave xsaveopt xtopology xtpr
Type: l1tf
Type: srbds status: Vulnerable: No microcode
Device-1: Intel 3rd Gen Core processor Graphics vendor: Apple driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:0166 class-ID: 0300
Device-2: NVIDIA GK107M [GeForce GT 650M Mac Edition] vendor: Apple
driver: nouveau v: kernel bus-ID: 01:00.0 chip-ID: 10de:0fd5 class-ID: 0300
Device-3: Apple FaceTime HD Camera type: USB driver: uvcvideo
bus-ID: 1-1.1:3 chip-ID: 05ac:8509 class-ID: 0e02 serial: <filter>
Display: wayland server: X.Org 1.21.1.4 compositor: gnome-shell driver:
loaded: modesetting alternate: fbdev,vesa display-ID: :0 screens: 1
Screen-1: 0 s-res: 3360x1050 s-dpi: 96 s-size: 889x277mm (35.0x10.9")
s-diag: 931mm (36.7")
Monitor-1: XWAYLAND0 res: 1680x1050 hz: 60 dpi: 129
size: 330x210mm (13.0x8.3") diag: 391mm (15.4")
Monitor-2: XWAYLAND1 res: 1680x1050 hz: 60 dpi: 129
OpenGL: renderer: NVE7 v: 4.3 Mesa 21.3.4 direct render: Yes
Device-1: Intel 7 Series/C216 Family High Definition Audio
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1e20
class-ID: 0403
Device-2: NVIDIA GK107 HDMI Audio vendor: Apple driver: snd_hda_intel
v: kernel bus-ID: 01:00.1 chip-ID: 10de:0e1b class-ID: 0403
Sound Server-1: ALSA v: k5.15.16-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.43 running: no
Device-1: Broadcom NetXtreme BCM57765 Gigabit Ethernet PCIe driver: tg3
v: kernel port: N/A bus-ID: 02:00.0 chip-ID: 14e4:16b4 class-ID: 0200
IF: enp2s0f0 state: down mac: <filter>
Device-2: Broadcom BCM4331 802.11a/b/g/n driver: bcma-pci-bridge v: N/A
modules: bcma bus-ID: 03:00.0 chip-ID: 14e4:4331 class-ID: 0280
IF-ID-1: wlp3s0b1 state: up mac: <filter>
Device-1: Apple Bluetooth USB Host Controller type: USB driver: btusb v: 0.8
bus-ID: 2-1.8.1.3:9 chip-ID: 05ac:821d class-ID: fe01
Device-1: luks-7c5bb4e0-2f2e-42aa-966f-96aefda76d1b maj-min: 254:0
type: LUKS dm: dm-0 size: 438.03 GiB
Components:
p-1: sdb2 maj-min: 8:18 size: 438.03 GiB
Device-2: luks-e47fa923-04f4-4257-9db4-b14b68389573 maj-min: 254:1
type: LUKS dm: dm-1 size: 8.8 GiB
Components:
p-1: sdb3 maj-min: 8:19 size: 8.8 GiB
Local Storage: total: 913.05 GiB used: 10.14 GiB (1.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Apple model: SSD SM512E
size: 465.92 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 7A1Q scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: KingMAX model: SSD 480GB
size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 4E scheme: GPT
ID-1: / raw-size: 438.03 GiB size: 430.09 GiB (98.19%)
used: 10.14 GiB (2.4%) fs: ext4 dev: /dev/dm-0 maj-min: 254:0
mapped: luks-7c5bb4e0-2f2e-42aa-966f-96aefda76d1b label: N/A
uuid: 5b00aa74-4572-4c1b-883d-63755cb04e4e
used: 440 KiB (0.1%) fs: vfat dev: /dev/sdb1 maj-min: 8:17 label: NO_LABEL
uuid: 6C2C-865F
dev: /dev/dm-1 maj-min: 254:1
mapped: luks-e47fa923-04f4-4257-9db4-b14b68389573 label: swap
uuid: 646939f1-17cc-41e0-879e-cba469de2215
ID-1: /dev/sda1 maj-min: 8:1 size: 200 MiB fs: vfat label: EFI
uuid: 67E3-17ED
ID-2: /dev/sda2 maj-min: 8:2 size: 464.51 GiB fs: hfsplus label: OSX
uuid: f7570295-fb9f-385e-8298-72ac36b8ab8d
Hub-1: 1-0:1 info: Full speed or root hub ports: 2 rev: 2.0 speed: 480 Mb/s
speed: 480 Mb/s chip-ID: 8087:0024 class-ID: 0900
Device-1: 1-1.1:3 info: Apple FaceTime HD Camera type: Video
driver: uvcvideo interfaces: 3 rev: 2.0 speed: 480 Mb/s power: 500mA
Hub-3: 2-0:1 info: Full speed or root hub ports: 2 rev: 2.0
Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
Hub-5: 2-1.8:3 info: Microchip (formerly SMSC) 2.0 Hub ports: 3 rev: 2.0
speed: 480 Mb/s power: 2mA chip-ID: 0424:2513 class-ID: 0900
Hub-6: 2-1.8.1:4
info: Broadcom BCM2046B1 USB 2.0 Hub (part of BCM2046 Bluetooth) ports: 3
rev: 2.0 speed: 12 Mb/s power: 94mA chip-ID: 0a5c:4500 class-ID: 0900
Device-1: 2-1.8.1.3:9 info: Apple Bluetooth USB Host Controller
type: Bluetooth driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s
Device-2: 2-1.8.2:5 info: Apple Built-in IR Receiver type: HID
driver: appleir,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s power: 100mA
chip-ID: 05ac:8242 class-ID: 0300
Device-3: 2-1.8.3:6 info: Apple Internal Keyboard/Trackpad (ISO)
type: Keyboard,HID,Mouse driver: apple,bcm5974,usbhid interfaces: 3 rev: 2.0
speed: 12 Mb/s power: 40mA chip-ID: 05ac:0253 class-ID: 0301
Hub-7: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-8: 4-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
System Temperatures: cpu: 69.0 C mobo: N/A gpu: nouveau temp: 58.0 C
Processes: 294 Uptime: 0m wakeups: 2 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1154 lib: 306
flatpak: 0 Shell: Zsh v: 5.8 running-in: gnome-terminal inxi: 3.3.12
Driver info
> PCI Device: /devices/pci0000:00/0000:00:01.0/0000:01:00.0 (0300:10de:0fd5)
Display controller nVidia Corporation GK107M [GeForce GT 650M Mac Edition]
> INSTALLED:
ATTACHED: PCI
VERSION: 2018.05.04
INFO: Standard open source drivers.
PRIORITY: 2
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300 0380 0302
VENDORIDS: 1002 8086 10de
> AVAILABLE:
ATTACHED: PCI
VERSION: 2021.12.18
INFO: Hybrid bumblebee solution for NVIDIA Optimus Technology - Closed source NVIDIA driver & open source intel driver.
PRIORITY: 6
FREEDRIVER: false
DEPENDS: -
CONFLICTS: video*nvidia*
CLASSIDS: 0300 0302 0300
VENDORIDS: 10de 8086
ATTACHED: PCI
VERSION: 2021.12.18
INFO: Closed source NVIDIA drivers for linux.
PRIORITY: 3
FREEDRIVER: false
DEPENDS: -
CLASSIDS: 0300 0302
VENDORIDS: 10de
ATTACHED: PCI
VERSION: 2018.05.04
PRIORITY: 2
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
ATTACHED: PCI
VERSION: 2020.01.13
INFO: X .org modesetting video driver.
PRIORITY: 1
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300
VENDORIDS: *
ATTACHED: PCI
VERSION: 2017.03.12
INFO: X .org vesa video driver.
PRIORITY: 0
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300
VENDORIDS: *
> PCI Device: /devices/pci0000:00/0000:00:02.0 (0300:8086:0166)
Display controller Intel Corporation 3rd Gen Core processor Graphics Controller
> INSTALLED:
ATTACHED: PCI
VERSION: 2018.05.04
PRIORITY: 2
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
> AVAILABLE:
ATTACHED: PCI
VERSION: 2021.12.18
PRIORITY: 6
FREEDRIVER: false
DEPENDS: -
ATTACHED: PCI
VERSION: 2018.05.04
PRIORITY: 2
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
ATTACHED: PCI
VERSION: 2020.01.13
INFO: X. org modesetting video driver.
PRIORITY: 1
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300
VENDORIDS: *
ATTACHED: PCI
VERSION: 2017.03.12
PRIORITY: 0
FREEDRIVER: true
DEPENDS: -
CONFLICTS: -
CLASSIDS: 0300
VENDORIDS: *
Warning: no configs for USB devices found!
Bumblebee install info
> Installing video-hybrid-intel-nvidia-390xx-bumblebee...
Sourcing /etc/mhwd-x86_64.conf
Has lib32 support: true
Sourcing /var/lib/mhwd/db/pci/graphic_drivers/hybrid-intel-nvidia-390xx-bumblebee/MHWDCONFIG
Processing classid: 0300
Sourcing /var/lib/mhwd/scripts/include/0300
core downloading...
extra downloading...
community downloading...
multilib downloading...
warning: xf86-video-intel-1:2.99.917+916+g31486f40-2 is up to date -- skipping
resolving dependencies...
warning: dependency cycle detected:
warning: primus will be installed before its bumblebee dependency
Packages (12) egl-wayland-2:1.1.9+r3+g582b2d3-1 eglexternalplatform-1.1-2 primus-20151110-9 bumblebee-3.2.1-22 lib32-nvidia-390xx-utils-390.147-2 lib32-primus-20151110-4 libxnvctrl-390xx-390.147-1 linux510-bbswitch-0.8-109 linux510-nvidia-390xx-390.147-7 linux515-bbswitch-0.8-23 linux515-nvidia-390xx-390.147-7 nvidia-390xx-utils-390.147-3
Total Download Size: 104.94 MiB
Total Installed Size: 241.26 MiB
:: Retrieving packages...
Y
nvidia-390xx-utils-390.147-3-x86_64 downloading...
lib32-nvidia-390xx-utils-390.147-2-x86_64 downloading...
linux515-nvidia-390xx-390.147-7-x86_64 downloading...
linux510-nvidia-390xx-390.147-7-x86_64 downloading...
linux515-bbswitch-0.8-23-x86_64 downloading...
linux510-bbswitch-0.8-109-x86_64 downloading...
libxnvctrl-390xx-390.147-1-x86_64 downloading...
primus-20151110-9-x86_64 downloading...
lib32-primus-20151110-4-x86_64 downloading...
bumblebee-3.2.1-22-x86_64 downloading...
egl-wayland-2:1.1.9+r3+g582b2d3-1-x86_64 downloading...
eglexternalplatform-1.1-2-any downloading...
checking keyring...
checking package integrity...
loading package files...
checking for file conflicts...
checking available disk space...
installing primus...
installing eglexternalplatform...
installing egl-wayland...
installing libxnvctrl-390xx...
installing nvidia-390xx-utils...
==> If you run into trouble with CUDA not being available, run nvidia-modprobe first.
Optional dependencies for nvidia-390xx-utils
xorg-server-devel: nvidia-xconfig
opencl-nvidia-390xx: OpenCL support
installing bumblebee...
Don't forget to add yourself to the 'bumblebee' group to use Bumblebee
Optional dependencies for bumblebee
xf86-video-nouveau: nouveau driver [installed]
nouveau-dri: 3D acceleration features fo nouveau
bbswitch: switch on/off discrete card [pending]
nvidia: NVIDIA kernel driver [pending]
virtualgl: alternative back-end for optirun
lib32-virtualgl: run 32bit applications with optirun
lib32-primus: faster back-end for optirun [pending]
installing lib32-nvidia-390xx-utils...
Optional dependencies for lib32-nvidia-390xx-utils
lib32-opencl-nvidia
installing lib32-primus...
installing linux510-nvidia-390xx...
In order to use nvidia module, reboot the system.
installing linux510-bbswitch...
installing linux515-nvidia-390xx...
installing linux515-bbswitch...
(1/7) Creating system user accounts...
Creating group 'bumblebee' with GID 56.
Creating group 'nvidia-persistenced' with GID 143.
Creating user 'nvidia-persistenced' (NVIDIA Persistence Daemon) with UID 143 and GID 143.
(2/7) Reloading system manager configuration...
(3/7) Reloading device manager configuration...
(4/7) Arming ConditionNeedsUpdate...
(5/7) Updating module dependencies...
(6/7) Refreshing PackageKit...
(7/7) Updating the desktop file MIME type cache...
bumblebee: install reason has been set to 'explicitly installed'
nvidia-390xx-utils: install reason has been set to 'explicitly installed'
libxnvctrl-390xx: install reason has been set to 'explicitly installed'
xf86-video-intel: install reason has been set to 'explicitly installed'
lib32-primus: install reason has been set to 'explicitly installed'
lib32-nvidia-390xx-utils: install reason has been set to 'explicitly installed'
linux510-nvidia-390xx: install reason has been set to 'explicitly installed'
linux510-bbswitch: install reason has been set to 'explicitly installed'
linux515-nvidia-390xx: install reason has been set to 'explicitly installed'
linux515-bbswitch: install reason has been set to 'explicitly installed'
modprobe: ERROR: could not insert 'bbswitch': No such device
xorg configuration file: '/etc/X11/mhwd.d/intel.conf'
Created symlink /etc/systemd/system/multi-user.target.wants/bumblebeed.service → /usr/lib/systemd/system/bumblebeed.service.
> Successfully installed video-hybrid-intel-nvidia-390xx-bumblebee
