Installing and using XLibre on Manjaro
Hi, everyone! Has anyone successfully got XLibre working on Manjaro?
I’m currently using Manjaro + Wayland + GDM + GNOME with all updates applied.
I ran the install script as instructed here:
$ sudo sh -c "$(curl -fsSL https://x11libre.net/repo/arch_based/x86_64/install-xlibre.sh)"
The XLibre packages got installed, but I don’t know how to use it.
I tried disabling Wayland and switching to LightDM without success. Whenever I run:
$ echo $XDG_SESSION_TYPE
I get wayland.
I found no option to start XLibre then GNOME.
At least I didn’t loose access to my everyday GNOME desktop trying things…
Thank you in advance!
Gnome no longer supports X11, so you won’t be able to use it with xlibre.
Many thanks! I was not aware of that…
According to a quick search, there are some desktops that still support X11, including XFCE, Cinnamon, MATE, LXQt and LXDE.
Just out of curiosity, I decided to give Cinnamon a try:
$ sudo pacman -S cinnamon cinnamon-wallpapers cinnamon-sounds
Then with LightDM I started a Cinnamon session.
I can confirm that I’m running XLibre on Manjaro:
x11
$ sudo X -version
XLibre X Server 1.25.0
Current Operating System: Linux predator 6.18.33-1-MANJARO #1 SMP PREEMPT_DYNAMIC Sun, 24 May 2026 04:55:09 +0000 x86_64
Kernel command line: BOOT_IMAGE=/@/boot/vmlinuz-6.18-x86_64 root=UUID=30aa7898-0bce-4ed7-ad91-a68a047ebdb8 rw rootflags=subvol=@ quiet splash apparmor=1 security=apparmor resume=UUID=245b1017-029b-4b7c-8a6c-c850bd5aeef3 udev.log_priority=3
Current version of pixman: 0.46.4
	Before reporting problems, check https://github.com/X11Libre/xserver
Do you know something that works with XLibre that does not work with Wayland? The Resize feature of the Web Developer Google Chrome extension.
Check the Spins section of the forum. Some spins use it by default.
SonicDE (Based of KDE) XLibre KDE I think.
And XLibre
for those interested in xorg based window managers, xlibre is very nearly a ‘godsend’.
I use xlibre on all of my Arch-based systems, including those that are primarily Wayland. My main system is Hyprland:
$ pacman -Qs 'hypr|xlibre'
local/hyprcursor 0.1.13-6
    The hyprland cursor format, library and utilities
local/hyprgraphics 0.5.1-2
    hyprland graphics resources and utilities
local/hyprland 0.55.4-1
    a highly customizable dynamic tiling Wayland compositor
local/hyprland-guiutils 0.2.1-6
    Hyprland GUI utilities
local/hyprlang 0.6.8-4
    implementation library for the hypr config language
local/hyprshot 1.3.0-4
    Hyprland screenshot utility
local/hyprtoolkit 0.5.4-2
    A modern C++ Wayland-native GUI toolkit
local/hyprutils 0.13.1-1
    Hyprland utilities library used across the ecosystem
local/hyprwayland-scanner 0.4.6-1
    A Hyprland implementation of wayland-scanner, in and for C++
local/hyprwire 0.3.1-2
    A fast and consistent wire protocol for IPC
local/nwg-displays 0.4.3-1
    Output management utility for sway and Hyprland Wayland compositors
local/xlibre-input-evdev 25.0.0-7 (xlibre-drivers)
    XLibre fork of X.Org evdev input driver
local/xlibre-input-libinput 25.0.1-2 (xlibre-drivers)
    Generic input driver for the XLibre Xserver based on libinput
local/xlibre-xserver 25.1.8-1 (xlibre)
    XLibre X server
local/xlibre-xserver-common 25.1.8-1 (xlibre)
    XLibre server common files
local/xlibre-xserver-devel 25.1.8-1 (xlibre)
    Development files for the XLibre Xserver
It sucks Arch took XLibre of the repo.
Other than the various AUR packages (which are what I’m using), I don’t remember it ever being in the Arch repos.
Spoon feeding seems needed here. Somebody just set a repo for this and testers are needed. Still, besides DelinuxCo check also the Sbk spins, i think he also had a xlibre flavour.
I just updated all of my XLibre-based Manjaro systems - no problems with any of them. These systems were already running on XLibre (with the same package versions), so I didn’t expect any issues, other than maybe from the new repo.
Linux Mint ditched Ubuntu as a base, so big things happen sometimes. Still on Wayland though….
I don’t know where you got that information, and I am sorry, but I am not going to watch yet another YouTube talking head — and in Portugese for that matter — but it’s not true.
What is true is that Mint has for several years already been offering LMDE, which is a long-term-support release directly based upon Debian. But the “normal” versions of Mint are based upon Ubuntu, and the next release is either way also still going to be based on Ubuntu.
Ok, I thought the whole point of the video was that. Why did they ditch the Ubuntu installer? I misundrestood, apparently. He never really said Debian is the only base now, but why say they ditched the Ubuntu installer? I only said, what it sounded like to me. Odd, it is english audio for me, no translation ad on also.
Modedit: removed useless screenshot.
It has original Portugese audio and machine translated audiotracks for English and Spanish.
Ok, I was wondering what was going on. My dad played it on his phone & it wasn’t English.
