GOD1
19 November 2021 10:25
1
I am trying to install 2bwm on xfce but failed
i refer GitHub - venam/2bwm: A fast floating WM written over the XCB library and derived from mcwm. and 2bwm - ArchWiki
but failed i have the dependencies but when i ran 2bwm
and even changed wm to 2bwm it gave error xcb_request_check:faild.
I have tried adding 2bwm.desktop
in /usr/share/xsessions
and both 2bwm and 2bwm-git package
plz help me fix this
GOD1
20 November 2021 09:41
2
i tried to install 3bwm from github branch it gave error fish: Job 1, '2bwm' terminated by signal SIGSEGV (Address boundary error)
It’s not an easy task to set up 2bwm.
Wen you start it you needs to start a root window which you should never close.
GOD1
24 November 2021 06:48
4
@eugen-b xcb_request_check:faild. urxvt: the locale is not supported by Xlib, continuing without locale support
for now i will leave it and use qtile and networkmanager applet is not saving password maybe i need to search and configure more or create another forum
system
Closed
26 November 2021 20:48
5
