Installer doesn't boot with proprietary drivers, stuck at blinking cursor
Hello Manjaro community,
i have a problem with manjaro which prevents me from using it on my computer. I wouldn’t call myself a total linux newbie, however when it comes to troubleshooting something as systembreaking as this, i have no idea where to even start. Sometime around the beginning of December, I had a perfectly working manjaro install, that i unfortunately hadn’t used in about a month and when i attempted an update, it broke and hung on a blinking cursor screen. I wanted to do a clean reinstall, but I couldn’t boot into the install it behaved exactly the same. The issue is that when i attempt to boot the installer with proprietary drivers, it fails in the same way.
Installing with open source drivers works, but when i install the nvidia drivers, it breaks again. When i boot an older iso with kernel 513, it works as intended, but since 513 is eol, it is of no use to me and i suspect, it would break when updated anyway.
The problem:
Whenever i attempt to boot the installer it goes on normally until “reached target graphical interface”, at that point, the screen becomes blank with only a blinking cursor in the top right. The blinking is irregular, it isnt periodic, like it normally is in tty. It doesnt allow me to switch to tty2, it simply doesnt react to pressing the button combination. Sometimes when i hold the button combination, i can see the tty2 login flash on screen for a split second before it returns to the blinking cursor.
I originally tought that it was just the current nvidia driver version not being happy with my particular hardware combination, and that it will get fixed with an update(as has happened to me already in August of this year). Unfortunately the newest update hasn’t fixed anything.
Branch: Stable
Desktop Environment: Happens on all of them (XFCE,KDE,GNOME)
CPU: Ryzen 1600X (6 core) @ 3.6GHz
GPU: Nvidia RTX 3070
I can’t really provide more, since the system doesn’t even allow me to access the tty. I will try to respond/edit this post with any and all extra information that might help fix this issue.
Thank you for reading my post and, in advance, for your answers.
Interesting. Booting with runlevel 3 did allow me to access tty and log in successfuly. Updating did nothing, since the iso is new so there were no new packages to install.
Starting X fails with an error. In the x log there is a line “NVIDIA: Error failed to initialize the NVIDIA GPU at PCI:36:0:0.” It also tells me to check the kernel log, however i don’t know where that is located.
In /var/log/mhwd-live.log there are some error lines at the end. Specifically
“mrmmod: Error could not remove ‘ttm’: Resource temporarily unavailable”
“mrmmod Error: Could not remove module ttm: Resource temporarily unavaliable”
The same messages are then repeates for “drm_kms_helper” and “drm”
So it seems, that it is really the Nvidia drivers throwing a fit, the question is, whether i can somehow stop them from doing it.
Since you’re able to use tty now, can you provide your system information inxi -Fazy and kernel log sudo dmesg?
This can help:
Sorry for the late reply, the requested logs are located on these links:
https://0x0.st/oi7p.txt - inxi
https://0x0.st/oi7f.json -dmesg
Your inxi output:
  Kernel: 5.15.12-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
    parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
    misobasedir=manjaro misolabel=MANJARO_XFCE_2121 3 systemd.show_status=1
    apparmor=1 security=apparmor driver=nonfree nouveau.modeset=0
    i915.modeset=1 radeon.modeset=1
  Console: tty 1 DM: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
  Type: Laptop Mobo: Micro-Star model: X370 GAMING PRO CARBON (MS-7A32) v: 1.0
    serial: <superuser required> UEFI: American Megatrends v: 1.20
    date: 03/16/2017
  Info: model: AMD Ryzen 5 1600X bits: 64 type: MT MCP arch: Zen
    family: 0x17 (23) model-id: 1 stepping: 1 microcode: 0x8001105
    L1: 576 KiB desc: d-6x32 KiB; i-6x64 KiB L2: 3 MiB desc: 6x512 KiB
    L3: 16 MiB desc: 2x8 MiB
  Speed (MHz): avg: 1955 high: 2747 min/max: 2200/3800 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1881 2: 2747
    3: 1895 4: 1892 5: 1894 6: 1888 7: 1879 8: 1876 9: 1881 10: 1875 11: 1880
    12: 1876 bogomips: 91069
  Type: spectre_v2
    mitigation: Full AMD retpoline, STIBP: disabled, RSB filling
  Device-1: NVIDIA GA104 [GeForce RTX 3070] vendor: ASUSTeK driver: nvidia
    v: 495.44 alternate: nouveau,nvidia_drm bus-ID: 24:00.0 chip-ID: 10de:2484
    class-ID: 0300
  Display: server: X.org 1.21.1.2 driver: loaded: nvidia
    note: n/a (using device driver) tty: 128x48
  Device-1: NVIDIA GA104 High Definition Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel bus-ID: 24:00.1 chip-ID: 10de:228b
    class-ID: 0403
  Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI
    driver: snd_hda_intel v: kernel bus-ID: 26:00.3 chip-ID: 1022:1457
    class-ID: 0403
  Device-3: Shure MV5 type: USB driver: hid-generic,snd-usb-audio,usbhid
    bus-ID: 5-3:3 chip-ID: 14ed:1000 class-ID: 0300
  Sound Server-1: ALSA v: k5.15.12-1-MANJARO running: yes
  Sound Server-3: PulseAudio v: 15.0 running: no
  Sound Server-4: PipeWire v: 0.3.42 running: no
  Device-1: Intel I211 Gigabit Network vendor: Micro-Star MSI driver: igb
    v: kernel port: f000 bus-ID: 1e:00.0 chip-ID: 8086:1539 class-ID: 0200
  IF: enp30s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Local Storage: total: 2.64 TiB used: 0 KiB (0.0%)
    model: WDS100T2B0C-00PXH0 size: 931.51 GiB block-size: physical: 512 B
    rev: 211210WD temp: 43.9 C scheme: GPT
  ID-2: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS541010A9E680
    type: HDD rpm: 5400 serial: <filter> rev: A560 scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 vendor: Western Digital
    model: WDS250G2B0B-00YS70 size: 232.89 GiB block-size: physical: 512 B
    logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter> rev: 30WD
    scheme: GPT
  ID-4: /dev/sdc maj-min: 8:32 vendor: Toshiba model: MK6476GSX
    size: 596.17 GiB block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s
    type: HDD rpm: 5400 serial: <filter> rev: 1C scheme: GPT
  ID-5: /dev/sdd maj-min: 8:48 type: USB vendor: Kingston
    model: DataTraveler 2.0 size: 14.54 GiB block-size: physical: 512 B
    logical: 512 B type: N/A serial: <filter> rev: PMAP scheme: MBR
  Message: No partition data found.
  System Temperatures: cpu: 39.4 C mobo: N/A
  Processes: 247 Uptime: 2m wakeups: 0 Memory: 15.64 GiB
  used: 1.88 GiB (12.0%) Init: systemd v: 250 tool: systemctl Compilers:
  gcc: N/A Packages: pacman: 1145 lib: 315 flatpak: 0 Shell: Bash (login)
  v: 5.1.12 running-in: tty 1 inxi: 3.3.11
Your dmesg output:
[    0.000000] Linux version 5.15.12-1-MANJARO (builduser@fv-az39-353) (gcc (GCC) 11.1.0, GNU ld (GNU Binutils) 2.36.1) #1 SMP PREEMPT Wed Dec 29 18:08:07 UTC 2021
[    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC misobasedir=manjaro misolabel=MANJARO_XFCE_2121 3 systemd.show_status=1 apparmor=1 security=apparmor driver=nonfree nouveau.modeset=0 i915.modeset=1 radeon.modeset=1
[    0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[    0.000000] x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
[    0.000000] x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'compacted' format.
[    0.000000] signal: max sigframe size: 1776
[    0.000000] BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009ffff] usable
[    0.000000] BIOS-e820: [mem 0x00000000000a0000-0x00000000000fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x0000000001d7ffff] usable
[    0.000000] BIOS-e820: [mem 0x0000000001d80000-0x0000000001ffffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000002000000-0x00000000dcd71fff] usable
[    0.000000] BIOS-e820: [mem 0x00000000dcd72000-0x00000000dced7fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000dced8000-0x00000000dd292fff] usable
[    0.000000] BIOS-e820: [mem 0x00000000dd293000-0x00000000dd39cfff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x00000000dd39d000-0x00000000de387fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000de388000-0x00000000de3ebfff] type 20
[    0.000000] BIOS-e820: [mem 0x00000000de3ec000-0x00000000deffffff] usable
[    0.000000] BIOS-e820: [mem 0x00000000df000000-0x00000000dfffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000f8000000-0x00000000fbffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fdf00000-0x00000000fdffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fea00000-0x00000000fea0ffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000feb80000-0x00000000fec01fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fec10000-0x00000000fec10fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fec30000-0x00000000fec30fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed40000-0x00000000fed44fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed80000-0x00000000fed8ffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fedc2000-0x00000000fedcffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fedd4000-0x00000000fedd5fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000feefffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000041f37ffff] usable
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] efi: EFI v2.50 by American Megatrends
[    0.000000] efi: TPMFinalLog=0xdd34f000 ACPI 2.0=0xdd293000 ACPI=0xdd293000 SMBIOS=0xde2f9000 ESRT=0xd8fe3a98
[    0.000000] SMBIOS 3.0 present.
[    0.000000] DMI: Micro-Star International Co., Ltd MS-7A32/X370 GAMING PRO CARBON (MS-7A32), BIOS 1.20 03/16/2017
[    0.000000] tsc: Fast TSC calibration failed
[    0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[    0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.000000] last_pfn = 0x41f380 max_arch_pfn = 0x400000000
[    0.000000] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
[    0.000000] total RAM covered: 3568M
[    0.000000] Found optimal setting for mtrr clean up
[    0.000000]  gran_size: 64K 	chunk_size: 1G 	num_reg: 3  	lose cover RAM: 0G
[    0.000000] e820: update [mem 0xdf000000-0xffffffff] usable ==> reserved
[    0.000000] last_pfn = 0xdf000 max_arch_pfn = 0x400000000
[    0.000000] esrt: Reserving ESRT space from 0x00000000d8fe3a98 to 0x00000000d8fe3ad0.
[    0.000000] e820: update [mem 0xd8fe3000-0xd8fe3fff] usable ==> reserved
[    0.000000] Using GB pages for direct mapping
[    0.000000] Secure boot disabled
[    0.000000] RAMDISK: [mem 0x318f1000-0x34c6ffff]
[    0.000000] ACPI: Early table checksum verification disabled
[    0.000000] ACPI: RSDP 0x00000000DD293000 000024 (v02 ALASKA)
[    0.000000] ACPI: XSDT 0x00000000DD2930A0 0000C4 (v01 ALASKA A M I    01072009 AMI  00010013)
[    0.000000] ACPI: FACP 0x00000000DD298E30 000114 (v06 ALASKA A M I    01072009 AMI  00010013)
[    0.000000] ACPI BIOS Warning (bug): Optional FADT field Pm2ControlBlock has valid Length but zero Address: 0x0000000000000000/0x1 (20210730/tbfadt-615)
[    0.000000] ACPI: DSDT 0x00000000DD293200 005C2F (v02 ALASKA A M I    01072009 INTL 20120913)
[    0.000000] ACPI: FACS 0x00000000DD39AC80 000040
[    0.000000] ACPI: APIC 0x00000000DD298F48 0000DE (v03 ALASKA A M I    01072009 AMI  00010013)
[    0.000000] ACPI: FPDT 0x00000000DD299028 000044 (v01 ALASKA A M I    01072009 AMI  00010013)
[    0.000000] ACPI: SSDT 0x00000000DD299070 008C4C (v02                 00000002 MSFT 04000000)
[    0.000000] ACPI: FIDT 0x00000000DD2A1CC0 00009C (v01 ALASKA A M I    01072009 AMI  00010013)
[    0.000000] ACPI: SSDT 0x00000000DD2A1D60 0018B4 (v01 AMD    AmdTable 00000001 AMD  00000001)
[    0.000000] ACPI: SRAT 0x00000000DD2A3618 0000F0 (v03 AMD    AmdTable 00000001 AMD  00000001)
[    0.000000] ACPI: CRAT 0x00000000DD2A3708 000BD0 (v01 AMD    AmdTable 00000001 AMD  00000001)
[    0.000000] ACPI: CDIT 0x00000000DD2A42D8 000029 (v01 AMD    AmdTable 00000001 AMD  00000001)
[    0.000000] ACPI: SSDT 0x00000000DD2A4308 0017A1 (v01 AMD    AOD      00000001 INTL 20120913)
[    0.000000] ACPI: MCFG 0x00000000DD2A5AB0 00003C (v01 ALASKA A M I    01072009 MSFT 00010013)
[    0.000000] ACPI: HPET 0x00000000DD2A5AF0 000038 (v01 ALASKA A M I    01072009 AMI  00000005)
[    0.000000] ACPI: SSDT 0x00000000DD2A5B28 000024 (v01 AMDFCH FCHZP    00001000 INTL 20120913)
[    0.000000] ACPI: UEFI 0x00000000DD2A5B50 000042 (v01                 00000000      00000000)
[    0.000000] ACPI: TPM2 0x00000000DD2A5B98 000034 (v03        Tpm2Tabl 00000001 AMI  00000000)
[    0.000000] ACPI: IVRS 0x00000000DD2A5BD0 0000D0 (v02                 00000001 AMD  00000000)
[    0.000000] ACPI: BGRT 0x00000000DD2A5CA0 000038 (v01 ALASKA A M I    01072009 AMI  00010013)
[    0.000000] ACPI: SSDT 0x00000000DD2A5CD8 0000F8 (v01 AMDFCH FCHPT    00001000 INTL 20120913)
[    0.000000] ACPI: SSDT 0x00000000DD2A5DD0 001664 (v01 AMD    CPMCMN   00000001 INTL 20120913)
[    0.000000] ACPI: BGRT 0x00000000DD2A7438 000038 (v01 ALASKA A M I    01072009 AMI  00010013)
[    0.000000] ACPI: Reserving FACP table memory at [mem 0xdd298e30-0xdd298f43]
[    0.000000] ACPI: Reserving DSDT table memory at [mem 0xdd293200-0xdd298e2e]
[    0.000000] ACPI: Reserving FACS table memory at [mem 0xdd39ac80-0xdd39acbf]
[    0.000000] ACPI: Reserving APIC table memory at [mem 0xdd298f48-0xdd299025]
[    0.000000] ACPI: Reserving FPDT table memory at [mem 0xdd299028-0xdd29906b]
[    0.000000] ACPI: Reserving SSDT table memory at [mem 0xdd299070-0xdd2a1cbb]
[    0.000000] ACPI: Reserving FIDT table memory at [mem 0xdd2a1cc0-0xdd2a1d5b]
[    0.000000] ACPI: Reserving SSDT table memory at [mem 0xdd2a1d60-0xdd2a3613]
[    0.000000] ACPI: Reserving SRAT table memory at [mem 0xdd2a3618-0xdd2a3707]
[    0.000000] ACPI: Reserving CRAT table memory at [mem 0xdd2a3708-0xdd2a42d7]
[    0.000000] ACPI: Reserving CDIT table memory at [mem 0xdd2a42d8-0xdd2a4300]
[    0.000000] ACPI: Reserving SSDT table memory at [mem 0xdd2a4308-0xdd2a5aa8]
[    0.000000] ACPI: Reserving MCFG table memory at [mem 0xdd2a5ab0-0xdd2a5aeb]
[    0.000000] ACPI: Reserving HPET table memory at [mem 0xdd2a5af0-0xdd2a5b27]
[    0.000000] ACPI: Reserving SSDT table memory at [mem 0xdd2a5b28-0xdd2a5b4b]
[    0.000000] ACPI: Reserving UEFI table memory at [mem 0xdd2a5b50-0xdd2a5b91]
[    0.000000] ACPI: Reserving TPM2 table memory at [mem 0xdd2a5b98-0xdd2a5bcb]
[    0.000000] ACPI: Reserving IVRS table memory at [mem 0xdd2a5bd0-0xdd2a5c9f]
[    0.000000] ACPI: Reserving BGRT table memory at [mem 0xdd2a5ca0-0xdd2a5cd7]
[    0.000000] ACPI: Reserving SSDT table memory at [mem 0xdd2a5cd8-0xdd2a5dcf]
[    0.000000] ACPI: Reserving SSDT table memory at [mem 0xdd2a5dd0-0xdd2a7433]
[    0.000000] ACPI: Reserving BGRT table memory at [mem 0xdd2a7438-0xdd2a746f]
[    0.000000] system APIC only can use physical flat
[    0.000000] Setting APIC routing to physical flat.
[    0.000000] SRAT: PXM 0 -> APIC 0x00 -> Node 0
[    0.000000] SRAT: PXM 0 -> APIC 0x01 -> Node 0
[    0.000000] SRAT: PXM 0 -> APIC 0x02 -> Node 0
[    0.000000] SRAT: PXM 0 -> APIC 0x03 -> Node 0
[    0.000000] SRAT: PXM 0 -> APIC 0x04 -> Node 0
[    0.000000] SRAT: PXM 0 -> APIC 0x05 -> Node 0
[    0.000000] SRAT: PXM 0 -> APIC 0x08 -> Node 0
[    0.000000] SRAT: PXM 0 -> APIC 0x09 -> Node 0
[    0.000000] SRAT: PXM 0 -> APIC 0x0a -> Node 0
[    0.000000] SRAT: PXM 0 -> APIC 0x0b -> Node 0
[    0.000000] SRAT: PXM 0 -> APIC 0x0c -> Node 0
[    0.000000] SRAT: PXM 0 -> APIC 0x0d -> Node 0
[    0.000000] No NUMA configuration found
[    0.000000] Faking a node at [mem 0x0000000000000000-0x000000041f37ffff]
[    0.000000] NODE_DATA(0) allocated [mem 0x41f37c000-0x41f37ffff]
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[    0.000000]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
[    0.000000]   Normal   [mem 0x0000000100000000-0x000000041f37ffff]
[    0.000000]   Device   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000001000-0x000000000009ffff]
[    0.000000]   node   0: [mem 0x0000000000100000-0x0000000001d7ffff]
[    0.000000]   node   0: [mem 0x0000000002000000-0x00000000dcd71fff]
[    0.000000]   node   0: [mem 0x00000000dced8000-0x00000000dd292fff]
[    0.000000]   node   0: [mem 0x00000000de3ec000-0x00000000deffffff]
[    0.000000]   node   0: [mem 0x0000000100000000-0x000000041f37ffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000001000-0x000000041f37ffff]
[    0.000000] On node 0, zone DMA: 1 pages in unavailable ranges
[    0.000000] On node 0, zone DMA: 96 pages in unavailable ranges
[    0.000000] On node 0, zone DMA32: 640 pages in unavailable ranges
[    0.000000] On node 0, zone DMA32: 358 pages in unavailable ranges
[    0.000000] On node 0, zone DMA32: 4441 pages in unavailable ranges
[    0.000000] On node 0, zone Normal: 4096 pages in unavailable ranges
[    0.000000] On node 0, zone Normal: 3200 pages in unavailable ranges
[    0.000000] ACPI: PM-Timer IO Port: 0x808
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[    0.000000] IOAPIC[0]: apic_id 13, version 33, address 0xfec00000, GSI 0-23
[    0.000000] IOAPIC[1]: apic_id 14, version 33, address 0xfec01000, GSI 24-55
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
[    0.000000] ACPI: Using ACPI (MADT) for SMP configuration information
[    0.000000] ACPI: HPET id: 0x10228201 base: 0xfed00000
[    0.000000] e820: update [mem 0xd5fa2000-0xd5ff6fff] usable ==> reserved
[    0.000000] smpboot: Allowing 16 CPUs, 4 hotplug CPUs
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000fffff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0x01d80000-0x01ffffff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0xd5fa2000-0xd5ff6fff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0xd8fe3000-0xd8fe3fff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0xdcd72000-0xdced7fff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0xdd293000-0xdd39cfff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0xdd39d000-0xde387fff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0xde388000-0xde3ebfff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0xdf000000-0xdfffffff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0xe0000000-0xf7ffffff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0xf8000000-0xfbffffff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0xfc000000-0xfdefffff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0xfdf00000-0xfdffffff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0xfe000000-0xfe9fffff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0xfea00000-0xfea0ffff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0xfea10000-0xfeb7ffff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0xfeb80000-0xfec01fff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0xfec02000-0xfec0ffff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0xfec10000-0xfec10fff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0xfec11000-0xfec2ffff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0xfec30000-0xfec30fff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0xfec31000-0xfecfffff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0xfed00000-0xfed00fff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0xfed01000-0xfed3ffff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0xfed40000-0xfed44fff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0xfed45000-0xfed7ffff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0xfed80000-0xfed8ffff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0xfed90000-0xfedc1fff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0xfedc2000-0xfedcffff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0xfedd0000-0xfedd3fff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0xfedd4000-0xfedd5fff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0xfedd6000-0xfedfffff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfeefffff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0xfef00000-0xfeffffff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0xff000000-0xffffffff]
[    0.000000] [mem 0xe0000000-0xf7ffffff] available for PCI devices
[    0.000000] Booting paravirtualized kernel on bare hardware
[    0.000000] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[    0.000000] setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:16 nr_node_ids:1
[    0.000000] percpu: Embedded 61 pages/cpu s212992 r8192 d28672 u262144
[    0.000000] pcpu-alloc: s212992 r8192 d28672 u262144 alloc=1*2097152
[    0.000000] pcpu-alloc: [0] 00 01 02 03 04 05 06 07 [0] 08 09 10 11 12 13 14 15
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 4115975
[    0.000000] Policy zone: Normal
[    0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC misobasedir=manjaro misolabel=MANJARO_XFCE_2121 3 systemd.show_status=1 apparmor=1 security=apparmor driver=nonfree nouveau.modeset=0 i915.modeset=1 radeon.modeset=1
[    0.000000] Unknown kernel command line parameters "3 BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC misobasedir=manjaro misolabel=MANJARO_XFCE_2121 driver=nonfree", will be passed to user space.
[    0.000000] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[    0.000000] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[    0.000000] mem auto-init: stack:byref_all(zero), heap alloc:on, heap free:off
[    0.000000] Memory: 15998184K/16725888K available (14344K kernel code, 2097K rwdata, 10884K rodata, 1864K init, 3784K bss, 727444K reserved, 0K cma-reserved)
[    0.000000] random: get_random_u64 called from __kmem_cache_create+0x2a/0x540 with crng_init=0
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=16, Nodes=1
[    0.000000] ftrace: allocating 44515 entries in 174 pages
[    0.000000] ftrace: allocated 174 pages with 5 groups
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu: 	RCU dyntick-idle grace-period acceleration is enabled.
[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=16.
[    0.000000] rcu: 	RCU priority boosting: priority 1 delay 500 ms.
[    0.000000] 	Trampoline variant of Tasks RCU enabled.
[    0.000000] 	Rude variant of Tasks RCU enabled.
[    0.000000] 	Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=16
[    0.000000] NR_IRQS: 20736, nr_irqs: 1096, preallocated irqs: 16
[    0.000000] kfence: initialized - using 2097152 bytes for 255 objects at 0x(____ptrval____)-0x(____ptrval____)
[    0.000000] Console: colour dummy device 80x25
[    0.000000] printk: console [tty0] enabled
[    0.000000] ACPI: Core revision 20210730
[    0.000000] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484873504 ns
[    0.000000] APIC: Switch to symmetric I/O mode setup
[    0.003333] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.023333] tsc: PIT calibration matches HPET. 1 loops
[    0.023333] tsc: Detected 3793.013 MHz processor
[    0.000002] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x6d591f5ef2a, max_idle_ns: 881590767406 ns
[    0.000005] Calibrating delay loop (skipped), value calculated using timer frequency.. 7589.11 BogoMIPS (lpj=12643376)
[    0.000007] pid_max: default: 32768 minimum: 301
[    0.005527] LSM: Security Framework initializing
[    0.005534] landlock: Up and running.
[    0.005535] Yama: becoming mindful.
[    0.005555] AppArmor: AppArmor initialized
[    0.005592] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.005621] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.005869] LVT offset 1 assigned for vector 0xf9
[    0.005946] LVT offset 2 assigned for vector 0xf4
[    0.005962] Last level iTLB entries: 4KB 1024, 2MB 1024, 4MB 512
[    0.005963] Last level dTLB entries: 4KB 1536, 2MB 1536, 4MB 768, 1GB 0
[    0.005966] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[    0.005968] Spectre V2 : Mitigation: Full AMD retpoline
[    0.005968] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[    0.005970] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[    0.008276] Freeing SMP alternatives memory: 36K
[    0.117704] smpboot: CPU0: AMD Ryzen 5 1600X Six-Core Processor (family: 0x17, model: 0x1, stepping: 0x1)
[    0.117827] Performance Events: Fam17h+ core perfctr, AMD PMU driver.
[    0.117831] ... version:                0
[    0.117832] ... bit width:              48
[    0.117832] ... generic registers:      6
[    0.117833] ... value mask:             0000ffffffffffff
[    0.117834] ... max period:             00007fffffffffff
[    0.117834] ... fixed-purpose events:   0
[    0.117835] ... event mask:             000000000000003f
[    0.117885] rcu: Hierarchical SRCU implementation.
[    0.118235] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[    0.118348] smp: Bringing up secondary CPUs ...
[    0.118434] x86: Booting SMP configuration:
[    0.118435] .... node  #0, CPUs:        #1  #2  #3  #4  #5  #6  #7  #8  #9 #10 #11
[    0.142222] smp: Brought up 1 node, 12 CPUs
[    0.142222] smpboot: Max logical packages: 2
[    0.142222] smpboot: Total of 12 processors activated (91068.32 BogoMIPS)
[    0.143890] devtmpfs: initialized
[    0.143890] x86/mm: Memory block size: 128MB
[    0.144076] ACPI: PM: Registering ACPI NVS region [mem 0xdd293000-0xdd39cfff] (1089536 bytes)
[    0.144076] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[    0.144076] futex hash table entries: 4096 (order: 6, 262144 bytes, linear)
[    0.144076] pinctrl core: initialized pinctrl subsystem
[    0.144076] PM: RTC time: 22:50:37, date: 2022-01-11
[    0.144076] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.144076] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[    0.144076] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.144138] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.144143] audit: initializing netlink subsys (disabled)
[    0.144150] audit: type=2000 audit(1641941437.166:1): state=initialized audit_enabled=0 res=1
[    0.144150] thermal_sys: Registered thermal governor 'fair_share'
[    0.144150] thermal_sys: Registered thermal governor 'bang_bang'
[    0.144150] thermal_sys: Registered thermal governor 'step_wise'
[    0.144150] thermal_sys: Registered thermal governor 'user_space'
[    0.144150] thermal_sys: Registered thermal governor 'power_allocator'
[    0.144150] cpuidle: using governor ladder
[    0.144150] cpuidle: using governor menu
[    0.144150] HugeTLB: can free 4094 vmemmap pages for hugepages-1048576kB
[    0.144150] ACPI: bus type PCI registered
[    0.144150] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.144150] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
[    0.144150] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
[    0.144150] pmd_set_huge: Cannot satisfy [mem 0xf8000000-0xf8200000] with a huge-page mapping due to MTRR override.
[    0.144150] PCI: Using configuration type 1 for base access
[    0.147348] Kprobes globally optimized
[    0.147352] HugeTLB: can free 6 vmemmap pages for hugepages-2048kB
[    0.147352] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.147352] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.147352] ACPI: Added _OSI(Module Device)
[    0.147352] ACPI: Added _OSI(Processor Device)
[    0.147352] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.147352] ACPI: Added _OSI(Processor Aggregator Device)
[    0.147352] ACPI: Added _OSI(Linux-Dell-Video)
[    0.147352] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[    0.147352] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[    0.150865] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[    0.159546] ACPI: 7 ACPI AML tables successfully acquired and loaded
[    0.163686] ACPI: Interpreter enabled
[    0.163701] ACPI: PM: (supports S0 S3 S4 S5)
[    0.163702] ACPI: Using IOAPIC for interrupt routing
[    0.163819] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.164057] ACPI: Enabled 2 GPEs in block 00 to 1F
[    0.170546] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[    0.170551] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[    0.170714] acpi PNP0A08:00: _OSC: platform does not support [SHPCHotplug LTR DPC]
[    0.170870] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
[    0.170878] acpi PNP0A08:00: [Firmware Info]: MMCONFIG for domain 0000 [bus 00-3f] only partially covers this bridge
[    0.171219] PCI host bridge to bus 0000:00
[    0.171220] pci_bus 0000:00: root bus resource [io  0x0000-0x03af window]
[    0.171222] pci_bus 0000:00: root bus resource [io  0x03e0-0x0cf7 window]
[    0.171223] pci_bus 0000:00: root bus resource [io  0x03b0-0x03df window]
[    0.171224] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    0.171225] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[    0.171227] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000dffff window]
[    0.171228] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xfec2ffff window]
[    0.171229] pci_bus 0000:00: root bus resource [mem 0xfee00000-0xffffffff window]
[    0.171230] pci_bus 0000:00: root bus resource [bus 00-ff]
[    0.171293] pci 0000:00:00.0: [1022:1450] type 00 class 0x060000
[    0.171414] pci 0000:00:00.2: [1022:1451] type 00 class 0x080600
[    0.171512] pci 0000:00:01.0: [1022:1452] type 00 class 0x060000
[    0.171636] pci 0000:00:01.1: [1022:1453] type 01 class 0x060400
[    0.171681] pci 0000:00:01.1: PME# supported from D0 D3hot D3cold
[    0.171797] pci 0000:00:01.3: [1022:1453] type 01 class 0x060400
[    0.171841] pci 0000:00:01.3: PME# supported from D0 D3hot D3cold
[    0.171933] pci 0000:00:02.0: [1022:1452] type 00 class 0x060000
[    0.172030] pci 0000:00:03.0: [1022:1452] type 00 class 0x060000
[    0.172151] pci 0000:00:03.1: [1022:1453] type 01 class 0x060400
[    0.172194] pci 0000:00:03.1: PME# supported from D0 D3hot D3cold
[    0.172284] pci 0000:00:04.0: [1022:1452] type 00 class 0x060000
[    0.172383] pci 0000:00:07.0: [1022:1452] type 00 class 0x060000
[    0.172501] pci 0000:00:07.1: [1022:1454] type 01 class 0x060400
[    0.172520] pci 0000:00:07.1: enabling Extended Tags
[    0.172543] pci 0000:00:07.1: PME# supported from D0 D3hot D3cold
[    0.172631] pci 0000:00:08.0: [1022:1452] type 00 class 0x060000
[    0.172750] pci 0000:00:08.1: [1022:1454] type 01 class 0x060400
[    0.172770] pci 0000:00:08.1: enabling Extended Tags
[    0.172794] pci 0000:00:08.1: PME# supported from D0 D3hot D3cold
[    0.172918] pci 0000:00:14.0: [1022:790b] type 00 class 0x0c0500
[    0.173072] pci 0000:00:14.3: [1022:790e] type 00 class 0x060100
[    0.173206] pci 0000:00:18.0: [1022:1460] type 00 class 0x060000
[    0.173287] pci 0000:00:18.1: [1022:1461] type 00 class 0x060000
[    0.173370] pci 0000:00:18.2: [1022:1462] type 00 class 0x060000
[    0.173451] pci 0000:00:18.3: [1022:1463] type 00 class 0x060000
[    0.173536] pci 0000:00:18.4: [1022:1464] type 00 class 0x060000
[    0.173615] pci 0000:00:18.5: [1022:1465] type 00 class 0x060000
[    0.173696] pci 0000:00:18.6: [1022:1466] type 00 class 0x060000
[    0.173776] pci 0000:00:18.7: [1022:1467] type 00 class 0x060000
[    0.173911] pci 0000:01:00.0: [15b7:5009] type 00 class 0x010802
[    0.173926] pci 0000:01:00.0: reg 0x10: [mem 0xfd900000-0xfd903fff 64bit]
[    0.173947] pci 0000:01:00.0: reg 0x20: [mem 0xfd904000-0xfd9040ff 64bit]
[    0.174078] pci 0000:00:01.1: PCI bridge to [bus 01]
[    0.174082] pci 0000:00:01.1:   bridge window [mem 0xfd900000-0xfd9fffff]
[    0.174134] pci 0000:03:00.0: [1022:43b9] type 00 class 0x0c0330
[    0.174149] pci 0000:03:00.0: reg 0x10: [mem 0xfd7a0000-0xfd7a7fff 64bit]
[    0.174227] pci 0000:03:00.0: PME# supported from D3hot D3cold
[    0.174322] pci 0000:03:00.1: [1022:43b5] type 00 class 0x010601
[    0.174362] pci 0000:03:00.1: reg 0x24: [mem 0xfd780000-0xfd79ffff]
[    0.174369] pci 0000:03:00.1: reg 0x30: [mem 0xfd700000-0xfd77ffff pref]
[    0.174408] pci 0000:03:00.1: PME# supported from D3hot D3cold
[    0.174464] pci 0000:03:00.2: [1022:43b0] type 01 class 0x060400
[    0.174539] pci 0000:03:00.2: PME# supported from D3hot D3cold
[    0.174628] pci 0000:00:01.3: PCI bridge to [bus 03-23]
[    0.174631] pci 0000:00:01.3:   bridge window [io  0xf000-0xffff]
[    0.174633] pci 0000:00:01.3:   bridge window [mem 0xfd500000-0xfd7fffff]
[    0.174688] pci 0000:04:00.0: [1022:43b4] type 01 class 0x060400
[    0.174778] pci 0000:04:00.0: PME# supported from D3hot D3cold
[    0.174867] pci 0000:04:01.0: [1022:43b4] type 01 class 0x060400
[    0.174957] pci 0000:04:01.0: PME# supported from D3hot D3cold
[    0.175029] pci 0000:04:02.0: [1022:43b4] type 01 class 0x060400
[    0.175119] pci 0000:04:02.0: PME# supported from D3hot D3cold
[    0.175189] pci 0000:04:03.0: [1022:43b4] type 01 class 0x060400
[    0.175278] pci 0000:04:03.0: PME# supported from D3hot D3cold
[    0.175349] pci 0000:04:04.0: [1022:43b4] type 01 class 0x060400
[    0.175438] pci 0000:04:04.0: PME# supported from D3hot D3cold
[    0.175512] pci 0000:04:08.0: [1022:43b4] type 01 class 0x060400
[    0.175601] pci 0000:04:08.0: PME# supported from D3hot D3cold
[    0.175677] pci 0000:03:00.2: PCI bridge to [bus 04-23]
[    0.175682] pci 0000:03:00.2:   bridge window [io  0xf000-0xffff]
[    0.175684] pci 0000:03:00.2:   bridge window [mem 0xfd500000-0xfd6fffff]
[    0.175770] pci 0000:1e:00.0: [8086:1539] type 00 class 0x020000
[    0.175804] pci 0000:1e:00.0: reg 0x10: [mem 0xfd600000-0xfd61ffff]
[    0.175837] pci 0000:1e:00.0: reg 0x18: [io  0xf000-0xf01f]
[    0.175857] pci 0000:1e:00.0: reg 0x1c: [mem 0xfd620000-0xfd623fff]
[    0.176047] pci 0000:1e:00.0: PME# supported from D0 D3hot D3cold
[    0.176240] pci 0000:04:00.0: PCI bridge to [bus 1e]
[    0.176245] pci 0000:04:00.0:   bridge window [io  0xf000-0xffff]
[    0.176248] pci 0000:04:00.0:   bridge window [mem 0xfd600000-0xfd6fffff]
[    0.176279] pci 0000:04:01.0: PCI bridge to [bus 1f]
[    0.176316] pci 0000:04:02.0: PCI bridge to [bus 20]
[    0.176352] pci 0000:04:03.0: PCI bridge to [bus 21]
[    0.176390] pci 0000:04:04.0: PCI bridge to [bus 22]
[    0.176468] pci 0000:23:00.0: [1b21:2142] type 00 class 0x0c0330
[    0.176495] pci 0000:23:00.0: reg 0x10: [mem 0xfd500000-0xfd507fff 64bit]
[    0.176712] pci 0000:23:00.0: PME# supported from D0 D3hot D3cold
[    0.177222] pci 0000:04:08.0: PCI bridge to [bus 23]
[    0.177228] pci 0000:04:08.0:   bridge window [mem 0xfd500000-0xfd5fffff]
[    0.177301] pci 0000:24:00.0: [10de:2484] type 00 class 0x030000
[    0.177311] pci 0000:24:00.0: reg 0x10: [mem 0xfc000000-0xfcffffff]
[    0.177319] pci 0000:24:00.0: reg 0x14: [mem 0xe0000000-0xefffffff 64bit pref]
[    0.177326] pci 0000:24:00.0: reg 0x1c: [mem 0xf0000000-0xf1ffffff 64bit pref]
[    0.177332] pci 0000:24:00.0: reg 0x24: [io  0xe000-0xe07f]
[    0.177337] pci 0000:24:00.0: reg 0x30: [mem 0xfd000000-0xfd07ffff pref]
[    0.177350] pci 0000:24:00.0: BAR 1: assigned to efifb
[    0.177386] pci 0000:24:00.0: PME# supported from D0 D3hot
[    0.177449] pci 0000:24:00.0: 126.016 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x16 link at 0000:00:03.1 (capable of 252.048 Gb/s with 16.0 GT/s PCIe x16 link)
[    0.177485] pci 0000:24:00.1: [10de:228b] type 00 class 0x040300
[    0.177493] pci 0000:24:00.1: reg 0x10: [mem 0xfd080000-0xfd083fff]
[    0.177592] pci 0000:00:03.1: PCI bridge to [bus 24]
[    0.177595] pci 0000:00:03.1:   bridge window [io  0xe000-0xefff]
[    0.177597] pci 0000:00:03.1:   bridge window [mem 0xfc000000-0xfd0fffff]
[    0.177599] pci 0000:00:03.1:   bridge window [mem 0xe0000000-0xf1ffffff 64bit pref]
[    0.177638] pci 0000:25:00.0: [1022:145a] type 00 class 0x130000
[    0.177659] pci 0000:25:00.0: enabling Extended Tags
[    0.177720] pci 0000:25:00.2: [1022:1456] type 00 class 0x108000
[    0.177731] pci 0000:25:00.2: reg 0x18: [mem 0xfd300000-0xfd3fffff]
[    0.177738] pci 0000:25:00.2: reg 0x24: [mem 0xfd400000-0xfd401fff]
[    0.177744] pci 0000:25:00.2: enabling Extended Tags
[    0.177817] pci 0000:25:00.3: [1022:145c] type 00 class 0x0c0330
[    0.177826] pci 0000:25:00.3: reg 0x10: [mem 0xfd200000-0xfd2fffff 64bit]
[    0.177845] pci 0000:25:00.3: enabling Extended Tags
[    0.177868] pci 0000:25:00.3: PME# supported from D0 D3hot D3cold
[    0.177920] pci 0000:00:07.1: PCI bridge to [bus 25]
[    0.177923] pci 0000:00:07.1:   bridge window [mem 0xfd200000-0xfd4fffff]
[    0.177971] pci 0000:26:00.0: [1022:1455] type 00 class 0x130000
[    0.177993] pci 0000:26:00.0: enabling Extended Tags
[    0.178062] pci 0000:26:00.2: [1022:7901] type 00 class 0x010601
[    0.178086] pci 0000:26:00.2: reg 0x24: [mem 0xfd808000-0xfd808fff]
[    0.178093] pci 0000:26:00.2: enabling Extended Tags
[    0.178118] pci 0000:26:00.2: PME# supported from D3hot D3cold
[    0.178173] pci 0000:26:00.3: [1022:1457] type 00 class 0x040300
[    0.178180] pci 0000:26:00.3: reg 0x10: [mem 0xfd800000-0xfd807fff]
[    0.178198] pci 0000:26:00.3: enabling Extended Tags
[    0.178222] pci 0000:26:00.3: PME# supported from D0 D3hot D3cold
[    0.178278] pci 0000:00:08.1: PCI bridge to [bus 26]
[    0.178281] pci 0000:00:08.1:   bridge window [mem 0xfd800000-0xfd8fffff]
[    0.178534] ACPI: PCI: Interrupt link LNKA configured for IRQ 0
[    0.178584] ACPI: PCI: Interrupt link LNKB configured for IRQ 0
[    0.178627] ACPI: PCI: Interrupt link LNKC configured for IRQ 0
[    0.178680] ACPI: PCI: Interrupt link LNKD configured for IRQ 0
[    0.178728] ACPI: PCI: Interrupt link LNKE configured for IRQ 0
[    0.178767] ACPI: PCI: Interrupt link LNKF configured for IRQ 0
[    0.178807] ACPI: PCI: Interrupt link LNKG configured for IRQ 0
[    0.178846] ACPI: PCI: Interrupt link LNKH configured for IRQ 0
[    0.179371] iommu: Default domain type: Translated
[    0.179372] iommu: DMA domain TLB invalidation policy: lazy mode
[    0.179382] pci 0000:24:00.0: vgaarb: VGA device added: decodes=io+mem,owns=none,locks=none
[    0.179382] pci 0000:24:00.0: vgaarb: bridge control possible
[    0.179382] pci 0000:24:00.0: vgaarb: setting as boot device
[    0.179382] vgaarb: loaded
[    0.179382] SCSI subsystem initialized
[    0.179382] libata version 3.00 loaded.
[    0.179382] ACPI: bus type USB registered
[    0.179382] usbcore: registered new interface driver usbfs
[    0.179382] usbcore: registered new interface driver hub
[    0.179382] usbcore: registered new device driver usb
[    0.179382] pps_core: LinuxPPS API ver. 1 registered
[    0.179382] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.179382] PTP clock support registered
[    0.179382] EDAC MC: Ver: 3.0.0
[    0.179382] Registered efivars operations
[    0.179382] NetLabel: Initializing
[    0.179382] NetLabel:  domain hash size = 128
[    0.179382] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.179382] NetLabel:  unlabeled traffic allowed by default
[    0.179382] PCI: Using ACPI for IRQ routing
[    0.181394] PCI: pci_cache_line_size set to 64 bytes
[    0.181454] e820: reserve RAM buffer [mem 0x01d80000-0x03ffffff]
[    0.181456] e820: reserve RAM buffer [mem 0xd5fa2000-0xd7ffffff]
[    0.181457] e820: reserve RAM buffer [mem 0xd8fe3000-0xdbffffff]
[    0.181457] e820: reserve RAM buffer [mem 0xdcd72000-0xdfffffff]
[    0.181458] e820: reserve RAM buffer [mem 0xdd293000-0xdfffffff]
[    0.181459] e820: reserve RAM buffer [mem 0xdf000000-0xdfffffff]
[    0.181460] e820: reserve RAM buffer [mem 0x41f380000-0x41fffffff]
[    0.181465] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[    0.181465] hpet0: 3 comparators, 32-bit 14.318180 MHz counter
[    0.183402] clocksource: Switched to clocksource tsc-early
[    0.189517] VFS: Disk quotas dquot_6.6.0
[    0.189533] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.189624] AppArmor: AppArmor Filesystem Enabled
[    0.189658] pnp: PnP ACPI init
[    0.189796] system 00:00: [mem 0xf8000000-0xfbffffff] has been reserved
[    0.189863] system 00:01: [mem 0xfeb80000-0xfebfffff] could not be reserved
[    0.190133] system 00:03: [io  0x0a00-0x0a0f] has been reserved
[    0.190136] system 00:03: [io  0x0a10-0x0a1f] has been reserved
[    0.190137] system 00:03: [io  0x0a20-0x0a2f] has been reserved
[    0.190138] system 00:03: [io  0x0a40-0x0a4f] has been reserved
[    0.190366] system 00:04: [io  0x04d0-0x04d1] has been reserved
[    0.190367] system 00:04: [io  0x040b] has been reserved
[    0.190368] system 00:04: [io  0x04d6] has been reserved
[    0.190370] system 00:04: [io  0x0c00-0x0c01] has been reserved
[    0.190371] system 00:04: [io  0x0c14] has been reserved
[    0.190372] system 00:04: [io  0x0c50-0x0c51] has been reserved
[    0.190373] system 00:04: [io  0x0c52] has been reserved
[    0.190374] system 00:04: [io  0x0c6c] has been reserved
[    0.190374] system 00:04: [io  0x0c6f] has been reserved
[    0.190375] system 00:04: [io  0x0cd0-0x0cd1] has been reserved
[    0.190376] system 00:04: [io  0x0cd2-0x0cd3] has been reserved
[    0.190377] system 00:04: [io  0x0cd4-0x0cd5] has been reserved
[    0.190378] system 00:04: [io  0x0cd6-0x0cd7] has been reserved
[    0.190379] system 00:04: [io  0x0cd8-0x0cdf] has been reserved
[    0.190380] system 00:04: [io  0x0800-0x089f] has been reserved
[    0.190381] system 00:04: [io  0x0b00-0x0b0f] has been reserved
[    0.190382] system 00:04: [io  0x0b20-0x0b3f] has been reserved
[    0.190383] system 00:04: [io  0x0900-0x090f] has been reserved
[    0.190384] system 00:04: [io  0x0910-0x091f] has been reserved
[    0.190386] system 00:04: [mem 0xfec00000-0xfec00fff] could not be reserved
[    0.190388] system 00:04: [mem 0xfec01000-0xfec01fff] could not be reserved
[    0.190390] system 00:04: [mem 0xfedc0000-0xfedc0fff] has been reserved
[    0.190392] system 00:04: [mem 0xfee00000-0xfee00fff] has been reserved
[    0.190393] system 00:04: [mem 0xfed80000-0xfed8ffff] could not be reserved
[    0.190395] system 00:04: [mem 0xfec10000-0xfec10fff] has been reserved
[    0.190396] system 00:04: [mem 0xff000000-0xffffffff] has been reserved
[    0.190757] pnp: PnP ACPI: found 5 devices
[    0.196394] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    0.196439] NET: Registered PF_INET protocol family
[    0.196655] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.198194] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
[    0.198309] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.198453] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[    0.198524] TCP: Hash tables configured (established 131072 bind 65536)
[    0.198597] MPTCP token hash table entries: 16384 (order: 6, 393216 bytes, linear)
[    0.198642] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
[    0.198682] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
[    0.198740] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.198744] NET: Registered PF_XDP protocol family
[    0.198752] pci 0000:04:02.0: bridge window [io  0x1000-0x0fff] to [bus 20] add_size 1000
[    0.198754] pci 0000:04:02.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 20] add_size 200000 add_align 100000
[    0.198757] pci 0000:04:02.0: bridge window [mem 0x00100000-0x000fffff] to [bus 20] add_size 200000 add_align 100000
[    0.198761] pci 0000:03:00.2: bridge window [mem 0x00100000-0x001fffff 64bit pref] to [bus 04-23] add_size 200000 add_align 100000
[    0.198764] pci 0000:00:01.3: bridge window [mem 0x00100000-0x001fffff 64bit pref] to [bus 03-23] add_size 200000 add_align 100000
[    0.198773] pci 0000:00:01.3: BAR 15: assigned [mem 0xf2000000-0xf22fffff 64bit pref]
[    0.198776] pci 0000:00:01.1: PCI bridge to [bus 01]
[    0.198779] pci 0000:00:01.1:   bridge window [mem 0xfd900000-0xfd9fffff]
[    0.198783] pci 0000:03:00.2: BAR 15: assigned [mem 0xf2000000-0xf22fffff 64bit pref]
[    0.198786] pci 0000:04:02.0: BAR 14: no space for [mem size 0x00200000]
[    0.198788] pci 0000:04:02.0: BAR 14: failed to assign [mem size 0x00200000]
[    0.198789] pci 0000:04:02.0: BAR 15: assigned [mem 0xf2000000-0xf21fffff 64bit pref]
[    0.198791] pci 0000:04:02.0: BAR 13: no space for [io  size 0x1000]
[    0.198792] pci 0000:04:02.0: BAR 13: failed to assign [io  size 0x1000]
[    0.198794] pci 0000:04:02.0: BAR 14: no space for [mem size 0x00200000]
[    0.198795] pci 0000:04:02.0: BAR 14: failed to assign [mem size 0x00200000]
[    0.198796] pci 0000:04:02.0: BAR 13: no space for [io  size 0x1000]
[    0.198797] pci 0000:04:02.0: BAR 13: failed to assign [io  size 0x1000]
[    0.198798] pci 0000:04:00.0: PCI bridge to [bus 1e]
[    0.198800] pci 0000:04:00.0:   bridge window [io  0xf000-0xffff]
[    0.198804] pci 0000:04:00.0:   bridge window [mem 0xfd600000-0xfd6fffff]
[    0.198810] pci 0000:04:01.0: PCI bridge to [bus 1f]
[    0.198819] pci 0000:04:02.0: PCI bridge to [bus 20]
[    0.198824] pci 0000:04:02.0:   bridge window [mem 0xf2000000-0xf21fffff 64bit pref]
[    0.198829] pci 0000:04:03.0: PCI bridge to [bus 21]
[    0.198838] pci 0000:04:04.0: PCI bridge to [bus 22]
[    0.198847] pci 0000:04:08.0: PCI bridge to [bus 23]
[    0.198850] pci 0000:04:08.0:   bridge window [mem 0xfd500000-0xfd5fffff]
[    0.198856] pci 0000:03:00.2: PCI bridge to [bus 04-23]
[    0.198858] pci 0000:03:00.2:   bridge window [io  0xf000-0xffff]
[    0.198861] pci 0000:03:00.2:   bridge window [mem 0xfd500000-0xfd6fffff]
[    0.198864] pci 0000:03:00.2:   bridge window [mem 0xf2000000-0xf22fffff 64bit pref]
[    0.198868] pci 0000:00:01.3: PCI bridge to [bus 03-23]
[    0.198869] pci 0000:00:01.3:   bridge window [io  0xf000-0xffff]
[    0.198871] pci 0000:00:01.3:   bridge window [mem 0xfd500000-0xfd7fffff]
[    0.198873] pci 0000:00:01.3:   bridge window [mem 0xf2000000-0xf22fffff 64bit pref]
[    0.198876] pci 0000:00:03.1: PCI bridge to [bus 24]
[    0.198877] pci 0000:00:03.1:   bridge window [io  0xe000-0xefff]
[    0.198879] pci 0000:00:03.1:   bridge window [mem 0xfc000000-0xfd0fffff]
[    0.198881] pci 0000:00:03.1:   bridge window [mem 0xe0000000-0xf1ffffff 64bit pref]
[    0.198884] pci 0000:00:07.1: PCI bridge to [bus 25]
[    0.198886] pci 0000:00:07.1:   bridge window [mem 0xfd200000-0xfd4fffff]
[    0.198890] pci 0000:00:08.1: PCI bridge to [bus 26]
[    0.198892] pci 0000:00:08.1:   bridge window [mem 0xfd800000-0xfd8fffff]
[    0.198896] pci_bus 0000:00: resource 4 [io  0x0000-0x03af window]
[    0.198898] pci_bus 0000:00: resource 5 [io  0x03e0-0x0cf7 window]
[    0.198899] pci_bus 0000:00: resource 6 [io  0x03b0-0x03df window]
[    0.198900] pci_bus 0000:00: resource 7 [io  0x0d00-0xffff window]
[    0.198901] pci_bus 0000:00: resource 8 [mem 0x000a0000-0x000bffff window]
[    0.198902] pci_bus 0000:00: resource 9 [mem 0x000c0000-0x000dffff window]
[    0.198903] pci_bus 0000:00: resource 10 [mem 0xe0000000-0xfec2ffff window]
[    0.198904] pci_bus 0000:00: resource 11 [mem 0xfee00000-0xffffffff window]
[    0.198905] pci_bus 0000:01: resource 1 [mem 0xfd900000-0xfd9fffff]
[    0.198906] pci_bus 0000:03: resource 0 [io  0xf000-0xffff]
[    0.198907] pci_bus 0000:03: resource 1 [mem 0xfd500000-0xfd7fffff]
[    0.198908] pci_bus 0000:03: resource 2 [mem 0xf2000000-0xf22fffff 64bit pref]
[    0.198909] pci_bus 0000:04: resource 0 [io  0xf000-0xffff]
[    0.198910] pci_bus 0000:04: resource 1 [mem 0xfd500000-0xfd6fffff]
[    0.198911] pci_bus 0000:04: resource 2 [mem 0xf2000000-0xf22fffff 64bit pref]
[    0.198912] pci_bus 0000:1e: resource 0 [io  0xf000-0xffff]
[    0.198913] pci_bus 0000:1e: resource 1 [mem 0xfd600000-0xfd6fffff]
[    0.198914] pci_bus 0000:20: resource 2 [mem 0xf2000000-0xf21fffff 64bit pref]
[    0.198916] pci_bus 0000:23: resource 1 [mem 0xfd500000-0xfd5fffff]
[    0.198917] pci_bus 0000:24: resource 0 [io  0xe000-0xefff]
[    0.198918] pci_bus 0000:24: resource 1 [mem 0xfc000000-0xfd0fffff]
[    0.198918] pci_bus 0000:24: resource 2 [mem 0xe0000000-0xf1ffffff 64bit pref]
[    0.198920] pci_bus 0000:25: resource 1 [mem 0xfd200000-0xfd4fffff]
[    0.198921] pci_bus 0000:26: resource 1 [mem 0xfd800000-0xfd8fffff]
[    0.199148] pci 0000:23:00.0: PME# does not work under D0, disabling it
[    0.199284] pci 0000:24:00.1: D0 power state depends on 0000:24:00.0
[    0.199417] PCI: CLS 64 bytes, default 64
[    0.199425] AMD-Vi: [Firmware Warn]: EFR mismatch. Use IVHD EFR (0xf77ef22294ada : 0x400f77ef22294ada).
[    0.199430] pci 0000:00:00.2: AMD-Vi: IOMMU performance counters supported
[    0.199466] pci 0000:00:00.2: can't derive routing for PCI INT A
[    0.199467] pci 0000:00:00.2: PCI INT A: not connected
[    0.199486] Trying to unpack rootfs image as initramfs...
[    0.199489] pci 0000:00:01.0: Adding to iommu group 0
[    0.199497] pci 0000:00:01.1: Adding to iommu group 0
[    0.199504] pci 0000:00:01.3: Adding to iommu group 0
[    0.199516] pci 0000:00:02.0: Adding to iommu group 1
[    0.199530] pci 0000:00:03.0: Adding to iommu group 2
[    0.199536] pci 0000:00:03.1: Adding to iommu group 2
[    0.199547] pci 0000:00:04.0: Adding to iommu group 3
[    0.199561] pci 0000:00:07.0: Adding to iommu group 4
[    0.199569] pci 0000:00:07.1: Adding to iommu group 4
[    0.199583] pci 0000:00:08.0: Adding to iommu group 5
[    0.199590] pci 0000:00:08.1: Adding to iommu group 5
[    0.199605] pci 0000:00:14.0: Adding to iommu group 6
[    0.199613] pci 0000:00:14.3: Adding to iommu group 6
[    0.199648] pci 0000:00:18.0: Adding to iommu group 7
[    0.199656] pci 0000:00:18.1: Adding to iommu group 7
[    0.199664] pci 0000:00:18.2: Adding to iommu group 7
[    0.199672] pci 0000:00:18.3: Adding to iommu group 7
[    0.199679] pci 0000:00:18.4: Adding to iommu group 7
[    0.199687] pci 0000:00:18.5: Adding to iommu group 7
[    0.199694] pci 0000:00:18.6: Adding to iommu group 7
[    0.199702] pci 0000:00:18.7: Adding to iommu group 7
[    0.199705] pci 0000:01:00.0: Adding to iommu group 0
[    0.199708] pci 0000:03:00.0: Adding to iommu group 0
[    0.199712] pci 0000:03:00.1: Adding to iommu group 0
[    0.199715] pci 0000:03:00.2: Adding to iommu group 0
[    0.199733] pci 0000:04:00.0: Adding to iommu group 0
[    0.199738] pci 0000:04:01.0: Adding to iommu group 0
[    0.199742] pci 0000:04:02.0: Adding to iommu group 0
[    0.199747] pci 0000:04:03.0: Adding to iommu group 0
[    0.199752] pci 0000:04:04.0: Adding to iommu group 0
[    0.199756] pci 0000:04:08.0: Adding to iommu group 0
[    0.199760] pci 0000:1e:00.0: Adding to iommu group 0
[    0.199765] pci 0000:23:00.0: Adding to iommu group 0
[    0.199769] pci 0000:24:00.0: Adding to iommu group 2
[    0.199782] pci 0000:24:00.1: Adding to iommu group 2
[    0.199785] pci 0000:25:00.0: Adding to iommu group 4
[    0.199789] pci 0000:25:00.2: Adding to iommu group 4
[    0.199792] pci 0000:25:00.3: Adding to iommu group 4
[    0.199796] pci 0000:26:00.0: Adding to iommu group 5
[    0.199800] pci 0000:26:00.2: Adding to iommu group 5
[    0.199803] pci 0000:26:00.3: Adding to iommu group 5
[    0.201084] pci 0000:00:00.2: AMD-Vi: Found IOMMU cap 0x40
[    0.201088] AMD-Vi: Extended features (0x400f77ef22294ada): PPR NX GT IA GA PC GA_vAPIC
[    0.201094] AMD-Vi: Interrupt remapping enabled
[    0.201095] AMD-Vi: Virtual APIC enabled
[    0.201223] software IO TLB: tearing down default memory pool
[    0.202020] perf/amd_iommu: Detected AMD IOMMU #0 (2 banks, 4 counters/bank).
[    0.212753] Initialise system trusted keyrings
[    0.212762] Key type blacklist registered
[    0.212798] workingset: timestamp_bits=41 max_order=22 bucket_order=0
[    0.213565] zbud: loaded
[    0.221910] Key type asymmetric registered
[    0.221912] Asymmetric key parser 'x509' registered
[    0.221925] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
[    0.221961] io scheduler mq-deadline registered
[    0.221962] io scheduler kyber registered
[    0.221986] io scheduler bfq registered
[    0.222219] pcieport 0000:00:01.1: PME: Signaling with IRQ 28
[    0.222301] pcieport 0000:00:01.3: PME: Signaling with IRQ 29
[    0.222385] pcieport 0000:00:03.1: PME: Signaling with IRQ 30
[    0.222460] pcieport 0000:00:07.1: PME: Signaling with IRQ 31
[    0.222616] pcieport 0000:00:08.1: PME: Signaling with IRQ 33
[    0.223082] pcieport 0000:04:02.0: pciehp: Slot #1 AttnBtn+ PwrCtrl+ MRL- AttnInd+ PwrInd+ HotPlug+ Surprise- Interlock- NoCompl- IbPresDis- LLActRep+
[    1.200026] tsc: Refined TSC clocksource calibration: 3792.873 MHz
[    1.200037] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x6d5818a734c, max_idle_ns: 881590694765 ns
[    1.200067] clocksource: Switched to clocksource tsc
[    1.903360] pcieport 0000:04:02.0: pciehp: Timeout on hotplug command 0x03c0 (issued 1684 msec ago)
[    1.920022] pcieport 0000:04:02.0: pciehp: Timeout on hotplug command 0x03c0 (issued 1700 msec ago)
[    3.603358] pcieport 0000:04:02.0: pciehp: Timeout on hotplug command 0x07c0 (issued 1684 msec ago)
[    3.620023] pcieport 0000:04:02.0: pciehp: Timeout on hotplug command 0x07c0 (issued 1700 msec ago)
[    3.620594] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[    3.620699] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[    3.620717] ACPI: button: Power Button [PWRB]
[    3.620738] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[    3.620763] ACPI: button: Power Button [PWRF]
[    3.620791] ACPI: \_PR_.P000: Found 2 idle states
[    3.620871] ACPI: \_PR_.P001: Found 2 idle states
[    3.620927] ACPI: \_PR_.P002: Found 2 idle states
[    3.620979] ACPI: \_PR_.P003: Found 2 idle states
[    3.621028] ACPI: \_PR_.P004: Found 2 idle states
[    3.621070] ACPI: \_PR_.P005: Found 2 idle states
[    3.621120] ACPI: \_PR_.P006: Found 2 idle states
[    3.621188] ACPI: \_PR_.P007: Found 2 idle states
[    3.621242] ACPI: \_PR_.P008: Found 2 idle states
[    3.621309] ACPI: \_PR_.P009: Found 2 idle states
[    3.621363] ACPI: \_PR_.P00A: Found 2 idle states
[    3.621427] ACPI: \_PR_.P00B: Found 2 idle states
[    3.621643] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[    3.621815] serial8250: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[    3.622853] Non-volatile memory driver v1.3
[    3.622854] Linux agpgart interface v0.103
[    3.622895] AMD-Vi: AMD IOMMUv2 loaded and initialized
[    3.623580] nvme nvme0: pci function 0000:01:00.0
[    3.623617] ahci 0000:03:00.1: version 3.0
[    3.623786] ahci 0000:03:00.1: SSS flag set, parallel bus scan disabled
[    3.623842] ahci 0000:03:00.1: AHCI 0001.0301 32 slots 8 ports 6 Gbps 0xff impl SATA mode
[    3.623845] ahci 0000:03:00.1: flags: 64bit ncq sntf stag pm led clo only pmp pio slum part sxs deso sadm sds apst
[    3.624269] scsi host0: ahci
[    3.624358] scsi host1: ahci
[    3.624429] scsi host2: ahci
[    3.624491] scsi host3: ahci
[    3.624557] scsi host4: ahci
[    3.624621] scsi host5: ahci
[    3.624687] scsi host6: ahci
[    3.624750] scsi host7: ahci
[    3.624770] ata1: SATA max UDMA/133 abar m131072@0xfd780000 port 0xfd780100 irq 44
[    3.624773] ata2: SATA max UDMA/133 abar m131072@0xfd780000 port 0xfd780180 irq 44
[    3.624774] ata3: SATA max UDMA/133 abar m131072@0xfd780000 port 0xfd780200 irq 44
[    3.624776] ata4: SATA max UDMA/133 abar m131072@0xfd780000 port 0xfd780280 irq 44
[    3.624777] ata5: SATA max UDMA/133 abar m131072@0xfd780000 port 0xfd780300 irq 44
[    3.624779] ata6: SATA max UDMA/133 abar m131072@0xfd780000 port 0xfd780380 irq 44
[    3.624780] ata7: SATA max UDMA/133 abar m131072@0xfd780000 port 0xfd780400 irq 44
[    3.624782] ata8: SATA max UDMA/133 abar m131072@0xfd780000 port 0xfd780480 irq 44
[    3.624890] ahci 0000:26:00.2: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x1 impl SATA mode
[    3.624893] ahci 0000:26:00.2: flags: 64bit ncq sntf ilck led clo only pmp fbs pio
[    3.625010] scsi host8: ahci
[    3.625034] ata9: SATA max UDMA/133 abar m4096@0xfd808000 port 0xfd808100 irq 47
[    3.625059] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    3.625062] ehci-pci: EHCI PCI platform driver
[    3.625069] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    3.625071] ohci-pci: OHCI PCI platform driver
[    3.625076] uhci_hcd: USB Universal Host Controller Interface driver
[    3.625101] usbcore: registered new interface driver usbserial_generic
[    3.625104] usbserial: USB Serial support registered for generic
[    3.625160] rtc_cmos 00:02: RTC can wake from S4
[    3.625331] rtc_cmos 00:02: registered as rtc0
[    3.625361] rtc_cmos 00:02: setting system clock to 2022-01-11T22:50:41 UTC (1641941441)
[    3.625372] rtc_cmos 00:02: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[    3.625487] ledtrig-cpu: registered to indicate activity on CPUs
[    3.625611] efifb: probing for efifb
[    3.625618] efifb: framebuffer at 0xe0000000, using 3072k, total 3072k
[    3.625619] efifb: mode is 1024x768x32, linelength=4096, pages=1
[    3.625620] efifb: scrolling: redraw
[    3.625621] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[    3.625647] fbcon: Deferring console take-over
[    3.625648] fb0: EFI VGA frame buffer device
[    3.625664] hid: raw HID events driver (C) Jiri Kosina
[    3.625708] ashmem: initialized
[    3.625766] drop_monitor: Initializing network drop monitor service
[    3.625817] Initializing XFRM netlink socket
[    3.625872] NET: Registered PF_INET6 protocol family
[    3.640900] nvme nvme0: allocated 32 MiB host memory buffer.
[    3.642388] nvme nvme0: 16/0/0 default/read/poll queues
[    3.645847]  nvme0n1: p1 p2 p3
[    3.936430] ata9: SATA link down (SStatus 0 SControl 300)
[    4.056041] Freeing initrd memory: 52732K
[    4.059462] Segment Routing with IPv6
[    4.059463] RPL Segment Routing with IPv6
[    4.059473] In-situ OAM (IOAM) with IPv6
[    4.059498] NET: Registered PF_PACKET protocol family
[    4.060222] microcode: CPU0: patch_level=0x08001105
[    4.060228] microcode: CPU1: patch_level=0x08001105
[    4.060234] microcode: CPU2: patch_level=0x08001105
[    4.060240] microcode: CPU3: patch_level=0x08001105
[    4.060243] microcode: CPU4: patch_level=0x08001105
[    4.060249] microcode: CPU5: patch_level=0x08001105
[    4.060256] microcode: CPU6: patch_level=0x08001105
[    4.060263] microcode: CPU7: patch_level=0x08001105
[    4.060269] microcode: CPU8: patch_level=0x08001105
[    4.060275] microcode: CPU9: patch_level=0x08001105
[    4.060281] microcode: CPU10: patch_level=0x08001105
[    4.060288] microcode: CPU11: patch_level=0x08001105
[    4.060291] microcode: Microcode Update Driver: v2.2.
[    4.060295] IPI shorthand broadcast: enabled
[    4.060303] sched_clock: Marking stable (4083466116, -23328785)->(4068098187, -7960856)
[    4.060609] registered taskstats version 1
[    4.060817] Loading compiled-in X.509 certificates
[    4.063211] Loaded X.509 cert 'Build time autogenerated kernel key: 9612dc616146eeaafd46db77e26f033f23e1efc3'
[    4.065702] zswap: loaded using pool zstd/z3fold
[    4.066109] Key type ._fscrypt registered
[    4.066110] Key type .fscrypt registered
[    4.066111] Key type fscrypt-provisioning registered
[    4.066150] AppArmor: AppArmor sha1 policy hashing enabled
[    4.066361] PM:   Magic number: 6:916:855
[    4.066548] RAS: Correctable Errors collector initialized.
[    4.093774] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    4.094805] ata1.00: ATA-8: HGST HTS541010A9E680, JA0OA560, max UDMA/133
[    4.095083] ata1.00: ATA Identify Device Log not supported
[    4.095085] ata1.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[    4.096519] ata1.00: ATA Identify Device Log not supported
[    4.096522] ata1.00: configured for UDMA/133
[    4.096614] scsi 0:0:0:0: Direct-Access     ATA      HGST HTS541010A9 A560 PQ: 0 ANSI: 5
[    4.096780] sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[    4.096783] sd 0:0:0:0: [sda] 4096-byte physical blocks
[    4.096790] sd 0:0:0:0: [sda] Write Protect is off
[    4.096791] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    4.096801] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    4.407063] ata2: SATA link down (SStatus 0 SControl 300)
[    4.877099] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    4.878478] ata3.00: ATA-11: WDC WDS250G2B0B-00YS70, X61130WD, max UDMA/133
[    4.878523] ata3.00: 488397168 sectors, multi 1: LBA48 NCQ (depth 32), AA
[    4.879130] ata3.00: Features: Dev-Sleep
[    4.881240] ata3.00: configured for UDMA/133
[    4.881387] scsi 2:0:0:0: Direct-Access     ATA      WDC WDS250G2B0B- 30WD PQ: 0 ANSI: 5
[    4.881607] sd 2:0:0:0: [sdb] 488397168 512-byte logical blocks: (250 GB/233 GiB)
[    4.881615] sd 2:0:0:0: [sdb] Write Protect is off
[    4.881617] sd 2:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[    4.881627] sd 2:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    4.908660]  sdb: sdb1 sdb2 sdb3
[    4.933811] sd 2:0:0:0: [sdb] Attached SCSI disk
[    5.190768] ata4: SATA link down (SStatus 0 SControl 300)
[    5.500771] ata5: SATA link down (SStatus 0 SControl 330)
[    6.434315]  sda: sda1
[    6.453811] sd 0:0:0:0: [sda] Attached SCSI disk
[    6.533754] ata6: failed to resume link (SControl 0)
[    6.533771] ata6: SATA link down (SStatus 0 SControl 0)
[    7.003761] ata7: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[    7.004102] ata7.00: ATA-8: TOSHIBA MK6476GSX, GS001C, max UDMA/100
[    7.004141] ata7.00: 1250263728 sectors, multi 16: LBA48 NCQ (depth 32), AA
[    7.004492] ata7.00: configured for UDMA/100
[    7.004592] scsi 6:0:0:0: Direct-Access     ATA      TOSHIBA MK6476GS 1C   PQ: 0 ANSI: 5
[    7.004799] sd 6:0:0:0: [sdc] 1250263728 512-byte logical blocks: (640 GB/596 GiB)
[    7.004808] sd 6:0:0:0: [sdc] Write Protect is off
[    7.004810] sd 6:0:0:0: [sdc] Mode Sense: 00 3a 00 00
[    7.004820] sd 6:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    7.313760] ata8: SATA link down (SStatus 0 SControl 300)
[    7.482815]  sdc: sdc1
[    7.507144] sd 6:0:0:0: [sdc] Attached SCSI disk
[    7.508058] Freeing unused decrypted memory: 2036K
[    7.508252] Freeing unused kernel image (initmem) memory: 1864K
[    7.508253] Write protecting the kernel read-only data: 28672k
[    7.508594] Freeing unused kernel image (text/rodata gap) memory: 2036K
[    7.508776] Freeing unused kernel image (rodata/data gap) memory: 1404K
[    7.540845] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    7.540850] rodata_test: all tests were successful
[    7.540855] Run /init as init process
[    7.540856]   with arguments:
[    7.540857]     /init
[    7.540857]     3
[    7.540858]   with environment:
[    7.540858]     HOME=/
[    7.540859]     TERM=linux
[    7.540859]     BOOT_IMAGE=/boot/vmlinuz-x86_64
[    7.540860]     lang=en_US
[    7.540861]     keytable=us
[    7.540861]     tz=UTC
[    7.540861]     misobasedir=manjaro
[    7.540862]     misolabel=MANJARO_XFCE_2121
[    7.540862]     driver=nonfree
[    7.609402] fbcon: Taking over console
[    7.609502] Console: switching to colour frame buffer device 128x48
[    7.633173] loop: module loaded
[    7.639307] device-mapper: uevent: version 1.0.3
[    7.639351] device-mapper: ioctl: 4.45.0-ioctl (2021-03-22) initialised: dm-devel@redhat.com
[    7.704488] xhci_hcd 0000:03:00.0: xHCI Host Controller
[    7.704495] xhci_hcd 0000:03:00.0: new USB bus registered, assigned bus number 1
[    7.708553] dca service started, version 1.12.1
[    7.717374] igb: Intel(R) Gigabit Ethernet Network Driver
[    7.717381] igb: Copyright (c) 2007-2014 Intel Corporation.
[    7.720032] cryptd: max_cpu_qlen set to 1000
[    7.729950] AVX2 version of gcm_enc/dec engaged.
[    7.730001] AES CTR mode by8 optimization enabled
[    7.746500] pps pps0: new PPS source ptp0
[    7.746545] igb 0000:1e:00.0: added PHC on eth0
[    7.746547] igb 0000:1e:00.0: Intel(R) Gigabit Ethernet Network Connection
[    7.746548] igb 0000:1e:00.0: eth0: (PCIe:2.5Gb/s:Width x1) 4c:cc:6a:fd:50:6a
[    7.746550] igb 0000:1e:00.0: eth0: PBA No: FFFFFF-0FF
[    7.746552] igb 0000:1e:00.0: Using MSI-X interrupts. 2 rx queue(s), 2 tx queue(s)
[    7.759859] xhci_hcd 0000:03:00.0: hcc params 0x0200ef81 hci version 0x110 quirks 0x0000010008000410
[    7.760138] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[    7.760142] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    7.760144] usb usb1: Product: xHCI Host Controller
[    7.760146] usb usb1: Manufacturer: Linux 5.15.12-1-MANJARO xhci-hcd
[    7.760147] usb usb1: SerialNumber: 0000:03:00.0
[    7.760365] hub 1-0:1.0: USB hub found
[    7.760384] hub 1-0:1.0: 14 ports detected
[    7.760957] xhci_hcd 0000:03:00.0: xHCI Host Controller
[    7.760960] xhci_hcd 0000:03:00.0: new USB bus registered, assigned bus number 2
[    7.760964] xhci_hcd 0000:03:00.0: Host supports USB 3.1 Enhanced SuperSpeed
[    7.761015] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    7.761035] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[    7.761038] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    7.761039] usb usb2: Product: xHCI Host Controller
[    7.761041] usb usb2: Manufacturer: Linux 5.15.12-1-MANJARO xhci-hcd
[    7.761042] usb usb2: SerialNumber: 0000:03:00.0
[    7.761118] hub 2-0:1.0: USB hub found
[    7.761131] hub 2-0:1.0: 8 ports detected
[    7.762273] xhci_hcd 0000:23:00.0: xHCI Host Controller
[    7.762279] xhci_hcd 0000:23:00.0: new USB bus registered, assigned bus number 3
[    7.817165] xhci_hcd 0000:23:00.0: hcc params 0x0200ef80 hci version 0x110 quirks 0x0000000000800010
[    7.817462] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[    7.817464] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    7.817465] usb usb3: Product: xHCI Host Controller
[    7.817467] usb usb3: Manufacturer: Linux 5.15.12-1-MANJARO xhci-hcd
[    7.817468] usb usb3: SerialNumber: 0000:23:00.0
[    7.817559] hub 3-0:1.0: USB hub found
[    7.817567] hub 3-0:1.0: 2 ports detected
[    7.817673] xhci_hcd 0000:23:00.0: xHCI Host Controller
[    7.817676] xhci_hcd 0000:23:00.0: new USB bus registered, assigned bus number 4
[    7.817678] xhci_hcd 0000:23:00.0: Host supports USB 3.1 Enhanced SuperSpeed
[    7.817708] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[    7.817725] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[    7.817727] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    7.817728] usb usb4: Product: xHCI Host Controller
[    7.817729] usb usb4: Manufacturer: Linux 5.15.12-1-MANJARO xhci-hcd
[    7.817731] usb usb4: SerialNumber: 0000:23:00.0
[    7.817801] hub 4-0:1.0: USB hub found
[    7.817808] hub 4-0:1.0: 2 ports detected
[    7.817956] xhci_hcd 0000:25:00.3: xHCI Host Controller
[    7.817959] xhci_hcd 0000:25:00.3: new USB bus registered, assigned bus number 5
[    7.818055] xhci_hcd 0000:25:00.3: hcc params 0x0270f665 hci version 0x100 quirks 0x0000000040000410
[    7.818155] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[    7.818156] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    7.818157] usb usb5: Product: xHCI Host Controller
[    7.818158] usb usb5: Manufacturer: Linux 5.15.12-1-MANJARO xhci-hcd
[    7.818159] usb usb5: SerialNumber: 0000:25:00.3
[    7.818223] hub 5-0:1.0: USB hub found
[    7.818229] hub 5-0:1.0: 4 ports detected
[    7.818361] xhci_hcd 0000:25:00.3: xHCI Host Controller
[    7.818363] xhci_hcd 0000:25:00.3: new USB bus registered, assigned bus number 6
[    7.818365] xhci_hcd 0000:25:00.3: Host supports USB 3.0 SuperSpeed
[    7.818376] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
[    7.818388] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[    7.818390] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    7.818391] usb usb6: Product: xHCI Host Controller
[    7.818391] usb usb6: Manufacturer: Linux 5.15.12-1-MANJARO xhci-hcd
[    7.818392] usb usb6: SerialNumber: 0000:25:00.3
[    7.818457] hub 6-0:1.0: USB hub found
[    7.818463] hub 6-0:1.0: 4 ports detected
[    7.824080] raid6: skip pq benchmark and using algorithm avx2x4
[    7.824084] raid6: using avx2x2 recovery algorithm
[    7.827238] xor: automatically using best checksumming function   avx
[    7.847359] random: fast init done
[    7.907089] Btrfs loaded, crc32c=crc32c-intel, zoned=yes, fsverity=yes
[    7.907625] BTRFS: device fsid 6f9b0443-7f3e-4e40-8212-a9e548c67b71 devid 1 transid 169 /dev/sdb2 scanned by systemd-udevd (281)
[    8.010072] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[    8.066708] usb 5-2: new full-speed USB device number 2 using xhci_hcd
[    8.070024] usb 3-2: new high-speed USB device number 2 using xhci_hcd
[    8.180454] usb 1-1: New USB device found, idVendor=0930, idProduct=6545, bcdDevice= 1.00
[    8.180459] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    8.180460] usb 1-1: Product: DataTraveler 2.0
[    8.180461] usb 1-1: Manufacturer: Kingston
[    8.180462] usb 1-1: SerialNumber: C860008861F9EDA09A070050
[    8.190853] usb-storage 1-1:1.0: USB Mass Storage device detected
[    8.190982] scsi host9: usb-storage 1-1:1.0
[    8.191039] usbcore: registered new interface driver usb-storage
[    8.194032] usbcore: registered new interface driver uas
[    8.229418] usb 5-2: New USB device found, idVendor=046d, idProduct=c08b, bcdDevice=27.03
[    8.229422] usb 5-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    8.229424] usb 5-2: Product: G502 HERO Gaming Mouse
[    8.229425] usb 5-2: Manufacturer: Logitech
[    8.229426] usb 5-2: SerialNumber: 118938673338
[    8.239500] usb 3-2: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=32.98
[    8.239503] usb 3-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    8.239505] usb 3-2: Product: USB2.0 Hub
[    8.245551] hub 3-2:1.0: USB hub found
[    8.249524] hub 3-2:1.0: 3 ports detected
[    8.260536] input: Logitech G502 HERO Gaming Mouse as /devices/pci0000:00/0000:00:07.1/0000:25:00.3/usb5/5-2/5-2:1.0/0003:046D:C08B.0001/input/input2
[    8.260599] hid-generic 0003:046D:C08B.0001: input,hidraw0: USB HID v1.11 Mouse [Logitech G502 HERO Gaming Mouse] on usb-0000:25:00.3-2/input0
[    8.269789] input: Logitech G502 HERO Gaming Mouse Keyboard as /devices/pci0000:00/0000:00:07.1/0000:25:00.3/usb5/5-2/5-2:1.1/0003:046D:C08B.0002/input/input3
[    8.310027] usb 1-10: new full-speed USB device number 3 using xhci_hcd
[    8.323488] hid-generic 0003:046D:C08B.0002: input,hiddev96,hidraw1: USB HID v1.11 Keyboard [Logitech G502 HERO Gaming Mouse] on usb-0000:25:00.3-2/input1
[    8.323526] usbcore: registered new interface driver usbhid
[    8.323528] usbhid: USB HID core driver
[    8.363374] usb 5-3: new full-speed USB device number 3 using xhci_hcd
[    8.571425] usb 5-3: New USB device found, idVendor=14ed, idProduct=1000, bcdDevice= 0.00
[    8.571431] usb 5-3: New USB device strings: Mfr=8, Product=9, SerialNumber=0
[    8.571432] usb 5-3: Product: Shure MV5
[    8.571434] usb 5-3: Manufacturer: Shure Inc
[    8.627222] usb 1-10: New USB device found, idVendor=3299, idProduct=4ea2, bcdDevice= 1.03
[    8.627225] usb 1-10: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    8.627227] usb 1-10: Product: GK650 Gaming Keyboard
[    8.627228] usb 1-10: Manufacturer: SONiX
[    8.639213] input: SONiX GK650 Gaming Keyboard as /devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-10/1-10:1.0/0003:3299:4EA2.0003/input/input6
[    8.671591] hid-generic 0003:14ED:1000.0004: hiddev97,hidraw2: USB HID v1.11 Device [Shure Inc Shure MV5] on usb-0000:25:00.3-3/input3
[    8.693555] hid-generic 0003:3299:4EA2.0003: input,hidraw3: USB HID v1.11 Keyboard [SONiX GK650 Gaming Keyboard] on usb-0000:03:00.0-10/input0
[    8.700734] input: SONiX GK650 Gaming Keyboard as /devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-10/1-10:1.1/0003:3299:4EA2.0005/input/input7
[    8.756840] input: SONiX GK650 Gaming Keyboard as /devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-10/1-10:1.1/0003:3299:4EA2.0005/input/input8
[    8.756879] input: SONiX GK650 Gaming Keyboard Mouse as /devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-10/1-10:1.1/0003:3299:4EA2.0005/input/input9
[    8.756954] hid-generic 0003:3299:4EA2.0005: input,hiddev98,hidraw4: USB HID v1.11 Keyboard [SONiX GK650 Gaming Keyboard] on usb-0000:03:00.0-10/input1
[    9.206053] scsi 9:0:0:0: Direct-Access     Kingston DataTraveler 2.0 PMAP PQ: 0 ANSI: 4
[    9.206796] sd 9:0:0:0: [sdd] 30489408 512-byte logical blocks: (15.6 GB/14.5 GiB)
[    9.206921] sd 9:0:0:0: [sdd] Write Protect is off
[    9.206923] sd 9:0:0:0: [sdd] Mode Sense: 23 00 00 00
[    9.207045] sd 9:0:0:0: [sdd] No Caching mode page found
[    9.207063] sd 9:0:0:0: [sdd] Assuming drive cache: write through
[    9.209744]  sdd: sdd1 sdd2
[    9.210832] sd 9:0:0:0: [sdd] Attached SCSI removable disk
[    9.393661] BTRFS info (device sdb2): flagging fs with big metadata feature
[    9.393665] BTRFS info (device sdb2): disk space caching is enabled
[    9.393666] BTRFS info (device sdb2): has skinny extents
[    9.398912] BTRFS info (device sdb2): enabling ssd optimizations
[    9.501809] random: crng init done
[    9.757794] EXT4-fs (sdc1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[   11.106851] BTRFS info (device sdb2): flagging fs with big metadata feature
[   11.106855] BTRFS info (device sdb2): disk space caching is enabled
[   11.106856] BTRFS info (device sdb2): has skinny extents
[   11.111350] BTRFS info (device sdb2): enabling ssd optimizations
[   11.413427] EXT4-fs (sdc1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[   11.507466] ISO 9660 Extensions: Microsoft Joliet Level 3
[   11.508349] ISO 9660 Extensions: RRIP_1991A
[   11.576308] ISO 9660 Extensions: Microsoft Joliet Level 3
[   11.577221] ISO 9660 Extensions: RRIP_1991A
[   11.582103] loop0: detected capacity change from 0 to 265736
[   11.707642] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[   11.737030] loop1: detected capacity change from 0 to 1817096
[   11.857012] loop2: detected capacity change from 0 to 3151496
[   11.972796] loop3: detected capacity change from 0 to 1588416
[   12.096780] overlayfs: null uuid detected in lower fs '/', falling back to xino=off,index=off,nfs_export=off.
[   13.029051] systemd[1]: systemd 250-5-manjaro running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK +XKBCOMMON +UTMP -SYSVINIT default-hierarchy=unified)
[   13.043474] systemd[1]: Detected architecture x86-64.
[   14.442452] systemd[1]: Queued start job for default target Multi-User System.
[   14.443189] systemd[1]: Created slice Slice /system/getty.
[   14.443450] systemd[1]: Created slice Slice /system/modprobe.
[   14.443633] systemd[1]: Created slice User and Session Slice.
[   14.443708] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[   14.443775] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   14.443911] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[   14.443967] systemd[1]: Reached target Local Encrypted Volumes.
[   14.444009] systemd[1]: Reached target Local Integrity Protected Volumes.
[   14.444055] systemd[1]: Reached target Remote File Systems.
[   14.444091] systemd[1]: Reached target Slice Units.
[   14.444130] systemd[1]: Reached target Swaps.
[   14.444166] systemd[1]: Reached target Local Verity Protected Volumes.
[   14.444242] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[   14.444714] systemd[1]: Listening on LVM2 poll daemon socket.
[   14.445599] systemd[1]: Listening on Process Core Dump Socket.
[   14.445730] systemd[1]: Listening on Journal Audit Socket.
[   14.446186] systemd[1]: Listening on Journal Socket (/dev/log).
[   14.446636] systemd[1]: Listening on Journal Socket.
[   14.447482] systemd[1]: Listening on udev Control Socket.
[   14.448007] systemd[1]: Listening on udev Kernel Socket.
[   14.448898] systemd[1]: Mounting Huge Pages File System...
[   14.449765] systemd[1]: Mounting POSIX Message Queue File System...
[   14.450617] systemd[1]: Mounting Kernel Debug File System...
[   14.451446] systemd[1]: Mounting Kernel Trace File System...
[   14.458247] systemd[1]: Mounting Temporary Directory /tmp...
[   14.459168] systemd[1]: Starting Load AppArmor profiles...
[   14.460263] systemd[1]: Starting Create List of Static Device Nodes...
[   14.461111] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[   14.462086] systemd[1]: Starting Load Kernel Module configfs...
[   14.462977] systemd[1]: Starting Load Kernel Module drm...
[   14.463914] systemd[1]: Starting Load Kernel Module fuse...
[   14.499362] systemd[1]: Starting Load Kernel Modules...
[   14.500291] systemd[1]: Starting Remount Root and Kernel File Systems...
[   14.502861] fuse: init (API version 7.34)
[   14.553652] systemd[1]: Repartition Root Disk was skipped because all trigger condition checks failed.
[   14.554330] systemd[1]: Starting Coldplug All udev Devices...
[   14.556014] systemd[1]: Mounted Huge Pages File System.
[   14.556452] systemd[1]: Mounted POSIX Message Queue File System.
[   14.556879] systemd[1]: Mounted Kernel Debug File System.
[   14.557295] systemd[1]: Mounted Kernel Trace File System.
[   14.558172] systemd[1]: Mounted Temporary Directory /tmp.
[   14.558656] systemd[1]: Finished Create List of Static Device Nodes.
[   14.559190] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[   14.559269] systemd[1]: Finished Load Kernel Module configfs.
[   14.559792] systemd[1]: modprobe@drm.service: Deactivated successfully.
[   14.559867] systemd[1]: Finished Load Kernel Module drm.
[   14.560360] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[   14.560433] systemd[1]: Finished Load Kernel Module fuse.
[   14.560907] systemd[1]: Finished Remount Root and Kernel File Systems.
[   14.561809] systemd[1]: Mounting FUSE Control File System...
[   14.562630] systemd[1]: Mounting Kernel Configuration File System...
[   14.563028] systemd[1]: First Boot Wizard was skipped because of a failed condition check (ConditionFirstBoot=yes).
[   14.615282] systemd[1]: Rebuild Hardware Database was skipped because of a failed condition check (ConditionNeedsUpdate=/etc).
[   14.615950] systemd[1]: Starting Load/Save Random Seed...
[   14.616365] systemd[1]: Create System Users was skipped because of a failed condition check (ConditionNeedsUpdate=/etc).
[   14.616843] systemd[1]: Starting Create Static Device Nodes in /dev...
[   14.618129] systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
[   14.618624] systemd[1]: Mounted FUSE Control File System.
[   14.619060] systemd[1]: Mounted Kernel Configuration File System.
[   14.698972] systemd[1]: Finished Load/Save Random Seed.
[   14.699465] systemd[1]: First Boot Complete was skipped because of a failed condition check (ConditionFirstBoot=yes).
[   14.721168] systemd[1]: Finished Coldplug All udev Devices.
[   14.790844] spl: loading out-of-tree module taints kernel.
[   14.790906] spl: module verification failed: signature and/or required key missing - tainting kernel
[   14.813483] znvpair: module license 'CDDL' taints kernel.
[   14.813486] Disabling lock debugging due to kernel taint
[   14.874822] audit: type=1400 audit(1641941452.746:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=549 comm="apparmor_parser"
[   14.879170] systemd[1]: Finished Create Static Device Nodes in /dev.
[   14.879636] systemd[1]: Reached target Preparation for Local File Systems.
[   14.880758] systemd[1]: Mounting Temporary /etc/pacman.d/gnupg directory...
[   14.881244] systemd[1]: Virtual Machine and Container Storage (Compatibility) was skipped because of a failed condition check (ConditionPathExists=/var/lib/machines.raw).
[   14.881258] systemd[1]: Entropy Daemon based on the HAVEGE algorithm was skipped because of a failed condition check (ConditionKernelVersion=<5.6).
[   14.882204] systemd[1]: Starting Journal Service...
[   14.883533] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[   14.885112] systemd[1]: Mounted Temporary /etc/pacman.d/gnupg directory.
[   14.885777] systemd[1]: Reached target Local File Systems.
[   14.886450] systemd[1]: Rebuild Dynamic Linker Cache was skipped because all trigger condition checks failed.
[   14.886893] systemd[1]: Set Up Additional Binary Formats was skipped because all trigger condition checks failed.
[   14.886923] systemd[1]: Store a System Token in an EFI Variable was skipped because of a failed condition check (ConditionPathExists=/sys/firmware/efi/efivars/LoaderFeatures-4a67b082-0a4c-41cf-b6c7-440b29bb8c4f).
[   14.886958] systemd[1]: Commit a transient machine-id on disk was skipped because of a failed condition check (ConditionPathIsMountPoint=/etc/machine-id).
[   14.905685] audit: type=1400 audit(1641941452.776:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="dovecot-script-login" pid=552 comm="apparmor_parser"
[   14.914485] audit: type=1400 audit(1641941452.786:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=550 comm="apparmor_parser"
[   14.915461] audit: type=1400 audit(1641941452.786:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=550 comm="apparmor_parser"
[   14.918643] audit: type=1400 audit(1641941452.789:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="php-fpm" pid=551 comm="apparmor_parser"
[   14.969238] audit: type=1400 audit(1641941452.839:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/lightdm/lightdm-guest-session" pid=548 comm="apparmor_parser"
[   14.970186] audit: type=1400 audit(1641941452.843:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/lightdm/lightdm-guest-session//chromium" pid=548 comm="apparmor_parser"
[   14.996155] systemd[1]: Started Journal Service.
[   14.996704] audit: type=1130 audit(1641941452.866:9): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   15.037838] systemd-journald[555]: Received client request to flush runtime journal.
[   15.039054] audit: type=1130 audit(1641941452.909:10): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   15.094298] audit: type=1400 audit(1641941452.966:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine" pid=553 comm="apparmor_parser"
[   15.497063] acpi_cpufreq: overriding BIOS provided _PSD data
[   15.557378] input: PC Speaker as /devices/platform/pcspkr/input/input10
[   15.607311] igb 0000:1e:00.0 enp30s0: renamed from eth0
[   15.808495] piix4_smbus 0000:00:14.0: SMBus Host Controller at 0xb00, revision 0
[   15.808499] piix4_smbus 0000:00:14.0: Using register 0x02 for SMBus port selection
[   15.808564] piix4_smbus 0000:00:14.0: Auxiliary SMBus Host Controller at 0xb20
[   15.982941] ccp 0000:25:00.2: enabling device (0000 -> 0002)
[   15.983405] ccp 0000:25:00.2: ccp enabled
[   16.069234] sp5100_tco: SP5100/SB800 TCO WatchDog Timer Driver
[   16.069372] sp5100-tco sp5100-tco: Using 0xfeb00000 for watchdog MMIO address
[   16.069393] tpm_crb MSFT0101:00: [Firmware Bug]: ACPI region does not cover the entire command/response buffer. [mem 0xdd37f000-0xdd37ffff flags 0x200] vs dd37f000 4000
[   16.069496] sp5100-tco sp5100-tco: initialized. heartbeat=60 sec (nowayout=0)
[   16.069541] RAPL PMU: API unit is 2^-32 Joules, 1 fixed counters, 163840 ms ovfl timer
[   16.069580] RAPL PMU: hw unit of domain package 2^-16 Joules
[   16.070420] tpm_crb MSFT0101:00: can't request region for resource [mem 0xdd37f000-0xdd37ffff]
[   16.070422] tpm_crb: probe of MSFT0101:00 failed with error -16
[   16.867989] kvm: Nested Virtualization enabled
[   16.867992] SVM: kvm: Nested Paging enabled
[   16.867993] SEV supported: 16 ASIDs
[   16.868001] SVM: Virtual VMLOAD VMSAVE supported
[   16.868002] SVM: Virtual GIF supported
[   16.932192] snd_hda_intel 0000:24:00.1: enabling device (0000 -> 0002)
[   16.932272] snd_hda_intel 0000:24:00.1: Disabling MSI
[   16.932281] snd_hda_intel 0000:24:00.1: Handle vga_switcheroo audio client
[   16.932568] snd_hda_intel 0000:26:00.3: enabling device (0000 -> 0002)
[   16.932628] MCE: In-kernel MCE decoding enabled.
[   17.048755] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:03.1/0000:24:00.1/sound/card0/input11
[   17.048830] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:03.1/0000:24:00.1/sound/card0/input12
[   17.048883] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:03.1/0000:24:00.1/sound/card0/input13
[   17.048947] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:03.1/0000:24:00.1/sound/card0/input14
[   17.049023] input: HDA NVidia HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:03.1/0000:24:00.1/sound/card0/input15
[   17.049085] input: HDA NVidia HDMI/DP,pcm=11 as /devices/pci0000:00/0000:00:03.1/0000:24:00.1/sound/card0/input16
[   17.049140] input: HDA NVidia HDMI/DP,pcm=12 as /devices/pci0000:00/0000:00:03.1/0000:24:00.1/sound/card0/input17
[   17.125266] intel_rapl_common: Found RAPL domain package
[   17.125270] intel_rapl_common: Found RAPL domain core
[   17.204234] snd_hda_codec_realtek hdaudioC1D0: autoconfig for ALC1220: line_outs=3 (0x14/0x15/0x16/0x0/0x0) type:line
[   17.204241] snd_hda_codec_realtek hdaudioC1D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[   17.204244] snd_hda_codec_realtek hdaudioC1D0:    hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[   17.204247] snd_hda_codec_realtek hdaudioC1D0:    mono: mono_out=0x0
[   17.204248] snd_hda_codec_realtek hdaudioC1D0:    dig-out=0x1e/0x0
[   17.204250] snd_hda_codec_realtek hdaudioC1D0:    inputs:
[   17.204251] snd_hda_codec_realtek hdaudioC1D0:      Front Mic=0x19
[   17.204253] snd_hda_codec_realtek hdaudioC1D0:      Rear Mic=0x18
[   17.204255] snd_hda_codec_realtek hdaudioC1D0:      Line=0x1a
[   17.217220] input: HD-Audio Generic Front Mic as /devices/pci0000:00/0000:00:08.1/0000:26:00.3/sound/card1/input18
[   17.217292] input: HD-Audio Generic Rear Mic as /devices/pci0000:00/0000:00:08.1/0000:26:00.3/sound/card1/input19
[   17.217336] input: HD-Audio Generic Line as /devices/pci0000:00/0000:00:08.1/0000:26:00.3/sound/card1/input20
[   17.217377] input: HD-Audio Generic Line Out Front as /devices/pci0000:00/0000:00:08.1/0000:26:00.3/sound/card1/input21
[   17.217414] input: HD-Audio Generic Line Out Surround as /devices/pci0000:00/0000:00:08.1/0000:26:00.3/sound/card1/input22
[   17.217450] input: HD-Audio Generic Line Out CLFE as /devices/pci0000:00/0000:00:08.1/0000:26:00.3/sound/card1/input23
[   17.217489] input: HD-Audio Generic Front Headphone as /devices/pci0000:00/0000:00:08.1/0000:26:00.3/sound/card1/input24
[   17.762613] ZFS: Loaded module v2.1.1-1, ZFS pool version 5000, ZFS filesystem version 5
[   18.975121] mousedev: PS/2 mouse device common for all mice
[   19.184862] mc: Linux media interface: v0.10
[   19.621719] usbcore: registered new interface driver snd-usb-audio
[   19.842421] st: Version 20160209, fixed bufsize 32768, s/g segs 256
[   19.979963] sd 0:0:0:0: Attached scsi generic sg0 type 0
[   19.980003] sd 2:0:0:0: Attached scsi generic sg1 type 0
[   19.980042] sd 6:0:0:0: Attached scsi generic sg2 type 0
[   19.980075] sd 9:0:0:0: Attached scsi generic sg3 type 0
[   20.211955] loop4: detected capacity change from 0 to 8
[   20.612254] kauditd_printk_skb: 24 callbacks suppressed
[   20.612258] audit: type=1130 audit(1641941458.483:36): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   20.734076] audit: type=1130 audit(1641941458.606:37): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=cups comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   20.740863] NET: Registered PF_QIPCRTR protocol family
[   20.742561] audit: type=1130 audit(1641941458.613:38): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=ModemManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   20.972025] audit: type=1400 audit(1641941458.839:39): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/usr/lib/snapd/snap-confine" pid=1262 comm="apparmor_parser"
[   21.000057] audit: type=1300 audit(1641941458.839:39): arch=c000003e syscall=1 success=yes exit=69825 a0=6 a1=5611bd766a40 a2=110c1 a3=0 items=0 ppid=1259 pid=1262 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="apparmor_parser" exe="/usr/bin/apparmor_parser" subj==unconfined key=(null)
[   21.000063] audit: type=1327 audit(1641941458.839:39): proctitle=61707061726D6F725F706172736572002D2D7265706C616365002D2D77726974652D6361636865002D4F006E6F2D657870722D73696D706C696679002D2D63616368652D6C6F633D2F7661722F63616368652F61707061726D6F72002D2D736B69702D726561642D6361636865002D2D7175696574002F6574632F6170706172
[   21.000819] audit: type=1400 audit(1641941458.873:40): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="/usr/lib/snapd/snap-confine//mount-namespace-capture-helper" pid=1262 comm="apparmor_parser"
[   21.000832] audit: type=1300 audit(1641941458.873:40): arch=c000003e syscall=1 success=yes exit=16065 a0=6 a1=5611bd839a30 a2=3ec1 a3=0 items=0 ppid=1259 pid=1262 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="apparmor_parser" exe="/usr/bin/apparmor_parser" subj==unconfined key=(null)
[   21.000835] audit: type=1327 audit(1641941458.873:40): proctitle=61707061726D6F725F706172736572002D2D7265706C616365002D2D77726974652D6361636865002D4F006E6F2D657870722D73696D706C696679002D2D63616368652D6C6F633D2F7661722F63616368652F61707061726D6F72002D2D736B69702D726561642D6361636865002D2D7175696574002F6574632F6170706172
[   21.009952] audit: type=1130 audit(1641941458.879:41): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=snapd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   23.093900] igb 0000:1e:00.0 enp30s0: igb: enp30s0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
[   23.200255] IPv6: ADDRCONF(NETDEV_CHANGE): enp30s0: link becomes ready
[   28.064741] kauditd_printk_skb: 6 callbacks suppressed
[   28.064744] audit: type=1116 audit(1641941465.936:48): pid=1645 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=adding group acct="manjaro" exe="/usr/bin/useradd" hostname=? addr=? terminal=? res=success'
[   28.065064] audit: type=1114 audit(1641941465.936:49): pid=1645 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=adding user id=1000 exe="/usr/bin/useradd" hostname=? addr=? terminal=? res=success'
[   28.065075] audit: type=1114 audit(1641941465.936:50): pid=1645 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=adding user to group acct="manjaro" exe="/usr/bin/useradd" hostname=? addr=? terminal=? res=success'
[   28.065091] audit: type=1114 audit(1641941465.936:51): pid=1645 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=adding user to group acct="manjaro" exe="/usr/bin/useradd" hostname=? addr=? terminal=? res=success'
[   28.065103] audit: type=1114 audit(1641941465.936:52): pid=1645 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=adding user to group acct="manjaro" exe="/usr/bin/useradd" hostname=? addr=? terminal=? res=success'
[   28.065117] audit: type=1114 audit(1641941465.936:53): pid=1645 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=adding user to group acct="manjaro" exe="/usr/bin/useradd" hostname=? addr=? terminal=? res=success'
[   28.065129] audit: type=1114 audit(1641941465.936:54): pid=1645 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=adding user to group acct="manjaro" exe="/usr/bin/useradd" hostname=? addr=? terminal=? res=success'
[   28.065144] audit: type=1114 audit(1641941465.936:55): pid=1645 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=adding user to shadow group acct="manjaro" exe="/usr/bin/useradd" hostname=? addr=? terminal=? res=success'
[   28.065158] audit: type=1114 audit(1641941465.936:56): pid=1645 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=adding user to shadow group acct="manjaro" exe="/usr/bin/useradd" hostname=? addr=? terminal=? res=success'
[   28.065171] audit: type=1114 audit(1641941465.936:57): pid=1645 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=adding user to shadow group acct="manjaro" exe="/usr/bin/useradd" hostname=? addr=? terminal=? res=success'
[   36.015667] kauditd_printk_skb: 11 callbacks suppressed
[   36.015671] audit: type=1131 audit(1641941473.886:69): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=snapd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   36.910182] audit: type=1130 audit(1641941474.783:70): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=pacman-init comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   49.791857] audit: type=1131 audit(1641941487.663:71): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   49.920522] audit: type=1334 audit(1641941487.793:72): prog-id=0 op=UNLOAD
[   49.920531] audit: type=1334 audit(1641941487.793:73): prog-id=0 op=UNLOAD
[   49.920536] audit: type=1334 audit(1641941487.793:74): prog-id=0 op=UNLOAD
[   51.177337] audit: type=1131 audit(1641941489.049:75): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   51.226835] audit: type=1334 audit(1641941489.099:76): prog-id=0 op=UNLOAD
[   51.226842] audit: type=1334 audit(1641941489.099:77): prog-id=0 op=UNLOAD
[   51.226845] audit: type=1334 audit(1641941489.099:78): prog-id=0 op=UNLOAD
[   62.682149] audit: type=1334 audit(1641941500.553:79): prog-id=18 op=LOAD
[   62.682155] audit: type=1334 audit(1641941500.553:80): prog-id=0 op=UNLOAD
[   62.682260] audit: type=1334 audit(1641941500.553:81): prog-id=19 op=LOAD
[   62.682325] audit: type=1334 audit(1641941500.553:82): prog-id=20 op=LOAD
[   62.682336] audit: type=1334 audit(1641941500.553:83): prog-id=0 op=UNLOAD
[   62.682343] audit: type=1334 audit(1641941500.553:84): prog-id=0 op=UNLOAD
[   62.684136] audit: type=1334 audit(1641941500.556:85): prog-id=21 op=LOAD
[   62.684150] audit: type=1334 audit(1641941500.556:86): prog-id=0 op=UNLOAD
[   62.684244] audit: type=1334 audit(1641941500.556:87): prog-id=22 op=LOAD
[   62.684306] audit: type=1334 audit(1641941500.556:88): prog-id=23 op=LOAD
[   78.666740] nvidia-nvlink: Nvlink Core is being initialized, major device number 510
[   78.667585] nvidia 0000:24:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=none
[   78.714666] NVRM: loading NVIDIA UNIX x86_64 Kernel Module  495.44  Fri Oct 22 06:13:12 UTC 2021
[   78.739574] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms  495.44  Fri Oct 22 06:05:22 UTC 2021
[   78.759048] [drm] [nvidia-drm] [GPU ID 0x00002400] Loading driver
[   78.759053] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:24:00.0 on minor 0
[   78.763177] kauditd_printk_skb: 8 callbacks suppressed
[   78.763180] audit: type=1130 audit(1641941516.633:97): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=mhwd-live comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   78.763186] audit: type=1131 audit(1641941516.633:98): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=mhwd-live comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   78.771227] audit: type=1130 audit(1641941516.643:99): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-user-sessions comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   78.773398] audit: type=1130 audit(1641941516.646:100): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=getty@tty1 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  104.722114] audit: type=1100 audit(1641941542.593:101): pid=4683 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="manjaro" exe="/usr/bin/login" hostname=manjaro addr=? terminal=/dev/tty1 res=success'
[  104.722391] audit: type=1101 audit(1641941542.593:102): pid=4683 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="manjaro" exe="/usr/bin/login" hostname=manjaro addr=? terminal=/dev/tty1 res=success'
[  104.722907] audit: type=1103 audit(1641941542.593:103): pid=4683 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="manjaro" exe="/usr/bin/login" hostname=manjaro addr=? terminal=/dev/tty1 res=success'
[  104.722976] audit: type=1006 audit(1641941542.593:104): pid=4683 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=tty1 old-ses=4294967295 ses=1 res=1
[  104.722986] audit: type=1300 audit(1641941542.593:104): arch=c000003e syscall=1 success=yes exit=4 a0=5 a1=7ffce6e159f0 a2=4 a3=3e8 items=0 ppid=1 pid=4683 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=1000 fsgid=0 tty=tty1 ses=1 comm="login" exe="/usr/bin/login" subj==unconfined key=(null)
[  104.722990] audit: type=1327 audit(1641941542.593:104): proctitle=2F62696E2F6C6F67696E002D70002D2D
[  104.739238] audit: type=1130 audit(1641941542.609:105): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  104.745651] audit: type=1101 audit(1641941542.616:106): pid=4688 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="manjaro" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  104.745674] audit: type=1103 audit(1641941542.616:107): pid=4688 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="manjaro" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[  104.745731] audit: type=1006 audit(1641941542.616:108): pid=4688 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=2 res=1
[  195.191665] kauditd_printk_skb: 10 callbacks suppressed
[  195.191669] audit: type=1101 audit(1641941633.063:115): pid=4862 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="manjaro" exe="/usr/bin/sudo" hostname=manjaro addr=? terminal=/dev/tty1 res=success'
[  195.192290] audit: type=1110 audit(1641941633.063:116): pid=4862 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=manjaro addr=? terminal=/dev/tty1 res=success'
[  195.195305] audit: type=1105 audit(1641941633.066:117): pid=4862 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=manjaro addr=? terminal=/dev/tty1 res=success'
  Kernel: 5.15.12-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
    parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC
    misobasedir=manjaro misolabel=MANJARO_XFCE_2121 3 systemd.show_status=1
    apparmor=1 security=apparmor driver=nonfree nouveau.modeset=0
    i915.modeset=1 radeon.modeset=1
This i915.modeset=1 radeon.modeset=1 seems odd. Just to be safe, you should remove it (i915.modeset=0 radeon.modeset=0) because your GPU is NVIDIA.
Also check if there’s an update to your BIOS.
Overall, the dmesg logs shows that your computer system is fine.
I’m sorry, turns out dmesg wasnt showing an error because i forgot to attempt to startx. When i attempt to startx, the dmesg looks as following:
http://0x0.st/o-ia.json
Updated dmesg:
[    0.000000] Linux version 5.15.12-1-MANJARO (builduser@fv-az39-353) (gcc (GCC) 11.1.0, GNU ld (GNU Binutils) 2.36.1) #1 SMP PREEMPT Wed Dec 29 18:08:07 UTC 2021
[    0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC misobasedir=manjaro misolabel=MANJARO_XFCE_2121 3 systemd.show_status=1 apparmor=1 security=apparmor driver=nonfree nouveau.modeset=0 i915.modeset=0 radeon.modeset=0
[    0.000000] x86/fpu: Supporting XSAVE feature 0x001: 'x87 floating point registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x002: 'SSE registers'
[    0.000000] x86/fpu: Supporting XSAVE feature 0x004: 'AVX registers'
[    0.000000] x86/fpu: xstate_offset[2]:  576, xstate_sizes[2]:  256
[    0.000000] x86/fpu: Enabled xstate features 0x7, context size is 832 bytes, using 'compacted' format.
[    0.000000] signal: max sigframe size: 1776
[    0.000000] BIOS-provided physical RAM map:
[    0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009ffff] usable
[    0.000000] BIOS-e820: [mem 0x00000000000a0000-0x00000000000fffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000000100000-0x0000000001d7ffff] usable
[    0.000000] BIOS-e820: [mem 0x0000000001d80000-0x0000000001ffffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000002000000-0x00000000dcd71fff] usable
[    0.000000] BIOS-e820: [mem 0x00000000dcd72000-0x00000000dced7fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000dced8000-0x00000000dd292fff] usable
[    0.000000] BIOS-e820: [mem 0x00000000dd293000-0x00000000dd39cfff] ACPI NVS
[    0.000000] BIOS-e820: [mem 0x00000000dd39d000-0x00000000de387fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000de388000-0x00000000de3ebfff] type 20
[    0.000000] BIOS-e820: [mem 0x00000000de3ec000-0x00000000deffffff] usable
[    0.000000] BIOS-e820: [mem 0x00000000df000000-0x00000000dfffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000f8000000-0x00000000fbffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fdf00000-0x00000000fdffffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fea00000-0x00000000fea0ffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000feb80000-0x00000000fec01fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fec10000-0x00000000fec10fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fec30000-0x00000000fec30fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed00fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed40000-0x00000000fed44fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fed80000-0x00000000fed8ffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fedc2000-0x00000000fedcffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fedd4000-0x00000000fedd5fff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000feefffff] reserved
[    0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
[    0.000000] BIOS-e820: [mem 0x0000000100000000-0x000000041f37ffff] usable
[    0.000000] NX (Execute Disable) protection: active
[    0.000000] efi: EFI v2.50 by American Megatrends
[    0.000000] efi: TPMFinalLog=0xdd34f000 ACPI 2.0=0xdd293000 ACPI=0xdd293000 SMBIOS=0xde2f9000 ESRT=0xd8fe3a98
[    0.000000] SMBIOS 3.0 present.
[    0.000000] DMI: Micro-Star International Co., Ltd MS-7A32/X370 GAMING PRO CARBON (MS-7A32), BIOS 1.20 03/16/2017
[    0.000000] tsc: Fast TSC calibration failed
[    0.000000] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[    0.000000] e820: remove [mem 0x000a0000-0x000fffff] usable
[    0.000000] last_pfn = 0x41f380 max_arch_pfn = 0x400000000
[    0.000000] x86/PAT: Configuration [0-7]: WB  WC  UC- UC  WB  WP  UC- WT
[    0.000000] total RAM covered: 3568M
[    0.000000] Found optimal setting for mtrr clean up
[    0.000000]  gran_size: 64K 	chunk_size: 1G 	num_reg: 3  	lose cover RAM: 0G
[    0.000000] e820: update [mem 0xdf000000-0xffffffff] usable ==> reserved
[    0.000000] last_pfn = 0xdf000 max_arch_pfn = 0x400000000
[    0.000000] esrt: Reserving ESRT space from 0x00000000d8fe3a98 to 0x00000000d8fe3ad0.
[    0.000000] e820: update [mem 0xd8fe3000-0xd8fe3fff] usable ==> reserved
[    0.000000] Using GB pages for direct mapping
[    0.000000] Secure boot disabled
[    0.000000] RAMDISK: [mem 0x318f1000-0x34c6ffff]
[    0.000000] ACPI: Early table checksum verification disabled
[    0.000000] ACPI: RSDP 0x00000000DD293000 000024 (v02 ALASKA)
[    0.000000] ACPI: XSDT 0x00000000DD2930A0 0000C4 (v01 ALASKA A M I    01072009 AMI  00010013)
[    0.000000] ACPI: FACP 0x00000000DD298E30 000114 (v06 ALASKA A M I    01072009 AMI  00010013)
[    0.000000] ACPI BIOS Warning (bug): Optional FADT field Pm2ControlBlock has valid Length but zero Address: 0x0000000000000000/0x1 (20210730/tbfadt-615)
[    0.000000] ACPI: DSDT 0x00000000DD293200 005C2F (v02 ALASKA A M I    01072009 INTL 20120913)
[    0.000000] ACPI: FACS 0x00000000DD39AC80 000040
[    0.000000] ACPI: APIC 0x00000000DD298F48 0000DE (v03 ALASKA A M I    01072009 AMI  00010013)
[    0.000000] ACPI: FPDT 0x00000000DD299028 000044 (v01 ALASKA A M I    01072009 AMI  00010013)
[    0.000000] ACPI: SSDT 0x00000000DD299070 008C4C (v02                 00000002 MSFT 04000000)
[    0.000000] ACPI: FIDT 0x00000000DD2A1CC0 00009C (v01 ALASKA A M I    01072009 AMI  00010013)
[    0.000000] ACPI: SSDT 0x00000000DD2A1D60 0018B4 (v01 AMD    AmdTable 00000001 AMD  00000001)
[    0.000000] ACPI: SRAT 0x00000000DD2A3618 0000F0 (v03 AMD    AmdTable 00000001 AMD  00000001)
[    0.000000] ACPI: CRAT 0x00000000DD2A3708 000BD0 (v01 AMD    AmdTable 00000001 AMD  00000001)
[    0.000000] ACPI: CDIT 0x00000000DD2A42D8 000029 (v01 AMD    AmdTable 00000001 AMD  00000001)
[    0.000000] ACPI: SSDT 0x00000000DD2A4308 0017A1 (v01 AMD    AOD      00000001 INTL 20120913)
[    0.000000] ACPI: MCFG 0x00000000DD2A5AB0 00003C (v01 ALASKA A M I    01072009 MSFT 00010013)
[    0.000000] ACPI: HPET 0x00000000DD2A5AF0 000038 (v01 ALASKA A M I    01072009 AMI  00000005)
[    0.000000] ACPI: SSDT 0x00000000DD2A5B28 000024 (v01 AMDFCH FCHZP    00001000 INTL 20120913)
[    0.000000] ACPI: UEFI 0x00000000DD2A5B50 000042 (v01                 00000000      00000000)
[    0.000000] ACPI: TPM2 0x00000000DD2A5B98 000034 (v03        Tpm2Tabl 00000001 AMI  00000000)
[    0.000000] ACPI: IVRS 0x00000000DD2A5BD0 0000D0 (v02                 00000001 AMD  00000000)
[    0.000000] ACPI: BGRT 0x00000000DD2A5CA0 000038 (v01 ALASKA A M I    01072009 AMI  00010013)
[    0.000000] ACPI: SSDT 0x00000000DD2A5CD8 0000F8 (v01 AMDFCH FCHPT    00001000 INTL 20120913)
[    0.000000] ACPI: SSDT 0x00000000DD2A5DD0 001664 (v01 AMD    CPMCMN   00000001 INTL 20120913)
[    0.000000] ACPI: BGRT 0x00000000DD2A7438 000038 (v01 ALASKA A M I    01072009 AMI  00010013)
[    0.000000] ACPI: Reserving FACP table memory at [mem 0xdd298e30-0xdd298f43]
[    0.000000] ACPI: Reserving DSDT table memory at [mem 0xdd293200-0xdd298e2e]
[    0.000000] ACPI: Reserving FACS table memory at [mem 0xdd39ac80-0xdd39acbf]
[    0.000000] ACPI: Reserving APIC table memory at [mem 0xdd298f48-0xdd299025]
[    0.000000] ACPI: Reserving FPDT table memory at [mem 0xdd299028-0xdd29906b]
[    0.000000] ACPI: Reserving SSDT table memory at [mem 0xdd299070-0xdd2a1cbb]
[    0.000000] ACPI: Reserving FIDT table memory at [mem 0xdd2a1cc0-0xdd2a1d5b]
[    0.000000] ACPI: Reserving SSDT table memory at [mem 0xdd2a1d60-0xdd2a3613]
[    0.000000] ACPI: Reserving SRAT table memory at [mem 0xdd2a3618-0xdd2a3707]
[    0.000000] ACPI: Reserving CRAT table memory at [mem 0xdd2a3708-0xdd2a42d7]
[    0.000000] ACPI: Reserving CDIT table memory at [mem 0xdd2a42d8-0xdd2a4300]
[    0.000000] ACPI: Reserving SSDT table memory at [mem 0xdd2a4308-0xdd2a5aa8]
[    0.000000] ACPI: Reserving MCFG table memory at [mem 0xdd2a5ab0-0xdd2a5aeb]
[    0.000000] ACPI: Reserving HPET table memory at [mem 0xdd2a5af0-0xdd2a5b27]
[    0.000000] ACPI: Reserving SSDT table memory at [mem 0xdd2a5b28-0xdd2a5b4b]
[    0.000000] ACPI: Reserving UEFI table memory at [mem 0xdd2a5b50-0xdd2a5b91]
[    0.000000] ACPI: Reserving TPM2 table memory at [mem 0xdd2a5b98-0xdd2a5bcb]
[    0.000000] ACPI: Reserving IVRS table memory at [mem 0xdd2a5bd0-0xdd2a5c9f]
[    0.000000] ACPI: Reserving BGRT table memory at [mem 0xdd2a5ca0-0xdd2a5cd7]
[    0.000000] ACPI: Reserving SSDT table memory at [mem 0xdd2a5cd8-0xdd2a5dcf]
[    0.000000] ACPI: Reserving SSDT table memory at [mem 0xdd2a5dd0-0xdd2a7433]
[    0.000000] ACPI: Reserving BGRT table memory at [mem 0xdd2a7438-0xdd2a746f]
[    0.000000] system APIC only can use physical flat
[    0.000000] Setting APIC routing to physical flat.
[    0.000000] SRAT: PXM 0 -> APIC 0x00 -> Node 0
[    0.000000] SRAT: PXM 0 -> APIC 0x01 -> Node 0
[    0.000000] SRAT: PXM 0 -> APIC 0x02 -> Node 0
[    0.000000] SRAT: PXM 0 -> APIC 0x03 -> Node 0
[    0.000000] SRAT: PXM 0 -> APIC 0x04 -> Node 0
[    0.000000] SRAT: PXM 0 -> APIC 0x05 -> Node 0
[    0.000000] SRAT: PXM 0 -> APIC 0x08 -> Node 0
[    0.000000] SRAT: PXM 0 -> APIC 0x09 -> Node 0
[    0.000000] SRAT: PXM 0 -> APIC 0x0a -> Node 0
[    0.000000] SRAT: PXM 0 -> APIC 0x0b -> Node 0
[    0.000000] SRAT: PXM 0 -> APIC 0x0c -> Node 0
[    0.000000] SRAT: PXM 0 -> APIC 0x0d -> Node 0
[    0.000000] No NUMA configuration found
[    0.000000] Faking a node at [mem 0x0000000000000000-0x000000041f37ffff]
[    0.000000] NODE_DATA(0) allocated [mem 0x41f37c000-0x41f37ffff]
[    0.000000] Zone ranges:
[    0.000000]   DMA      [mem 0x0000000000001000-0x0000000000ffffff]
[    0.000000]   DMA32    [mem 0x0000000001000000-0x00000000ffffffff]
[    0.000000]   Normal   [mem 0x0000000100000000-0x000000041f37ffff]
[    0.000000]   Device   empty
[    0.000000] Movable zone start for each node
[    0.000000] Early memory node ranges
[    0.000000]   node   0: [mem 0x0000000000001000-0x000000000009ffff]
[    0.000000]   node   0: [mem 0x0000000000100000-0x0000000001d7ffff]
[    0.000000]   node   0: [mem 0x0000000002000000-0x00000000dcd71fff]
[    0.000000]   node   0: [mem 0x00000000dced8000-0x00000000dd292fff]
[    0.000000]   node   0: [mem 0x00000000de3ec000-0x00000000deffffff]
[    0.000000]   node   0: [mem 0x0000000100000000-0x000000041f37ffff]
[    0.000000] Initmem setup node 0 [mem 0x0000000000001000-0x000000041f37ffff]
[    0.000000] On node 0, zone DMA: 1 pages in unavailable ranges
[    0.000000] On node 0, zone DMA: 96 pages in unavailable ranges
[    0.000000] On node 0, zone DMA32: 640 pages in unavailable ranges
[    0.000000] On node 0, zone DMA32: 358 pages in unavailable ranges
[    0.000000] On node 0, zone DMA32: 4441 pages in unavailable ranges
[    0.000000] On node 0, zone Normal: 4096 pages in unavailable ranges
[    0.000000] On node 0, zone Normal: 3200 pages in unavailable ranges
[    0.000000] ACPI: PM-Timer IO Port: 0x808
[    0.000000] ACPI: LAPIC_NMI (acpi_id[0xff] high edge lint[0x1])
[    0.000000] IOAPIC[0]: apic_id 13, version 33, address 0xfec00000, GSI 0-23
[    0.000000] IOAPIC[1]: apic_id 14, version 33, address 0xfec01000, GSI 24-55
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.000000] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
[    0.000000] ACPI: Using ACPI (MADT) for SMP configuration information
[    0.000000] ACPI: HPET id: 0x10228201 base: 0xfed00000
[    0.000000] e820: update [mem 0xd5fa2000-0xd5ff6fff] usable ==> reserved
[    0.000000] smpboot: Allowing 16 CPUs, 4 hotplug CPUs
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0x000a0000-0x000fffff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0x01d80000-0x01ffffff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0xd5fa2000-0xd5ff6fff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0xd8fe3000-0xd8fe3fff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0xdcd72000-0xdced7fff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0xdd293000-0xdd39cfff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0xdd39d000-0xde387fff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0xde388000-0xde3ebfff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0xdf000000-0xdfffffff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0xe0000000-0xf7ffffff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0xf8000000-0xfbffffff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0xfc000000-0xfdefffff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0xfdf00000-0xfdffffff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0xfe000000-0xfe9fffff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0xfea00000-0xfea0ffff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0xfea10000-0xfeb7ffff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0xfeb80000-0xfec01fff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0xfec02000-0xfec0ffff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0xfec10000-0xfec10fff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0xfec11000-0xfec2ffff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0xfec30000-0xfec30fff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0xfec31000-0xfecfffff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0xfed00000-0xfed00fff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0xfed01000-0xfed3ffff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0xfed40000-0xfed44fff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0xfed45000-0xfed7ffff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0xfed80000-0xfed8ffff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0xfed90000-0xfedc1fff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0xfedc2000-0xfedcffff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0xfedd0000-0xfedd3fff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0xfedd4000-0xfedd5fff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0xfedd6000-0xfedfffff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0xfee00000-0xfeefffff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0xfef00000-0xfeffffff]
[    0.000000] PM: hibernation: Registered nosave memory: [mem 0xff000000-0xffffffff]
[    0.000000] [mem 0xe0000000-0xf7ffffff] available for PCI devices
[    0.000000] Booting paravirtualized kernel on bare hardware
[    0.000000] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[    0.000000] setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:16 nr_node_ids:1
[    0.000000] percpu: Embedded 61 pages/cpu s212992 r8192 d28672 u262144
[    0.000000] pcpu-alloc: s212992 r8192 d28672 u262144 alloc=1*2097152
[    0.000000] pcpu-alloc: [0] 00 01 02 03 04 05 06 07 [0] 08 09 10 11 12 13 14 15
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 4115975
[    0.000000] Policy zone: Normal
[    0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC misobasedir=manjaro misolabel=MANJARO_XFCE_2121 3 systemd.show_status=1 apparmor=1 security=apparmor driver=nonfree nouveau.modeset=0 i915.modeset=0 radeon.modeset=0
[    0.000000] Unknown kernel command line parameters "3 BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC misobasedir=manjaro misolabel=MANJARO_XFCE_2121 driver=nonfree", will be passed to user space.
[    0.000000] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[    0.000000] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[    0.000000] mem auto-init: stack:byref_all(zero), heap alloc:on, heap free:off
[    0.000000] Memory: 15998184K/16725888K available (14344K kernel code, 2097K rwdata, 10884K rodata, 1864K init, 3784K bss, 727444K reserved, 0K cma-reserved)
[    0.000000] random: get_random_u64 called from __kmem_cache_create+0x2a/0x540 with crng_init=0
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=16, Nodes=1
[    0.000000] ftrace: allocating 44515 entries in 174 pages
[    0.000000] ftrace: allocated 174 pages with 5 groups
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu: 	RCU dyntick-idle grace-period acceleration is enabled.
[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=16.
[    0.000000] rcu: 	RCU priority boosting: priority 1 delay 500 ms.
[    0.000000] 	Trampoline variant of Tasks RCU enabled.
[    0.000000] 	Rude variant of Tasks RCU enabled.
[    0.000000] 	Tracing variant of Tasks RCU enabled.
[    0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=16
[    0.000000] NR_IRQS: 20736, nr_irqs: 1096, preallocated irqs: 16
[    0.000000] kfence: initialized - using 2097152 bytes for 255 objects at 0x(____ptrval____)-0x(____ptrval____)
[    0.000000] Console: colour dummy device 80x25
[    0.000000] printk: console [tty0] enabled
[    0.000000] ACPI: Core revision 20210730
[    0.000000] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 133484873504 ns
[    0.000000] APIC: Switch to symmetric I/O mode setup
[    0.003333] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.023333] tsc: PIT calibration matches HPET. 1 loops
[    0.023333] tsc: Detected 3792.695 MHz processor
[    0.000002] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x6d56c8fc7d8, max_idle_ns: 881591049806 ns
[    0.000005] Calibrating delay loop (skipped), value calculated using timer frequency.. 7588.44 BogoMIPS (lpj=12642316)
[    0.000007] pid_max: default: 32768 minimum: 301
[    0.005478] LSM: Security Framework initializing
[    0.005485] landlock: Up and running.
[    0.005486] Yama: becoming mindful.
[    0.005506] AppArmor: AppArmor initialized
[    0.005542] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.005572] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.005821] LVT offset 1 assigned for vector 0xf9
[    0.005898] LVT offset 2 assigned for vector 0xf4
[    0.005914] Last level iTLB entries: 4KB 1024, 2MB 1024, 4MB 512
[    0.005915] Last level dTLB entries: 4KB 1536, 2MB 1536, 4MB 768, 1GB 0
[    0.005918] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[    0.005920] Spectre V2 : Mitigation: Full AMD retpoline
[    0.005921] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[    0.005922] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[    0.008225] Freeing SMP alternatives memory: 36K
[    0.116127] smpboot: CPU0: AMD Ryzen 5 1600X Six-Core Processor (family: 0x17, model: 0x1, stepping: 0x1)
[    0.116250] Performance Events: Fam17h+ core perfctr, AMD PMU driver.
[    0.116254] ... version:                0
[    0.116255] ... bit width:              48
[    0.116255] ... generic registers:      6
[    0.116256] ... value mask:             0000ffffffffffff
[    0.116256] ... max period:             00007fffffffffff
[    0.116257] ... fixed-purpose events:   0
[    0.116258] ... event mask:             000000000000003f
[    0.116309] rcu: Hierarchical SRCU implementation.
[    0.116660] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[    0.116671] smp: Bringing up secondary CPUs ...
[    0.116671] x86: Booting SMP configuration:
[    0.116671] .... node  #0, CPUs:        #1  #2  #3  #4  #5  #6  #7  #8  #9 #10 #11
[    0.138889] smp: Brought up 1 node, 12 CPUs
[    0.138889] smpboot: Max logical packages: 2
[    0.138889] smpboot: Total of 12 processors activated (91061.37 BogoMIPS)
[    0.140560] devtmpfs: initialized
[    0.140560] x86/mm: Memory block size: 128MB
[    0.140724] ACPI: PM: Registering ACPI NVS region [mem 0xdd293000-0xdd39cfff] (1089536 bytes)
[    0.140724] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[    0.140724] futex hash table entries: 4096 (order: 6, 262144 bytes, linear)
[    0.140724] pinctrl core: initialized pinctrl subsystem
[    0.140724] PM: RTC time: 11:59:54, date: 2022-01-12
[    0.140724] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[    0.140724] DMA: preallocated 2048 KiB GFP_KERNEL pool for atomic allocations
[    0.140724] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[    0.140810] DMA: preallocated 2048 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[    0.140815] audit: initializing netlink subsys (disabled)
[    0.140823] audit: type=2000 audit(1641988794.163:1): state=initialized audit_enabled=0 res=1
[    0.140823] thermal_sys: Registered thermal governor 'fair_share'
[    0.140823] thermal_sys: Registered thermal governor 'bang_bang'
[    0.140823] thermal_sys: Registered thermal governor 'step_wise'
[    0.140823] thermal_sys: Registered thermal governor 'user_space'
[    0.140823] thermal_sys: Registered thermal governor 'power_allocator'
[    0.140823] cpuidle: using governor ladder
[    0.140823] cpuidle: using governor menu
[    0.140823] HugeTLB: can free 4094 vmemmap pages for hugepages-1048576kB
[    0.140823] ACPI: bus type PCI registered
[    0.140823] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.140823] PCI: MMCONFIG for domain 0000 [bus 00-3f] at [mem 0xf8000000-0xfbffffff] (base 0xf8000000)
[    0.140823] PCI: MMCONFIG at [mem 0xf8000000-0xfbffffff] reserved in E820
[    0.140823] pmd_set_huge: Cannot satisfy [mem 0xf8000000-0xf8200000] with a huge-page mapping due to MTRR override.
[    0.140823] PCI: Using configuration type 1 for base access
[    0.143994] Kprobes globally optimized
[    0.143997] HugeTLB: can free 6 vmemmap pages for hugepages-2048kB
[    0.143997] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.143997] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.143997] ACPI: Added _OSI(Module Device)
[    0.143997] ACPI: Added _OSI(Processor Device)
[    0.143997] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.143997] ACPI: Added _OSI(Processor Aggregator Device)
[    0.143997] ACPI: Added _OSI(Linux-Dell-Video)
[    0.143997] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[    0.143997] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[    0.147526] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[    0.156214] ACPI: 7 ACPI AML tables successfully acquired and loaded
[    0.160363] ACPI: Interpreter enabled
[    0.160378] ACPI: PM: (supports S0 S3 S4 S5)
[    0.160380] ACPI: Using IOAPIC for interrupt routing
[    0.160496] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.160733] ACPI: Enabled 2 GPEs in block 00 to 1F
[    0.167211] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
[    0.167217] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[    0.167378] acpi PNP0A08:00: _OSC: platform does not support [SHPCHotplug LTR DPC]
[    0.167532] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
[    0.167540] acpi PNP0A08:00: [Firmware Info]: MMCONFIG for domain 0000 [bus 00-3f] only partially covers this bridge
[    0.167881] PCI host bridge to bus 0000:00
[    0.167882] pci_bus 0000:00: root bus resource [io  0x0000-0x03af window]
[    0.167884] pci_bus 0000:00: root bus resource [io  0x03e0-0x0cf7 window]
[    0.167885] pci_bus 0000:00: root bus resource [io  0x03b0-0x03df window]
[    0.167887] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    0.167888] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[    0.167889] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000dffff window]
[    0.167890] pci_bus 0000:00: root bus resource [mem 0xe0000000-0xfec2ffff window]
[    0.167891] pci_bus 0000:00: root bus resource [mem 0xfee00000-0xffffffff window]
[    0.167892] pci_bus 0000:00: root bus resource [bus 00-ff]
[    0.167955] pci 0000:00:00.0: [1022:1450] type 00 class 0x060000
[    0.168076] pci 0000:00:00.2: [1022:1451] type 00 class 0x080600
[    0.168175] pci 0000:00:01.0: [1022:1452] type 00 class 0x060000
[    0.168299] pci 0000:00:01.1: [1022:1453] type 01 class 0x060400
[    0.168344] pci 0000:00:01.1: PME# supported from D0 D3hot D3cold
[    0.168462] pci 0000:00:01.3: [1022:1453] type 01 class 0x060400
[    0.168505] pci 0000:00:01.3: PME# supported from D0 D3hot D3cold
[    0.168597] pci 0000:00:02.0: [1022:1452] type 00 class 0x060000
[    0.168695] pci 0000:00:03.0: [1022:1452] type 00 class 0x060000
[    0.168817] pci 0000:00:03.1: [1022:1453] type 01 class 0x060400
[    0.168860] pci 0000:00:03.1: PME# supported from D0 D3hot D3cold
[    0.168950] pci 0000:00:04.0: [1022:1452] type 00 class 0x060000
[    0.169049] pci 0000:00:07.0: [1022:1452] type 00 class 0x060000
[    0.169168] pci 0000:00:07.1: [1022:1454] type 01 class 0x060400
[    0.169186] pci 0000:00:07.1: enabling Extended Tags
[    0.169209] pci 0000:00:07.1: PME# supported from D0 D3hot D3cold
[    0.169297] pci 0000:00:08.0: [1022:1452] type 00 class 0x060000
[    0.169417] pci 0000:00:08.1: [1022:1454] type 01 class 0x060400
[    0.169437] pci 0000:00:08.1: enabling Extended Tags
[    0.169461] pci 0000:00:08.1: PME# supported from D0 D3hot D3cold
[    0.169586] pci 0000:00:14.0: [1022:790b] type 00 class 0x0c0500
[    0.169740] pci 0000:00:14.3: [1022:790e] type 00 class 0x060100
[    0.169874] pci 0000:00:18.0: [1022:1460] type 00 class 0x060000
[    0.169955] pci 0000:00:18.1: [1022:1461] type 00 class 0x060000
[    0.170038] pci 0000:00:18.2: [1022:1462] type 00 class 0x060000
[    0.170118] pci 0000:00:18.3: [1022:1463] type 00 class 0x060000
[    0.170201] pci 0000:00:18.4: [1022:1464] type 00 class 0x060000
[    0.170280] pci 0000:00:18.5: [1022:1465] type 00 class 0x060000
[    0.170360] pci 0000:00:18.6: [1022:1466] type 00 class 0x060000
[    0.170440] pci 0000:00:18.7: [1022:1467] type 00 class 0x060000
[    0.170574] pci 0000:01:00.0: [15b7:5009] type 00 class 0x010802
[    0.170589] pci 0000:01:00.0: reg 0x10: [mem 0xfd900000-0xfd903fff 64bit]
[    0.170610] pci 0000:01:00.0: reg 0x20: [mem 0xfd904000-0xfd9040ff 64bit]
[    0.170740] pci 0000:00:01.1: PCI bridge to [bus 01]
[    0.170744] pci 0000:00:01.1:   bridge window [mem 0xfd900000-0xfd9fffff]
[    0.170795] pci 0000:03:00.0: [1022:43b9] type 00 class 0x0c0330
[    0.170810] pci 0000:03:00.0: reg 0x10: [mem 0xfd7a0000-0xfd7a7fff 64bit]
[    0.170887] pci 0000:03:00.0: PME# supported from D3hot D3cold
[    0.170980] pci 0000:03:00.1: [1022:43b5] type 00 class 0x010601
[    0.171020] pci 0000:03:00.1: reg 0x24: [mem 0xfd780000-0xfd79ffff]
[    0.171027] pci 0000:03:00.1: reg 0x30: [mem 0xfd700000-0xfd77ffff pref]
[    0.171065] pci 0000:03:00.1: PME# supported from D3hot D3cold
[    0.171121] pci 0000:03:00.2: [1022:43b0] type 01 class 0x060400
[    0.171195] pci 0000:03:00.2: PME# supported from D3hot D3cold
[    0.171283] pci 0000:00:01.3: PCI bridge to [bus 03-23]
[    0.171286] pci 0000:00:01.3:   bridge window [io  0xf000-0xffff]
[    0.171288] pci 0000:00:01.3:   bridge window [mem 0xfd500000-0xfd7fffff]
[    0.171342] pci 0000:04:00.0: [1022:43b4] type 01 class 0x060400
[    0.171431] pci 0000:04:00.0: PME# supported from D3hot D3cold
[    0.171518] pci 0000:04:01.0: [1022:43b4] type 01 class 0x060400
[    0.171607] pci 0000:04:01.0: PME# supported from D3hot D3cold
[    0.171678] pci 0000:04:02.0: [1022:43b4] type 01 class 0x060400
[    0.171766] pci 0000:04:02.0: PME# supported from D3hot D3cold
[    0.171836] pci 0000:04:03.0: [1022:43b4] type 01 class 0x060400
[    0.171924] pci 0000:04:03.0: PME# supported from D3hot D3cold
[    0.171993] pci 0000:04:04.0: [1022:43b4] type 01 class 0x060400
[    0.172081] pci 0000:04:04.0: PME# supported from D3hot D3cold
[    0.172154] pci 0000:04:08.0: [1022:43b4] type 01 class 0x060400
[    0.172242] pci 0000:04:08.0: PME# supported from D3hot D3cold
[    0.172317] pci 0000:03:00.2: PCI bridge to [bus 04-23]
[    0.172321] pci 0000:03:00.2:   bridge window [io  0xf000-0xffff]
[    0.172324] pci 0000:03:00.2:   bridge window [mem 0xfd500000-0xfd6fffff]
[    0.172410] pci 0000:1e:00.0: [8086:1539] type 00 class 0x020000
[    0.172444] pci 0000:1e:00.0: reg 0x10: [mem 0xfd600000-0xfd61ffff]
[    0.172480] pci 0000:1e:00.0: reg 0x18: [io  0xf000-0xf01f]
[    0.172501] pci 0000:1e:00.0: reg 0x1c: [mem 0xfd620000-0xfd623fff]
[    0.172686] pci 0000:1e:00.0: PME# supported from D0 D3hot D3cold
[    0.172860] pci 0000:04:00.0: PCI bridge to [bus 1e]
[    0.172865] pci 0000:04:00.0:   bridge window [io  0xf000-0xffff]
[    0.172867] pci 0000:04:00.0:   bridge window [mem 0xfd600000-0xfd6fffff]
[    0.172899] pci 0000:04:01.0: PCI bridge to [bus 1f]
[    0.172935] pci 0000:04:02.0: PCI bridge to [bus 20]
[    0.172970] pci 0000:04:03.0: PCI bridge to [bus 21]
[    0.173007] pci 0000:04:04.0: PCI bridge to [bus 22]
[    0.173085] pci 0000:23:00.0: [1b21:2142] type 00 class 0x0c0330
[    0.173112] pci 0000:23:00.0: reg 0x10: [mem 0xfd500000-0xfd507fff 64bit]
[    0.173320] pci 0000:23:00.0: PME# supported from D0 D3hot D3cold
[    0.173455] pci 0000:04:08.0: PCI bridge to [bus 23]
[    0.173462] pci 0000:04:08.0:   bridge window [mem 0xfd500000-0xfd5fffff]
[    0.173534] pci 0000:24:00.0: [10de:2484] type 00 class 0x030000
[    0.173544] pci 0000:24:00.0: reg 0x10: [mem 0xfc000000-0xfcffffff]
[    0.173551] pci 0000:24:00.0: reg 0x14: [mem 0xe0000000-0xefffffff 64bit pref]
[    0.173559] pci 0000:24:00.0: reg 0x1c: [mem 0xf0000000-0xf1ffffff 64bit pref]
[    0.173564] pci 0000:24:00.0: reg 0x24: [io  0xe000-0xe07f]
[    0.173570] pci 0000:24:00.0: reg 0x30: [mem 0xfd000000-0xfd07ffff pref]
[    0.173583] pci 0000:24:00.0: BAR 1: assigned to efifb
[    0.173619] pci 0000:24:00.0: PME# supported from D0 D3hot
[    0.173682] pci 0000:24:00.0: 126.016 Gb/s available PCIe bandwidth, limited by 8.0 GT/s PCIe x16 link at 0000:00:03.1 (capable of 252.048 Gb/s with 16.0 GT/s PCIe x16 link)
[    0.173718] pci 0000:24:00.1: [10de:228b] type 00 class 0x040300
[    0.173726] pci 0000:24:00.1: reg 0x10: [mem 0xfd080000-0xfd083fff]
[    0.173825] pci 0000:00:03.1: PCI bridge to [bus 24]
[    0.173828] pci 0000:00:03.1:   bridge window [io  0xe000-0xefff]
[    0.173830] pci 0000:00:03.1:   bridge window [mem 0xfc000000-0xfd0fffff]
[    0.173832] pci 0000:00:03.1:   bridge window [mem 0xe0000000-0xf1ffffff 64bit pref]
[    0.173871] pci 0000:25:00.0: [1022:145a] type 00 class 0x130000
[    0.173892] pci 0000:25:00.0: enabling Extended Tags
[    0.173954] pci 0000:25:00.2: [1022:1456] type 00 class 0x108000
[    0.173964] pci 0000:25:00.2: reg 0x18: [mem 0xfd300000-0xfd3fffff]
[    0.173972] pci 0000:25:00.2: reg 0x24: [mem 0xfd400000-0xfd401fff]
[    0.173977] pci 0000:25:00.2: enabling Extended Tags
[    0.174051] pci 0000:25:00.3: [1022:145c] type 00 class 0x0c0330
[    0.174059] pci 0000:25:00.3: reg 0x10: [mem 0xfd200000-0xfd2fffff 64bit]
[    0.174078] pci 0000:25:00.3: enabling Extended Tags
[    0.174101] pci 0000:25:00.3: PME# supported from D0 D3hot D3cold
[    0.174153] pci 0000:00:07.1: PCI bridge to [bus 25]
[    0.174156] pci 0000:00:07.1:   bridge window [mem 0xfd200000-0xfd4fffff]
[    0.174204] pci 0000:26:00.0: [1022:1455] type 00 class 0x130000
[    0.174227] pci 0000:26:00.0: enabling Extended Tags
[    0.174296] pci 0000:26:00.2: [1022:7901] type 00 class 0x010601
[    0.174319] pci 0000:26:00.2: reg 0x24: [mem 0xfd808000-0xfd808fff]
[    0.174326] pci 0000:26:00.2: enabling Extended Tags
[    0.174351] pci 0000:26:00.2: PME# supported from D3hot D3cold
[    0.174407] pci 0000:26:00.3: [1022:1457] type 00 class 0x040300
[    0.174414] pci 0000:26:00.3: reg 0x10: [mem 0xfd800000-0xfd807fff]
[    0.174431] pci 0000:26:00.3: enabling Extended Tags
[    0.174455] pci 0000:26:00.3: PME# supported from D0 D3hot D3cold
[    0.174511] pci 0000:00:08.1: PCI bridge to [bus 26]
[    0.174515] pci 0000:00:08.1:   bridge window [mem 0xfd800000-0xfd8fffff]
[    0.174768] ACPI: PCI: Interrupt link LNKA configured for IRQ 0
[    0.174818] ACPI: PCI: Interrupt link LNKB configured for IRQ 0
[    0.174862] ACPI: PCI: Interrupt link LNKC configured for IRQ 0
[    0.174915] ACPI: PCI: Interrupt link LNKD configured for IRQ 0
[    0.174963] ACPI: PCI: Interrupt link LNKE configured for IRQ 0
[    0.175002] ACPI: PCI: Interrupt link LNKF configured for IRQ 0
[    0.175042] ACPI: PCI: Interrupt link LNKG configured for IRQ 0
[    0.175081] ACPI: PCI: Interrupt link LNKH configured for IRQ 0
[    0.175601] iommu: Default domain type: Translated
[    0.175602] iommu: DMA domain TLB invalidation policy: lazy mode
[    0.175612] pci 0000:24:00.0: vgaarb: VGA device added: decodes=io+mem,owns=none,locks=none
[    0.175612] pci 0000:24:00.0: vgaarb: bridge control possible
[    0.175612] pci 0000:24:00.0: vgaarb: setting as boot device
[    0.175612] vgaarb: loaded
[    0.175612] SCSI subsystem initialized
[    0.175612] libata version 3.00 loaded.
[    0.175612] ACPI: bus type USB registered
[    0.175612] usbcore: registered new interface driver usbfs
[    0.175612] usbcore: registered new interface driver hub
[    0.175612] usbcore: registered new device driver usb
[    0.175612] pps_core: LinuxPPS API ver. 1 registered
[    0.175612] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.175612] PTP clock support registered
[    0.175612] EDAC MC: Ver: 3.0.0
[    0.175612] Registered efivars operations
[    0.175612] NetLabel: Initializing
[    0.175612] NetLabel:  domain hash size = 128
[    0.175612] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.175612] NetLabel:  unlabeled traffic allowed by default
[    0.175612] PCI: Using ACPI for IRQ routing
[    0.177623] PCI: pci_cache_line_size set to 64 bytes
[    0.177682] e820: reserve RAM buffer [mem 0x01d80000-0x03ffffff]
[    0.177684] e820: reserve RAM buffer [mem 0xd5fa2000-0xd7ffffff]
[    0.177685] e820: reserve RAM buffer [mem 0xd8fe3000-0xdbffffff]
[    0.177685] e820: reserve RAM buffer [mem 0xdcd72000-0xdfffffff]
[    0.177686] e820: reserve RAM buffer [mem 0xdd293000-0xdfffffff]
[    0.177687] e820: reserve RAM buffer [mem 0xdf000000-0xdfffffff]
[    0.177688] e820: reserve RAM buffer [mem 0x41f380000-0x41fffffff]
[    0.177692] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0
[    0.177692] hpet0: 3 comparators, 32-bit 14.318180 MHz counter
[    0.178811] clocksource: Switched to clocksource tsc-early
[    0.182865] VFS: Disk quotas dquot_6.6.0
[    0.182881] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.182972] AppArmor: AppArmor Filesystem Enabled
[    0.183005] pnp: PnP ACPI init
[    0.183136] system 00:00: [mem 0xf8000000-0xfbffffff] has been reserved
[    0.183206] system 00:01: [mem 0xfeb80000-0xfebfffff] could not be reserved
[    0.183476] system 00:03: [io  0x0a00-0x0a0f] has been reserved
[    0.183478] system 00:03: [io  0x0a10-0x0a1f] has been reserved
[    0.183479] system 00:03: [io  0x0a20-0x0a2f] has been reserved
[    0.183481] system 00:03: [io  0x0a40-0x0a4f] has been reserved
[    0.183711] system 00:04: [io  0x04d0-0x04d1] has been reserved
[    0.183713] system 00:04: [io  0x040b] has been reserved
[    0.183714] system 00:04: [io  0x04d6] has been reserved
[    0.183715] system 00:04: [io  0x0c00-0x0c01] has been reserved
[    0.183716] system 00:04: [io  0x0c14] has been reserved
[    0.183717] system 00:04: [io  0x0c50-0x0c51] has been reserved
[    0.183718] system 00:04: [io  0x0c52] has been reserved
[    0.183719] system 00:04: [io  0x0c6c] has been reserved
[    0.183720] system 00:04: [io  0x0c6f] has been reserved
[    0.183721] system 00:04: [io  0x0cd0-0x0cd1] has been reserved
[    0.183722] system 00:04: [io  0x0cd2-0x0cd3] has been reserved
[    0.183723] system 00:04: [io  0x0cd4-0x0cd5] has been reserved
[    0.183724] system 00:04: [io  0x0cd6-0x0cd7] has been reserved
[    0.183725] system 00:04: [io  0x0cd8-0x0cdf] has been reserved
[    0.183725] system 00:04: [io  0x0800-0x089f] has been reserved
[    0.183726] system 00:04: [io  0x0b00-0x0b0f] has been reserved
[    0.183727] system 00:04: [io  0x0b20-0x0b3f] has been reserved
[    0.183728] system 00:04: [io  0x0900-0x090f] has been reserved
[    0.183729] system 00:04: [io  0x0910-0x091f] has been reserved
[    0.183731] system 00:04: [mem 0xfec00000-0xfec00fff] could not be reserved
[    0.183733] system 00:04: [mem 0xfec01000-0xfec01fff] could not be reserved
[    0.183735] system 00:04: [mem 0xfedc0000-0xfedc0fff] has been reserved
[    0.183737] system 00:04: [mem 0xfee00000-0xfee00fff] has been reserved
[    0.183738] system 00:04: [mem 0xfed80000-0xfed8ffff] could not be reserved
[    0.183740] system 00:04: [mem 0xfec10000-0xfec10fff] has been reserved
[    0.183742] system 00:04: [mem 0xff000000-0xffffffff] has been reserved
[    0.184095] pnp: PnP ACPI: found 5 devices
[    0.189734] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    0.189781] NET: Registered PF_INET protocol family
[    0.189996] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.191535] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
[    0.191646] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.191790] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[    0.191861] TCP: Hash tables configured (established 131072 bind 65536)
[    0.191934] MPTCP token hash table entries: 16384 (order: 6, 393216 bytes, linear)
[    0.191981] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
[    0.192020] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
[    0.192078] NET: Registered PF_UNIX/PF_LOCAL protocol family
[    0.192082] NET: Registered PF_XDP protocol family
[    0.192091] pci 0000:04:02.0: bridge window [io  0x1000-0x0fff] to [bus 20] add_size 1000
[    0.192093] pci 0000:04:02.0: bridge window [mem 0x00100000-0x000fffff 64bit pref] to [bus 20] add_size 200000 add_align 100000
[    0.192095] pci 0000:04:02.0: bridge window [mem 0x00100000-0x000fffff] to [bus 20] add_size 200000 add_align 100000
[    0.192099] pci 0000:03:00.2: bridge window [mem 0x00100000-0x001fffff 64bit pref] to [bus 04-23] add_size 200000 add_align 100000
[    0.192101] pci 0000:00:01.3: bridge window [mem 0x00100000-0x001fffff 64bit pref] to [bus 03-23] add_size 200000 add_align 100000
[    0.192111] pci 0000:00:01.3: BAR 15: assigned [mem 0xf2000000-0xf22fffff 64bit pref]
[    0.192114] pci 0000:00:01.1: PCI bridge to [bus 01]
[    0.192117] pci 0000:00:01.1:   bridge window [mem 0xfd900000-0xfd9fffff]
[    0.192122] pci 0000:03:00.2: BAR 15: assigned [mem 0xf2000000-0xf22fffff 64bit pref]
[    0.192125] pci 0000:04:02.0: BAR 14: no space for [mem size 0x00200000]
[    0.192126] pci 0000:04:02.0: BAR 14: failed to assign [mem size 0x00200000]
[    0.192128] pci 0000:04:02.0: BAR 15: assigned [mem 0xf2000000-0xf21fffff 64bit pref]
[    0.192129] pci 0000:04:02.0: BAR 13: no space for [io  size 0x1000]
[    0.192130] pci 0000:04:02.0: BAR 13: failed to assign [io  size 0x1000]
[    0.192132] pci 0000:04:02.0: BAR 14: no space for [mem size 0x00200000]
[    0.192133] pci 0000:04:02.0: BAR 14: failed to assign [mem size 0x00200000]
[    0.192134] pci 0000:04:02.0: BAR 13: no space for [io  size 0x1000]
[    0.192135] pci 0000:04:02.0: BAR 13: failed to assign [io  size 0x1000]
[    0.192136] pci 0000:04:00.0: PCI bridge to [bus 1e]
[    0.192138] pci 0000:04:00.0:   bridge window [io  0xf000-0xffff]
[    0.192142] pci 0000:04:00.0:   bridge window [mem 0xfd600000-0xfd6fffff]
[    0.192148] pci 0000:04:01.0: PCI bridge to [bus 1f]
[    0.192157] pci 0000:04:02.0: PCI bridge to [bus 20]
[    0.192162] pci 0000:04:02.0:   bridge window [mem 0xf2000000-0xf21fffff 64bit pref]
[    0.192167] pci 0000:04:03.0: PCI bridge to [bus 21]
[    0.192175] pci 0000:04:04.0: PCI bridge to [bus 22]
[    0.192184] pci 0000:04:08.0: PCI bridge to [bus 23]
[    0.192187] pci 0000:04:08.0:   bridge window [mem 0xfd500000-0xfd5fffff]
[    0.192193] pci 0000:03:00.2: PCI bridge to [bus 04-23]
[    0.192195] pci 0000:03:00.2:   bridge window [io  0xf000-0xffff]
[    0.192198] pci 0000:03:00.2:   bridge window [mem 0xfd500000-0xfd6fffff]
[    0.192201] pci 0000:03:00.2:   bridge window [mem 0xf2000000-0xf22fffff 64bit pref]
[    0.192205] pci 0000:00:01.3: PCI bridge to [bus 03-23]
[    0.192206] pci 0000:00:01.3:   bridge window [io  0xf000-0xffff]
[    0.192208] pci 0000:00:01.3:   bridge window [mem 0xfd500000-0xfd7fffff]
[    0.192210] pci 0000:00:01.3:   bridge window [mem 0xf2000000-0xf22fffff 64bit pref]
[    0.192213] pci 0000:00:03.1: PCI bridge to [bus 24]
[    0.192215] pci 0000:00:03.1:   bridge window [io  0xe000-0xefff]
[    0.192217] pci 0000:00:03.1:   bridge window [mem 0xfc000000-0xfd0fffff]
[    0.192218] pci 0000:00:03.1:   bridge window [mem 0xe0000000-0xf1ffffff 64bit pref]
[    0.192221] pci 0000:00:07.1: PCI bridge to [bus 25]
[    0.192223] pci 0000:00:07.1:   bridge window [mem 0xfd200000-0xfd4fffff]
[    0.192227] pci 0000:00:08.1: PCI bridge to [bus 26]
[    0.192229] pci 0000:00:08.1:   bridge window [mem 0xfd800000-0xfd8fffff]
[    0.192234] pci_bus 0000:00: resource 4 [io  0x0000-0x03af window]
[    0.192235] pci_bus 0000:00: resource 5 [io  0x03e0-0x0cf7 window]
[    0.192236] pci_bus 0000:00: resource 6 [io  0x03b0-0x03df window]
[    0.192237] pci_bus 0000:00: resource 7 [io  0x0d00-0xffff window]
[    0.192238] pci_bus 0000:00: resource 8 [mem 0x000a0000-0x000bffff window]
[    0.192239] pci_bus 0000:00: resource 9 [mem 0x000c0000-0x000dffff window]
[    0.192240] pci_bus 0000:00: resource 10 [mem 0xe0000000-0xfec2ffff window]
[    0.192241] pci_bus 0000:00: resource 11 [mem 0xfee00000-0xffffffff window]
[    0.192243] pci_bus 0000:01: resource 1 [mem 0xfd900000-0xfd9fffff]
[    0.192244] pci_bus 0000:03: resource 0 [io  0xf000-0xffff]
[    0.192245] pci_bus 0000:03: resource 1 [mem 0xfd500000-0xfd7fffff]
[    0.192246] pci_bus 0000:03: resource 2 [mem 0xf2000000-0xf22fffff 64bit pref]
[    0.192247] pci_bus 0000:04: resource 0 [io  0xf000-0xffff]
[    0.192248] pci_bus 0000:04: resource 1 [mem 0xfd500000-0xfd6fffff]
[    0.192248] pci_bus 0000:04: resource 2 [mem 0xf2000000-0xf22fffff 64bit pref]
[    0.192250] pci_bus 0000:1e: resource 0 [io  0xf000-0xffff]
[    0.192251] pci_bus 0000:1e: resource 1 [mem 0xfd600000-0xfd6fffff]
[    0.192252] pci_bus 0000:20: resource 2 [mem 0xf2000000-0xf21fffff 64bit pref]
[    0.192253] pci_bus 0000:23: resource 1 [mem 0xfd500000-0xfd5fffff]
[    0.192254] pci_bus 0000:24: resource 0 [io  0xe000-0xefff]
[    0.192255] pci_bus 0000:24: resource 1 [mem 0xfc000000-0xfd0fffff]
[    0.192256] pci_bus 0000:24: resource 2 [mem 0xe0000000-0xf1ffffff 64bit pref]
[    0.192257] pci_bus 0000:25: resource 1 [mem 0xfd200000-0xfd4fffff]
[    0.192258] pci_bus 0000:26: resource 1 [mem 0xfd800000-0xfd8fffff]
[    0.192479] pci 0000:23:00.0: PME# does not work under D0, disabling it
[    0.192613] pci 0000:24:00.1: D0 power state depends on 0000:24:00.0
[    0.192741] PCI: CLS 64 bytes, default 64
[    0.192749] AMD-Vi: [Firmware Warn]: EFR mismatch. Use IVHD EFR (0xf77ef22294ada : 0x400f77ef22294ada).
[    0.192754] pci 0000:00:00.2: AMD-Vi: IOMMU performance counters supported
[    0.192789] pci 0000:00:00.2: can't derive routing for PCI INT A
[    0.192791] pci 0000:00:00.2: PCI INT A: not connected
[    0.192795] Trying to unpack rootfs image as initramfs...
[    0.192813] pci 0000:00:01.0: Adding to iommu group 0
[    0.192821] pci 0000:00:01.1: Adding to iommu group 0
[    0.192828] pci 0000:00:01.3: Adding to iommu group 0
[    0.192841] pci 0000:00:02.0: Adding to iommu group 1
[    0.192855] pci 0000:00:03.0: Adding to iommu group 2
[    0.192862] pci 0000:00:03.1: Adding to iommu group 2
[    0.192874] pci 0000:00:04.0: Adding to iommu group 3
[    0.192888] pci 0000:00:07.0: Adding to iommu group 4
[    0.192896] pci 0000:00:07.1: Adding to iommu group 4
[    0.192910] pci 0000:00:08.0: Adding to iommu group 5
[    0.192917] pci 0000:00:08.1: Adding to iommu group 5
[    0.192931] pci 0000:00:14.0: Adding to iommu group 6
[    0.192938] pci 0000:00:14.3: Adding to iommu group 6
[    0.192973] pci 0000:00:18.0: Adding to iommu group 7
[    0.192981] pci 0000:00:18.1: Adding to iommu group 7
[    0.192988] pci 0000:00:18.2: Adding to iommu group 7
[    0.192996] pci 0000:00:18.3: Adding to iommu group 7
[    0.193004] pci 0000:00:18.4: Adding to iommu group 7
[    0.193013] pci 0000:00:18.5: Adding to iommu group 7
[    0.193021] pci 0000:00:18.6: Adding to iommu group 7
[    0.193029] pci 0000:00:18.7: Adding to iommu group 7
[    0.193033] pci 0000:01:00.0: Adding to iommu group 0
[    0.193036] pci 0000:03:00.0: Adding to iommu group 0
[    0.193040] pci 0000:03:00.1: Adding to iommu group 0
[    0.193043] pci 0000:03:00.2: Adding to iommu group 0
[    0.193048] pci 0000:04:00.0: Adding to iommu group 0
[    0.193051] pci 0000:04:01.0: Adding to iommu group 0
[    0.193054] pci 0000:04:02.0: Adding to iommu group 0
[    0.193058] pci 0000:04:03.0: Adding to iommu group 0
[    0.193061] pci 0000:04:04.0: Adding to iommu group 0
[    0.193064] pci 0000:04:08.0: Adding to iommu group 0
[    0.193067] pci 0000:1e:00.0: Adding to iommu group 0
[    0.193071] pci 0000:23:00.0: Adding to iommu group 0
[    0.193074] pci 0000:24:00.0: Adding to iommu group 2
[    0.193076] pci 0000:24:00.1: Adding to iommu group 2
[    0.193079] pci 0000:25:00.0: Adding to iommu group 4
[    0.193083] pci 0000:25:00.2: Adding to iommu group 4
[    0.193086] pci 0000:25:00.3: Adding to iommu group 4
[    0.193090] pci 0000:26:00.0: Adding to iommu group 5
[    0.193094] pci 0000:26:00.2: Adding to iommu group 5
[    0.193097] pci 0000:26:00.3: Adding to iommu group 5
[    0.194428] pci 0000:00:00.2: AMD-Vi: Found IOMMU cap 0x40
[    0.194432] AMD-Vi: Extended features (0x400f77ef22294ada): PPR NX GT IA GA PC GA_vAPIC
[    0.194438] AMD-Vi: Interrupt remapping enabled
[    0.194439] AMD-Vi: Virtual APIC enabled
[    0.194553] software IO TLB: tearing down default memory pool
[    0.195339] perf/amd_iommu: Detected AMD IOMMU #0 (2 banks, 4 counters/bank).
[    0.206526] Initialise system trusted keyrings
[    0.206539] Key type blacklist registered
[    0.206575] workingset: timestamp_bits=41 max_order=22 bucket_order=0
[    0.207344] zbud: loaded
[    0.215635] Key type asymmetric registered
[    0.215637] Asymmetric key parser 'x509' registered
[    0.215647] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
[    0.215681] io scheduler mq-deadline registered
[    0.215682] io scheduler kyber registered
[    0.215704] io scheduler bfq registered
[    0.215936] pcieport 0000:00:01.1: PME: Signaling with IRQ 28
[    0.216016] pcieport 0000:00:01.3: PME: Signaling with IRQ 29
[    0.216101] pcieport 0000:00:03.1: PME: Signaling with IRQ 30
[    0.216177] pcieport 0000:00:07.1: PME: Signaling with IRQ 31
[    0.216333] pcieport 0000:00:08.1: PME: Signaling with IRQ 33
[    0.216787] pcieport 0000:04:02.0: pciehp: Slot #1 AttnBtn+ PwrCtrl+ MRL- AttnInd+ PwrInd+ HotPlug+ Surprise- Interlock- NoCompl- IbPresDis- LLActRep+
[    1.200026] tsc: Refined TSC clocksource calibration: 3792.874 MHz
[    1.200037] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x6d5818a734c, max_idle_ns: 881590694765 ns
[    1.200067] clocksource: Switched to clocksource tsc
[    1.896689] pcieport 0000:04:02.0: pciehp: Timeout on hotplug command 0x03c0 (issued 1684 msec ago)
[    1.913355] pcieport 0000:04:02.0: pciehp: Timeout on hotplug command 0x03c0 (issued 1700 msec ago)
[    3.596690] pcieport 0000:04:02.0: pciehp: Timeout on hotplug command 0x07c0 (issued 1684 msec ago)
[    3.613355] pcieport 0000:04:02.0: pciehp: Timeout on hotplug command 0x07c0 (issued 1700 msec ago)
[    3.613917] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[    3.614021] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[    3.614039] ACPI: button: Power Button [PWRB]
[    3.614059] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[    3.614085] ACPI: button: Power Button [PWRF]
[    3.614113] ACPI: \_PR_.P000: Found 2 idle states
[    3.614191] ACPI: \_PR_.P001: Found 2 idle states
[    3.614248] ACPI: \_PR_.P002: Found 2 idle states
[    3.614299] ACPI: \_PR_.P003: Found 2 idle states
[    3.614353] ACPI: \_PR_.P004: Found 2 idle states
[    3.614394] ACPI: \_PR_.P005: Found 2 idle states
[    3.614444] ACPI: \_PR_.P006: Found 2 idle states
[    3.614513] ACPI: \_PR_.P007: Found 2 idle states
[    3.614569] ACPI: \_PR_.P008: Found 2 idle states
[    3.614635] ACPI: \_PR_.P009: Found 2 idle states
[    3.614691] ACPI: \_PR_.P00A: Found 2 idle states
[    3.614758] ACPI: \_PR_.P00B: Found 2 idle states
[    3.614973] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[    3.615141] serial8250: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[    3.616188] Non-volatile memory driver v1.3
[    3.616190] Linux agpgart interface v0.103
[    3.616230] AMD-Vi: AMD IOMMUv2 loaded and initialized
[    3.616911] nvme nvme0: pci function 0000:01:00.0
[    3.616944] ahci 0000:03:00.1: version 3.0
[    3.617100] ahci 0000:03:00.1: SSS flag set, parallel bus scan disabled
[    3.617157] ahci 0000:03:00.1: AHCI 0001.0301 32 slots 8 ports 6 Gbps 0xff impl SATA mode
[    3.617159] ahci 0000:03:00.1: flags: 64bit ncq sntf stag pm led clo only pmp pio slum part sxs deso sadm sds apst
[    3.617584] scsi host0: ahci
[    3.617675] scsi host1: ahci
[    3.617746] scsi host2: ahci
[    3.617811] scsi host3: ahci
[    3.617874] scsi host4: ahci
[    3.617940] scsi host5: ahci
[    3.618001] scsi host6: ahci
[    3.618064] scsi host7: ahci
[    3.618085] ata1: SATA max UDMA/133 abar m131072@0xfd780000 port 0xfd780100 irq 44
[    3.618087] ata2: SATA max UDMA/133 abar m131072@0xfd780000 port 0xfd780180 irq 44
[    3.618089] ata3: SATA max UDMA/133 abar m131072@0xfd780000 port 0xfd780200 irq 44
[    3.618090] ata4: SATA max UDMA/133 abar m131072@0xfd780000 port 0xfd780280 irq 44
[    3.618092] ata5: SATA max UDMA/133 abar m131072@0xfd780000 port 0xfd780300 irq 44
[    3.618094] ata6: SATA max UDMA/133 abar m131072@0xfd780000 port 0xfd780380 irq 44
[    3.618095] ata7: SATA max UDMA/133 abar m131072@0xfd780000 port 0xfd780400 irq 44
[    3.618097] ata8: SATA max UDMA/133 abar m131072@0xfd780000 port 0xfd780480 irq 44
[    3.618204] ahci 0000:26:00.2: AHCI 0001.0301 32 slots 1 ports 6 Gbps 0x1 impl SATA mode
[    3.618207] ahci 0000:26:00.2: flags: 64bit ncq sntf ilck led clo only pmp fbs pio
[    3.618320] scsi host8: ahci
[    3.618344] ata9: SATA max UDMA/133 abar m4096@0xfd808000 port 0xfd808100 irq 47
[    3.618371] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    3.618374] ehci-pci: EHCI PCI platform driver
[    3.618381] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    3.618382] ohci-pci: OHCI PCI platform driver
[    3.618387] uhci_hcd: USB Universal Host Controller Interface driver
[    3.618413] usbcore: registered new interface driver usbserial_generic
[    3.618416] usbserial: USB Serial support registered for generic
[    3.618471] rtc_cmos 00:02: RTC can wake from S4
[    3.618643] rtc_cmos 00:02: registered as rtc0
[    3.618672] rtc_cmos 00:02: setting system clock to 2022-01-12T11:59:57 UTC (1641988797)
[    3.618683] rtc_cmos 00:02: alarms up to one month, y3k, 114 bytes nvram, hpet irqs
[    3.618799] ledtrig-cpu: registered to indicate activity on CPUs
[    3.618923] efifb: probing for efifb
[    3.618931] efifb: framebuffer at 0xe0000000, using 3072k, total 3072k
[    3.618932] efifb: mode is 1024x768x32, linelength=4096, pages=1
[    3.618933] efifb: scrolling: redraw
[    3.618934] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[    3.618960] fbcon: Deferring console take-over
[    3.618961] fb0: EFI VGA frame buffer device
[    3.618979] hid: raw HID events driver (C) Jiri Kosina
[    3.619024] ashmem: initialized
[    3.619084] drop_monitor: Initializing network drop monitor service
[    3.619135] Initializing XFRM netlink socket
[    3.619191] NET: Registered PF_INET6 protocol family
[    3.634183] nvme nvme0: allocated 32 MiB host memory buffer.
[    3.635685] nvme nvme0: 16/0/0 default/read/poll queues
[    3.639130]  nvme0n1: p1 p2 p3
[    3.929774] ata9: SATA link down (SStatus 0 SControl 300)
[    4.048313] Freeing initrd memory: 52732K
[    4.051721] Segment Routing with IPv6
[    4.051722] RPL Segment Routing with IPv6
[    4.051733] In-situ OAM (IOAM) with IPv6
[    4.051758] NET: Registered PF_PACKET protocol family
[    4.052437] microcode: CPU0: patch_level=0x08001105
[    4.052443] microcode: CPU1: patch_level=0x08001105
[    4.052448] microcode: CPU2: patch_level=0x08001105
[    4.052455] microcode: CPU3: patch_level=0x08001105
[    4.052457] microcode: CPU4: patch_level=0x08001105
[    4.052463] microcode: CPU5: patch_level=0x08001105
[    4.052470] microcode: CPU6: patch_level=0x08001105
[    4.052478] microcode: CPU7: patch_level=0x08001105
[    4.052484] microcode: CPU8: patch_level=0x08001105
[    4.052490] microcode: CPU9: patch_level=0x08001105
[    4.052496] microcode: CPU10: patch_level=0x08001105
[    4.052503] microcode: CPU11: patch_level=0x08001105
[    4.052506] microcode: Microcode Update Driver: v2.2.
[    4.052510] IPI shorthand broadcast: enabled
[    4.052520] sched_clock: Marking stable (4075679788, -23328735)->(4058301098, -5950045)
[    4.052816] registered taskstats version 1
[    4.053016] Loading compiled-in X.509 certificates
[    4.055433] Loaded X.509 cert 'Build time autogenerated kernel key: 9612dc616146eeaafd46db77e26f033f23e1efc3'
[    4.057988] zswap: loaded using pool zstd/z3fold
[    4.058383] Key type ._fscrypt registered
[    4.058384] Key type .fscrypt registered
[    4.058385] Key type fscrypt-provisioning registered
[    4.058423] AppArmor: AppArmor sha1 policy hashing enabled
[    4.058625] PM:   Magic number: 6:478:984
[    4.058679] platform PNP0C14:01: hash matches
[    4.058690] acpi PNP0C14:01: hash matches
[    4.058827] RAS: Correctable Errors collector initialized.
[    4.087093] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    4.088135] ata1.00: ATA-8: HGST HTS541010A9E680, JA0OA560, max UDMA/133
[    4.088413] ata1.00: ATA Identify Device Log not supported
[    4.088414] ata1.00: 1953525168 sectors, multi 16: LBA48 NCQ (depth 32), AA
[    4.089860] ata1.00: ATA Identify Device Log not supported
[    4.089863] ata1.00: configured for UDMA/133
[    4.089992] scsi 0:0:0:0: Direct-Access     ATA      HGST HTS541010A9 A560 PQ: 0 ANSI: 5
[    4.090147] sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[    4.090149] sd 0:0:0:0: [sda] 4096-byte physical blocks
[    4.090154] sd 0:0:0:0: [sda] Write Protect is off
[    4.090155] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[    4.090171] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    4.400827] ata2: SATA link down (SStatus 0 SControl 300)
[    4.870417] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[    4.871799] ata3.00: ATA-11: WDC WDS250G2B0B-00YS70, X61130WD, max UDMA/133
[    4.871856] ata3.00: 488397168 sectors, multi 1: LBA48 NCQ (depth 32), AA
[    4.872463] ata3.00: Features: Dev-Sleep
[    4.874517] ata3.00: configured for UDMA/133
[    4.874663] scsi 2:0:0:0: Direct-Access     ATA      WDC WDS250G2B0B- 30WD PQ: 0 ANSI: 5
[    4.874843] sd 2:0:0:0: [sdb] 488397168 512-byte logical blocks: (250 GB/233 GiB)
[    4.874851] sd 2:0:0:0: [sdb] Write Protect is off
[    4.874852] sd 2:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[    4.874861] sd 2:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    4.905213]  sdb: sdb1 sdb2 sdb3
[    4.930476] sd 2:0:0:0: [sdb] Attached SCSI disk
[    5.184085] ata4: SATA link down (SStatus 0 SControl 300)
[    5.493856] ata5: SATA link down (SStatus 0 SControl 330)
[    6.437123]  sda: sda1
[    6.467137] sd 0:0:0:0: [sda] Attached SCSI disk
[    6.527079] ata6: failed to resume link (SControl 0)
[    6.527095] ata6: SATA link down (SStatus 0 SControl 0)
[    6.997083] ata7: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
[    6.997427] ata7.00: ATA-8: TOSHIBA MK6476GSX, GS001C, max UDMA/100
[    6.997468] ata7.00: 1250263728 sectors, multi 16: LBA48 NCQ (depth 32), AA
[    6.997824] ata7.00: configured for UDMA/100
[    6.997936] scsi 6:0:0:0: Direct-Access     ATA      TOSHIBA MK6476GS 1C   PQ: 0 ANSI: 5
[    6.998147] sd 6:0:0:0: [sdc] 1250263728 512-byte logical blocks: (640 GB/596 GiB)
[    6.998154] sd 6:0:0:0: [sdc] Write Protect is off
[    6.998156] sd 6:0:0:0: [sdc] Mode Sense: 00 3a 00 00
[    6.998167] sd 6:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[    7.307420] ata8: SATA link down (SStatus 0 SControl 300)
[    7.426462]  sdc: sdc1
[    7.440472] sd 6:0:0:0: [sdc] Attached SCSI disk
[    7.441391] Freeing unused decrypted memory: 2036K
[    7.441591] Freeing unused kernel image (initmem) memory: 1864K
[    7.441593] Write protecting the kernel read-only data: 28672k
[    7.441934] Freeing unused kernel image (text/rodata gap) memory: 2036K
[    7.442135] Freeing unused kernel image (rodata/data gap) memory: 1404K
[    7.474201] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    7.474205] rodata_test: all tests were successful
[    7.474222] Run /init as init process
[    7.474223]   with arguments:
[    7.474223]     /init
[    7.474224]     3
[    7.474225]   with environment:
[    7.474225]     HOME=/
[    7.474226]     TERM=linux
[    7.474226]     BOOT_IMAGE=/boot/vmlinuz-x86_64
[    7.474227]     lang=en_US
[    7.474227]     keytable=us
[    7.474228]     tz=UTC
[    7.474228]     misobasedir=manjaro
[    7.474228]     misolabel=MANJARO_XFCE_2121
[    7.474229]     driver=nonfree
[    7.544736] fbcon: Taking over console
[    7.544843] Console: switching to colour frame buffer device 128x48
[    7.568424] loop: module loaded
[    7.574587] device-mapper: uevent: version 1.0.3
[    7.574628] device-mapper: ioctl: 4.45.0-ioctl (2021-03-22) initialised: dm-devel@redhat.com
[    7.641288] xhci_hcd 0000:03:00.0: xHCI Host Controller
[    7.641300] xhci_hcd 0000:03:00.0: new USB bus registered, assigned bus number 1
[    7.645880] dca service started, version 1.12.1
[    7.654153] cryptd: max_cpu_qlen set to 1000
[    7.656807] igb: Intel(R) Gigabit Ethernet Network Driver
[    7.656811] igb: Copyright (c) 2007-2014 Intel Corporation.
[    7.662030] AVX2 version of gcm_enc/dec engaged.
[    7.662067] AES CTR mode by8 optimization enabled
[    7.674127] random: fast init done
[    7.686174] pps pps0: new PPS source ptp0
[    7.686230] igb 0000:1e:00.0: added PHC on eth0
[    7.686232] igb 0000:1e:00.0: Intel(R) Gigabit Ethernet Network Connection
[    7.686233] igb 0000:1e:00.0: eth0: (PCIe:2.5Gb/s:Width x1) 4c:cc:6a:fd:50:6a
[    7.686236] igb 0000:1e:00.0: eth0: PBA No: FFFFFF-0FF
[    7.686237] igb 0000:1e:00.0: Using MSI-X interrupts. 2 rx queue(s), 2 tx queue(s)
[    7.696649] xhci_hcd 0000:03:00.0: hcc params 0x0200ef81 hci version 0x110 quirks 0x0000010008000410
[    7.696836] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[    7.696838] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    7.696840] usb usb1: Product: xHCI Host Controller
[    7.696841] usb usb1: Manufacturer: Linux 5.15.12-1-MANJARO xhci-hcd
[    7.696842] usb usb1: SerialNumber: 0000:03:00.0
[    7.696979] hub 1-0:1.0: USB hub found
[    7.696994] hub 1-0:1.0: 14 ports detected
[    7.697406] xhci_hcd 0000:03:00.0: xHCI Host Controller
[    7.697409] xhci_hcd 0000:03:00.0: new USB bus registered, assigned bus number 2
[    7.697412] xhci_hcd 0000:03:00.0: Host supports USB 3.1 Enhanced SuperSpeed
[    7.697440] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    7.697456] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[    7.697458] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    7.697459] usb usb2: Product: xHCI Host Controller
[    7.697460] usb usb2: Manufacturer: Linux 5.15.12-1-MANJARO xhci-hcd
[    7.697460] usb usb2: SerialNumber: 0000:03:00.0
[    7.697521] hub 2-0:1.0: USB hub found
[    7.697532] hub 2-0:1.0: 8 ports detected
[    7.697791] xhci_hcd 0000:23:00.0: xHCI Host Controller
[    7.697794] xhci_hcd 0000:23:00.0: new USB bus registered, assigned bus number 3
[    7.726481] raid6: skip pq benchmark and using algorithm avx2x4
[    7.726484] raid6: using avx2x2 recovery algorithm
[    7.729156] xor: automatically using best checksumming function   avx
[    7.752673] xhci_hcd 0000:23:00.0: hcc params 0x0200ef80 hci version 0x110 quirks 0x0000000000800010
[    7.753250] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[    7.753252] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    7.753254] usb usb3: Product: xHCI Host Controller
[    7.753255] usb usb3: Manufacturer: Linux 5.15.12-1-MANJARO xhci-hcd
[    7.753256] usb usb3: SerialNumber: 0000:23:00.0
[    7.753323] hub 3-0:1.0: USB hub found
[    7.753332] hub 3-0:1.0: 2 ports detected
[    7.753455] xhci_hcd 0000:23:00.0: xHCI Host Controller
[    7.753458] xhci_hcd 0000:23:00.0: new USB bus registered, assigned bus number 4
[    7.753461] xhci_hcd 0000:23:00.0: Host supports USB 3.1 Enhanced SuperSpeed
[    7.753512] usb usb4: We don't know the algorithms for LPM for this host, disabling LPM.
[    7.753532] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[    7.753535] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    7.753536] usb usb4: Product: xHCI Host Controller
[    7.753537] usb usb4: Manufacturer: Linux 5.15.12-1-MANJARO xhci-hcd
[    7.753539] usb usb4: SerialNumber: 0000:23:00.0
[    7.753613] hub 4-0:1.0: USB hub found
[    7.753622] hub 4-0:1.0: 2 ports detected
[    7.753777] xhci_hcd 0000:25:00.3: xHCI Host Controller
[    7.753781] xhci_hcd 0000:25:00.3: new USB bus registered, assigned bus number 5
[    7.753881] xhci_hcd 0000:25:00.3: hcc params 0x0270f665 hci version 0x100 quirks 0x0000000040000410
[    7.753979] usb usb5: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.15
[    7.753981] usb usb5: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    7.753982] usb usb5: Product: xHCI Host Controller
[    7.753983] usb usb5: Manufacturer: Linux 5.15.12-1-MANJARO xhci-hcd
[    7.753984] usb usb5: SerialNumber: 0000:25:00.3
[    7.754060] hub 5-0:1.0: USB hub found
[    7.754068] hub 5-0:1.0: 4 ports detected
[    7.754239] xhci_hcd 0000:25:00.3: xHCI Host Controller
[    7.754242] xhci_hcd 0000:25:00.3: new USB bus registered, assigned bus number 6
[    7.754245] xhci_hcd 0000:25:00.3: Host supports USB 3.0 SuperSpeed
[    7.754265] usb usb6: We don't know the algorithms for LPM for this host, disabling LPM.
[    7.754278] usb usb6: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.15
[    7.754280] usb usb6: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    7.754281] usb usb6: Product: xHCI Host Controller
[    7.754282] usb usb6: Manufacturer: Linux 5.15.12-1-MANJARO xhci-hcd
[    7.754283] usb usb6: SerialNumber: 0000:25:00.3
[    7.754343] hub 6-0:1.0: USB hub found
[    7.754348] hub 6-0:1.0: 4 ports detected
[    7.834071] Btrfs loaded, crc32c=crc32c-intel, zoned=yes, fsverity=yes
[    7.835162] BTRFS: device fsid 6f9b0443-7f3e-4e40-8212-a9e548c67b71 devid 1 transid 169 /dev/sdb2 scanned by systemd-udevd (285)
[    7.946711] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[    8.003682] usb 5-2: new full-speed USB device number 2 using xhci_hcd
[    8.003700] usb 3-2: new high-speed USB device number 2 using xhci_hcd
[    8.117108] usb 1-1: New USB device found, idVendor=0930, idProduct=6545, bcdDevice= 1.00
[    8.117113] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    8.117114] usb 1-1: Product: DataTraveler 2.0
[    8.117116] usb 1-1: Manufacturer: Kingston
[    8.117117] usb 1-1: SerialNumber: C860008861F9EDA09A070050
[    8.169313] usb 5-2: New USB device found, idVendor=046d, idProduct=c08b, bcdDevice=27.03
[    8.169318] usb 5-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    8.169320] usb 5-2: Product: G502 HERO Gaming Mouse
[    8.169322] usb 5-2: Manufacturer: Logitech
[    8.169323] usb 5-2: SerialNumber: 118938673338
[    8.169839] usb 3-2: New USB device found, idVendor=05e3, idProduct=0610, bcdDevice=32.98
[    8.169841] usb 3-2: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[    8.169843] usb 3-2: Product: USB2.0 Hub
[    8.170503] usb-storage 1-1:1.0: USB Mass Storage device detected
[    8.170634] scsi host9: usb-storage 1-1:1.0
[    8.170706] usbcore: registered new interface driver usb-storage
[    8.174789] usbcore: registered new interface driver uas
[    8.175850] hub 3-2:1.0: USB hub found
[    8.179829] hub 3-2:1.0: 3 ports detected
[    8.193563] input: Logitech G502 HERO Gaming Mouse as /devices/pci0000:00/0000:00:07.1/0000:25:00.3/usb5/5-2/5-2:1.0/0003:046D:C08B.0001/input/input2
[    8.193640] hid-generic 0003:046D:C08B.0001: input,hidraw0: USB HID v1.11 Mouse [Logitech G502 HERO Gaming Mouse] on usb-0000:25:00.3-2/input0
[    8.203186] input: Logitech G502 HERO Gaming Mouse Keyboard as /devices/pci0000:00/0000:00:07.1/0000:25:00.3/usb5/5-2/5-2:1.1/0003:046D:C08B.0002/input/input3
[    8.246927] usb 1-10: new full-speed USB device number 3 using xhci_hcd
[    8.257116] hid-generic 0003:046D:C08B.0002: input,hiddev96,hidraw1: USB HID v1.11 Keyboard [Logitech G502 HERO Gaming Mouse] on usb-0000:25:00.3-2/input1
[    8.257154] usbcore: registered new interface driver usbhid
[    8.257155] usbhid: USB HID core driver
[    8.303373] usb 5-3: new full-speed USB device number 3 using xhci_hcd
[    8.511304] usb 5-3: New USB device found, idVendor=14ed, idProduct=1000, bcdDevice= 0.00
[    8.511308] usb 5-3: New USB device strings: Mfr=8, Product=9, SerialNumber=0
[    8.511310] usb 5-3: Product: Shure MV5
[    8.511311] usb 5-3: Manufacturer: Shure Inc
[    8.564928] usb 1-10: New USB device found, idVendor=3299, idProduct=4ea2, bcdDevice= 1.03
[    8.564933] usb 1-10: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[    8.564934] usb 1-10: Product: GK650 Gaming Keyboard
[    8.564936] usb 1-10: Manufacturer: SONiX
[    8.577790] input: SONiX GK650 Gaming Keyboard as /devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-10/1-10:1.0/0003:3299:4EA2.0003/input/input6
[    8.606507] hid-generic 0003:14ED:1000.0004: hiddev97,hidraw2: USB HID v1.11 Device [Shure Inc Shure MV5] on usb-0000:25:00.3-3/input3
[    8.633491] hid-generic 0003:3299:4EA2.0003: input,hidraw3: USB HID v1.11 Keyboard [SONiX GK650 Gaming Keyboard] on usb-0000:03:00.0-10/input0
[    8.641251] input: SONiX GK650 Gaming Keyboard as /devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-10/1-10:1.1/0003:3299:4EA2.0005/input/input7
[    8.700077] input: SONiX GK650 Gaming Keyboard as /devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-10/1-10:1.1/0003:3299:4EA2.0005/input/input8
[    8.700115] input: SONiX GK650 Gaming Keyboard Mouse as /devices/pci0000:00/0000:00:01.3/0000:03:00.0/usb1/1-10/1-10:1.1/0003:3299:4EA2.0005/input/input9
[    8.700184] hid-generic 0003:3299:4EA2.0005: input,hiddev98,hidraw4: USB HID v1.11 Keyboard [SONiX GK650 Gaming Keyboard] on usb-0000:03:00.0-10/input1
[    9.179273] scsi 9:0:0:0: Direct-Access     Kingston DataTraveler 2.0 PMAP PQ: 0 ANSI: 4
[    9.180046] sd 9:0:0:0: [sdd] 30489408 512-byte logical blocks: (15.6 GB/14.5 GiB)
[    9.180182] sd 9:0:0:0: [sdd] Write Protect is off
[    9.180184] sd 9:0:0:0: [sdd] Mode Sense: 23 00 00 00
[    9.180310] sd 9:0:0:0: [sdd] No Caching mode page found
[    9.180329] sd 9:0:0:0: [sdd] Assuming drive cache: write through
[    9.182959]  sdd: sdd1 sdd2
[    9.184161] sd 9:0:0:0: [sdd] Attached SCSI removable disk
[    9.307023] BTRFS info (device sdb2): flagging fs with big metadata feature
[    9.307027] BTRFS info (device sdb2): disk space caching is enabled
[    9.307029] BTRFS info (device sdb2): has skinny extents
[    9.311584] BTRFS info (device sdb2): enabling ssd optimizations
[    9.482526] random: crng init done
[    9.656502] EXT4-fs (sdc1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[   11.009747] BTRFS info (device sdb2): flagging fs with big metadata feature
[   11.009752] BTRFS info (device sdb2): disk space caching is enabled
[   11.009753] BTRFS info (device sdb2): has skinny extents
[   11.014564] BTRFS info (device sdb2): enabling ssd optimizations
[   11.357073] EXT4-fs (sdc1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[   11.450518] ISO 9660 Extensions: Microsoft Joliet Level 3
[   11.451417] ISO 9660 Extensions: RRIP_1991A
[   11.519693] ISO 9660 Extensions: Microsoft Joliet Level 3
[   11.520609] ISO 9660 Extensions: RRIP_1991A
[   11.525288] loop0: detected capacity change from 0 to 265736
[   11.642087] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[   11.663767] loop1: detected capacity change from 0 to 1817096
[   11.816811] loop2: detected capacity change from 0 to 3151496
[   11.979683] loop3: detected capacity change from 0 to 1588416
[   12.156945] overlayfs: null uuid detected in lower fs '/', falling back to xino=off,index=off,nfs_export=off.
[   13.078014] systemd[1]: systemd 250-5-manjaro running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK +XKBCOMMON +UTMP -SYSVINIT default-hierarchy=unified)
[   13.093452] systemd[1]: Detected architecture x86-64.
[   14.458615] systemd[1]: Queued start job for default target Multi-User System.
[   14.459364] systemd[1]: Created slice Slice /system/getty.
[   14.459613] systemd[1]: Created slice Slice /system/modprobe.
[   14.459800] systemd[1]: Created slice User and Session Slice.
[   14.459882] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[   14.459950] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   14.460088] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[   14.460147] systemd[1]: Reached target Local Encrypted Volumes.
[   14.460188] systemd[1]: Reached target Local Integrity Protected Volumes.
[   14.460235] systemd[1]: Reached target Remote File Systems.
[   14.460271] systemd[1]: Reached target Slice Units.
[   14.460308] systemd[1]: Reached target Swaps.
[   14.460344] systemd[1]: Reached target Local Verity Protected Volumes.
[   14.460421] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[   14.460930] systemd[1]: Listening on LVM2 poll daemon socket.
[   14.461844] systemd[1]: Listening on Process Core Dump Socket.
[   14.461974] systemd[1]: Listening on Journal Audit Socket.
[   14.462428] systemd[1]: Listening on Journal Socket (/dev/log).
[   14.462876] systemd[1]: Listening on Journal Socket.
[   14.463710] systemd[1]: Listening on udev Control Socket.
[   14.464150] systemd[1]: Listening on udev Kernel Socket.
[   14.465041] systemd[1]: Mounting Huge Pages File System...
[   14.465929] systemd[1]: Mounting POSIX Message Queue File System...
[   14.466787] systemd[1]: Mounting Kernel Debug File System...
[   14.467643] systemd[1]: Mounting Kernel Trace File System...
[   14.473752] systemd[1]: Mounting Temporary Directory /tmp...
[   14.474662] systemd[1]: Starting Load AppArmor profiles...
[   14.475703] systemd[1]: Starting Create List of Static Device Nodes...
[   14.476551] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[   14.477531] systemd[1]: Starting Load Kernel Module configfs...
[   14.478410] systemd[1]: Starting Load Kernel Module drm...
[   14.479328] systemd[1]: Starting Load Kernel Module fuse...
[   14.512413] fuse: init (API version 7.34)
[   14.514958] systemd[1]: Starting Load Kernel Modules...
[   14.516172] systemd[1]: Starting Remount Root and Kernel File Systems...
[   14.566433] systemd[1]: Repartition Root Disk was skipped because all trigger condition checks failed.
[   14.567107] systemd[1]: Starting Coldplug All udev Devices...
[   14.568803] systemd[1]: Mounted Huge Pages File System.
[   14.569238] systemd[1]: Mounted POSIX Message Queue File System.
[   14.569655] systemd[1]: Mounted Kernel Debug File System.
[   14.570076] systemd[1]: Mounted Kernel Trace File System.
[   14.570957] systemd[1]: Mounted Temporary Directory /tmp.
[   14.571444] systemd[1]: Finished Create List of Static Device Nodes.
[   14.571976] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[   14.572054] systemd[1]: Finished Load Kernel Module configfs.
[   14.572563] systemd[1]: modprobe@drm.service: Deactivated successfully.
[   14.572638] systemd[1]: Finished Load Kernel Module drm.
[   14.573155] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[   14.573230] systemd[1]: Finished Load Kernel Module fuse.
[   14.573719] systemd[1]: Finished Remount Root and Kernel File Systems.
[   14.574617] systemd[1]: Mounting FUSE Control File System...
[   14.575472] systemd[1]: Mounting Kernel Configuration File System...
[   14.575871] systemd[1]: First Boot Wizard was skipped because of a failed condition check (ConditionFirstBoot=yes).
[   14.624199] systemd[1]: Rebuild Hardware Database was skipped because of a failed condition check (ConditionNeedsUpdate=/etc).
[   14.624792] systemd[1]: Starting Load/Save Random Seed...
[   14.625199] systemd[1]: Create System Users was skipped because of a failed condition check (ConditionNeedsUpdate=/etc).
[   14.625641] systemd[1]: Starting Create Static Device Nodes in /dev...
[   14.626875] systemd[1]: Finished Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling.
[   14.627376] systemd[1]: Mounted FUSE Control File System.
[   14.627810] systemd[1]: Mounted Kernel Configuration File System.
[   14.715817] systemd[1]: Finished Load/Save Random Seed.
[   14.716305] systemd[1]: First Boot Complete was skipped because of a failed condition check (ConditionFirstBoot=yes).
[   14.741943] systemd[1]: Finished Coldplug All udev Devices.
[   14.812094] spl: loading out-of-tree module taints kernel.
[   14.812173] spl: module verification failed: signature and/or required key missing - tainting kernel
[   14.840766] znvpair: module license 'CDDL' taints kernel.
[   14.840770] Disabling lock debugging due to kernel taint
[   14.853191] audit: type=1400 audit(1641988808.729:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=547 comm="apparmor_parser"
[   14.854083] audit: type=1400 audit(1641988808.733:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=547 comm="apparmor_parser"
[   14.857130] audit: type=1400 audit(1641988808.736:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=546 comm="apparmor_parser"
[   14.866797] systemd[1]: Finished Create Static Device Nodes in /dev.
[   14.867240] systemd[1]: Reached target Preparation for Local File Systems.
[   14.868438] systemd[1]: Mounting Temporary /etc/pacman.d/gnupg directory...
[   14.872074] audit: type=1400 audit(1641988808.749:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="dovecot-script-login" pid=549 comm="apparmor_parser"
[   14.873657] systemd[1]: Virtual Machine and Container Storage (Compatibility) was skipped because of a failed condition check (ConditionPathExists=/var/lib/machines.raw).
[   14.873680] systemd[1]: Entropy Daemon based on the HAVEGE algorithm was skipped because of a failed condition check (ConditionKernelVersion=<5.6).
[   14.874818] systemd[1]: Starting Journal Service...
[   14.876138] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[   14.877727] systemd[1]: Mounted Temporary /etc/pacman.d/gnupg directory.
[   14.878382] systemd[1]: Reached target Local File Systems.
[   14.879063] systemd[1]: Rebuild Dynamic Linker Cache was skipped because all trigger condition checks failed.
[   14.879577] systemd[1]: Set Up Additional Binary Formats was skipped because all trigger condition checks failed.
[   14.879608] systemd[1]: Store a System Token in an EFI Variable was skipped because of a failed condition check (ConditionPathExists=/sys/firmware/efi/efivars/LoaderFeatures-4a67b082-0a4c-41cf-b6c7-440b29bb8c4f).
[   14.879649] systemd[1]: Commit a transient machine-id on disk was skipped because of a failed condition check (ConditionPathIsMountPoint=/etc/machine-id).
[   14.907588] audit: type=1400 audit(1641988808.786:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="php-fpm" pid=548 comm="apparmor_parser"
[   14.945120] audit: type=1400 audit(1641988808.823:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/lightdm/lightdm-guest-session" pid=545 comm="apparmor_parser"
[   14.946055] audit: type=1400 audit(1641988808.823:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/lightdm/lightdm-guest-session//chromium" pid=545 comm="apparmor_parser"
[   14.972924] systemd[1]: Started Journal Service.
[   14.973463] audit: type=1130 audit(1641988808.853:9): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   15.015277] systemd-journald[556]: Received client request to flush runtime journal.
[   15.016429] audit: type=1130 audit(1641988808.893:10): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   15.043991] audit: type=1400 audit(1641988808.923:11): apparmor="STATUS" operation="profile_load" profile="unconfined" name="/usr/lib/snapd/snap-confine" pid=550 comm="apparmor_parser"
[   15.545933] acpi_cpufreq: overriding BIOS provided _PSD data
[   15.546758] input: PC Speaker as /devices/platform/pcspkr/input/input10
[   15.707570] igb 0000:1e:00.0 enp30s0: renamed from eth0
[   15.847404] piix4_smbus 0000:00:14.0: SMBus Host Controller at 0xb00, revision 0
[   15.847409] piix4_smbus 0000:00:14.0: Using register 0x02 for SMBus port selection
[   15.847483] piix4_smbus 0000:00:14.0: Auxiliary SMBus Host Controller at 0xb20
[   15.856573] tpm_crb MSFT0101:00: [Firmware Bug]: ACPI region does not cover the entire command/response buffer. [mem 0xdd37f000-0xdd37ffff flags 0x200] vs dd37f000 4000
[   15.857468] tpm_crb MSFT0101:00: can't request region for resource [mem 0xdd37f000-0xdd37ffff]
[   15.857947] tpm_crb: probe of MSFT0101:00 failed with error -16
[   15.864796] ccp 0000:25:00.2: enabling device (0000 -> 0002)
[   15.865133] ccp 0000:25:00.2: ccp enabled
[   16.048721] sp5100_tco: SP5100/SB800 TCO WatchDog Timer Driver
[   16.048775] RAPL PMU: API unit is 2^-32 Joules, 1 fixed counters, 163840 ms ovfl timer
[   16.048780] RAPL PMU: hw unit of domain package 2^-16 Joules
[   16.048842] sp5100-tco sp5100-tco: Using 0xfeb00000 for watchdog MMIO address
[   16.049012] sp5100-tco sp5100-tco: initialized. heartbeat=60 sec (nowayout=0)
[   16.683382] kvm: Nested Virtualization enabled
[   16.683386] SVM: kvm: Nested Paging enabled
[   16.683387] SEV supported: 16 ASIDs
[   16.683399] SVM: Virtual VMLOAD VMSAVE supported
[   16.683399] SVM: Virtual GIF supported
[   16.800888] MCE: In-kernel MCE decoding enabled.
[   16.882903] snd_hda_intel 0000:24:00.1: enabling device (0000 -> 0002)
[   16.883002] snd_hda_intel 0000:24:00.1: Disabling MSI
[   16.883012] snd_hda_intel 0000:24:00.1: Handle vga_switcheroo audio client
[   16.883127] snd_hda_intel 0000:26:00.3: enabling device (0000 -> 0002)
[   17.060265] input: HDA NVidia HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:03.1/0000:24:00.1/sound/card0/input11
[   17.060320] input: HDA NVidia HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:03.1/0000:24:00.1/sound/card0/input12
[   17.060377] input: HDA NVidia HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:03.1/0000:24:00.1/sound/card0/input13
[   17.060420] input: HDA NVidia HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:03.1/0000:24:00.1/sound/card0/input14
[   17.060459] input: HDA NVidia HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:03.1/0000:24:00.1/sound/card0/input15
[   17.060507] input: HDA NVidia HDMI/DP,pcm=11 as /devices/pci0000:00/0000:00:03.1/0000:24:00.1/sound/card0/input16
[   17.060553] input: HDA NVidia HDMI/DP,pcm=12 as /devices/pci0000:00/0000:00:03.1/0000:24:00.1/sound/card0/input17
[   17.180963] intel_rapl_common: Found RAPL domain package
[   17.180967] intel_rapl_common: Found RAPL domain core
[   17.296143] snd_hda_codec_realtek hdaudioC1D0: autoconfig for ALC1220: line_outs=3 (0x14/0x15/0x16/0x0/0x0) type:line
[   17.296152] snd_hda_codec_realtek hdaudioC1D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[   17.296157] snd_hda_codec_realtek hdaudioC1D0:    hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
[   17.296160] snd_hda_codec_realtek hdaudioC1D0:    mono: mono_out=0x0
[   17.296162] snd_hda_codec_realtek hdaudioC1D0:    dig-out=0x1e/0x0
[   17.296166] snd_hda_codec_realtek hdaudioC1D0:    inputs:
[   17.296168] snd_hda_codec_realtek hdaudioC1D0:      Front Mic=0x19
[   17.296169] snd_hda_codec_realtek hdaudioC1D0:      Rear Mic=0x18
[   17.296173] snd_hda_codec_realtek hdaudioC1D0:      Line=0x1a
[   17.308975] input: HD-Audio Generic Front Mic as /devices/pci0000:00/0000:00:08.1/0000:26:00.3/sound/card1/input18
[   17.309036] input: HD-Audio Generic Rear Mic as /devices/pci0000:00/0000:00:08.1/0000:26:00.3/sound/card1/input19
[   17.309079] input: HD-Audio Generic Line as /devices/pci0000:00/0000:00:08.1/0000:26:00.3/sound/card1/input20
[   17.309139] input: HD-Audio Generic Line Out Front as /devices/pci0000:00/0000:00:08.1/0000:26:00.3/sound/card1/input21
[   17.309179] input: HD-Audio Generic Line Out Surround as /devices/pci0000:00/0000:00:08.1/0000:26:00.3/sound/card1/input22
[   17.309225] input: HD-Audio Generic Line Out CLFE as /devices/pci0000:00/0000:00:08.1/0000:26:00.3/sound/card1/input23
[   17.309265] input: HD-Audio Generic Front Headphone as /devices/pci0000:00/0000:00:08.1/0000:26:00.3/sound/card1/input24
[   17.826802] ZFS: Loaded module v2.1.1-1, ZFS pool version 5000, ZFS filesystem version 5
[   19.033439] mc: Linux media interface: v0.10
[   19.056870] mousedev: PS/2 mouse device common for all mice
[   19.381589] usbcore: registered new interface driver snd-usb-audio
[   19.949345] kauditd_printk_skb: 22 callbacks suppressed
[   19.949350] audit: type=1130 audit(1641988813.826:34): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   20.009192] audit: type=1130 audit(1641988813.886:35): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=polkit comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   20.039885] st: Version 20160209, fixed bufsize 32768, s/g segs 256
[   20.234050] sd 0:0:0:0: Attached scsi generic sg0 type 0
[   20.234083] sd 2:0:0:0: Attached scsi generic sg1 type 0
[   20.234110] sd 6:0:0:0: Attached scsi generic sg2 type 0
[   20.234137] sd 9:0:0:0: Attached scsi generic sg3 type 0
[   20.306077] loop4: detected capacity change from 0 to 8
[   20.748016] audit: type=1130 audit(1641988814.626:36): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   20.860750] audit: type=1130 audit(1641988814.739:37): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=cups comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   20.896946] NET: Registered PF_QIPCRTR protocol family
[   20.899351] audit: type=1130 audit(1641988814.776:38): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=ModemManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   21.065569] audit: type=1400 audit(1641988814.939:39): apparmor="STATUS" operation="profile_replace" profile="unconfined" name="/usr/lib/snapd/snap-confine" pid=1259 comm="apparmor_parser"
[   21.093390] audit: type=1300 audit(1641988814.939:39): arch=c000003e syscall=1 success=yes exit=69825 a0=6 a1=558135c48b30 a2=110c1 a3=0 items=0 ppid=1257 pid=1259 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="apparmor_parser" exe="/usr/bin/apparmor_parser" subj==unconfined key=(null)
[   21.093397] audit: type=1327 audit(1641988814.939:39): proctitle=61707061726D6F725F706172736572002D2D7265706C616365002D2D77726974652D6361636865002D4F006E6F2D657870722D73696D706C696679002D2D63616368652D6C6F633D2F7661722F63616368652F61707061726D6F72002D2D736B69702D726561642D6361636865002D2D7175696574002F6574632F6170706172
[   21.094180] audit: type=1400 audit(1641988814.973:40): apparmor="STATUS" operation="profile_replace" info="same as current profile, skipping" profile="unconfined" name="/usr/lib/snapd/snap-confine//mount-namespace-capture-helper" pid=1259 comm="apparmor_parser"
[   21.094194] audit: type=1300 audit(1641988814.973:40): arch=c000003e syscall=1 success=yes exit=16065 a0=6 a1=558135682d00 a2=3ec1 a3=0 items=0 ppid=1257 pid=1259 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="apparmor_parser" exe="/usr/bin/apparmor_parser" subj==unconfined key=(null)
[   23.307229] igb 0000:1e:00.0 enp30s0: igb: enp30s0 NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
[   23.413584] IPv6: ADDRCONF(NETDEV_CHANGE): enp30s0: link becomes ready
[   28.018852] kauditd_printk_skb: 8 callbacks suppressed
[   28.018857] audit: type=1116 audit(1641988821.896:48): pid=1661 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=adding group acct="manjaro" exe="/usr/bin/useradd" hostname=? addr=? terminal=? res=success'
[   28.019227] audit: type=1114 audit(1641988821.896:49): pid=1661 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=adding user id=1000 exe="/usr/bin/useradd" hostname=? addr=? terminal=? res=success'
[   28.019234] audit: type=1114 audit(1641988821.896:50): pid=1661 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=adding user to group acct="manjaro" exe="/usr/bin/useradd" hostname=? addr=? terminal=? res=success'
[   28.019259] audit: type=1114 audit(1641988821.896:51): pid=1661 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=adding user to group acct="manjaro" exe="/usr/bin/useradd" hostname=? addr=? terminal=? res=success'
[   28.019277] audit: type=1114 audit(1641988821.896:52): pid=1661 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=adding user to group acct="manjaro" exe="/usr/bin/useradd" hostname=? addr=? terminal=? res=success'
[   28.019295] audit: type=1114 audit(1641988821.896:53): pid=1661 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=adding user to group acct="manjaro" exe="/usr/bin/useradd" hostname=? addr=? terminal=? res=success'
[   28.019311] audit: type=1114 audit(1641988821.896:54): pid=1661 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=adding user to group acct="manjaro" exe="/usr/bin/useradd" hostname=? addr=? terminal=? res=success'
[   28.019332] audit: type=1114 audit(1641988821.896:55): pid=1661 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=adding user to shadow group acct="manjaro" exe="/usr/bin/useradd" hostname=? addr=? terminal=? res=success'
[   28.019356] audit: type=1114 audit(1641988821.896:56): pid=1661 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=adding user to shadow group acct="manjaro" exe="/usr/bin/useradd" hostname=? addr=? terminal=? res=success'
[   28.019369] audit: type=1114 audit(1641988821.896:57): pid=1661 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=adding user to shadow group acct="manjaro" exe="/usr/bin/useradd" hostname=? addr=? terminal=? res=success'
[   36.128046] kauditd_printk_skb: 11 callbacks suppressed
[   36.128050] audit: type=1131 audit(1641988830.006:69): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=snapd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   36.139550] audit: type=1130 audit(1641988830.016:70): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=pacman-init comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   50.002874] audit: type=1131 audit(1641988843.879:71): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   50.106794] audit: type=1334 audit(1641988843.986:72): prog-id=0 op=UNLOAD
[   50.106801] audit: type=1334 audit(1641988843.986:73): prog-id=0 op=UNLOAD
[   50.106806] audit: type=1334 audit(1641988843.986:74): prog-id=0 op=UNLOAD
[   51.303974] audit: type=1131 audit(1641988845.183:75): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-timedated comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   51.346809] audit: type=1334 audit(1641988845.226:76): prog-id=0 op=UNLOAD
[   51.346817] audit: type=1334 audit(1641988845.226:77): prog-id=0 op=UNLOAD
[   51.346820] audit: type=1334 audit(1641988845.226:78): prog-id=0 op=UNLOAD
[   62.939955] audit: type=1334 audit(1641988856.816:79): prog-id=18 op=LOAD
[   62.939962] audit: type=1334 audit(1641988856.816:80): prog-id=0 op=UNLOAD
[   62.940055] audit: type=1334 audit(1641988856.819:81): prog-id=19 op=LOAD
[   62.940124] audit: type=1334 audit(1641988856.819:82): prog-id=20 op=LOAD
[   62.940140] audit: type=1334 audit(1641988856.819:83): prog-id=0 op=UNLOAD
[   62.940147] audit: type=1334 audit(1641988856.819:84): prog-id=0 op=UNLOAD
[   62.941031] audit: type=1334 audit(1641988856.819:85): prog-id=21 op=LOAD
[   62.941045] audit: type=1334 audit(1641988856.819:86): prog-id=0 op=UNLOAD
[   62.941158] audit: type=1334 audit(1641988856.819:87): prog-id=22 op=LOAD
[   62.941229] audit: type=1334 audit(1641988856.819:88): prog-id=23 op=LOAD
[   78.996073] nvidia-nvlink: Nvlink Core is being initialized, major device number 510
[   78.996924] nvidia 0000:24:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=none:owns=none
[   79.043994] NVRM: loading NVIDIA UNIX x86_64 Kernel Module  495.44  Fri Oct 22 06:13:12 UTC 2021
[   79.079345] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms  495.44  Fri Oct 22 06:05:22 UTC 2021
[   79.100308] [drm] [nvidia-drm] [GPU ID 0x00002400] Loading driver
[   79.100311] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:24:00.0 on minor 0
[   79.103917] kauditd_printk_skb: 8 callbacks suppressed
[   79.103920] audit: type=1130 audit(1641988872.983:97): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=mhwd-live comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   79.103926] audit: type=1131 audit(1641988872.983:98): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=mhwd-live comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   79.109680] audit: type=1130 audit(1641988872.986:99): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-user-sessions comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   79.111712] audit: type=1130 audit(1641988872.989:100): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=getty@tty1 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   84.407157] audit: type=1100 audit(1641988878.286:101): pid=4691 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="manjaro" exe="/usr/bin/login" hostname=manjaro addr=? terminal=/dev/tty1 res=success'
[   84.407435] audit: type=1101 audit(1641988878.286:102): pid=4691 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="manjaro" exe="/usr/bin/login" hostname=manjaro addr=? terminal=/dev/tty1 res=success'
[   84.407964] audit: type=1103 audit(1641988878.286:103): pid=4691 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="manjaro" exe="/usr/bin/login" hostname=manjaro addr=? terminal=/dev/tty1 res=success'
[   84.408034] audit: type=1006 audit(1641988878.286:104): pid=4691 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=tty1 old-ses=4294967295 ses=1 res=1
[   84.408044] audit: type=1300 audit(1641988878.286:104): arch=c000003e syscall=1 success=yes exit=4 a0=5 a1=7ffe4dec2280 a2=4 a3=3e8 items=0 ppid=1 pid=4691 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=1000 fsgid=0 tty=tty1 ses=1 comm="login" exe="/usr/bin/login" subj==unconfined key=(null)
[   84.408047] audit: type=1327 audit(1641988878.286:104): proctitle=2F62696E2F6C6F67696E002D70002D2D
[   84.423971] audit: type=1130 audit(1641988878.303:105): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   84.430793] audit: type=1101 audit(1641988878.309:106): pid=4695 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="manjaro" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   84.430837] audit: type=1103 audit(1641988878.309:107): pid=4695 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=? acct="manjaro" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
[   84.430903] audit: type=1006 audit(1641988878.309:108): pid=4695 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=2 res=1
[   87.877352] NVRM: GPU 0000:24:00.0: RmInitAdapter failed! (0x26:0x56:1479)
[   87.877400] NVRM: GPU 0000:24:00.0: rm_init_adapter failed, device minor number 0
[   88.484199] NVRM: GPU 0000:24:00.0: RmInitAdapter failed! (0x26:0x56:1479)
[   88.484246] NVRM: GPU 0000:24:00.0: rm_init_adapter failed, device minor number 0
[  144.110735] kauditd_printk_skb: 10 callbacks suppressed
[  144.110738] audit: type=1101 audit(1641988937.989:115): pid=4755 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="manjaro" exe="/usr/bin/sudo" hostname=manjaro addr=? terminal=/dev/tty1 res=success'
[  144.111149] audit: type=1110 audit(1641988937.989:116): pid=4755 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=manjaro addr=? terminal=/dev/tty1 res=success'
[  144.113116] audit: type=1105 audit(1641988937.989:117): pid=4755 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_systemd_home,pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=manjaro addr=? terminal=/dev/tty1 res=success'
The NVIDIA driver is properly loaded, but there’s an error trying to initialize the RTX 3070 GPU:
This is likely to be a bug. You should try NVIDIA driver version 495.46 first and see if the bug still persists. I think mhwd hasn’t updated the driver to the latest version, so you probably need to install manually:
https://www.nvidia.com/en-us/drivers/unix/
If the above error still persists in 495.46, refer to below how to file a driver bug to NVIDIA:
https://nvidia.custhelp.com/app/answers/detail/a_id/44/~/where-can-i-get-support-for-linux-drivers%3F
You probably want to attach a link to this post when filing your bug.
It turns out updating the bios somehow fixed it. Tbh I didn’t even realize just how out of date my bios was. Thank you so much for your help.
Ok, so somehow the old BIOS caused an issue with the latest NVIDIA driver. Not many people know this, but you also need to keep your firmware BIOS/UEFI updated (important !!!) aside from the OS and applications themselves.
