Hi,
I’ve installed and removed linux mint 19.3 xfce before. I’ve deleted entire partition and grub from windows boot loader.
I’m trying to install latest manjaro gnome edition as dual boot to my lenovo thinkpad E14 gen1. Installer gives an error while creating partition table.
I’ve tried secureboot on and off, UEFI and BOTH options. Also I got same error at linux mint 20 install.
My partition table before install:
pasteboard .co/JIU9vAB.png
After Install:
pasteboard .co/JIU9Ewf.png
The error I got:
pasteboard .co/JIU9QOV.jpg
recheck all option in Bios to get only UEFI
disable secureboot
disable fastboot
no CSM or Legacy
choose UEFI only or first or others ( not windows )
disks on AHCI
no optane RST
and boot in UEFI only on USB iso
you should see this
UEFI < USB vendor name > < partition 1>
can you boot on USB iso manjaro
open a terminal and a browser on this topic
and returns
inxi -Fza
test -d /sys/firmware/efi && echo efi || echo bios
sudo parted -l
sudo efibootmgr -v
Hi I’ve deleted everything on ssd and tried to install but no luck.
~ inxi -Fza ✔
Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=tr tz=UTC
misobasedir=manjaro misolabel=MANJARO_GNOME_2021 quiet
systemd.show_status=1 driver=free nouveau.modeset=1 i915.modeset=1
radeon.modeset=1
Desktop: GNOME 3.38.2 tk: GTK 3.24.24 wm: gnome-shell dm: GDM 3.38.2.1
Distro: Manjaro Linux
Type: Laptop System: LENOVO product: 20RBS1L200 v: ThinkPad E14
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: LENOVO model: 20RBS1L200 serial: <filter> UEFI: LENOVO
v: R16ET28W (1.14 ) date: 09/14/2020
ID-1: BAT0 charge: 32.4 Wh condition: 45.0/45.0 Wh (100%) volts: 11.8/11.1
model: LGC 5B10W138 type: Li-poly serial: <filter> status: Discharging
cycles: 6
Info: Quad Core model: Intel Core i5-10210U bits: 64 type: MT MCP
arch: Kaby Lake note: check family: 6 model-id: 8E (142) stepping: C (12)
microcode: DE L2 cache: 6 MiB
bogomips: 33615
Speed: 900 MHz min/max: 400/4200 MHz Core speeds (MHz): 1: 900 2: 900
3: 900 4: 900 5: 900 6: 900 7: 900 8: 900
Type: srbds mitigation: TSX disabled
Device-1: Intel UHD Graphics vendor: Lenovo driver: i915 v: kernel
bus ID: 00:02.0 chip ID: 8086:9b41
Device-2: IMC Networks Integrated Camera type: USB driver: uvcvideo
bus ID: 1-8:3 chip ID: 13d3:5415
Display: wayland server: X.org 1.20.10 compositor: gnome-shell
driver: i915 note: n/a (using device driver) - try sudo/root display ID: 0
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 20.3.1
direct render: Yes
Device-1: Intel vendor: Lenovo driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci bus ID: 00:1f.3 chip ID: 8086:02c8
Sound Server: ALSA v: k5.9.16-1-MANJARO
Device-1: Intel Wireless-AC 9462 driver: iwlwifi v: kernel port: 3000
bus ID: 00:14.3 chip ID: 8086:02f0
vendor: Lenovo driver: r8169 v: kernel port: 2000 bus ID: 04:00.0
chip ID: 10ec:8168
IF: enp4s0 state: down mac: <filter>
Local Storage: total: 491.85 GiB used: 149.8 MiB (0.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: TeamGroup model: TM8FP6512G
size: 476.94 GiB block size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: V1.0 temp: 47.9 C
ID-2: /dev/sda maj-min: 8:0 type: USB vendor: SanDisk model: Cruzer Glide
size: 14.91 GiB block size: physical: 512 B logical: 512 B
serial: <filter> rev: 1.27
ID-1: / raw size: N/A size: 11.59 GiB used: 149.8 MiB (1.3%) fs: overlay
source: ERR-102
System Temperatures: cpu: 45.0 C mobo: 0.0 C
Fan Speeds (RPM): cpu: 0
Processes: 270 Uptime: 3m wakeups: 3229 Memory: 15.45 GiB
used: 2.15 GiB (13.9%) Init: systemd v: 247 Compilers: gcc: N/A Packages:
pacman: 1285 lib: 368 flatpak: 0 Shell: Zsh v: 5.8
running in: gnome-terminal inxi: 3.2.01
~ test -d /sys/firmware/efi && echo efi || echo bios ✔
efi
~ sudo parted -l ✔
We trust you have received the usual lecture from the local System
Administrator. It usually boils down to these three things:
#1) Respect the privacy of others.
#2) Think before you type.
#3) With great power comes great responsibility.
[sudo] password for manjaro:
Model: SanDisk Cruzer Glide (scsi)
Disk /dev/sda: 16.0GB
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags
2 2954MB 2958MB 4194kB primary esp
Model: TEAM TM8FP6512G (nvme)
Disk /dev/nvme0n1: 512GB
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
1 1049kB 538MB 537MB fat32 msftdata
2 538MB 42.5GB 41.9GB
~ sudo efibootmgr -v ✔ 4s
BootCurrent: 001F
Timeout: 0 seconds
BootOrder: 0000,0010,0011,0012,0013,0014,0018,0019,001A,001B,001C,001D,001E,001F,0020
Boot0000* manjaro HD(4,MBR,0xc2a43cc,0x3b9d9800,0x5a34)/File(\EFI\manjaro\grubx64.efi)
Boot0010 Setup FvFile(721c8b66-426c-4e86-8e99-3457c46ab0b9)
Boot0011 Boot Menu FvFile(126a762d-5758-4fca-8531-201a7f57f850)
Boot0012 Diagnostic Splash Screen FvFile(a7d8d9a6-6ab0-4aeb-ad9d-163e59a7a380)
Boot0013 Lenovo Diagnostics FvFile(3f7e615b-0d45-4f80-88dc-26b234958560)
Boot0014 Regulatory Information FvFile(478c92a0-2622-42b7-a65d-5894169e4d24)
Boot0015 Startup Interrupt Menu FvFile(f46ee6f4-4785-43a3-923d-7f786c3c8479)
Boot0016 Rescue and Recovery FvFile(665d3f60-ad3e-4cad-8e26-db46eee9f1b5)
Boot0017 MEBx Hot Key FvFile(ac6fd56a-3d41-4efd-a1b9-870293811a28)
Boot0018* USB CD VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,86701296aa5a7848b66cd49dd3ba6a55)
Boot0019* USB FDD VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,6ff015a28830b543a8b8641009461e49)
Boot001A* NVMe0 VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,001c199932d94c4eae9aa0b6e98eb8a400)
Boot001B* NVMe1 VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,001c199932d94c4eae9aa0b6e98eb8a401)
Boot001C* ATA HDD0 VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,91af625956449f41a7b91f4f892ab0f600)
Boot001D* ATA HDD1 VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,91af625956449f41a7b91f4f892ab0f601)
Boot001E* ATA HDD2 VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,91af625956449f41a7b91f4f892ab0f602)
Boot001F* USB HDD VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,33e821aaaf33bc4789bd419f88c50803)
Boot0020* PXE BOOT VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,78a84aaf2b2afc4ea79cf5cc8f3d3803)
Boot0021* IDER BOOT CDROM PciRoot(0x0)/Pci(0x14,0x0)/USB(11,1)
Boot0022* IDER BOOT Floppy PciRoot(0x0)/Pci(0x14,0x0)/USB(11,0)
Boot0023* ATA HDD VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,91af625956449f41a7b91f4f892ab0f6)
Boot0024* ATAPI CD VenMsg(bc7838d2-0f82-4d60-8316-c068ee79d25b,aea2090adfde214e8b3a5e471856a354)
boot on USB iso manjaro with Free Drivers
use (e)dit on Grub screen ,
use arrows
add on boot kernel “nvme_core.default_ps_max_latency_us=0”
before install launch Gparted
( if not present add sudo pacman -S gparted )
create partition
/boot/efi ( vfat - fat32 ) 100Mo
/ ext4 40Go
/home ext 4 all the rest
add flag boot & esp on /boot/efi
then lauch install , select manual ,add as mountpoint
I followed the steps you provided. Gparted is also failed.
I got two errors.
" 64-bit filesystem support is not enabled. The larger feilds afforded by this feature enable full-strength checksumming. Pass -0 64but to rectify. "
mkfs.Ext4 : error input/output while writing out and closing file system.
I also checked ssd with smart and badblocks it seems fine.
I’ve create partition table with an bootable partition wizard before I install manjaro. After that I just go with manual option to bind mounts. It successfully installed at the moment.
