So I downloaded the rtl8812au drivers as instructed in the old archived tutorial (I cant post links). Unfortunately the driver doesn’t work at all.
This is the info I am required to provide:
inxi command
Kernel: 5.10.23-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=61c2f66b-3122-44e1-9040-95007056741d rw quiet apparmor=1
intel_iommu=on security=apparmor udev.log_priority=3
Desktop: KDE Plasma 5.21.3 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: Gigabyte model: Z270-Gaming K3 v: x.x serial: <filter>
UEFI: American Megatrends v: F8 date: 07/06/2017
RAM: total: 15.59 GiB used: 2.81 GiB (18.0%)
Info: Dual Core model: Intel Core i3-7100 bits: 64 type: MT MCP
arch: Kaby Lake family: 6 model-id: 9E (158) stepping: 9 microcode: DE
cache: L2: 3 MiB bogomips: 31211
Speed: 800 MHz min/max: 800/3900 MHz Core speeds (MHz): 1: 800 2: 800 3: 800
4: 800
Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art
avx avx2 bmi1 bmi2 bts clflush clflushopt cmov constant_tsc cpuid
cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts ept ept_ad erms est f16c
flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window hwp_epp
hwp_notify ibpb ibrs intel_pt invpcid invpcid_single lahf_lm lm mca mce
md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid
pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand
rdseed rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2
ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme
vmx vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Type: l1tf
Device-1: AMD Ellesmere [Radeon RX 470/480/570/570X/580/580X/590]
vendor: Micro-Star MSI driver: amdgpu v: kernel bus-ID: 01:00.0
chip-ID: 1002:67df class-ID: 0300
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
loaded: amdgpu,ati unloaded: modesetting alternate: fbdev,vesa
display-ID: :0 screens: 1
s-diag: 582mm (22.9")
Monitor-1: HDMI-A-0 res: 1920x1080 hz: 72 dpi: 82
size: 598x336mm (23.5x13.2") diag: 686mm (27")
OpenGL: renderer: Radeon RX 570 Series (POLARIS10 DRM 3.40.0
5.10.23-1-MANJARO LLVM 11.1.0)
v: 4.6 Mesa 20.3.4 direct render: Yes
Device-1: Intel 200 Series PCH HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a2f0
class-ID: 0403
Device-2: AMD Ellesmere HDMI Audio [Radeon RX 470/480 / 570/580/590]
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel bus-ID: 01:00.1
chip-ID: 1002:aaf0 class-ID: 0403
Device-3: Kingston HyperX Cloud Revolver S type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 3-1:2 chip-ID: 0951:16ad
class-ID: 0300 serial: <filter>
Sound Server-1: ALSA v: k5.10.23-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.23 running: yes
Device-1: Qualcomm Atheros Killer E2500 Gigabit Ethernet vendor: Gigabyte
driver: alx v: kernel port: d000 bus-ID: 06:00.0 chip-ID: 1969:e0b1
class-ID: 0200
IF: enp6s0 state: down mac: <filter>
Device-2: TRENDnet 802.11ac NIC type: USB driver: N/A bus-ID: 1-2:2
chip-ID: 20f4:809a class-ID: 0000 serial: <filter>
IF-ID-1: enp0s20f0u4u2 state: unknown speed: N/A duplex: N/A mac: <filter>
Device-1: Samsung GT-I9070 (network tethering USB debugging enabled)
type: USB driver: rndis_host v: kernel bus-ID: 1-4.2:7 chip-ID: 04e8:6864
class-ID: 0a00 serial: <filter>
Message: No LVM data was found.
Local Storage: total: 3.86 TiB used: 37.62 GiB (1.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: GOODRAM model: N/A size: 223.57 GiB
block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s rotation: SSD
serial: <filter> rev: 71.0 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD20EARS-42S0XB0
size: 1.82 TiB block-size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
rotation: 5400 rpm serial: <filter> rev: 1D04 scheme: GPT
ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital
model: WD2003FZEX-00SRLA0 size: 1.82 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s rotation: 7200 rpm serial: <filter> rev: 1A01
scheme: MBR
ID-1: / raw-size: 223.27 GiB size: 218.71 GiB (97.96%)
used: 37.62 GiB (17.2%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 61c2f66b-3122-44e1-9040-95007056741d
used: 296 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: NO_LABEL
uuid: EACE-1E42
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
ID-1: /dev/sdb1 maj-min: 8:17 size: 1.82 TiB fs: ntfs label: Nowy
uuid: 4602A16D02A162A3
ID-2: /dev/sdc1 maj-min: 8:33 size: 1.82 TiB fs: btrfs label: Zajebisty
uuid: 735870f6-b970-4d63-b4e0-9c78b03cd404
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 16 rev: 2.0
Device-1: 1-2:2 info: TRENDnet 802.11ac NIC type: WiFi driver: N/A
interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 20f4:809a
Hub-2: 1-4:3 info: Genesys Logic Hub ports: 3 rev: 2.0 speed: 480 Mb/s
Device-1: 1-4.1:4 info: SteelSeries ApS SteelSeries Apex 350 Gaming Keyboard
type: HID,Keyboard driver: hid-generic,usbhid interfaces: 3 rev: 1.1
speed: 12 Mb/s power: 2mA chip-ID: 1038:1206 class-ID: 0300
Device-2: 1-4.2:7
info: Samsung GT-I9070 (network tethering USB debugging enabled)
type: Bluetooth,CDC-Data driver: rndis_host interfaces: 3 rev: 2.0
speed: 480 Mb/s power: 500mA chip-ID: 04e8:6864 class-ID: 0a00
serial: <filter>
Device-3: 1-4.3:5 info: Logitech G502 SE HERO Gaming Mouse type: Mouse,HID
power: 300mA chip-ID: 046d:c08b class-ID: 0300 serial: <filter>
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 10 rev: 3.0 speed: 5 Gb/s
Hub-4: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Device-1: 3-1:2 info: Kingston HyperX Cloud Revolver S type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
speed: 12 Mb/s power: 300mA chip-ID: 0951:16ad class-ID: 0300
serial: <filter>
Hub-5: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 29.8 C mobo: 27.8 C gpu: amdgpu temp: 29.0 C
Fan Speeds (RPM): N/A gpu: amdgpu fan: 1095
Processes: 203 Uptime: 1h 51m wakeups: 0 Init: systemd v: 247
tool: systemctl Compilers: gcc: 10.2.0 Packages: pacman: 1312 lib: 352
flatpak: 0 Shell: Bash v: 5.1.0 running-in: yakuake inxi: 3.3.03
My WiFi adapter is TRENDnet TEW809UB/A and the wifi chipset is rtl8812au.
The adapter uses a cable between the PC and the actual adapter and it is not possible to plug the adapter in directly.
