I installed pantheon-code on my laptop and clicked the option to check spelling, but I didn’t realize that I needed aspell or another dictionary file. Now, when I open it, I get the following popup message:
"No Suitable Dictionaries Were Found
Please install at least one [aspell] dictionary"
I can’t close the popup and I can’t close the program now without going into the Task Manager and killing it.
I tried uninstalling and reinstalling it, I tried removing it via pamac, and I’ve tried using -Rns in pacman, but I can’t get it to work.
I’m still a bit of a Linux newbie, and I’m not sure where all of the install files are normally kept so I can’t manually go back through the /home directory to completely wipe it out and start back over.
Does anyone have any advice, please? Thank you in advance!
It works fine without aspell, but when I went into the program’s options and click the option to check spelling as you type, then it started to glitch.
(io.elementary.code:7587): Gtk-WARNING **: 13:45:08.267: GtkListBox with a model will ignore sort and filter functions
** (io.elementary.code:7587): WARNING **: 13:45:08.475: Error loading plugin: libhspell.so.0: cannot open shared object file: No such file or directory
** (io.elementary.code:7587): WARNING **: 13:45:08.476: Error loading plugin: libvoikko.so.1: cannot open shared object file: No such file or directory
** (io.elementary.code:7587): WARNING **: 13:45:08.476: Error loading plugin: libnuspell.so.5: cannot open shared object file: No such file or directory
Install libvoikkonuspellhunspellhspell and aspell. By default these are not installed, so that explains the problem. Just make sure your system is updated and also you reboot it after the update:
