what exactly did you do with your system?
so reboot and then run the commands
Just like you guys told me to. run the journalctl commands? Both of them?
yes both of them run, and post output here
only thing I see as a possible problem : kernel: e820 update [mem0x]
next line : kernel: e820 remove Mem0x]
then after 18 lines later (bios, Nx, efi, SMBIOS, DMI, tsc, tsc,) it repeats e820: update [mem 0x jujjjjjjjjjjjjjjjjjjjjjjjjjjjjjun
later it says e820: update [mem ox00000000-0x00000fff] usable ==>reserved
e820 remove [mem] 0x000a0000-0x000fffff] usable
still locked in journalctl
How can I send you the entire I’m in windows typing this.
haha … you just copy the output from the journal here… click this icon in editor: </> and copy the output there …
and what size is your journal:
journalctl --disk-usage
/ [[bobcapp@asusz97a-qonos-2126 ~]$ sudo pacman journalctl
[sudo] password for bobcapp:
error: no operation specified (use -h for help)
[bobcapp@asusz97a-qonos-2126 ~]$ journalctl
Jun 17 04:45:39 asusz97a-qonos-2126 kernel: microcode: microcode>
Jun 17 04:45:39 asusz97a-qonos-2126 kernel: Linux version 5.15.3>
Jun 17 04:45:39 asusz97a-qonos-2126 kernel: Command line: BOOT_I>
Jun 17 04:45:39 asusz97a-qonos-2126 kernel: x86/fpu: Supporting >
Jun 17 04:45:39 asusz97a-qonos-2126 kernel: x86/fpu: xstate_offs>
Jun 17 04:45:39 asusz97a-qonos-2126 kernel: x86/fpu: Enabled xst>
Jun 17 04:45:39 asusz97a-qonos-2126 kernel: signal: max sigframe>
Jun 17 04:45:39 asusz97a-qonos-2126 kernel: BIOS-provided physic>
Jun 17 04:45:39 asusz97a-qonos-2126 kernel: BIOS-e820: [mem 0x00>
Jun 17 04:45:39 asusz97a-qonos-2126 kernel: NX (Execute Disable)>
Jun 17 04:45:39 asusz97a-qonos-2126 kernel: efi: EFI v2.31 by Am>
Jun 17 04:45:39 asusz97a-qonos-2126 kernel: efi: ESRT=0xcef4c818>
Jun 17 04:45:39 asusz97a-qonos-2126 kernel: SMBIOS 2.8 present.
Jun 17 04:45:39 asusz97a-qonos-2126 kernel: DMI: ASUS All Series>
Jun 17 04:45:39 asusz97a-qonos-2126 kernel: tsc: Fast TSC calibr>
...skipping...
Jun 17 04:45:39 asusz97a-qonos-2126 kernel: tsc: Detected 3506.0>
Jun 17 04:45:39 asusz97a-qonos-2126 kernel: e820: update [mem 0x>
Jun 17 04:45:39 asusz97a-qonos-2126 kernel: e820: remove [mem 0x>
Jun 17 04:45:39 asusz97a-qonos-2126 kernel: e820: update [mem 0xJuJJJJJJJJJJJJJJJJJJJJJJJJJJJJJJJJun 17 JJuJJJuJJJJuJJJJJJJJJJJJJJJJJJJJJJJJJJJJJJJJJJJJJJJJun 17 04:45:39 asusz97a-qonos-2126 kernel: BIOS-e820: [mem 0x00000000cdc9a000-0x00000000ce1c2fff] ACPI NVS
Jun 17 04:45:39 asusz97a-qonos-2126 kernel: BIOS-e820: [mem 0x00000000ce1c3000-0x00000000cef4dfff] reserved
Jun 17 04:45:39 asusz97a-qonos-2126 kernel: BIOS-e820: [mem 0x00000000cef4e000-0x00000000ceffefff] type 20
Jun 17 04:45:39 asusz97a-qonos-2126 kernel: BIOS-e820: [mem 0x00000000cefff000-0x00000000ceffffff] usable
Jun 17 04:45:39 asusz97a-qonos-2126 kernel: BIOS-e820: [mem 0x00000000e0000000-0x00000000efffffff] reserved
Jun 17 04:45:39 asusz97a-qonos-2126 kernel: BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
Jun 17 04:45:39 asusz97a-qonos-2126 kernel: BIOS-e820: [mem 0x00000000fed00000-0x00000000fed03fff] reserved
Jun 17 04:45:39 asusz97a-qonos-2126 kernel: BIOS-e820: [mem 0x00000000fed1c000-0x00000000fed1ffff] reserved
Jun 17 04:45:39 asusz97a-qonos-2126 kernel: BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
Jun 17 04:45:39 asusz97a-qonos-2126 kernel: BIOS-e820: [mem 0x00000000ff000000-0x00000000ffffffff] reserved
Jun 17 04:45:39 asusz97a-qonos-2126 kernel: BIOS-e820: [mem 0x0000000100000000-0x000000062effffff] usable
Jun 17 04:45:39 asusz97a-qonos-2126 kernel: NX (Execute Disable) protection: active
Jun 17 04:45:39 asusz97a-qonos-2126 kernel: efi: EFI v2.31 by American Megatrends
Jun 17 04:45:39 asusz97a-qonos-2126 kernel: efi: ESRT=0xcef4c818 ACPI 2.0=0xcdc82000 ACPI=0xcdc82000 SMBIOS=0xf04d0
Jun 17 04:45:39 asusz97a-qonos-2126 kernel: DMI: ASUS All Series/Z97-A, BIOS 2205 02/12/2015
Jun 17 04:45:39 asusz97a-qonos-2126 kernel: tsc: Fast TSC calibration using PIT
Jun 17 04:45:39 asusz97a-qonos-2126 kernel: tsc: Detected 3506.018 MHz processor
Jun 17 04:45:39 asusz97a-qonos-2126 kernel: e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
Jun 17 04:45:39 asusz97a-qonos-2126 kernel: e820: remove [mem 0x000a0000-0x000fffff] usable
Jun 17 04:45:39 asusz97a-qonos-2126 kernel: last_pfn = 0x62f000 max_arch_pfn = 0x400000000
Jun 17 04:45:39 asusz97a-qonos-2126 kernel: x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
Jun 17 04:45:39 asusz97a-qonos-2126 kernel: total RAM covered: 24560M
Jun 17 04:45:39 asusz97a-qonos-2126 kernel: Found optimal setting for mtrr clean up
Jun 17 04:45:39 asusz97a-qonos-2126 kernel: gran_size: 64K chunk_size: 32M num_reg: 9 lose cover RAM: 0G
Jun 17 04:45:39 asusz97a-qonos-2126 kernel: e820: update [mem 0xd0000000-0xffffffff] usable ==> reserved
Jun 17 04:45:39 asusz97a-qonos-2126 kernel: last_pfn = 0xcf000 max_arch_pfn = 0x400000000
Jun 17 04:45:39 asusz97a-qonos-2126 kernel: found SMP MP-table at [mem 0x000fd900-0x000fd90f]
Jun 17 04:45:39 asusz97a-qonos-2126 kernel: esrt: Reserving ESRT space from 0x00000000cef4c818 to 0x00000000cef4c850.
Jun 17 04:45:39 asusz97a-qonos-2126 kernel: Using GB pages for direct mapping
Jun 17 04:45:39 asusz97a-qonos-2126 kernel: Secure boot disabled
Jun 17 04:45:39 asusz97a-qonos-2126 kernel: RAMDISK: [mem 0x3664b000-0x3731cfff]
Jun 17 04:45:39 asusz97a-qonos-2126 kernel: ACPI: Early table checksum verification disabled
Jun 17 04:45:39 asusz97a-qonos-2126 kernel: ACPI: RSDP 0x00000000CDC82000 000024 (v02 ALASKA)
Jun 17 04:45:39 asusz97a-qonos-2126 kernel: ACPI: XSDT 0x00000000CDC82088 000084 (v01 ALASKA A M I 01072009 AMI 00010013)
Jun 17 04:45:39 asusz97a-qonos-2126 kernel: ACPI: FACP 0x00000000CDC91DF8 00010C (v05 ALASKA A M I 01072009 AMI 00010013)
Jun 17 04:45:39 asusz97a-qonos-2126 kernel: ACPI: DSDT 0x00000000CDC821A0 00FC58 (v02 ALASKA A M I 00000011 INTL 20120711)
Jun 17 04:45:39 asusz97a-qonos-2126 kernel: ACPI: FACS 0x00000000CE1C2F80 000040
lines 22-59
...skipping...
lines 22-59
Is this what you want?
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
not exactly, run this command:
journalctl -b0 -p4 --no-pager
and copy output from this command here and use formatting like its shown in this picture:
How do I get to a prompt again . i’m up to over 5000 pages in this journalctl?
just close the terminal/konsole, open it again and run the command:
Got it just hit quit
ep 22 11:32:29 asusz97a-qonos-2126 plasmashell[907]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x564229338170) QQmlContext(0x5642273ef5d0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Sep 22 11:32:29 asusz97a-qonos-2126 plasmashell[907]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x564229338170) QQmlContext(0x5642273ef5d0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Sep 22 11:32:29 asusz97a-qonos-2126 plasmashell[907]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Sep 22 11:32:29 asusz97a-qonos-2126 plasmashell[907]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Sep 22 11:32:29 asusz97a-qonos-2126 plasmashell[907]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/SelectableLabel.qml:38:5: QML TextArea: Binding loop detected for property "implicitHeight"
Sep 22 11:32:29 asusz97a-qonos-2126 plasmashell[907]: file:///usr/lib/qt/qml/org/kde/plasma/components.3/ScrollView.qml:45:27: QML ScrollBar: Binding loop detected for property "visible"
Sep 22 11:32:29 asusz97a-qonos-2126 plasmashell[907]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x5642291b5bd0) QQmlContext(0x5642273ef5d0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Sep 22 11:32:30 asusz97a-qonos-2126 plasmashell[907]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Sep 22 11:32:31 asusz97a-qonos-2126 mount.exfat[1890]: unknown entry type 0xff
Sep 22 11:32:31 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/x'
Sep 22 11:32:31 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/xx'
Sep 22 11:32:31 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/xxx'
Sep 22 11:37:01 asusz97a-qonos-2126 kwin_x11[868]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 43841, resource id: 81788936, major code: 18 (ChangeProperty), minor code: 0
Sep 22 11:39:43 asusz97a-qonos-2126 kwin_x11[868]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 47192, resource id: 18874490, major code: 18 (ChangeProperty), minor code: 0
Sep 22 11:40:10 asusz97a-qonos-2126 plasmashell[907]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x564228c0aa90) QQmlContext(0x5642273ef5d0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Sep 22 11:40:10 asusz97a-qonos-2126 plasmashell[907]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Sep 22 11:40:10 asusz97a-qonos-2126 plasmashell[907]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Sep 22 11:40:10 asusz97a-qonos-2126 plasmashell[907]: file:///usr/lib/qt/qml/org/kde/plasma/components.3/ScrollView.qml:45:27: QML ScrollBar: Binding loop detected for property "visible"
Sep 22 11:40:10 asusz97a-qonos-2126 plasmashell[907]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/SelectableLabel.qml:38:5: QML TextArea: Binding loop detected for property "implicitHeight"
Sep 22 11:46:31 asusz97a-qonos-2126 plasmashell[907]: file:///usr/share/plasma/plasmoids/org.kde.plasma.devicenotifier/contents/ui/DeviceItem.qml:169:5: Unable to assign [undefined] to QString
Sep 22 11:46:31 asusz97a-qonos-2126 kernel: I/O error, dev sdf, sector 4095999996 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 0
Sep 22 11:46:31 asusz97a-qonos-2126 kernel: sd 7:0:0:0: [sdf] tag#0 access beyond end of device
Sep 22 11:46:31 asusz97a-qonos-2126 kernel: I/O error, dev sdf, sector 4095999992 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
Sep 22 11:46:31 asusz97a-qonos-2126 kernel: Buffer I/O error on dev sdf, logical block 511999999, async page read
Sep 22 11:46:31 asusz97a-qonos-2126 plasmashell[907]: file:///usr/lib/qt/qml/org/kde/plasma/extras/ExpandableListItem.qml:291: TypeError: Cannot read property 'enabled' of null
Is this it? I appreciate your patience.
yes thats it, but the beginning is cut off … but it doesnt look like there si the pcie/aer spam…
now run this command:
rchived and active journals take up 301.4M in the file system.
```Do you want all of the beginning?
300M is not that much - doesnt look that there is spam … yes post all the logs from the beginning from this command:
330)
Sep 22 10:52:41 asusz97a-qonos-2126 kernel: ACPI Error: Aborting method \_SB.PCI0.SAT0.SPT4._GTF due to previous error (AE_NOT_FOUND) (20211217/psparse-529)
Sep 22 10:52:41 asusz97a-qonos-2126 kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.SPT5._GTF.DSSP], AE_NOT_FOUND (20211217/psargs-330)
Sep 22 10:52:41 asusz97a-qonos-2126 kernel: ACPI Error: Aborting method \_SB.PCI0.SAT0.SPT5._GTF due to previous error (AE_NOT_FOUND) (20211217/psparse-529)
Sep 22 10:52:41 asusz97a-qonos-2126 kernel: ata2.00: NCQ Send/Recv Log not supported
Sep 22 10:52:41 asusz97a-qonos-2126 kernel: ata5.00: NCQ Send/Recv Log not supported
Sep 22 10:52:41 asusz97a-qonos-2126 kernel: ata6.00: NCQ Send/Recv Log not supported
Sep 22 10:52:41 asusz97a-qonos-2126 kernel: nvme nvme0: missing or invalid SUBNQN field.
Sep 22 10:52:41 asusz97a-qonos-2126 kernel: ACPI Warning: SystemIO range 0x0000000000001828-0x000000000000182F conflicts with OpRegion 0x0000000000001800-0x000000000000187F (\PMIO) (20211217/utaddress-204)
Sep 22 10:52:41 asusz97a-qonos-2126 kernel: ACPI Warning: SystemIO range 0x0000000000001C40-0x0000000000001C4F conflicts with OpRegion 0x0000000000001C00-0x0000000000001C7F (\_GPE.GPBX) (20211217/utaddress-204)
Sep 22 10:52:41 asusz97a-qonos-2126 kernel: ACPI Warning: SystemIO range 0x0000000000001C40-0x0000000000001C4F conflicts with OpRegion 0x0000000000001C00-0x0000000000001FFF (\GPR) (20211217/utaddress-204)
Sep 22 10:52:41 asusz97a-qonos-2126 kernel: ACPI Warning: SystemIO range 0x0000000000001C30-0x0000000000001C3F conflicts with OpRegion 0x0000000000001C00-0x0000000000001C7F (\_GPE.GPBX) (20211217/utaddress-204)
Sep 22 10:52:41 asusz97a-qonos-2126 kernel: ACPI Warning: SystemIO range 0x0000000000001C30-0x0000000000001C3F conflicts with OpRegion 0x0000000000001C00-0x0000000000001C3F (\GPRL) (20211217/utaddress-204)
Sep 22 10:52:41 asusz97a-qonos-2126 kernel: ACPI Warning: SystemIO range 0x0000000000001C30-0x0000000000001C3F conflicts with OpRegion 0x0000000000001C00-0x0000000000001FFF (\GPR) (20211217/utaddress-204)
Sep 22 10:52:41 asusz97a-qonos-2126 kernel: ACPI Warning: SystemIO range 0x0000000000001C00-0x0000000000001C2F conflicts with OpRegion 0x0000000000001C00-0x0000000000001C7F (\_GPE.GPBX) (20211217/utaddress-204)
Sep 22 10:52:41 asusz97a-qonos-2126 kernel: ACPI Warning: SystemIO range 0x0000000000001C00-0x0000000000001C2F conflicts with OpRegion 0x0000000000001C00-0x0000000000001C3F (\GPRL) (20211217/utaddress-204)
Sep 22 10:52:41 asusz97a-qonos-2126 kernel: ACPI Warning: SystemIO range 0x0000000000001C00-0x0000000000001C2F conflicts with OpRegion 0x0000000000001C00-0x0000000000001FFF (\GPR) (20211217/utaddress-204)
Sep 22 10:52:41 asusz97a-qonos-2126 kernel: lpc_ich: Resource conflict(s) found affecting gpio_ich
Sep 22 10:52:41 asusz97a-qonos-2126 kernel: at24 0-0051: supply vcc not found, using dummy regulator
Sep 22 10:52:41 asusz97a-qonos-2126 kernel: at24 0-0052: supply vcc not found, using dummy regulator
Sep 22 10:52:41 asusz97a-qonos-2126 kernel: at24 0-0053: supply vcc not found, using dummy regulator
Sep 22 10:52:41 asusz97a-qonos-2126 systemd-udevd[383]: event10: Failed to call EVIOCSKEYCODE with scan code 0x7c, and key code 190: Invalid argument
Sep 22 10:52:42 asusz97a-qonos-2126 kernel: nvidia: loading out-of-tree module taints kernel.
Sep 22 10:52:42 asusz97a-qonos-2126 kernel: nvidia: module license 'NVIDIA' taints kernel.
Sep 22 10:52:42 asusz97a-qonos-2126 kernel: Disabling lock debugging due to kernel taint
Sep 22 10:52:44 asusz97a-qonos-2126 kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 470.141.03 Thu Jun 30 18:45:31 UTC 2022
Sep 22 10:52:44 asusz97a-qonos-2126 kernel: nvidia_uvm: module uses symbols from proprietary module nvidia, inheriting taint.
Sep 22 10:52:44 asusz97a-qonos-2126 kernel: kauditd_printk_skb: 231 callbacks suppressed
Sep 22 10:52:44 asusz97a-qonos-2126 systemd[669]: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
Sep 22 10:52:45 asusz97a-qonos-2126 kernel: resource sanity check: requesting [mem 0x000c0000-0x000fffff], which spans more than PCI Bus 0000:00 [mem 0x000d0000-0x000dffff window]
Sep 22 10:52:45 asusz97a-qonos-2126 kernel: caller _nv000720rm+0x1ad/0x200 [nvidia] mapping multiple BARs
Sep 22 10:52:46 asusz97a-qonos-2126 sddm-helper[797]: gkr-pam: no password is available for user
Sep 22 10:52:46 asusz97a-qonos-2126 sddm-helper[797]: pam_limits(sddm-autologin:session): invalid line 'End of file' - skipped
Sep 22 10:52:46 asusz97a-qonos-2126 systemd[799]: pam_limits(systemd-user:session): invalid line 'End of file' - skipped
Sep 22 10:52:46 asusz97a-qonos-2126 sddm-helper[797]: gkr-pam: couldn't unlock the login keyring.
Sep 22 10:52:47 asusz97a-qonos-2126 ksplashqml[834]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath.desktop/contents/splash/Splash.qml:49: ReferenceError: maxWidth is not defined
Sep 22 10:52:47 asusz97a-qonos-2126 ksplashqml[834]: file:///usr/share/plasma/look-and-feel/org.manjaro.breath.desktop/contents/splash/Splash.qml:81:29: Unable to assign int to QEasingCurve
Sep 22 10:52:47 asusz97a-qonos-2126 ksmserver[865]: Qt: Session management error: networkIdsList argument is NULL
Sep 22 10:52:47 asusz97a-qonos-2126 baloo_file[847]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.21'
Sep 22 10:52:47 asusz97a-qonos-2126 ksmserver[865]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.13'
Sep 22 10:52:47 asusz97a-qonos-2126 kwin_x11[868]: kwin_xkbcommon: XKB: inet:323:58: unrecognized keysym "XF86EmojiPicker"
Sep 22 10:52:47 asusz97a-qonos-2126 kwin_x11[868]: kwin_xkbcommon: XKB: inet:324:58: unrecognized keysym "XF86Dictate"
Sep 22 10:52:47 asusz97a-qonos-2126 plasmashell[907]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
Sep 22 10:52:47 asusz97a-qonos-2126 plasmashell[907]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
Sep 22 10:52:47 asusz97a-qonos-2126 kwin_x11[868]: kwin_platform_x11_standalone: Compositing disabled: video driver seems unstable. If you think it's a false positive, please remove "OpenGLIsUnsafe" from [Compositing] in kwinrc and restart kwin.
Sep 22 10:52:47 asusz97a-qonos-2126 kwin_x11[868]: kwin_core: Compositing is not possible
Sep 22 10:52:47 asusz97a-qonos-2126 backlighthelper[976]: org.kde.powerdevil: no kernel backlight interface found
Sep 22 10:52:47 asusz97a-qonos-2126 kded5[867]: kscreen.kded: PowerDevil SuspendSession action not available!
Sep 22 10:52:47 asusz97a-qonos-2126 org_kde_powerdevil[927]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds not supported"
Sep 22 10:52:47 asusz97a-qonos-2126 org_kde_powerdevil[927]: org.kde.powerdevil: org.kde.powerdevil.backlighthelper.brightness failed
Sep 22 10:52:47 asusz97a-qonos-2126 org_kde_powerdevil[927]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Sep 22 10:52:47 asusz97a-qonos-2126 org_kde_powerdevil[927]: org.kde.powerdevil: The profile "AC" tried to activate "DimDisplay" a non-existent action. This is usually due to an installation problem, a configuration problem, or because the action is not supported
Sep 22 10:52:48 asusz97a-qonos-2126 org_kde_powerdevil[927]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds not supported"
Sep 22 10:52:48 asusz97a-qonos-2126 plasmashell[907]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:70:5: QML Connections: Detected function "onConfigurationChanged" in Connections element. This is probably intended to be a signal handler but no signal of the target matches the name.
Sep 22 10:52:48 asusz97a-qonos-2126 plasmashell[907]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:70:5: QML Connections: Detected function "onRepaintNeeded" in Connections element. This is probably intended to be a signal handler but no signal of the target matches the name.
Sep 22 10:52:48 asusz97a-qonos-2126 plasmashell[907]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:67: TypeError: Cannot read property 'wallpaper' of null
Sep 22 10:52:48 asusz97a-qonos-2126 plasmashell[907]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:71: TypeError: Cannot read property 'wallpaper' of null
Sep 22 10:52:48 asusz97a-qonos-2126 kalendarac[1027]: Attribute Qt::AA_EnableHighDpiScaling must be set before QCoreApplication is created.
Sep 22 10:52:48 asusz97a-qonos-2126 kalendarac[1027]: org.kde.pim.akonadicore: Unable to execute akonadi_control, falling back to D-Bus auto-launch
Sep 22 10:52:48 asusz97a-qonos-2126 plasmashell[907]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
Sep 22 10:52:48 asusz97a-qonos-2126 pipewire[1137]: mod.rt: Can't find xdg-portal: (null)
Sep 22 10:52:48 asusz97a-qonos-2126 pipewire[1137]: mod.rt: found session bus but no portal
Sep 22 10:52:48 asusz97a-qonos-2126 pipewire-media-session[1138]: mod.rt: Can't find xdg-portal: (null)
Sep 22 10:52:48 asusz97a-qonos-2126 pipewire-media-session[1138]: mod.rt: found session bus but no portal
Sep 22 10:52:48 asusz97a-qonos-2126 pipewire-media-session[1138]: mod.rt: RTKit error: org.freedesktop.DBus.Error.AccessDenied
Sep 22 10:52:48 asusz97a-qonos-2126 pipewire-media-session[1138]: mod.rt: could not make thread 1142 realtime using RTKit: Permission denied
Sep 22 10:52:48 asusz97a-qonos-2126 pipewire[1137]: mod.rt: RTKit error: org.freedesktop.DBus.Error.AccessDenied
Sep 22 10:52:48 asusz97a-qonos-2126 pipewire[1137]: mod.rt: could not make thread 1154 realtime using RTKit: Permission denied
Sep 22 10:52:48 asusz97a-qonos-2126 plasmashell[907]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Panel.qml:179: TypeError: Cannot read property 'containmentDisplayHints' of null
Sep 22 10:52:48 asusz97a-qonos-2126 plasmashell[907]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Panel.qml:271: TypeError: Cannot read property 'location' of null
Sep 22 10:52:48 asusz97a-qonos-2126 plasmashell[907]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:532:9: QML Label: Binding loop detected for property "height"
Sep 22 10:52:48 asusz97a-qonos-2126 plasmashell[907]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:497:13: QML Label: Binding loop detected for property "height"
Sep 22 10:52:48 asusz97a-qonos-2126 bluetoothd[669]: src/adv_monitor.c:btd_adv_monitor_power_down() Unexpected NULL btd_adv_monitor_manager object upon power down
Sep 22 10:52:48 asusz97a-qonos-2126 plasmashell[907]: Trying to use rootObject before initialization is completed, whilst using setInitializationDelayed. Forcing completion
Sep 22 10:52:48 asusz97a-qonos-2126 plasmashell[907]: org.kde.plasma.kicker: Entry is not valid "org.kde.kontact.desktop" QSharedPointer(0x564226d15860)
Sep 22 10:52:48 asusz97a-qonos-2126 plasmashell[907]: org.kde.plasma.kicker: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x564226f1e6d0)
Sep 22 10:52:48 asusz97a-qonos-2126 plasmashell[907]: org.kde.plasma.kicker: Entry is not valid "org.kde.discover.desktop" QSharedPointer(0x564226d158b0)
Sep 22 10:52:48 asusz97a-qonos-2126 plasmashell[907]: org.kde.plasma.kicker: Entry is not valid "org.kde.kontact.desktop" QSharedPointer(0x564226f14800)
Sep 22 10:52:48 asusz97a-qonos-2126 plasmashell[907]: org.kde.plasma.kicker: Entry is not valid "ktp-contactlist.desktop" QSharedPointer(0x564226f1e430)
Sep 22 10:52:48 asusz97a-qonos-2126 plasmashell[907]: org.kde.plasma.kicker: Entry is not valid "org.kde.discover.desktop" QSharedPointer(0x564226e1a640)
Sep 22 10:52:49 asusz97a-qonos-2126 plasmashell[907]: file:///usr/share/plasma/plasmoids/org.kde.panel/contents/ui/ConfigOverlay.qml:312:17: QML SpinBox: Binding loop detected for property "implicitWidth"
Sep 22 10:52:49 asusz97a-qonos-2126 plasmashell[907]: file:///usr/share/plasma/plasmoids/org.kde.panel/contents/ui/ConfigOverlay.qml:304:17: QML Heading: Binding loop detected for property "verticalAlignment"
Sep 22 10:52:49 asusz97a-qonos-2126 plasmashell[907]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:497:13: QML Label: Binding loop detected for property "height"
Sep 22 10:52:49 asusz97a-qonos-2126 plasmashell[907]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:532:9: QML Label: Binding loop detected for property "height"
Sep 22 10:52:49 asusz97a-qonos-2126 plasmashell[907]: file:///usr/share/plasma/plasmoids/org.kde.plasma.digitalclock/contents/ui/DigitalClock.qml:554:5: QML Label: Binding loop detected for property "height"
Sep 22 10:52:49 asusz97a-qonos-2126 plasmashell[907]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/ThumbnailStrip.qml"
Sep 22 10:52:49 asusz97a-qonos-2126 plasmashell[907]: Cyclic dependency detected between "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml" and "file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationHeader.qml"
Sep 22 10:52:49 asusz97a-qonos-2126 plasmashell[907]: file:///usr/share/plasma/plasmoids/org.kde.plasma.volume/contents/ui/main.qml:603:39: Invalid property assignment: string expected - Assigning null to incompatible properties in QML is deprecated. This will become a compile error in future versions of Qt.
Sep 22 10:52:49 asusz97a-qonos-2126 plasmashell[907]: file:///usr/share/plasma/plasmoids/org.kde.plasma.private.systemtray/contents/ui/ExpandedRepresentation.qml:167:9: QML HiddenItemsView: Binding loop detected for property "implicitHeight"
Sep 22 10:52:49 asusz97a-qonos-2126 kwin_x11[868]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1315, resource id: 4194330, major code: 18 (ChangeProperty), minor code: 0
Sep 22 10:52:49 asusz97a-qonos-2126 plasmashell[907]: QFont::setPointSizeF: Point size <= 0 (0.000000), must be greater than 0
Sep 22 10:52:49 asusz97a-qonos-2126 plasmashell[907]: file:///usr/share/plasma/plasmoids/org.kde.plasma.battery/contents/ui/CompactRepresentation.qml:50:17: Unable to assign [undefined] to int
Sep 22 10:52:49 asusz97a-qonos-2126 avahi-daemon[668]: Host name conflict, retrying with asusz97a-qonos-2127
Sep 22 10:52:49 asusz97a-qonos-2126 pulseaudio[1210]: stat('/etc/pulse/default.pa.d'): No such file or directory
Sep 22 10:52:49 asusz97a-qonos-2126 plasmashell[907]: org.kde.plasma.pulseaudio: No object for name "alsa_output.pci-0000_00_1b.0.analog-stereo.monitor"
Sep 22 10:52:50 asusz97a-qonos-2126 plasmashell[907]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Sep 22 10:52:51 asusz97a-qonos-2126 plasmashell[907]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Sep 22 10:52:52 asusz97a-qonos-2126 plasmashell[907]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Sep 22 10:52:52 asusz97a-qonos-2126 plasmashell[907]: Qt Quick Layouts: Detected recursive rearrange. Aborting after two iterations.
Sep 22 10:52:52 asusz97a-qonos-2126 plasmashell[907]: file:///usr/share/plasma/plasmoids/org.kde.plasma.bluetooth/contents/ui/DeviceItem.qml:33:32: QML Action: Accessible must be attached to an Item
Sep 22 10:52:53 asusz97a-qonos-2126 plasmashell[907]: file:///usr/lib/qt/qml/org/kde/plasma/extras/PlaceholderMessage.qml:238:5: QML Heading: Binding loop detected for property "verticalAlignment"
Sep 22 10:52:53 asusz97a-qonos-2126 plasmashell[907]: file:///usr/share/plasma/plasmoids/org.kde.plasma.devicenotifier/contents/ui/DeviceItem.qml:206:32: QML Action: Accessible must be attached to an Item
Sep 22 10:52:54 asusz97a-qonos-2126 kernel: kauditd_printk_skb: 38 callbacks suppressed
Sep 22 10:53:01 asusz97a-qonos-2126 plasmashell[907]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 1356, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
Sep 22 10:53:01 asusz97a-qonos-2126 plasmashell[907]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1357, resource id: 27263040, major code: 55 (CreateGC), minor code: 0
Sep 22 10:53:01 asusz97a-qonos-2126 plasmashell[907]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1358, resource id: 27263040, major code: 72 (PutImage), minor code: 0
Sep 22 10:53:01 asusz97a-qonos-2126 plasmashell[907]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 1359, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
Sep 22 10:53:01 asusz97a-qonos-2126 plasmashell[907]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1360, resource id: 27263042, major code: 55 (CreateGC), minor code: 0
Sep 22 10:53:01 asusz97a-qonos-2126 plasmashell[907]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1361, resource id: 27263042, major code: 72 (PutImage), minor code: 0
Sep 22 10:53:01 asusz97a-qonos-2126 plasmashell[907]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 1362, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
Sep 22 10:53:01 asusz97a-qonos-2126 plasmashell[907]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1363, resource id: 27263044, major code: 55 (CreateGC), minor code: 0
Sep 22 10:53:01 asusz97a-qonos-2126 plasmashell[907]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1364, resource id: 27263044, major code: 72 (PutImage), minor code: 0
Sep 22 10:53:01 asusz97a-qonos-2126 plasmashell[907]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 1365, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
Sep 22 10:53:01 asusz97a-qonos-2126 plasmashell[907]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1366, resource id: 27263046, major code: 55 (CreateGC), minor code: 0
Sep 22 10:53:01 asusz97a-qonos-2126 plasmashell[907]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1367, resource id: 27263046, major code: 72 (PutImage), minor code: 0
Sep 22 10:53:01 asusz97a-qonos-2126 plasmashell[907]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 1368, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
Sep 22 10:53:01 asusz97a-qonos-2126 plasmashell[907]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1369, resource id: 27263048, major code: 55 (CreateGC), minor code: 0
Sep 22 10:53:01 asusz97a-qonos-2126 plasmashell[907]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1370, resource id: 27263048, major code: 72 (PutImage), minor code: 0
Sep 22 10:53:01 asusz97a-qonos-2126 plasmashell[907]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 1371, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
Sep 22 10:53:01 asusz97a-qonos-2126 plasmashell[907]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1372, resource id: 27263050, major code: 55 (CreateGC), minor code: 0
Sep 22 10:53:01 asusz97a-qonos-2126 plasmashell[907]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1373, resource id: 27263050, major code: 72 (PutImage), minor code: 0
Sep 22 10:53:01 asusz97a-qonos-2126 plasmashell[907]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 1374, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
Sep 22 10:53:01 asusz97a-qonos-2126 plasmashell[907]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1375, resource id: 27263052, major code: 55 (CreateGC), minor code: 0
Sep 22 10:53:01 asusz97a-qonos-2126 plasmashell[907]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1376, resource id: 27263052, major code: 72 (PutImage), minor code: 0
Sep 22 10:53:01 asusz97a-qonos-2126 plasmashell[907]: qt.qpa.xcb: QXcbConnection: XCB error: 2 (BadValue), sequence: 1377, resource id: 0, major code: 53 (CreatePixmap), minor code: 0
Sep 22 10:53:01 asusz97a-qonos-2126 plasmashell[907]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1378, resource id: 27263054, major code: 55 (CreateGC), minor code: 0
Sep 22 10:53:01 asusz97a-qonos-2126 plasmashell[907]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 1379, resource id: 27263054, major code: 72 (PutImage), minor code: 0
Sep 22 10:53:02 asusz97a-qonos-2126 plasmashell[907]: kf.service.services: The desktop entry file "/usr/share/applications/kcm_krunnersettings.desktop" has Type= "Application" but no Exec line
Sep 22 10:53:02 asusz97a-qonos-2126 plasmashell[907]: kf.service.sycoca: Invalid Service : "/usr/share/applications/kcm_krunnersettings.desktop"
Sep 22 10:53:30 asusz97a-qonos-2126 sudo[1298]: pam_limits(sudo:session): invalid line 'End of file' - skipped
Sep 22 10:55:45 asusz97a-qonos-2126 konsole[1275]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 3437, resource id: 18874442, major code: 40 (TranslateCoords), minor code: 0
Sep 22 10:56:49 asusz97a-qonos-2126 plasmashell[907]: trying to show an empty dialog
Sep 22 11:10:03 asusz97a-qonos-2126 kscreenlocker_greet[1355]: Qt: Session management error: networkIdsList argument is NULL
Sep 22 11:10:03 asusz97a-qonos-2126 kscreenlocker_greet[1355]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/lockscreen/LockScreenUi.qml:599: TypeError: Cannot read property 'longName' of undefined
Sep 22 11:10:03 asusz97a-qonos-2126 kscreenlocker_greet[1355]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/UserList.qml:43:9: Unable to assign [undefined] to bool
Sep 22 11:10:04 asusz97a-qonos-2126 kscreenlocker_greet[1355]: qt.virtualkeyboard.hunspell: Hunspell dictionary is missing for "en_US" . Search paths ("/usr/share/qt/qtvirtualkeyboard/hunspell", "/usr/share/hunspell", "/usr/share/myspell/dicts")
Sep 22 11:10:14 asusz97a-qonos-2126 kwin_x11[868]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 15310, resource id: 62914587, major code: 18 (ChangeProperty), minor code: 0
Sep 22 11:21:38 asusz97a-qonos-2126 kscreenlocker_greet[1388]: Qt: Session management error: networkIdsList argument is NULL
Sep 22 11:21:38 asusz97a-qonos-2126 kscreenlocker_greet[1388]: file:///usr/share/plasma/look-and-feel/org.kde.breeze.desktop/contents/components/UserList.qml:43:9: Unable to assign [undefined] to bool
Sep 22 11:21:39 asusz97a-qonos-2126 kscreenlocker_greet[1388]: qt.virtualkeyboard.hunspell: Hunspell dictionary is missing for "en_US" . Search paths ("/usr/share/qt/qtvirtualkeyboard/hunspell", "/usr/share/hunspell", "/usr/share/myspell/dicts")
Sep 22 11:22:18 asusz97a-qonos-2126 kwin_x11[868]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 16224, resource id: 62914591, major code: 18 (ChangeProperty), minor code: 0
Sep 22 11:30:37 asusz97a-qonos-2126 kernel: sd 7:0:0:0: [sdf] No Caching mode page found
Sep 22 11:30:37 asusz97a-qonos-2126 kernel: sd 7:0:0:0: [sdf] Assuming drive cache: write through
Sep 22 11:30:37 asusz97a-qonos-2126 plasmashell[907]: file:///usr/share/plasma/plasmoids/org.kde.plasma.devicenotifier/contents/ui/DeviceItem.qml:206:32: QML Action: Accessible must be attached to an Item
Sep 22 11:30:52 asusz97a-qonos-2126 mount.exfat[1889]: volume was not unmounted cleanly
Sep 22 11:30:52 asusz97a-qonos-2126 kde-open5[1896]: kf.service.services: KApplicationTrader: mimeType "x-scheme-handler/file" not found
Sep 22 11:30:52 asusz97a-qonos-2126 kwin_x11[868]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 30515, resource id: 77594629, major code: 18 (ChangeProperty), minor code: 0
Sep 22 11:30:52 asusz97a-qonos-2126 kwin_x11[868]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 30523, resource id: 77594631, major code: 18 (ChangeProperty), minor code: 0
Sep 22 11:30:53 asusz97a-qonos-2126 dolphin[1900]: kf.kio.core: "The file or folder /run/media/bobcapp/098fb215-2d89-41ee-8c63-ac3ef6d783a2/My Music/Al De Meola does not exist."
Sep 22 11:30:53 asusz97a-qonos-2126 dolphin[1900]: kf.kio.core: "The file or folder /run/media/bobcapp/098fb215-2d89-41ee-8c63-ac3ef6d783a2 does not exist."
Sep 22 11:30:53 asusz97a-qonos-2126 mount.exfat[1890]: unknown entry type 0xff
Sep 22 11:30:54 asusz97a-qonos-2126 mount.exfat[1890]: unknown entry type 0xff
Sep 22 11:30:54 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Best of Bowie'
Sep 22 11:30:55 asusz97a-qonos-2126 mount.exfat[1890]: unknown entry type 0xff
Sep 22 11:30:55 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Breathless'
Sep 22 11:30:55 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Crown Of Creation'
Sep 22 11:30:55 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Cunning Stunts'
Sep 22 11:30:55 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Deep Purple - 1972 Machine Head (25th Anniversary Edition) - CD2 (Remastered)'
Sep 22 11:30:55 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Diver Down (Remastered)'
Sep 22 11:30:55 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Best of Bowie'
Sep 22 11:30:55 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Fair Warning (Remastered)'
Sep 22 11:30:56 asusz97a-qonos-2126 mount.exfat[1890]: unknown entry type 0xff
Sep 22 11:30:56 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Best of Bowie'
Sep 22 11:31:05 asusz97a-qonos-2126 kwin_x11[868]: kwin_core: XCB error: 3 (BadWindow), sequence: 31323, resource id: 77594642, major code: 129 (SHAPE), minor code: 6 (Input)
Sep 22 11:31:05 asusz97a-qonos-2126 kwin_x11[868]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 31324, resource id: 77594642, major code: 2 (ChangeWindowAttributes), minor code: 0
Sep 22 11:31:36 asusz97a-qonos-2126 mount.exfat[1890]: unknown entry type 0xff
Sep 22 11:31:36 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Best of Bowie'
Sep 22 11:31:36 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Breathless'
Sep 22 11:31:36 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Crown Of Creation'
Sep 22 11:31:36 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Cunning Stunts'
Sep 22 11:31:36 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Deep Purple - 1972 Machine Head (25th Anniversary Edition) - CD2 (Remastered)'
Sep 22 11:31:36 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Diver Down (Remastered)'
Sep 22 11:31:36 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Fair Warning (Remastered)'
Sep 22 11:31:38 asusz97a-qonos-2126 mount.exfat[1890]: unknown entry type 0xff
Sep 22 11:31:38 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/I Can See Your House from Here'
Sep 22 11:31:38 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/In The Land Of Grey And Pink'
Sep 22 11:31:38 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Live At The Fillmore East'
Sep 22 11:31:38 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Machine Head'
Sep 22 11:31:38 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Mirage'
Sep 22 11:31:39 asusz97a-qonos-2126 mount.exfat[1890]: unknown entry type 0xff
Sep 22 11:31:39 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Phoenix_ Special Edition'
Sep 22 11:31:44 asusz97a-qonos-2126 mount.exfat[1890]: unknown entry type 0xff
Sep 22 11:31:44 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Best of Bowie'
Sep 22 11:31:44 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Breathless'
Sep 22 11:31:44 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Crown Of Creation'
Sep 22 11:31:44 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Cunning Stunts'
Sep 22 11:31:44 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Deep Purple - 1972 Machine Head (25th Anniversary Edition) - CD2 (Remastered)'
Sep 22 11:31:44 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Diver Down (Remastered)'
Sep 22 11:31:44 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Fair Warning (Remastered)'
Sep 22 11:31:44 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/I Can See Your House from Here'
Sep 22 11:31:44 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/In The Land Of Grey And Pink'
Sep 22 11:31:44 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Live At The Fillmore East'
Sep 22 11:31:44 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Machine Head'
Sep 22 11:31:44 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Mirage'
Sep 22 11:31:44 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Phoenix_ Special Edition'
Sep 22 11:31:46 asusz97a-qonos-2126 mount.exfat[1890]: unknown entry type 0xff
Sep 22 11:31:46 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Station to Station (2016 Remaster)'
Sep 22 11:31:46 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Surrealistic Pillow'
Sep 22 11:31:49 asusz97a-qonos-2126 mount.exfat[1890]: unknown entry type 0xff
Sep 22 11:31:49 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Best of Bowie'
Sep 22 11:31:49 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Breathless'
Sep 22 11:31:49 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Crown Of Creation'
Sep 22 11:31:49 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Cunning Stunts'
Sep 22 11:31:49 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Deep Purple - 1972 Machine Head (25th Anniversary Edition) - CD2 (Remastered)'
Sep 22 11:31:49 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Diver Down (Remastered)'
Sep 22 11:31:49 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Fair Warning (Remastered)'
Sep 22 11:31:49 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/I Can See Your House from Here'
Sep 22 11:31:49 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/In The Land Of Grey And Pink'
Sep 22 11:31:49 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Live At The Fillmore East'
Sep 22 11:31:49 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Machine Head'
Sep 22 11:31:49 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Mirage'
Sep 22 11:31:49 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Phoenix_ Special Edition'
Sep 22 11:31:49 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Station to Station (2016 Remaster)'
Sep 22 11:31:49 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Surrealistic Pillow'
Sep 22 11:31:50 asusz97a-qonos-2126 mount.exfat[1890]: unknown entry type 0xff
Sep 22 11:31:50 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/The Snow Goose'
Sep 22 11:31:51 asusz97a-qonos-2126 mount.exfat[1890]: unknown entry type 0xff
Sep 22 11:31:51 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Van Halen Live_ Right Here, Right Now'
Sep 22 11:31:51 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Volunteers'
Sep 22 11:31:51 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Who Do We Think We Are'
Sep 22 11:31:55 asusz97a-qonos-2126 mount.exfat[1890]: unknown entry type 0xff
Sep 22 11:31:55 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Best of Bowie'
Sep 22 11:31:55 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Breathless'
Sep 22 11:31:56 asusz97a-qonos-2126 mount.exfat[1890]: unknown entry type 0xff
Sep 22 11:31:56 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Crown Of Creation'
Sep 22 11:31:56 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Cunning Stunts'
Sep 22 11:31:56 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Deep Purple - 1972 Machine Head (25th Anniversary Edition) - CD2 (Remastered)'
Sep 22 11:31:56 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Diver Down (Remastered)'
Sep 22 11:31:56 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Fair Warning (Remastered)'
Sep 22 11:31:56 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/I Can See Your House from Here'
Sep 22 11:31:56 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/In The Land Of Grey And Pink'
Sep 22 11:31:56 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Live At The Fillmore East'
Sep 22 11:31:56 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Machine Head'
Sep 22 11:31:56 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Mirage'
Sep 22 11:31:57 asusz97a-qonos-2126 mount.exfat[1890]: unknown entry type 0xff
Sep 22 11:31:57 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Phoenix_ Special Edition'
Sep 22 11:31:57 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Station to Station (2016 Remaster)'
Sep 22 11:31:57 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Surrealistic Pillow'
Sep 22 11:31:57 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/The Snow Goose'
Sep 22 11:31:57 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Van Halen Live_ Right Here, Right Now'
Sep 22 11:31:57 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Volunteers'
Sep 22 11:31:57 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Who Do We Think We Are'
Sep 22 11:32:01 asusz97a-qonos-2126 mount.exfat[1890]: unknown entry type 0xff
Sep 22 11:32:01 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Best of Bowie'
Sep 22 11:32:01 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Breathless'
Sep 22 11:32:01 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Crown Of Creation'
Sep 22 11:32:01 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Cunning Stunts'
Sep 22 11:32:02 asusz97a-qonos-2126 mount.exfat[1890]: unknown entry type 0xff
Sep 22 11:32:02 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Deep Purple - 1972 Machine Head (25th Anniversary Edition) - CD2 (Remastered)'
Sep 22 11:32:02 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Diver Down (Remastered)'
Sep 22 11:32:02 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Fair Warning (Remastered)'
Sep 22 11:32:02 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/I Can See Your House from Here'
Sep 22 11:32:02 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/In The Land Of Grey And Pink'
Sep 22 11:32:02 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Live At The Fillmore East'
Sep 22 11:32:02 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Machine Head'
Sep 22 11:32:02 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Mirage'
Sep 22 11:32:02 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Phoenix_ Special Edition'
Sep 22 11:32:02 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Station to Station (2016 Remaster)'
Sep 22 11:32:02 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Surrealistic Pillow'
Sep 22 11:32:02 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/The Snow Goose'
Sep 22 11:32:02 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Van Halen Live_ Right Here, Right Now'
Sep 22 11:32:02 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Volunteers'
Sep 22 11:32:02 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Who Do We Think We Are'
Sep 22 11:32:05 asusz97a-qonos-2126 mount.exfat[1890]: unknown entry type 0xff
Sep 22 11:32:05 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Best of Bowie'
Sep 22 11:32:05 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Breathless'
Sep 22 11:32:06 asusz97a-qonos-2126 mount.exfat[1890]: unknown entry type 0xff
Sep 22 11:32:06 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Crown Of Creation'
Sep 22 11:32:06 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Cunning Stunts'
Sep 22 11:32:06 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Deep Purple - 1972 Machine Head (25th Anniversary Edition) - CD2 (Remastered)'
Sep 22 11:32:06 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Diver Down (Remastered)'
Sep 22 11:32:06 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Fair Warning (Remastered)'
Sep 22 11:32:07 asusz97a-qonos-2126 mount.exfat[1890]: unknown entry type 0xff
Sep 22 11:32:07 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/I Can See Your House from Here'
Sep 22 11:32:07 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/In The Land Of Grey And Pink'
Sep 22 11:32:07 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Live At The Fillmore East'
Sep 22 11:32:07 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Machine Head'
Sep 22 11:32:07 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Mirage'
Sep 22 11:32:07 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Phoenix_ Special Edition'
Sep 22 11:32:08 asusz97a-qonos-2126 mount.exfat[1890]: unknown entry type 0xff
Sep 22 11:32:08 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Station to Station (2016 Remaster)'
Sep 22 11:32:08 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Surrealistic Pillow'
Sep 22 11:32:08 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/The Snow Goose'
Sep 22 11:32:08 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Van Halen Live_ Right Here, Right Now'
Sep 22 11:32:08 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Volunteers'
Sep 22 11:32:08 asusz97a-qonos-2126 mount.exfat[1890]: failed to open directory '/Who Do We Think We Are'
Sep 22 11:51:51 asusz97a-qonos-2126 plasmashell[907]: QQmlEngine::setContextForObject(): Object already has a QQmlContext
Sep 22 11:51:51 asusz97a-qonos-2126 plasmashell[907]: file:///usr/lib/qt/qml/org/kde/kirigami.2/FormLayout.qml:288:9: QML QQuickItem* (parent or ancestor of QQuickLayoutAttached): Binding loop detected for property "preferredWidth"
Sep 22 11:51:51 asusz97a-qonos-2126 plasmashell[907]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/configuration/ConfigurationAppletPage.qml:38:5: QML Loader: Binding loop detected for property "height"
Sep 22 11:51:59 asusz97a-qonos-2126 plasmashell[907]: file:///usr/lib/qt/qml/org/kde/kirigami.2/PlaceholderMessage.qml:235:5: QML Heading: Binding loop detected for property "verticalAlignment"
Sep 22 11:51:59 asusz97a-qonos-2126 plasmashell[907]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/configuration/ConfigurationAppletPage.qml:38:5: QML Loader: Binding loop detected for property "height"
Sep 22 11:51:59 asusz97a-qonos-2126 plasmashell[907]: file:///usr/lib/qt/qml/org/kde/kirigami.2/private/globaltoolbar/BreadcrumbControl.qml:17:5: Unable to assign [undefined] to QQuickItem*
Sep 22 11:51:59 asusz97a-qonos-2126 plasmashell[907]: file:///usr/lib/qt/qml/org/kde/kirigami.2/ScrollablePage.qml:189:9: QML MouseArea: Binding loop detected for property "width"
Sep 22 11:52:05 asusz97a-qonos-2126 plasmashell[907]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x564227d1c0b0) QQmlContext(0x5642273ef5d0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Sep 22 11:52:05 asusz97a-qonos-2126 plasmashell[907]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Sep 22 11:52:05 asusz97a-qonos-2126 plasmashell[907]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Sep 22 11:52:05 asusz97a-qonos-2126 plasmashell[907]: file:///usr/lib/qt/qml/org/kde/plasma/components.3/ScrollView.qml:45:27: QML ScrollBar: Binding loop detected for property "visible"
Sep 22 11:52:05 asusz97a-qonos-2126 plasmashell[907]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/SelectableLabel.qml:38:5: QML TextArea: Binding loop detected for property "implicitHeight"
Sep 22 11:52:10 asusz97a-qonos-2126 kwin_x11[868]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 65308, resource id: 27263452, major code: 19 (DeleteProperty), minor code: 0
Sep 22 11:52:10 asusz97a-qonos-2126 kwin_x11[868]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 65310, resource id: 27263452, major code: 19 (DeleteProperty), minor code: 0
Sep 22 11:52:10 asusz97a-qonos-2126 kwin_x11[868]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 65311, resource id: 27263452, major code: 18 (ChangeProperty), minor code: 0
Sep 22 11:52:10 asusz97a-qonos-2126 kwin_x11[868]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 65312, resource id: 27263452, major code: 19 (DeleteProperty), minor code: 0
Sep 22 11:52:10 asusz97a-qonos-2126 kwin_x11[868]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 65313, resource id: 27263452, major code: 19 (DeleteProperty), minor code: 0
Sep 22 11:52:10 asusz97a-qonos-2126 kwin_x11[868]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 65314, resource id: 27263452, major code: 19 (DeleteProperty), minor code: 0
Sep 22 11:52:10 asusz97a-qonos-2126 kwin_x11[868]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 65315, resource id: 27263452, major code: 7 (ReparentWindow), minor code: 0
Sep 22 11:52:10 asusz97a-qonos-2126 kwin_x11[868]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 65316, resource id: 27263452, major code: 6 (ChangeSaveSet), minor code: 0
Sep 22 11:52:10 asusz97a-qonos-2126 kwin_x11[868]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 65317, resource id: 27263452, major code: 2 (ChangeWindowAttributes), minor code: 0
Sep 22 11:52:10 asusz97a-qonos-2126 kwin_x11[868]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 65318, resource id: 27263452, major code: 10 (UnmapWindow), minor code: 0
Sep 22 11:56:34 asusz97a-qonos-2126 plasmashell[907]: Could not find the Plasmoid for Plasma::FrameSvgItem(0x564226c3fdd0) QQmlContext(0x5642273ef5d0) QUrl("file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/global/Globals.qml")
Sep 22 11:56:34 asusz97a-qonos-2126 plasmashell[907]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Sep 22 11:56:34 asusz97a-qonos-2126 plasmashell[907]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/NotificationItem.qml:220:21: QML SelectableLabel: Binding loop detected for property "implicitHeight"
Sep 22 11:56:34 asusz97a-qonos-2126 plasmashell[907]: file:///usr/lib/qt/qml/org/kde/plasma/components.3/ScrollView.qml:45:27: QML ScrollBar: Binding loop detected for property "visible"
Sep 22 11:56:34 asusz97a-qonos-2126 plasmashell[907]: file:///usr/share/plasma/plasmoids/org.kde.plasma.notifications/contents/ui/SelectableLabel.qml:38:5: QML TextArea: Binding loop detected for property "implicitHeight"
Sep 22 11:56:39 asusz97a-qonos-2126 kwin_x11[868]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 6739, resource id: 27263461, major code: 15 (QueryTree), minor code: 0
all that exfat stuff is from an external usb I disconnected.
ok, no spam, but you have this:
probalby from the external usb that you mentioned …
also what kernel are you running? from the above logs it looks like you are running an old kernel, post output from:
uname -r
sorry didn't open the whole page before copying.
its ok, looks good, no spam … noticed you are using pipewire-media-session, it would be better if you installed wireplumber instead:
pamac install wireplumber
it will replace the media session
also what kernel are you running? check with:
uname -r
Have to say it again I had no problems with this machine. Use it every day almost.
thats how it should be, however it looks like its not up to date:
so check what kernel version are you running:
uname -r
I have 5.18.19-3-MANJARO.
