I would like to install the current software on another storage device.
Thus I started my computer from the file “manjaro-kde-21.0.7-210614-linux510.iso” by the means of the boot system “Ventoy 1.0.50”.
Now I wonder why the installation tool presents unexpected behaviour on the first wizard page.
Yes. - I am using logical volume management for my storage devices for some years. Should the tool “calamares” handle the involved partitions for further installation attempts?
I have very little experience with LVM itself but has been doing some playaround with various pen-testing distributions.
Kali Linux is setting up LVM and when I tried to replace Kali with a customized Manjaro (tried combining Manjaro with BlackArch repo - don’t replicate - it is a pain) it noted the Calamares installler hanging for a long time seemed like indefinite.
Now that is some time ago - and my memory is not what it used to be. From time to time the topic is brought up and it may have been solved - but from your topic it appears Calamares is not there yet.
If I recall this correct when Calamares finally loaded it displayed two disks which was easily mistaken - the one being the LVM - the other being the physical disk.
Would you like to point any development repositories out which would be helpful for testing the software behaviour of installation tool versions in more detailed ways?
