Installation using manjaro-kde-21.1.1-210827-linux54 failed to install network device drivers.
Since I don’t have access to any network resources on the target machine, I need to figure out where to get the correct drivers, and how to install them.
System: Dell Precision 7560, with an intel cpu, and a hybrid intel/nvidia graphics system.
Output from inxi -N:
Network: Device-1: Intel Ethernet I219-LM vendor: Dell driver: N/A port: efa0
bus-ID: 00:1f.6 chip-Id 8086:15f9 class-ID: 0200
Device-2: Wi-Fi 6 AX210/AX211/AX411 160MHz driver: N/A port: 3000
bus-ID: 93:00.0 chip-Id 8086:22725 class-ID: 0280
Output from rfkill list
0: dell-wifi: Wireless LAN
Soft blocked: no
Hard blocked: no
1: dell-bluetooth: Bluetooth
Soft blocked: no
Hard blocked: no
I assume I need to do 1 of 2 (or both) things:
- Download the firmware.cab from from fwupd.org (my machine model is LVFS listed) and install it through the bios, then re-install manjaro from the pahvo installer.
AND/OR - Download the latest linux-firmware (from where?) and install it (how?)
My UI didn’t install properly (probably a display driver problem), but I can tackle that after I get network up and running.
Am I on the right path? What do I need to do to get my network connection working??? Please keep in mind any solution will require me to be able to download a file to usb from another machine, mount the usb, and then do something with the file (I think…)
