It’s showing me this debug info
QStandardPaths: XDG_RUNTIME_DIR not set, defaulting to '/tmp/runtime-root'
11:57:28 [6]: Calamares::Settings::Settings(const QString&, bool)
Using Calamares settings file at "/etc/calamares/settings.conf"
WARNING: .. Required settings.conf key hide-back-and-next-during-exec is missing.
11:57:28 [6]: void Logger::setupLogfile()
Using log file: "/root/.cache/calamares/session.log"
11:57:28 [6]: void CalamaresApplication::init()
Calamares version: 3.2.40-4
.. languages: "ar, as, ast, az, az_AZ, be, bg, bn, ca, ca@valencia, cs_CZ, da, de, el, en, en_GB, eo, es, es_MX, es_PR, et, eu, fa, fi_FI, fr, fur, gl, he, hi, hr, hu, id, is, it_IT, ja, ko, lt, ml, mr, nb, nl, pl, pt_BR, pt_PT, ro, ru, sk, sl, sq, sr, sr@latin, sv, tg, th, tr_TR, uk, vi, zh_CN, zh_TW"
11:57:28 [6]: bool CalamaresUtils::initQmlModulesDir()
Using Calamares QML directory "/usr/share/calamares/qml"
11:57:28 [6]: Calamares::Branding::Branding(const QString&, QObject*)
Using Calamares branding file at "/usr/share/calamares/branding/manjaro/branding.desc"
11:57:28 [2]: void Calamares::flavorAndSide(const YAML::Node&, const char*, Calamares::Branding::PanelFlavor&, Calamares::Branding::PanelSide&)
WARNING: Branding setting for sidebar is missing, using "widget" "left"
WARNING: Branding setting for navigation is missing, using "widget" "bottom"
11:57:28 [2]: Calamares::Branding::Branding(const QString&, QObject*)
WARNING: the branding component "/usr/share/calamares/branding/manjaro" does not ship translations.
Loaded branding component "manjaro"
.. Loaded QRC translation "tz_" "en_US"
.. Loaded QRC translation "calamares_" "en_US"
.. STARTUP: initSettings, initQmlPath, initBranding done
.. STARTUP: initModuleManager: module init started
11:57:28 [2]: static Calamares::ModuleSystem::Descriptor Calamares::ModuleSystem::Descriptor::fromDescriptorData(const QVariantMap&)
WARNING: Module descriptor contains extra keys:
"requires"
11:57:28 [6]: void Calamares::ModuleManager::doInit()
Found 46 modules
11:57:28 [6]: void CalamaresApplication::initView()
STARTUP: initModuleManager: all modules init done
STARTUP: initJobQueue done
11:57:28 [6]: CalamaresWindow::CalamaresWindow(QWidget*)
Available desktop QSize(1366, 768) minimum size QSize(1024, 520)
.. Proposed window size: 1024 560
11:57:29 [2]: QString Calamares::_stylesheet(const QDir&)
WARNING: The branding component "/usr/share/calamares/branding/manjaro" does not ship stylesheet.qss.
11:57:29 [6]: void CalamaresApplication::initView()
STARTUP: CalamaresWindow created; loadModules started
11:57:29 [6]: void Calamares::Module::loadConfigurationFile(const QString&)
Loaded module configuration "/etc/calamares/modules/welcome.conf"
11:57:29 [6]: void Config::initLanguages()
Matching locale QLocale(English, Latin, United States)
.. Matched with index 14 "en_US"
11:57:29 [6]: void Config::setLocaleIndex(int)
Index 14 Selected locale QLocale(English, Latin, United States)
11:57:29 [6]: QPair<CalamaresUtils::Network::RequestStatus, QNetworkReply*> CalamaresUtils::Network::synchronousRun(QNetworkAccessManager*, const QUrl&, const CalamaresUtils::Network::RequestOptions&)
HTTP error QNetworkReply::HostNotFoundError on request for QUrl("https://ipapi.co/json")
11:57:29 [2]: virtual QString CalamaresUtils::GeoIP::GeoIPJSON::rawReply(const QByteArray&)
WARNING: Invalid YAML data for GeoIPJSON
11:57:29 [6]: virtual void Calamares::ViewModule::loadSelf()
ViewModule "welcome@welcome" loading complete.
Loaded module configuration "/etc/calamares/modules/locale.conf"
ViewModule "locale@locale" loading complete.
Loaded module configuration "/usr/share/calamares/modules/keyboard.conf"
11:57:29 [6]: KeyboardModelsModel::KeyboardModelsModel(QObject*)
Loaded 188 keyboard models
11:57:29 [6]: KeyboardPage::KeyboardPage(Config*, QWidget*)
Variants now 0 -1
11:57:29 [6]: void Config::detectCurrentKeyboardLayout()
("pc", "us", "inet(evdev)", "terminate(ctrl_alt_bksp)\"")
11:57:31 [6]: virtual void Calamares::ViewModule::loadSelf()
ViewModule "keyboard@keyboard" loading complete.
11:57:31 [6]: void Calamares::Module::loadConfigurationFile(const QString&)
Loaded module configuration "/etc/calamares/modules/partition.conf"
11:57:31 [6]: CalamaresUtils::Partition::InternalManager::InternalManager()
KPMCore backend starting ..
11:57:31 [6]: Loaded backend plugin: "pmsfdiskbackendplugin"
.. Backend @0x55fe6d15f970 "pmsfdiskbackendplugin" "1"
11:57:31 [6]: CalamaresUtils::Partition::KPMManager::KPMManager()
KPMManager 1 created.
11:57:31 [2]: virtual void PartitionViewStep::setConfigurationMap(const QVariantMap&)
WARNING: Partition-module setting *defaultPartitionTableType* is unset, will use gpt for efi or msdos for bios
ViewModule "partition@partition" loading complete.
Loaded module configuration "/etc/calamares/modules/users.conf"
ViewModule "users@users" loading complete.
ViewModule "summary@summary" loading complete.
11:57:31 [6]: void Calamares::ModuleManager::loadModules()
Module "partition@partition" already loaded.
11:57:31 [6]: Calamares::SlideshowQML::SlideshowQML(QWidget*)
QML import paths:
"/usr/bin"
"qrc:/qt-project.org/imports"
"/usr/lib/qt/qml"
Loaded module configuration "/usr/share/calamares/modules/mount.conf"
Loaded module configuration "/etc/calamares/modules/unpackfs.conf"
Loaded module configuration "/etc/calamares/modules/machineid.conf"
11:57:31 [2]: virtual void MachineIdJob::setConfigurationMap(const QVariantMap&)
WARNING: MachineId: configuration setting *symlink* is deprecated, use *dbus-symlink*.
11:57:31 [6]: virtual void Calamares::CppJobModule::loadSelf()
CppJobModule "machineid@machineid" loading complete.
Loaded module configuration "/usr/share/calamares/modules/fstab.conf"
Module "locale@locale" already loaded.
Module "keyboard@keyboard" already loaded.
Loaded module configuration "/usr/share/calamares/modules/luksopenswaphookcfg.conf"
CppJobModule "luksbootkeyfile@luksbootkeyfile" loading complete.
No config file for "initcpiocfg" found anywhere at
"/home/manjaro/src/modules/initcpiocfg/initcpiocfg.conf"
"/etc/calamares/modules/initcpiocfg.conf"
"/usr/share/calamares/modules/initcpiocfg.conf"
Loaded module configuration "/etc/calamares/modules/initcpio.conf"
CppJobModule "initcpio@initcpio" loading complete.
Module "users@users" already loaded.
Loaded module configuration "/etc/calamares/modules/displaymanager.conf"
Loaded module configuration "/etc/calamares/modules/mhwdcfg.conf"
Loaded module configuration "/etc/calamares/modules/services.conf"
Loaded module configuration "/usr/share/calamares/modules/grubcfg.conf"
Loaded module configuration "/etc/calamares/modules/bootloader.conf"
Loaded module configuration "/etc/calamares/modules/postcfg.conf"
Loaded module configuration "/usr/share/calamares/modules/umount.conf"
Loaded module configuration "/etc/calamares/modules/finished.conf"
11:57:31 [2]: void Config::setConfigurationMap(const QVariantMap&)
WARNING: Configuring the finished module with deprecated restartNowEnabled settings
ViewModule "finished@finished" loading complete.
11:57:31 [6]: Config::Config(QObject*)::<lambda(int)>::<lambda()>
xkbmap selection changed to: "us" - ""
11:57:31 [6]: setGeoIP(Config*, const QVariantMap&)::<lambda()>
GeoIP result for welcome= ""
11:57:31 [6]: void setCountry(Config*, const QString&, CalamaresUtils::GeoIP::Handler*)
Unusable country code ""
.. Obtained from "https://ipapi.co/json" ( 1 "country" )
11:57:31 [6]: void CalamaresApplication::initViewSteps()
STARTUP: loadModules for all modules done
11:57:31 [6]: void Calamares::ModuleManager::checkRequirements()
Checking module requirements ..
STARTUP: Window now visible and ProgressTreeView populated
.. 8 view steps loaded.
.. Loaded QRC translation "kb_" "en_US"
11:57:32 [6]: QPair<CalamaresUtils::Network::RequestStatus, QNetworkReply*> CalamaresUtils::Network::synchronousRun(QNetworkAccessManager*, const QUrl&, const CalamaresUtils::Network::RequestOptions&)
11:57:32 [6]: bool GeneralRequirements::checkHasPower()
A battery exists, checking for mains power.
HTTP error QNetworkReply::HostNotFoundError on request for QUrl("https://manjaro.org")
11:57:32 [6]: Calamares::RequirementsList GeneralRequirements::checkRequirements()
GeneralRequirements output:
storage : 8482560409
enoughStorage : true
RAM : 1073741824
enoughRam : true
hasPower : true
hasInternet : false
isRoot : true
11:57:32 [6]: void Calamares::RequirementsChecker::addCheckedRequirements(Calamares::Module*)
Got 5 requirement results from "welcome"
11:57:33 [6]: void Calamares::RequirementsChecker::reportProgress()
Remaining modules: 1
"partition"
11:57:34 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
11:57:35 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
11:57:36 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
11:57:37 [6]: smartctl initialization failed for "/dev/sdb" : No such file or directory
11:57:37 [6]: error during smart output parsing for "/dev/sdb" : Success
11:57:37 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
11:57:38 [6]: QList<Device*> PartUtils::getDevices(PartUtils::DeviceType)
Removing unsuitable devices: 2 candidates.
11:57:39 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
.. there are 2 devices left.
11:57:39 [6]: void PartitionCoreModule::doInit()
LIST OF DETECTED DEVICES:
.. node capacity name prettyName
.. @0x7f3a2c00f870
.. "/dev/sda" 1000202273280 "TOSHIBA MQ01ABD100" "TOSHIBA MQ01ABD100 – 931.51 GiB (/dev/sda)"
.. @0x7f3a2c00d9d0
.. "/dev/sdb" 15998169600 "Cruzer Blade" "Cruzer Blade – 14.90 GiB (/dev/sdb)"
.. 2 devices detected.
11:57:40 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
11:57:41 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
11:57:42 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
11:57:43 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
11:57:45 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
11:57:46 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
11:57:47 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
11:57:48 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
11:57:49 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
11:57:51 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
11:57:52 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
11:57:53 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
11:57:54 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
11:57:55 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
11:57:57 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
11:57:58 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
11:57:59 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
11:58:00 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
11:58:01 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
11:58:03 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
11:58:04 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
11:58:05 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
11:58:06 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
11:58:07 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
11:58:09 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
11:58:10 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
11:58:11 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
11:58:12 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
11:58:13 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
11:58:15 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
11:58:16 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
11:58:17 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
11:58:18 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
11:58:19 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
11:58:21 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
11:58:22 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
11:58:23 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
11:58:24 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
11:58:25 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
11:58:27 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
11:58:28 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
11:58:29 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
11:58:30 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
11:58:31 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
11:58:33 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
11:58:34 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
11:58:35 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
11:58:36 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
11:58:37 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
11:58:39 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
11:58:39 [1]: OsproberEntryList PartUtils::runOsprober(DeviceModel*)
ERROR: os-prober timed out.
11:58:39 [6]: OsproberEntryList PartUtils::runOsprober(DeviceModel*)
os-prober gave no output.
11:58:39 [2]: QProcess: Destroyed while process ("os-prober") is still running.
11:58:39 [6]: void PartitionCoreModule::scanForEfiSystemPartitions()
system is EFI and new EFI system partition has been found.
11:58:39 [6]: void Calamares::RequirementsChecker::addCheckedRequirements(Calamares::Module*)
Got 1 requirement results from "partition"
11:58:39 [6]: void ChoicePage::updateDeviceStatePreview()
Updating partitioning state widgets.
11:58:39 [6]: void ChoicePage::setupActions()
Setting up actions for "/dev/sda" with 0 entries.
.. Checking if "/dev/sda2" can be resized.
.. Partition "/dev/sda2" authorized for resize + autopartition install.
.. contains resizable "/dev/sda2"
.. Checking if "/dev/sda2" can be replaced.
.. Partition "/dev/sda2" authorized for replace install.
.. contains replaceable "/dev/sda2"
.. Checking if "/dev/sda8" can be resized.
.. Partition "/dev/sda8" authorized for resize + autopartition install.
.. contains resizable "/dev/sda8"
.. Checking if "/dev/sda8" can be replaced.
.. Partition "/dev/sda8" authorized for replace install.
.. contains replaceable "/dev/sda8"
.. Checking if "/dev/sda9" can be resized.
.. Partition "/dev/sda9" authorized for resize + autopartition install.
.. contains resizable "/dev/sda9"
.. Checking if "/dev/sda9" can be replaced.
.. Partition "/dev/sda9" authorized for replace install.
.. contains replaceable "/dev/sda9"
.. Checking if "/dev/sda5" can be resized.
.. Partition "/dev/sda5" authorized for resize + autopartition install.
.. contains resizable "/dev/sda5"
.. Checking if "/dev/sda5" can be replaced.
.. Partition "/dev/sda5" authorized for replace install.
.. contains replaceable "/dev/sda5"
.. Checking if "/dev/sda" can be resized.
.. NO, filesystem "unknown" does not support resize.
.. Checking if "/dev/sda" can be replaced.
.. NO, insufficient storage
Required storage B: 9019431321 "(7.9GiB)"
Available storage B: 1048576 "(0GiB)"
.. Checking if "/dev/sda6" can be resized.
.. Partition "/dev/sda6" authorized for resize + autopartition install.
.. contains resizable "/dev/sda6"
.. Checking if "/dev/sda6" can be replaced.
.. Partition "/dev/sda6" authorized for replace install.
.. contains replaceable "/dev/sda6"
.. Checking if "/dev/sda1" can be resized.
.. NO, filesystem "fat32" does not support resize.
.. Checking if "/dev/sda1" can be replaced.
Available storage B: 1074403328 "(1GiB)"
.. Checking if "/dev/sda7" can be resized.
Required storage B: 11166914969 "(10.4GiB)"
Available storage B: 4294966784 "(3GiB)" for "/dev/sda7" length: 8388607 sectorsUsed: 0 fsType: "linuxswap"
.. Checking if "/dev/sda7" can be replaced.
.. Checking if "/dev/sda3" can be resized.
.. Partition "/dev/sda3" authorized for resize + autopartition install.
.. contains resizable "/dev/sda3"
.. Checking if "/dev/sda3" can be replaced.
.. Partition "/dev/sda3" authorized for replace install.
.. contains replaceable "/dev/sda3"
.. Checking if "/dev/sda4" can be resized.
.. Partition "/dev/sda4" authorized for resize + autopartition install.
.. contains resizable "/dev/sda4"
.. Checking if "/dev/sda4" can be replaced.
.. Partition "/dev/sda4" authorized for replace install.
.. contains replaceable "/dev/sda4"
11:58:39 [6]: ChoicePage::setupActions()::<lambda()>
Setting texts for 0 osprober entries
11:58:39 [6]: void ChoicePage::continueApplyDeviceChoice()
Previous device -1 new device 0
11:58:39 [6]: void ChoicePage::applyActionChoice(InstallChoice)
Prev -1 InstallChoice Config::Erase "erase"
11:58:39 [6]: CalamaresUtils::Partition::KPMManager::KPMManager()
KPMManager 2 created.
11:58:39 [6]: PartitionTable* CreatePartitionTableJob::createTable()
CreatePartitionTableJob::createTable trying to make table for device "/dev/sda"
11:58:39 [6]: void Calamares::RequirementsChecker::finished()
All requirements have been checked.
11:58:39 [6]: void Calamares::RequirementsModel::describe() const
Requirements model has 6 items
.. requirement 0 "storage" satisfied? true mandatory? true
.. requirement 1 "ram" satisfied? true mandatory? true
.. requirement 2 "power" satisfied? true mandatory? false
.. requirement 3 "internet" satisfied? false mandatory? false
.. requirement 4 "root" satisfied? true mandatory? true
.. requirement 5 "partitions" satisfied? true mandatory? true
KPMManager 3 created.
KPMManager 4 created.
11:58:40 [6]: CalamaresUtils::Partition::KPMManager::KPMManager()
KPMManager 5 created.
11:58:40 [6]: void PartitionCoreModule::dumpQueue() const
# Queue:
.. ## Device: "TOSHIBA MQ01ABD100"
.. - "Create new gpt partition table on /dev/sda."
.. - "Create new 300MiB partition on /dev/sda (TOSHIBA MQ01ABD100)."
.. - "Set flags on 300MiB fat32 partition."
.. - "Create new 953565MiB partition on /dev/sda (TOSHIBA MQ01ABD100) with entries root."
.. ## Device: "Cruzer Blade"
11:58:40 [6]: void ChoicePage::updateActionChoicePreview(InstallChoice)
Updating partitioning preview widgets.
17:28:49 [6]: void Config::onActivate()
Got locale language "en_IN"
.. extracted country "India" :: ("en", "IN")
.. looking for locale part "IN"
.. matched "in"
17:28:50 [6]: void Config::guessLayout(const QStringList&)
Next level: "en"
17:28:50 [6]: Config::Config(QObject*)::<lambda(int)>::<lambda()>
xkbmap selection changed to: "in" - ""
17:28:53 [6]: Config::Config(QObject*)::<lambda(int)>::<lambda()>
17:28:57 [6]: void ChoicePage::applyActionChoice(InstallChoice)
Prev -1 InstallChoice Config::Manual "manual"
17:28:57 [6]: void ChoicePage::updateActionChoicePreview(InstallChoice)
17:28:58 [6]: CalamaresUtils::Partition::KPMManager::~KPMManager()
KPMManager 5 being destroyed.
KPMManager 4 being destroyed.
KPMManager 3 being destroyed.
KPMManager 2 being destroyed.
17:28:58 [6]: virtual void PartitionViewStep::next()
Choice applied: Config::Manual
From here , the installer is stuck at scanning storage devices
Sorry for the late reply
