Installation of manjaro failed
Hey there,
after some time using Windows I decided to switch back to Manjaro, so I slapped the KDE de on an USB stick, booted on it and tried to install.
This is how I partitioned it (could be wrong):
🟦 /dev/sda1               NTFS                              702,9 GiB
⬛ /dev/sda2               extended                          228,7 GiB
└🟥 New Partition          FAT32              /boot/efi      512,0 MiB
└🟧 New Partition          FAT32              /              228,2 GiB
(I use sda1 as my 2nd hard drive on Windows)
And this is the error message I get after the installation (translated from German):
Unpacking the image file "/run/miso/bootmnt/manjaro/x86_64/rootfs.sfs" failed
rsync failed with error code 13
I really don’t know what I’m doing so any help would be very appreciated :slight_smile:
Did you try verify the signature of the iso and test it beforehand in any virtual machine?
I didn’t but I got the iso from the original website so I managed it wouldn’t be a problem
At least, try installing it in a vm to see if there is any problem with the iso.
Am I reading this correctly? You’re trying to use FAT32 on the Linux system partition? :dizzy_face:
Choose a native Linux filesystem, such as XFS, Ext4, or Btrfs.
Also beware that depending on your motherboard, you might have issues when placing the EFI System Partition (“esp” / “boot”) on an extended/logical partition if you’re using an MBR table.
:rofl: you made my day…
sorry, but FAT32 is not a valid filesystem for the root device. Choose ext4, xfs, btrfs etc.
rsync is not compatible with filesystems without ACL and therefore troughs an error. Search for “13” here: https://linux.die.net/man/1/rsync
