Hi,
i’ve downloaded the v17.iso.
When i execute the .run-file, installation starts and then aborts with the following log:
Starting DaVinci Resolve install
Linux basementmedia 5.9.16-1-MANJARO #1 SMP PREEMPT Mon Dec 21 22:00:46 UTC 2020 x86_64 GNU/Linux
Install Location : /opt/resolve
User ID: 1000
User Home: /home/basementmedia
Removing old files
share
share/default-config.dat
share/blackmagicraw.xml
share/log-conf.xml
share/etc
share/etc/udev
share/etc/udev/rules.d
share/etc/udev/rules.d/99-BlackmagicDevices.rules
share/etc/udev/rules.d/99-ResolveKeyboardHID.rules
share/DaVinciResolve.desktop
share/DaVinciResolveCaptureLogs.desktop
share/DaVinciControlPanelsSetup.desktop
share/blackmagicraw-player.desktop
share/DaVinciResolveInstaller.desktop
share/DaVinciResolve.menu
share/DaVinciResolve.directory
share/resolve.xml
share/panels
share/panels/BMDPanelDaemon.sh
share/panels/dvpanel-framework-linux-x86_64.tgz
share/blackmagicraw-speedtest.desktop
share/default_cm_config.bin
scripts
scripts/script.logs.message
scripts/script.getlogs.v4
scripts/post_install.sh
scripts/script.checkfirmware
scripts/script.reboot
scripts/script.kill
scripts/pre_install.sh
scripts/script.update
scripts/script.start
scripts/uninstall.sh
scripts/script.halt
Technical Documentation
Technical Documentation/DaVinci Remote Panel.txt
Technical Documentation/User Configuration folders and customization.txt
UI_Resource
UI_Resource/Steinway
UI_Resource/Steinway/eclipseSize.bmp
UI_Resource/Steinway/add.bmp
UI_Resource/Steinway/global_y.bmp
UI_Resource/Steinway/farBlurRange.bmp
UI_Resource/Steinway/mode.bmp
UI_Resource/Steinway/sourceCinemaDNG.bmp
UI_Resource/Steinway/HighSaturation.bmp
UI_Resource/Steinway/blueRed.bmp
UI_Resource/Steinway/slider15.bmp
UI_Resource/Steinway/slider17.bmp
UI_Resource/Steinway/apertureGain.bmp
UI_Resource/Steinway/more.bmp
UI_Resource/Steinway/pauseRandomness.bmp
UI_Resource/Steinway/blueHighLevel.bmp
UI_Resource/Steinway/bottomRotate.bmp
UI_Resource/Steinway/h2_ysfx.bmp
UI_Resource/Steinway/addLayer.bmp
UI_Resource/Steinway/cameraShake.bmp
UI_Resource/Steinway/toggleDeckKeys.bmp
UI_Resource/Steinway/h2s_solo.bmp
UI_Resource/Steinway/hiddenParameter.bmp
UI_Resource/Steinway/preDenoise.bmp
UI_Resource/Steinway/mirrorPlacement.bmp
UI_Resource/Steinway/reset.bmp
UI_Resource/Steinway/scaling.bmp
UI_Resource/Steinway/columnCells.bmp
UI_Resource/Steinway/nextTrackEnd.bmp
UI_Resource/Steinway/whiteGamma.bmp
UI_Resource/Steinway/greenOffset.bmp
UI_Resource/Steinway/h2_tiltShiftBlur.bmp
UI_Resource/Steinway/extKeyGain.bmp
UI_Resource/Steinway/safeTitle.bmp
UI_Resource/Steinway/highlight.bmp
UI_Resource/Steinway/h2_tvBlanking.bmp
UI_Resource/Steinway/slider10.bmp
UI_Resource/Steinway/h2_scanline.bmp
UI_Resource/Steinway/audio1Source.bmp
UI_Resource/Steinway/h1_nodeKeyProcessing.bmp
UI_Resource/Steinway/useCustomOutputMax.bmp
UI_Resource/Steinway/h2_softenAndSharpen.bmp
UI_Resource/Steinway/lensDistortion.bmp
UI_Resource/Steinway/h2_formatSetup.bmp
UI_Resource/Steinway/cropLeft.bmp
UI_Resource/Steinway/80PercentLum.bmp
UI_Resource/Steinway/dehazeStrength.bmp
UI_Resource/Steinway/alphaMatteShrinkAndGrow.bmp
UI_Resource/Steinway/framingFine.bmp
UI_Resource/Steinway/h2_yellow.bmp
UI_Resource/Steinway/ledCurrent.bmp
UI_Resource/Steinway/brightness.bmp
UI_Resource/Steinway/pos.bmp
UI_Resource/Steinway/trackFwd.bmp
UI_Resource/Steinway/colorPalette.bmp
UI_Resource/Steinway/scrollScenes.bmp
UI_Resource/Steinway/outputColorSpace.bmp
UI_Resource/Steinway/nearBlurRange.bmp
UI_Resource/Steinway/edgeBrightness.bmp
UI_Resource/Steinway/filmSize.bmp
UI_Resource/Steinway/desaturateShadow.bmp
UI_Resource/Steinway/blue.bmp
UI_Resource/Steinway/greenRed.bmp
UI_Resource/Steinway/h1_spiritTelecineSetup.bmp
UI_Resource/Steinway/operatorShape.bmp
UI_Resource/Steinway/activateAll.bmp
UI_Resource/Steinway/h2_pcwControl.bmp
UI_Resource/Steinway/slider3.bmp
UI_Resource/Steinway/Avg.InputLuminance.bmp
UI_Resource/Steinway/rayDropoff.bmp
UI_Resource/Steinway/timing.bmp
UI_Resource/Steinway/motionEstType.bmp
UI_Resource/Steinway/copy.bmp
UI_Resource/Steinway/green_to_green.bmp
UI_Resource/Steinway/redCurve.bmp
UI_Resource/Steinway/addTexture.bmp
UI_Resource/Steinway/absoluteRipple.bmp
UI_Resource/Steinway/h2_polygonPowerWindowAdjustments.bmp
UI_Resource/Steinway/h2s_zoom.bmp
UI_Resource/Steinway/vertOffset.bmp
UI_Resource/Steinway/motionRange.bmp
UI_Resource/Steinway/tkPrimaries.bmp
UI_Resource/Steinway/copyAnalysis.bmp
UI_Resource/Steinway/alignVertSkew.bmp
UI_Resource/Steinway/x_or_y.bmp
UI_Resource/Steinway/h2_DolbyPrimaryTrims.bmp
UI_Resource/Steinway/motionThreshold.bmp
UI_Resource/Steinway/h2_mistEffectMasterControls.bmp
UI_Resource/Steinway/tkSetup.bmp
UI_Resource/Steinway/h2_black.bmp
UI_Resource/Steinway/markIn.bmp
UI_Resource/Steinway/edgeBehaviour.bmp
UI_Resource/Steinway/greenRadius.bmp
UI_Resource/Steinway/outputGamma.bmp
UI_Resource/Steinway/stabilizeLevelsHow.bmp
UI_Resource/Steinway/mBlackRed.bmp
UI_Resource/Steinway/blueHiSoft.bmp
UI_Resource/Steinway/showGradient.bmp
UI_Resource/Steinway/cueNext.bmp
UI_Resource/Steinway/h2_channelOffsetCustomCurves.bmp
UI_Resource/Steinway/cuePrevious.bmp
UI_Resource/Steinway/166.bmp
UI_Resource/Steinway/h2_matchMove.bmp
UI_Resource/Steinway/autoCue.bmp
UI_Resource/Steinway/h2_faceRefinement.bmp
UI_Resource/Steinway/compressHue.bmp
UI_Resource/Steinway/h2_edgeDetect.bmp
UI_Resource/Steinway/cpw.bmp
UI_Resource/Steinway/source_red_whitepoint.bmp
UI_Resource/Steinway/slider4.bmp
UI_Resource/Steinway/sharpAmount.bmp
UI_Resource/Steinway/deactivateAll.bmp
UI_Resource/Steinway/h1_primaries.bmp
UI_Resource/Steinway/splitScreenGroup.bmp
UI_Resource/Steinway/trackOneFwd.bmp
UI_Resource/Steinway/enableLightSourceMasking.bmp
UI_Resource/Steinway/chromaThreshold.bmp
UI_Resource/Steinway/clearTrackingForwards.bmp
UI_Resource/Steinway/blueBlur.bmp
UI_Resource/Steinway/colorPos.bmp
UI_Resource/Steinway/pasteToCurrent.bmp
UI_Resource/Steinway/illum.bmp
UI_Resource/Steinway/denoise.bmp
UI_Resource/Steinway/sourceWidth.bmp
UI_Resource/Steinway/h2_colorSharpeningCoring.bmp
UI_Resource/Steinway/qualifierMode.bmp
UI_Resource/Steinway/drawMirrorEdges.bmp
UI_Resource/Steinway/bristleScale.bmp
UI_Resource/Steinway/lt.bmp
UI_Resource/Steinway/h2_sourcePanasonicControls.bmp
UI_Resource/Steinway/h2_filmType.bmp
UI_Resource/Steinway/refHole.bmp
UI_Resource/Steinway/dirtClip.bmp
UI_Resource/Steinway/left.bmp
UI_Resource/Steinway/stabilizeWhiteBalance.bmp
UI_Resource/Steinway/useFaceMask.bmp
UI_Resource/Steinway/centerCross.bmp
UI_Resource/Steinway/toggle3.bmp
UI_Resource/Steinway/blueScaling.bmp
UI_Resource/Steinway/satHiSoft.bmp
UI_Resource/Steinway/horzPeak.bmp
UI_Resource/Steinway/fpnRed.bmp
UI_Resource/Steinway/switchToZonesGraph.bmp
UI_Resource/Steinway/chromaWeight.bmp
UI_Resource/Steinway/sh1Pos.bmp
UI_Resource/Steinway/greenSharpen.bmp
UI_Resource/Steinway/mWhiteRed.bmp
UI_Resource/Steinway/1125i59Hz.bmp
UI_Resource/Steinway/exitAsIs.bmp
UI_Resource/Steinway/scanline.bmp
UI_Resource/Steinway/inFocusRange.bmp
UI_Resource/Steinway/viewOriginal.bmp
UI_Resource/Steinway/softnessPlus.bmp
UI_Resource/Steinway/midContrastBias.bmp
UI_Resource/Steinway/cbdSize.bmp
UI_Resource/Steinway/global_x.bmp
UI_Resource/Steinway/rowCells.bmp
UI_Resource/Steinway/greenLowLevel.bmp
UI_Resource/Steinway/sixDbGain.bmp
UI_Resource/Steinway/h2_specular.bmp
UI_Resource/Steinway/blurAmount.bmp
UI_Resource/Steinway/filmHSize.bmp
UI_Resource/Steinway/primeNeg.bmp
UI_Resource/Steinway/diffuseLighting.bmp
UI_Resource/Steinway/scrollMode.bmp
UI_Resource/Steinway/whiteLevel.bmp
UI_Resource/Steinway/sharpenChroma.bmp
UI_Resource/Steinway/h2s_gang.bmp
UI_Resource/Steinway/lipHue.bmp
UI_Resource/Steinway/compressLuminance.bmp
UI_Resource/Steinway/verLineWidth.bmp
UI_Resource/Steinway/saturationMax.bmp
UI_Resource/Steinway/redHighlight.bmp
UI_Resource/Steinway/chromaticShift.bmp
UI_Resource/Steinway/primePos.bmp
UI_Resource/Steinway/mWhiteBlue.bmp
UI_Resource/Steinway/greenRatio.bmp
UI_Resource/Steinway/blueBlue.bmp
UI_Resource/Steinway/bottomPosition.bmp
UI_Resource/Steinway/delete.bmp
UI_Resource/Steinway/glowFraming.bmp
UI_Resource/Steinway/amplitudeVertical.bmp
UI_Resource/Steinway/scrollFrames.bmp
UI_Resource/Steinway/blue_to_green.bmp
UI_Resource/Steinway/showMask.bmp
UI_Resource/Steinway/dirtFrame.bmp
UI_Resource/Steinway/data59Hz.bmp
UI_Resource/Steinway/h2_lensDistortion.bmp
UI_Resource/Steinway/greenLowSoft.bmp
UI_Resource/Steinway/highlightThreshold.bmp
UI_Resource/Steinway/h2s_stereo.bmp
UI_Resource/Steinway/curves_lum_sat.bmp
UI_Resource/Steinway/user.bmp
UI_Resource/Steinway/showPath.bmp
UI_Resource/Steinway/shineStrength.bmp
UI_Resource/Steinway/extents.bmp
UI_Resource/Steinway/dent.bmp
UI_Resource/Steinway/grainAspectRatio.bmp
UI_Resource/Steinway/stabilizeRedChannel.bmp
UI_Resource/Steinway/interactive.bmp
UI_Resource/Steinway/redHighLevel.bmp
UI_Resource/Steinway/bar_bkgrnd.bmp
UI_Resource/Steinway/magenta_hue.bmp
UI_Resource/Steinway/loop.bmp
UI_Resource/Steinway/emulate.bmp
UI_Resource/Steinway/tiltAmplitude.bmp
UI_Resource/Steinway/240.bmp
UI_Resource/Steinway/h2_audioOneSetup.bmp
UI_Resource/Steinway/stdOverride.bmp
UI_Resource/Steinway/h2_mirror.bmp
UI_Resource/Steinway/greenYSFX.bmp
UI_Resource/Steinway/h2_lightRays.bmp
UI_Resource/Steinway/clipsYSFX.bmp
UI_Resource/Steinway/drawEdge.bmp
UI_Resource/Steinway/trackNext.bmp
UI_Resource/Steinway/centerSize.bmp
UI_Resource/Steinway/unlock.bmp
UI_Resource/Steinway/enableRotate.bmp
UI_Resource/Steinway/h2_log.bmp
UI_Resource/Steinway/yellow_hue.bmp
UI_Resource/Steinway/source_saturation.bmp
UI_Resource/Steinway/fpnIM.bmp
UI_Resource/Steinway/h1_spiritTelecinePans.bmp
UI_Resource/Steinway/source_red_colortemp.bmp
UI_Resource/Steinway/renderMotionBlur.bmp
UI_Resource/Steinway/warpScale.bmp
UI_Resource/Steinway/clearCurve.bmp
UI_Resource/Steinway/zoomChangeFreq.bmp
UI_Resource/Steinway/leftRotate.bmp
UI_Resource/Steinway/625SDTV.bmp
UI_Resource/Steinway/highChroma.bmp
UI_Resource/Steinway/h2_sourceCinemaDNGControls.bmp
UI_Resource/Steinway/tintRange.bmp
UI_Resource/Steinway/h2_glow.bmp
UI_Resource/Steinway/source_red_exposure.bmp
UI_Resource/Steinway/h1_nodeCircularPowerWindow.bmp
UI_Resource/Steinway/prevClip.bmp
UI_Resource/Steinway/splitScreenGalleryGrades.bmp
UI_Resource/Steinway/prevKeyfrm.bmp
UI_Resource/Steinway/resolution.bmp
UI_Resource/Steinway/source_red_drx.bmp
UI_Resource/Steinway/red_to_lum.bmp
UI_Resource/Steinway/blueRatio.bmp
UI_Resource/Steinway/h2_sourceBRAWControls.bmp
UI_Resource/Steinway/h2s_mono.bmp
UI_Resource/Steinway/hPlusV.bmp
UI_Resource/Steinway/h1_cameraraw.bmp
UI_Resource/Steinway/h1_nodeGradientPowerWindow.bmp
UI_Resource/Steinway/autoOffset.bmp
UI_Resource/Steinway/postMixGain.bmp
UI_Resource/Steinway/topSoft.bmp
UI_Resource/Steinway/cineScope.bmp
UI_Resource/Steinway/blueGamma.bmp
UI_Resource/Steinway/1080p23Hz.bmp
UI_Resource/Steinway/cyan_sat.bmp
UI_Resource/Steinway/depthMapPreview.bmp
UI_Resource/Steinway/colorMatchPrimary.bmp
UI_Resource/Steinway/h2_openFX.bmp
UI_Resource/Steinway/maxOuputLuminance.bmp
UI_Resource/Steinway/colorSpaceTransform.bmp
UI_Resource/Steinway/h2_lensFlare.bmp
UI_Resource/Steinway/blue_hue.bmp
UI_Resource/Steinway/h2_3DQualifier.bmp
UI_Resource/Steinway/hslMinus.bmp
UI_Resource/Steinway/copyLR.bmp
UI_Resource/Steinway/h2_colorSpaceTransform.bmp
UI_Resource/Steinway/ghost6Type.bmp
UI_Resource/Steinway/eclipseSoftness.bmp
UI_Resource/Steinway/fineAdjustment.bmp
UI_Resource/Steinway/largeTexture.bmp
UI_Resource/Steinway/pauseInterval.bmp
UI_Resource/Steinway/tvVCtr.bmp
UI_Resource/Steinway/cropRight.bmp
UI_Resource/Steinway/nextClip.bmp
UI_Resource/Steinway/redLowSoft.bmp
UI_Resource/Steinway/shineDirection.bmp
UI_Resource/Steinway/directionalBlur.bmp
UI_Resource/Steinway/toggle4.bmp
UI_Resource/Steinway/colorNeg.bmp
UI_Resource/Steinway/nodes.bmp
UI_Resource/Steinway/clips.bmp
UI_Resource/Steinway/133.bmp
UI_Resource/Steinway/cacheMode.bmp
UI_Resource/Steinway/h1_nodePowerCurveWindow.bmp
UI_Resource/Steinway/magBluCyan.bmp
UI_Resource/Steinway/mWhiteGreen.bmp
UI_Resource/Steinway/blackGamma.bmp
UI_Resource/Steinway/LightSourceMask.bmp
UI_Resource/Steinway/lumYSFX.bmp
UI_Resource/Steinway/h2_magenta.bmp
UI_Resource/Steinway/extKeyBlur.bmp
UI_Resource/Steinway/mediumSkinTexture.bmp
UI_Resource/Steinway/shadow.bmp
UI_Resource/Steinway/zoomMode.bmp
UI_Resource/Steinway/ghost3Type.bmp
UI_Resource/Steinway/sh2Neg.bmp
UI_Resource/Steinway/cntrCoring.bmp
UI_Resource/Steinway/shineSize.bmp
UI_Resource/Steinway/right.bmp
UI_Resource/Steinway/h2_alphaMatteShrinkAndGrow.bmp
UI_Resource/Steinway/blue_to_red.bmp
UI_Resource/Steinway/vertPeak.bmp
UI_Resource/Steinway/shine.bmp
UI_Resource/Steinway/h2_DolbySecondaryTrims.bmp
UI_Resource/Steinway/cancel.bmp
UI_Resource/Steinway/shineRemoval.bmp
UI_Resource/Steinway/filmVSize.bmp
UI_Resource/Steinway/source_arri_whiteBalance.bmp
UI_Resource/Steinway/redGamma.bmp
UI_Resource/Steinway/presets.bmp
UI_Resource/Steinway/enableTilt.bmp
UI_Resource/Steinway/irisShape.bmp
UI_Resource/Steinway/smallSkinTextureSize.bmp
UI_Resource/Steinway/gray60.bmp
UI_Resource/Steinway/fpnPos.bmp
UI_Resource/Steinway/tilt.bmp
UI_Resource/Steinway/randomness.bmp
UI_Resource/Steinway/stereoMono.bmp
UI_Resource/Steinway/global_pivot.bmp
UI_Resource/Steinway/blueSharpen.bmp
UI_Resource/Steinway/source_red_bluegain.bmp
UI_Resource/Steinway/40PercentLum.bmp
UI_Resource/Steinway/rightSoft.bmp
UI_Resource/Steinway/mediumTexture.bmp
UI_Resource/Steinway/slider13.bmp
UI_Resource/Steinway/mid_dark_sat.bmp
UI_Resource/Steinway/stabilizeMethod.bmp
UI_Resource/Steinway/pasteTrack.bmp
UI_Resource/Steinway/toggle1.bmp
UI_Resource/Steinway/centerY.bmp
UI_Resource/Steinway/show.bmp
UI_Resource/Steinway/h1_colorMist.bmp
UI_Resource/Steinway/blur.bmp
UI_Resource/Steinway/colorizeResult.bmp
UI_Resource/Steinway/ShowControlsFor.bmp
UI_Resource/Steinway/greenHiSoft.bmp
UI_Resource/Steinway/blueLowClip.bmp
UI_Resource/Steinway/redDistortion.bmp
UI_Resource/Steinway/blurStrength.bmp
UI_Resource/Steinway/h2_red.bmp
UI_Resource/Steinway/h1_mistEffect.bmp
UI_Resource/Steinway/greenScaling.bmp
UI_Resource/Steinway/zonePivot.bmp
UI_Resource/Steinway/eclipseChromaticShift.bmp
UI_Resource/Steinway/fineDetailSize.bmp
UI_Resource/Steinway/power.bmp
UI_Resource/Steinway/quantization.bmp
UI_Resource/Steinway/sharpenRadius.bmp
UI_Resource/Steinway/blue_to_lum.bmp
UI_Resource/Steinway/md_det.bmp
UI_Resource/Steinway/renderOverlayPlate.bmp
UI_Resource/Steinway/modifyPar.bmp
UI_Resource/Steinway/showCanvas.bmp
UI_Resource/Steinway/invert.bmp
UI_Resource/Steinway/steadiScan.bmp
UI_Resource/Steinway/copyTrack.bmp
UI_Resource/Steinway/redRatio.bmp
UI_Resource/Steinway/printerLites.bmp
UI_Resource/Steinway/sourceBlanking.bmp
UI_Resource/Steinway/denoiseType.bmp
UI_Resource/Steinway/nodePlusLpw.bmp
UI_Resource/Steinway/yellow_lum.bmp
UI_Resource/Steinway/allShots.bmp
UI_Resource/Steinway/slider18.bmp
UI_Resource/Steinway/refineMask.bmp
UI_Resource/Steinway/lumGain.bmp
UI_Resource/Steinway/zoomBlur.bmp
UI_Resource/Steinway/aberrationStrength.bmp
UI_Resource/Steinway/sourceThreshold.bmp
UI_Resource/Steinway/h1_imageSharpening.bmp
UI_Resource/Steinway/grainStrength.bmp
UI_Resource/Steinway/edgeStrength.bmp
UI_Resource/Steinway/h2_sceneBlackClips.bmp
UI_Resource/Steinway/h2_linearPowerWindowAdjustments.bmp
UI_Resource/Steinway/blue_lum.bmp
UI_Resource/Steinway/lumLift.bmp
UI_Resource/Steinway/motionMethod.bmp
UI_Resource/Steinway/trackOneRev.bmp
UI_Resource/Steinway/radius.bmp
UI_Resource/Steinway/rotate.bmp
UI_Resource/Steinway/h2_sourceRedControls.bmp
UI_Resource/Steinway/source_red_tint.bmp
UI_Resource/Steinway/patchSize.bmp
UI_Resource/Steinway/h2_lpwControl.bmp
UI_Resource/Steinway/redYSFX.bmp
UI_Resource/Steinway/colorspace.bmp
UI_Resource/Steinway/h2_outputSizingAdjustments.bmp
UI_Resource/Steinway/blushHue.bmp
UI_Resource/Steinway/blue_to_blue.bmp
UI_Resource/Steinway/refWipeHflip.bmp
UI_Resource/Steinway/h2_hue-lum-sat-sat.bmp
UI_Resource/Steinway/timelapseDeflicker.bmp
UI_Resource/Steinway/mirror.bmp
UI_Resource/Steinway/plusRed.bmp
UI_Resource/Steinway/audio1Monitor.bmp
UI_Resource/Steinway/masterHighlight.bmp
UI_Resource/Steinway/globalScaling.bmp
UI_Resource/Steinway/h2_MotionBlur.bmp
UI_Resource/Steinway/mBlackBlue.bmp
UI_Resource/Steinway/angle_strength.bmp
UI_Resource/Steinway/red_sat.bmp
UI_Resource/Steinway/h2_gpwControl.bmp
UI_Resource/Steinway/h2_gradientPowerWindowAdjustments.bmp
UI_Resource/Steinway/smoothing.bmp
UI_Resource/Steinway/grainOnly.bmp
UI_Resource/Steinway/525SDTV.bmp
UI_Resource/Steinway/numberOfSides.bmp
UI_Resource/Steinway/enableSaturationMapping.bmp
UI_Resource/Steinway/warper.bmp
UI_Resource/Steinway/source.bmp
UI_Resource/Steinway/relativeSpreadRed.bmp
UI_Resource/Steinway/blanking.bmp
UI_Resource/Steinway/stabilize.bmp
UI_Resource/Steinway/filmGrainPresets.bmp
UI_Resource/Steinway/h2_kilovectorRGBQualifier.bmp
UI_Resource/Steinway/openWheelsView.bmp
UI_Resource/Steinway/edgeMaskStrength.bmp
UI_Resource/Steinway/blurType.bmp
UI_Resource/Steinway/edgeDetectionThreshold.bmp
UI_Resource/Steinway/user3.bmp
UI_Resource/Steinway/h2_grid.bmp
UI_Resource/Steinway/lowRange.bmp
UI_Resource/Steinway/h2_colorGenerator.bmp
UI_Resource/Steinway/useRedChannel.bmp
UI_Resource/Steinway/toggle5.bmp
UI_Resource/Steinway/h2_waviness.bmp
UI_Resource/Steinway/greenShadow.bmp
UI_Resource/Steinway/lowMidSaturation.bmp
UI_Resource/Steinway/liveRegionAnalysis.bmp
UI_Resource/Steinway/enableMirror.bmp
UI_Resource/Steinway/highlightRecovery.bmp
UI_Resource/Steinway/denoiseMask.bmp
UI_Resource/Steinway/copyRL.bmp
UI_Resource/Steinway/satGain.bmp
UI_Resource/Steinway/h1_3d.bmp
UI_Resource/Steinway/source_highlights.bmp
UI_Resource/Steinway/user5.bmp
UI_Resource/Steinway/global_blk_offset.bmp
UI_Resource/Steinway/ptzr3DEnable.bmp
UI_Resource/Steinway/gainAudio1.bmp
UI_Resource/Steinway/red.bmp
UI_Resource/Steinway/recoveryAmount.bmp
UI_Resource/Steinway/softSharpen.bmp
UI_Resource/Steinway/HighThreshold.bmp
UI_Resource/Steinway/185.bmp
UI_Resource/Steinway/sAndGOffset.bmp
UI_Resource/Steinway/masterColor.bmp
UI_Resource/Steinway/midtoneOffset.bmp
UI_Resource/Steinway/blushSize.bmp
UI_Resource/Steinway/h2_deadPixelFixer.bmp
UI_Resource/Steinway/postMixInvert.bmp
UI_Resource/Steinway/rightRotate.bmp
UI_Resource/Steinway/position.bmp
UI_Resource/Steinway/h2_gaussianImageBlur.bmp
UI_Resource/Steinway/midtone.bmp
UI_Resource/Steinway/pvwMode.bmp
UI_Resource/Steinway/blueShadow.bmp
UI_Resource/Steinway/removerSize.bmp
UI_Resource/Steinway/iterateAbstraction.bmp
UI_Resource/Steinway/amplitude.bmp
UI_Resource/Steinway/minusRed.bmp
UI_Resource/Steinway/skinModelReady.bmp
UI_Resource/Steinway/h2_cameraShake.bmp
UI_Resource/Steinway/bottomSoft.bmp
UI_Resource/Steinway/h2_vortex.bmp
UI_Resource/Steinway/boxBlur.bmp
UI_Resource/Steinway/input.bmp
UI_Resource/Steinway/refSizing.bmp
UI_Resource/Steinway/sAndGRadius.bmp
UI_Resource/Steinway/leftRight.bmp
UI_Resource/Steinway/light_sat.bmp
UI_Resource/Steinway/previousTrackEnd.bmp
UI_Resource/Steinway/trackPrev.bmp
UI_Resource/Steinway/faceMaskSize.bmp
UI_Resource/Steinway/starburstSize.bmp
UI_Resource/Steinway/colFade.bmp
UI_Resource/Steinway/eyeBrightening.bmp
UI_Resource/Steinway/instructions.bmp
UI_Resource/Steinway/masterClip.bmp
UI_Resource/Steinway/fineDetails.bmp
UI_Resource/Steinway/global_strength.bmp
UI_Resource/Steinway/deleteTracking.bmp
UI_Resource/Steinway/greenHighLevel.bmp
UI_Resource/Steinway/green.bmp
UI_Resource/Steinway/top.bmp
UI_Resource/Steinway/h2_colorGaussianBlur.bmp
UI_Resource/Steinway/greenBlue.bmp
UI_Resource/Steinway/plusGreen.bmp
UI_Resource/Steinway/renderPlaceholderGrid.bmp
UI_Resource/Steinway/qualifierGain.bmp
UI_Resource/Steinway/primaries.bmp
UI_Resource/Steinway/h2_resolveFX.bmp
UI_Resource/Steinway/h1_spiritSixSectorSecondaries.bmp
UI_Resource/Steinway/zoneFalloff.bmp
UI_Resource/Steinway/redMeanLevel.bmp
UI_Resource/Steinway/slider23.bmp
UI_Resource/Steinway/compositeType.bmp
UI_Resource/Steinway/dehaze.bmp
UI_Resource/Steinway/operation.bmp
UI_Resource/Steinway/h2_temporalNoiseReduction.bmp
UI_Resource/Steinway/global_md_det.bmp
UI_Resource/Steinway/tint.bmp
UI_Resource/Steinway/maskThreshold.bmp
UI_Resource/Steinway/pointsDelete.bmp
UI_Resource/Steinway/h2_customCurves.bmp
UI_Resource/Steinway/slider19.bmp
UI_Resource/Steinway/greenGamma.bmp
UI_Resource/Steinway/h2_deband.bmp
UI_Resource/Steinway/matchingGrade.bmp
UI_Resource/Steinway/scaleComponent.bmp
UI_Resource/Steinway/lumCurve.bmp
UI_Resource/Steinway/fill-InMethod.bmp
UI_Resource/Steinway/lumHiClip.bmp
UI_Resource/Steinway/framingUp.bmp
UI_Resource/Steinway/addSerial.bmp
UI_Resource/Steinway/relativeSpreadBlue.bmp
UI_Resource/Steinway/sixScChroma.bmp
UI_Resource/Steinway/naturalSpeed.bmp
UI_Resource/Steinway/stabilizeBrightness.bmp
UI_Resource/Steinway/timeline.bmp
UI_Resource/Steinway/magenta_sat.bmp
UI_Resource/Steinway/frequencyScale.bmp
UI_Resource/Steinway/h2_hue-lum-lum-sat.bmp
UI_Resource/Steinway/edgeDetect.bmp
UI_Resource/Steinway/viewProcessed.bmp
UI_Resource/Steinway/regionOfAnalysis.bmp
UI_Resource/Steinway/hueCenter.bmp
UI_Resource/Steinway/temp.bmp
UI_Resource/Steinway/Animate.bmp
UI_Resource/Steinway/deadPixelFixer.bmp
UI_Resource/Steinway/printNeg.bmp
UI_Resource/Steinway/slider14.bmp
UI_Resource/Steinway/topPosition.bmp
UI_Resource/Steinway/pcw.bmp
UI_Resource/Steinway/iso.bmp
UI_Resource/Steinway/sat.bmp
UI_Resource/Steinway/hFlip.bmp
UI_Resource/Steinway/hueSoft.bmp
UI_Resource/Steinway/glareBrightness.bmp
UI_Resource/Steinway/vSize.bmp
UI_Resource/Steinway/h2_contrastPivot.bmp
UI_Resource/Steinway/skinMaskSource.bmp
UI_Resource/Steinway/enableLuminanceMapping.bmp
UI_Resource/Steinway/1080i60Hz.bmp
UI_Resource/Steinway/trackRev.bmp
UI_Resource/Steinway/clearTrack.bmp
UI_Resource/Steinway/h2_masking.bmp
UI_Resource/Steinway/size.bmp
UI_Resource/Steinway/preset.bmp
UI_Resource/Steinway/splitScreenNeighbor.bmp
UI_Resource/Steinway/stabilizeGreenChannel.bmp
UI_Resource/Steinway/symmetry.bmp
UI_Resource/Steinway/rippleMode.bmp
UI_Resource/Steinway/mix.bmp
UI_Resource/Steinway/monAudio2.bmp
UI_Resource/Steinway/green_hue.bmp
UI_Resource/Steinway/eyeLight.bmp
UI_Resource/Steinway/source_arri_colortemp.bmp
UI_Resource/Steinway/h2_keyParameters.bmp
UI_Resource/Steinway/back.bmp
UI_Resource/Steinway/dentType.bmp
UI_Resource/Steinway/redBlue.bmp
UI_Resource/Steinway/sdtvRatio.bmp
UI_Resource/Steinway/hippi.bmp
UI_Resource/Steinway/optimizedMode.bmp
UI_Resource/Steinway/22.bmp
UI_Resource/Steinway/global_angle.bmp
UI_Resource/Steinway/main.bmp
UI_Resource/Steinway/sh2Pos.bmp
UI_Resource/Steinway/globalSaturation.bmp
UI_Resource/Steinway/aperturePeak.bmp
UI_Resource/Steinway/nodePlusPpw.bmp
UI_Resource/Steinway/h1_resolveFX.bmp
UI_Resource/Steinway/h2_topLevel.bmp
UI_Resource/Steinway/sceneNumber.bmp
UI_Resource/Steinway/red_to_blue.bmp
UI_Resource/Steinway/faceMaskSoftness.bmp
UI_Resource/Steinway/wipe.bmp
UI_Resource/Steinway/paste.bmp
UI_Resource/Steinway/1080p24Hz.bmp
UI_Resource/Steinway/noiseReductionBlend.bmp
UI_Resource/Steinway/still.bmp
UI_Resource/Steinway/h2_gaussianBlur.bmp
UI_Resource/Steinway/interPos.bmp
UI_Resource/Steinway/minusBlue.bmp
UI_Resource/Steinway/outsideSoft.bmp
UI_Resource/Steinway/foreheadHue.bmp
UI_Resource/Steinway/lensBlur.bmp
UI_Resource/Steinway/gt.bmp
UI_Resource/Steinway/highlights.bmp
UI_Resource/Steinway/shadows.bmp
UI_Resource/Steinway/h1_spiritTelecinePrimaries.bmp
UI_Resource/Steinway/h2_apertureContours.bmp
UI_Resource/Steinway/h2_radialBlur.bmp
UI_Resource/Steinway/greenCurve.bmp
UI_Resource/Steinway/rgbMixer_Mono.bmp
UI_Resource/Steinway/h2_imageSizing.bmp
UI_Resource/Steinway/midPoint.bmp
UI_Resource/Steinway/controlVisibility.bmp
UI_Resource/Steinway/toggle8.bmp
UI_Resource/Steinway/h2_kilovectorLuminanceQualifier.bmp
UI_Resource/Steinway/colorPicker.bmp
UI_Resource/Steinway/clipFrame.bmp
UI_Resource/Steinway/displayDepth.bmp
UI_Resource/Steinway/16mmMode.bmp
UI_Resource/Steinway/green_sat.bmp
UI_Resource/Steinway/inputMax.bmp
UI_Resource/Steinway/detailSize.bmp
UI_Resource/Steinway/3d.bmp
UI_Resource/Steinway/channelSelect.bmp
UI_Resource/Steinway/toggle6.bmp
UI_Resource/Steinway/slider8.bmp
UI_Resource/Steinway/smooth.bmp
UI_Resource/Steinway/randomSeed.bmp
UI_Resource/Steinway/blockAspectRatio.bmp
UI_Resource/Steinway/firstFrame.bmp
UI_Resource/Steinway/shiftGreen.bmp
UI_Resource/Steinway/user1.bmp
UI_Resource/Steinway/cyan_lum.bmp
UI_Resource/Steinway/enableToneMapping.bmp
UI_Resource/Steinway/bar_frgrnd.bmp
UI_Resource/Steinway/h2_audioTwoSetup.bmp
UI_Resource/Steinway/upperLipSmooth.bmp
UI_Resource/Steinway/output.bmp
UI_Resource/Steinway/h2s_right.bmp
UI_Resource/Steinway/iterations.bmp
UI_Resource/Steinway/audio2Monitor.bmp
UI_Resource/Steinway/nextScene.bmp
UI_Resource/Steinway/colorMono.bmp
UI_Resource/Steinway/eyeSharpening.bmp
UI_Resource/Steinway/blueHighlight.bmp
UI_Resource/Steinway/h2_contoursSetup.bmp
UI_Resource/Steinway/greenHiClip.bmp
UI_Resource/Steinway/aspectMatch.bmp
UI_Resource/Steinway/deleteKeyframe.bmp
UI_Resource/Steinway/softnessBlur.bmp
UI_Resource/Steinway/imageMode.bmp
UI_Resource/Steinway/maxInputLuminance.bmp
UI_Resource/Steinway/save.bmp
UI_Resource/Steinway/repeatPositionSeed.bmp
UI_Resource/Steinway/starburstSplitAngle.bmp
UI_Resource/Steinway/60PercentLum.bmp
UI_Resource/Steinway/green_to_lum.bmp
UI_Resource/Steinway/audio2NR.bmp
UI_Resource/Steinway/convertToPCW.bmp
UI_Resource/Steinway/audio2Delay.bmp
UI_Resource/Steinway/jpegDamage.bmp
UI_Resource/Steinway/slider6.bmp
UI_Resource/Steinway/sizing.bmp
UI_Resource/Steinway/clearAllPoints.bmp
UI_Resource/Steinway/h2_sourceCanonControls.bmp
UI_Resource/Steinway/framesEitherSide.bmp
UI_Resource/Steinway/drawOverlays.bmp
UI_Resource/Steinway/hue.bmp
UI_Resource/Steinway/cyan_hue.bmp
UI_Resource/Steinway/h2_aspect.bmp
UI_Resource/Steinway/source_gain.bmp
UI_Resource/Steinway/lensCenterYPosition.bmp
UI_Resource/Steinway/tiltShiftBlur.bmp
UI_Resource/Steinway/glow.bmp
UI_Resource/Steinway/outputBlanking.bmp
UI_Resource/Steinway/sharpenAmount.bmp
UI_Resource/Steinway/tkPan.bmp
UI_Resource/Steinway/analyzeFrame.bmp
UI_Resource/Steinway/blueClip.bmp
UI_Resource/Steinway/h2_floatingWindows.bmp
UI_Resource/Steinway/h2_jpegDamage.bmp
UI_Resource/Steinway/yellow.bmp
UI_Resource/Steinway/data50Hz.bmp
UI_Resource/Steinway/horLineWidth.bmp
UI_Resource/Steinway/sourcered.bmp
UI_Resource/Steinway/highRange.bmp
UI_Resource/Steinway/h2_spatialNoiseReduction.bmp
UI_Resource/Steinway/slider22.bmp
UI_Resource/Steinway/178.bmp
UI_Resource/Steinway/audio1OnOff.bmp
UI_Resource/Steinway/h1_inputSizing.bmp
UI_Resource/Steinway/missingImage.bmp
UI_Resource/Steinway/h2_cpwControl.bmp
UI_Resource/Steinway/lensFlare.bmp
UI_Resource/Steinway/lumHiSoft.bmp
UI_Resource/Steinway/postMixOffset.bmp
UI_Resource/Steinway/radialBlur.bmp
UI_Resource/Steinway/splitScreenVersionsAndOriginal.bmp
UI_Resource/Steinway/blushSaturation.bmp
UI_Resource/Steinway/lumBlack.bmp
UI_Resource/Steinway/zoom.bmp
UI_Resource/Steinway/bars.bmp
UI_Resource/Steinway/start.bmp
UI_Resource/Steinway/lock.bmp
UI_Resource/Steinway/source_lift.bmp
UI_Resource/Steinway/lastFrame.bmp
UI_Resource/Steinway/toggle9.bmp
UI_Resource/Steinway/direction.bmp
UI_Resource/Steinway/amplitudeHorizontal.bmp
UI_Resource/Steinway/areaMark.bmp
UI_Resource/Steinway/masterOffset.bmp
UI_Resource/Steinway/h2_lensBlur.bmp
UI_Resource/Steinway/1250i50Hz.bmp
UI_Resource/Steinway/fcc.bmp
UI_Resource/Steinway/displayMode.bmp
UI_Resource/Steinway/MidHighSaturation.bmp
UI_Resource/Steinway/lensFlarePreset.bmp
UI_Resource/Steinway/deband.bmp
UI_Resource/Steinway/h2_redBluePotControls.bmp
UI_Resource/Steinway/exitSetup.bmp
UI_Resource/Steinway/ripple.bmp
UI_Resource/Steinway/wipeMode.bmp
UI_Resource/Steinway/trackingPatches.bmp
UI_Resource/Steinway/smallSkinTexture.bmp
UI_Resource/Steinway/eyebagRemoval.bmp
UI_Resource/Steinway/blackLevel.bmp
UI_Resource/Steinway/rayDirections.bmp
UI_Resource/Steinway/h1_externalKeyMatteSizing.bmp
UI_Resource/Steinway/topRotate.bmp
UI_Resource/Steinway/h2_highlight.bmp
UI_Resource/Steinway/showCenter.bmp
UI_Resource/Steinway/user4.bmp
UI_Resource/Steinway/shadowLevel.bmp
UI_Resource/Steinway/curves.bmp
UI_Resource/Steinway/yFlip.bmp
UI_Resource/Steinway/h2_lumGreenPotControls.bmp
UI_Resource/Steinway/amplitudeRotational.bmp
UI_Resource/Steinway/h2_3d.bmp
UI_Resource/Steinway/lum.bmp
UI_Resource/Steinway/printPos.bmp
UI_Resource/Steinway/starburstSplitBalance.bmp
UI_Resource/Steinway/userAspect.bmp
UI_Resource/Steinway/redClip.bmp
UI_Resource/Steinway/h2_telecineSpeed.bmp
UI_Resource/Steinway/175.bmp
UI_Resource/Steinway/wipeOnOff.bmp
UI_Resource/Steinway/flareSize.bmp
UI_Resource/Steinway/largeDetails.bmp
UI_Resource/Steinway/lumaThreshold.bmp
UI_Resource/Steinway/gamma.bmp
UI_Resource/Steinway/perfType.bmp
UI_Resource/Steinway/hueSymmetry.bmp
UI_Resource/Steinway/speedScale.bmp
UI_Resource/Steinway/smoothStrength.bmp
UI_Resource/Steinway/swapOutput.bmp
UI_Resource/Steinway/h2_dent.bmp
UI_Resource/Steinway/1080sf24Hz.bmp
UI_Resource/Steinway/h2_mosaicBlur.bmp
UI_Resource/Steinway/highLevel.bmp
UI_Resource/Steinway/largeSkinTexture.bmp
UI_Resource/Steinway/toggle2.bmp
UI_Resource/Steinway/relativeRipple.bmp
UI_Resource/Steinway/h2_rgbMixerControls.bmp
UI_Resource/Steinway/trackBackwards.bmp
UI_Resource/Steinway/xy_angle.bmp
UI_Resource/Steinway/xPosition.bmp
UI_Resource/Steinway/exit.bmp
UI_Resource/Steinway/greenGain.bmp
UI_Resource/Steinway/contours.bmp
UI_Resource/Steinway/globalDefocus.bmp
UI_Resource/Steinway/showTrackers.bmp
UI_Resource/Steinway/audio1Delay.bmp
UI_Resource/Steinway/filmVCtr.bmp
UI_Resource/Steinway/gpw.bmp
UI_Resource/Steinway/hueWidth.bmp
UI_Resource/Steinway/globalTemp.bmp
UI_Resource/Steinway/minusGreen.bmp
UI_Resource/Steinway/desaturationShadow.bmp
UI_Resource/Steinway/denoiseStrength.bmp
UI_Resource/Steinway/contrast.bmp
UI_Resource/Steinway/panAmplitude.bmp
UI_Resource/Steinway/deleteNode.bmp
UI_Resource/Steinway/switchToWheelsView.bmp
UI_Resource/Steinway/analyse.bmp
UI_Resource/Steinway/toneDetail.bmp
UI_Resource/Steinway/bankGlobal.bmp
UI_Resource/Steinway/redSharpen.bmp
UI_Resource/Steinway/ghost2Type.bmp
UI_Resource/Steinway/displayEdges.bmp
UI_Resource/Steinway/green_lum.bmp
UI_Resource/Steinway/blueMeanLevel.bmp
UI_Resource/Steinway/projn.bmp
UI_Resource/Steinway/emboss.bmp
UI_Resource/Steinway/currentFrame.bmp
UI_Resource/Steinway/colorGeneratorPlugin.bmp
UI_Resource/Steinway/redBlack.bmp
UI_Resource/Steinway/h2_light.bmp
UI_Resource/Steinway/lineShift.bmp
UI_Resource/Steinway/h2_green.bmp
UI_Resource/Steinway/red_to_green.bmp
UI_Resource/Steinway/greenBlack.bmp
UI_Resource/Steinway/adaptation.bmp
UI_Resource/Steinway/showWarpBoundaries.bmp
UI_Resource/Steinway/hslPlus.bmp
UI_Resource/Steinway/lightRays.bmp
UI_Resource/Steinway/mistParameter.bmp
UI_Resource/Steinway/h2_zoomBlur.bmp
UI_Resource/Steinway/showTrack.bmp
UI_Resource/Steinway/source_red_brightness.bmp
UI_Resource/Steinway/horizontalStrength.bmp
UI_Resource/Steinway/h2_prismBlur.bmp
UI_Resource/Steinway/stabilizationMethod.bmp
UI_Resource/Steinway/highlightRolloff.bmp
UI_Resource/Steinway/h2_kilovectorHSLQualifier.bmp
UI_Resource/Steinway/highAndLowChroma.bmp
UI_Resource/Steinway/green_to_red.bmp
UI_Resource/Steinway/global_exposure.bmp
UI_Resource/Steinway/crtGamma.bmp
UI_Resource/Steinway/filmHCtr.bmp
UI_Resource/Steinway/verticalStrength.bmp
UI_Resource/Steinway/aspect.bmp
UI_Resource/Steinway/keyMode.bmp
UI_Resource/Steinway/shearx.bmp
UI_Resource/Steinway/blueGreen.bmp
UI_Resource/Steinway/enableZoom.bmp
UI_Resource/Steinway/proxyOnOff.bmp
UI_Resource/Steinway/outputMax.bmp
UI_Resource/Steinway/h2_sourceSonyF65Controls.bmp
UI_Resource/Steinway/off.bmp
UI_Resource/Steinway/source_sharpness.bmp
UI_Resource/Steinway/redSoft.bmp
UI_Resource/Steinway/staticRipple.bmp
UI_Resource/Steinway/curves_sat_sat.bmp
UI_Resource/Steinway/source_red_gamma.bmp
UI_Resource/Steinway/rgbMixer_Color.bmp
UI_Resource/Steinway/redLowClip.bmp
UI_Resource/Steinway/redOffset.bmp
UI_Resource/Steinway/openZonesGraph.bmp
UI_Resource/Steinway/h2_sceneWhiteClips.bmp
UI_Resource/Steinway/leftSoft.bmp
UI_Resource/Steinway/wedgeWidth.bmp
UI_Resource/Steinway/pasteTrim.bmp
UI_Resource/Steinway/closeWheelsView.bmp
UI_Resource/Steinway/lumGamma.bmp
UI_Resource/Steinway/previous.bmp
UI_Resource/Steinway/0PercentLum.bmp
UI_Resource/Steinway/masterSoft.bmp
UI_Resource/Steinway/angle.bmp
UI_Resource/Steinway/hv.bmp
UI_Resource/Steinway/softness.bmp
UI_Resource/Steinway/lowLevel.bmp
UI_Resource/Steinway/h2_hslParametersQualifierBlur.bmp
UI_Resource/Steinway/plusMaster.bmp
UI_Resource/Steinway/720p59Hz.bmp
UI_Resource/Steinway/h2_imageSharpeningCoring.bmp
UI_Resource/Steinway/useMask.bmp
UI_Resource/Steinway/1080sf23Hz.bmp
UI_Resource/Steinway/selected.bmp
UI_Resource/Steinway/mBlackGreen.bmp
UI_Resource/Steinway/bottom.bmp
UI_Resource/Steinway/20PercentLum.bmp
UI_Resource/Steinway/detail.bmp
UI_Resource/Steinway/strength.bmp
UI_Resource/Steinway/cntrPeak.bmp
UI_Resource/Steinway/h2_refWipeSizingAdjustments.bmp
UI_Resource/Steinway/format.bmp
UI_Resource/Steinway/blueOffset.bmp
UI_Resource/Steinway/horzOffset.bmp
UI_Resource/Steinway/threshold.bmp
UI_Resource/Steinway/source_red_sat.bmp
UI_Resource/Steinway/pitch.bmp
UI_Resource/Steinway/virtualLightSourceSize.bmp
UI_Resource/Steinway/focus.bmp
UI_Resource/Steinway/tvHCtr.bmp
UI_Resource/Steinway/pointsClear.bmp
UI_Resource/Steinway/multiBurst.bmp
UI_Resource/Steinway/insideSoft.bmp
UI_Resource/Steinway/235.bmp
UI_Resource/Steinway/blueMidtone.bmp
UI_Resource/Steinway/internal.bmp
UI_Resource/Steinway/satHiClip.bmp
UI_Resource/Steinway/globalBrightness.bmp
UI_Resource/Steinway/redRadius.bmp
UI_Resource/Steinway/tvVSize.bmp
UI_Resource/Steinway/copyTrim.bmp
UI_Resource/Steinway/monAudio1.bmp
UI_Resource/Steinway/h2_boxBlur.bmp
UI_Resource/Steinway/redGain.bmp
UI_Resource/Steinway/blueDistortion.bmp
UI_Resource/Steinway/speed.bmp
UI_Resource/Steinway/useDefault.bmp
UI_Resource/Steinway/preBlur.bmp
UI_Resource/Steinway/source_red_iso.bmp
UI_Resource/Steinway/motionBlurShutterCycle.bmp
UI_Resource/Steinway/BlendAmount.bmp
UI_Resource/Steinway/h2_ripple.bmp
UI_Resource/Steinway/greenMeanLevel.bmp
UI_Resource/Steinway/linearEffect.bmp
UI_Resource/Steinway/greenMidtone.bmp
UI_Resource/Steinway/interNeg.bmp
UI_Resource/Steinway/threeD.bmp
UI_Resource/Steinway/BladeCurvature.bmp
UI_Resource/Steinway/cancelRipple.bmp
UI_Resource/Steinway/objectTracking.bmp
UI_Resource/Steinway/noiseReductionThreshold.bmp
UI_Resource/Steinway/curves_hue_hue.bmp
UI_Resource/Steinway/sourceXPosition.bmp
UI_Resource/Steinway/720p60Hz.bmp
UI_Resource/Steinway/nodePlusPcw.bmp
UI_Resource/Steinway/h2s_oppose.bmp
UI_Resource/Steinway/blank.bmp
UI_Resource/Steinway/slider7.bmp
UI_Resource/Steinway/sourceOfRays.bmp
UI_Resource/Steinway/red_lum.bmp
UI_Resource/Steinway/cueMode.bmp
UI_Resource/Steinway/yellow_sat.bmp
UI_Resource/Steinway/h2_gmSatComp.bmp
UI_Resource/Steinway/embossStyle.bmp
UI_Resource/Steinway/pauseAmt.bmp
UI_Resource/Steinway/h2_audioSetup.bmp
UI_Resource/Steinway/showPaths.bmp
UI_Resource/Steinway/logLin.bmp
UI_Resource/Steinway/tvSize.bmp
UI_Resource/Steinway/inputColorSpace.bmp
UI_Resource/Steinway/safeArea.bmp
UI_Resource/Steinway/mosaicBlur.bmp
UI_Resource/Steinway/useCustomInputMax.bmp
UI_Resource/Steinway/h2_blank.bmp
UI_Resource/Steinway/global_contrast.bmp
UI_Resource/Steinway/shadowRolloff.bmp
UI_Resource/Steinway/testPoint.bmp
UI_Resource/Steinway/nodePlusCpw.bmp
UI_Resource/Steinway/addParallel.bmp
UI_Resource/Steinway/enablePan.bmp
UI_Resource/Steinway/ghost5Type.bmp
UI_Resource/Steinway/clearSelectedKF.bmp
UI_Resource/Steinway/h2_warper.bmp
UI_Resource/Steinway/h2_outputBlankingAdjustments.bmp
UI_Resource/Steinway/greenHighlight.bmp
UI_Resource/Steinway/mWhiteMaster.bmp
UI_Resource/Steinway/Sheary.bmp
UI_Resource/Steinway/slider5.bmp
UI_Resource/Steinway/redRed.bmp
UI_Resource/Steinway/stereo.bmp
UI_Resource/Steinway/framingDown.bmp
UI_Resource/Steinway/source_arri_iso.bmp
UI_Resource/Steinway/colorBoost.bmp
UI_Resource/Steinway/gainBal.bmp
UI_Resource/Steinway/gmSatComp.bmp
UI_Resource/Steinway/hSize.bmp
UI_Resource/Steinway/blackClipMatte.bmp
UI_Resource/Steinway/slider16.bmp
UI_Resource/Steinway/h1_outputSizing.bmp
UI_Resource/Steinway/source_shadows.bmp
UI_Resource/Steinway/h2_emboss.bmp
UI_Resource/Steinway/gang.bmp
UI_Resource/Steinway/yaw.bmp
UI_Resource/Steinway/h2_NoiseReduction.bmp
UI_Resource/Steinway/whiteClipMatte.bmp
UI_Resource/Steinway/lumLowClip.bmp
UI_Resource/Steinway/width.bmp
UI_Resource/Steinway/canvasControls.bmp
UI_Resource/Steinway/edgeOverlay.bmp
UI_Resource/Steinway/recTC.bmp
UI_Resource/Steinway/invertWipe.bmp
UI_Resource/Steinway/verticalShineHeight.bmp
UI_Resource/Steinway/saw100.bmp
UI_Resource/Steinway/blurRadius.bmp
UI_Resource/Steinway/grainClip.bmp
UI_Resource/Steinway/greenSoft.bmp
UI_Resource/Steinway/lipSaturation.bmp
UI_Resource/Steinway/magenta.bmp
UI_Resource/Steinway/scale.bmp
UI_Resource/Steinway/lowSaturation.bmp
UI_Resource/Steinway/level.bmp
UI_Resource/Steinway/source_red_redgain.bmp
UI_Resource/Steinway/swapLR.bmp
UI_Resource/Steinway/slider20.bmp
UI_Resource/Steinway/rippleShape.bmp
UI_Resource/Steinway/grainSize.bmp
UI_Resource/Steinway/scanEffect.bmp
UI_Resource/Steinway/zoomType.bmp
UI_Resource/Steinway/regionForAnalysis.bmp
UI_Resource/Steinway/amount.bmp
UI_Resource/Steinway/h2_abstraction.bmp
UI_Resource/Steinway/smallTexture.bmp
UI_Resource/Steinway/contrastPop.bmp
UI_Resource/Steinway/numberOfColors.bmp
UI_Resource/Steinway/hvOffset.bmp
UI_Resource/Steinway/sharpenEdgePlugin.bmp
UI_Resource/Steinway/shineThreshold.bmp
UI_Resource/Steinway/h1_globalReferenceSizing.bmp
UI_Resource/Steinway/pan.bmp
UI_Resource/Steinway/lineAngle.bmp
UI_Resource/Steinway/smoothness.bmp
UI_Resource/Steinway/bristleDensity.bmp
UI_Resource/Steinway/wavinessType.bmp
UI_Resource/Steinway/h2_sourceArriControls.bmp
UI_Resource/Steinway/shiftBlue.bmp
UI_Resource/Steinway/displayEdge.bmp
UI_Resource/Steinway/sixScEnable.bmp
UI_Resource/Steinway/noiseReductionRadius.bmp
UI_Resource/Steinway/mBlackMaster.bmp
UI_Resource/Steinway/shadowThreshold.bmp
UI_Resource/Steinway/warpSharpness.bmp
UI_Resource/Steinway/rightPosition.bmp
UI_Resource/Steinway/brightening.bmp
UI_Resource/Steinway/h2_hue-lum-sat-lum.bmp
UI_Resource/Steinway/blend.bmp
UI_Resource/Steinway/sourceHeight.bmp
UI_Resource/Steinway/smoothingThreshold.bmp
UI_Resource/Steinway/source_color_boost.bmp
UI_Resource/Steinway/lowChroma.bmp
UI_Resource/Steinway/enable.bmp
UI_Resource/Steinway/splitScreenVersions.bmp
UI_Resource/Steinway/h2_dehaze.bmp
UI_Resource/Steinway/sourcearri.bmp
UI_Resource/Steinway/next.bmp
UI_Resource/Steinway/conv.bmp
UI_Resource/Steinway/refWipeVflip.bmp
UI_Resource/Steinway/1080p25Hz.bmp
UI_Resource/Steinway/starburstSoftness.bmp
UI_Resource/Steinway/sourceSonyF65.bmp
UI_Resource/Steinway/windows.bmp
UI_Resource/Steinway/Sharpening.bmp
UI_Resource/Steinway/h2_colorCompressor.bmp
UI_Resource/Steinway/decay.bmp
UI_Resource/Steinway/exitAsWas.bmp
UI_Resource/Steinway/extendRange.bmp
UI_Resource/Steinway/redHiClip.bmp
UI_Resource/Steinway/forcedRipple.bmp
UI_Resource/Steinway/blueCurve.bmp
UI_Resource/Steinway/redShadow.bmp
UI_Resource/Steinway/greenBlur.bmp
UI_Resource/Steinway/centerX.bmp
UI_Resource/Steinway/greenLowClip.bmp
UI_Resource/Steinway/blueHiClip.bmp
UI_Resource/Steinway/pivot.bmp
UI_Resource/Steinway/inOutRatio.bmp
UI_Resource/Steinway/saturationKnee.bmp
UI_Resource/Steinway/sharpen.bmp
UI_Resource/Steinway/blueLowLevel.bmp
UI_Resource/Steinway/239.bmp
UI_Resource/Steinway/waveShape.bmp
UI_Resource/Steinway/h2_watercolor.bmp
UI_Resource/Steinway/leftPosition.bmp
UI_Resource/Steinway/filmType.bmp
UI_Resource/Steinway/redMidtone.bmp
UI_Resource/Steinway/offline.bmp
UI_Resource/Steinway/apertureCoring.bmp
UI_Resource/Steinway/625844.bmp
UI_Resource/Steinway/audio2OnOff.bmp
UI_Resource/Steinway/h1_qualifier.bmp
UI_Resource/Steinway/randomnessSpeed.bmp
UI_Resource/Steinway/height.bmp
UI_Resource/Steinway/curves_sat_lum.bmp
UI_Resource/Steinway/greenDistortion.bmp
UI_Resource/Steinway/h2_cyan.bmp
UI_Resource/Steinway/source_red_flut.bmp
UI_Resource/Steinway/grnYlwRed.bmp
UI_Resource/Steinway/openFX.bmp
UI_Resource/Steinway/dark_sat.bmp
UI_Resource/Steinway/h2_fccModes.bmp
UI_Resource/Steinway/tkSixSector.bmp
UI_Resource/Steinway/pasteAnalysis.bmp
UI_Resource/Steinway/blackOffset.bmp
UI_Resource/Steinway/sizeBase.bmp
UI_Resource/Steinway/h1_HDR.bmp
UI_Resource/Steinway/geometry.bmp
UI_Resource/Steinway/offset.bmp
UI_Resource/Steinway/ghost7Type.bmp
UI_Resource/Steinway/pauseLength.bmp
UI_Resource/Steinway/cropTop.bmp
UI_Resource/Steinway/motionEffects.bmp
UI_Resource/Steinway/enableRipple.bmp
UI_Resource/Steinway/slider2.bmp
UI_Resource/Steinway/textureThreshold.bmp
UI_Resource/Steinway/adjustMask.bmp
UI_Resource/Steinway/lowThreshold.bmp
UI_Resource/Steinway/red_to_red.bmp
UI_Resource/Steinway/audio.bmp
UI_Resource/Steinway/abstractionStrength.bmp
UI_Resource/Steinway/flip.bmp
UI_Resource/Steinway/refReset.bmp
UI_Resource/Steinway/h2_shadow.bmp
UI_Resource/Steinway/plusBlue.bmp
UI_Resource/Steinway/source_red_greengain.bmp
UI_Resource/Steinway/handlesSnapToContent.bmp
UI_Resource/Steinway/ringing.bmp
UI_Resource/Steinway/opacity.bmp
UI_Resource/Steinway/showOverlay.bmp
UI_Resource/Steinway/gaussianBlur.bmp
UI_Resource/Steinway/blueBlack.bmp
UI_Resource/Steinway/resetAlign.bmp
UI_Resource/Steinway/key.bmp
UI_Resource/Steinway/channels.bmp
UI_Resource/Steinway/centerBrightness.bmp
UI_Resource/Steinway/curves_hue_lum.bmp
UI_Resource/Steinway/ghost1Type.bmp
UI_Resource/Steinway/showCompResult.bmp
UI_Resource/Steinway/abstraction.bmp
UI_Resource/Steinway/switchSession.bmp
UI_Resource/Steinway/quality.bmp
UI_Resource/Steinway/h2_filmGrain.bmp
UI_Resource/Steinway/h2_filmBlanking.bmp
UI_Resource/Steinway/zoomAmplitude.bmp
UI_Resource/Steinway/relativeSpreadGreen.bmp
UI_Resource/Steinway/reflectAtBorders.bmp
UI_Resource/Steinway/blueGain.bmp
UI_Resource/Steinway/masterShadow.bmp
UI_Resource/Steinway/useVideoBlackLevel.bmp
UI_Resource/Steinway/redScaling.bmp
UI_Resource/Steinway/black.bmp
UI_Resource/Steinway/rotation.bmp
UI_Resource/Steinway/prismBlur.bmp
UI_Resource/Steinway/majorLineWidth.bmp
UI_Resource/Steinway/h2_steadiscanSetup.bmp
UI_Resource/Steinway/cuePrev.bmp
UI_Resource/Steinway/slider12.bmp
UI_Resource/Steinway/safeAction.bmp
UI_Resource/Steinway/phase.bmp
UI_Resource/Steinway/zoomChangeAmpl.bmp
UI_Resource/Steinway/caACA.bmp
UI_Resource/Steinway/steps.bmp
UI_Resource/Steinway/numberOfFrames.bmp
UI_Resource/Steinway/colorMatchCurves.bmp
UI_Resource/Steinway/masterMidtone.bmp
UI_Resource/Steinway/redLowLevel.bmp
UI_Resource/Steinway/mediumDetails.bmp
UI_Resource/Steinway/stair.bmp
UI_Resource/Steinway/whatToStabilize.bmp
UI_Resource/Steinway/mid_light_sat.bmp
UI_Resource/Steinway/h1_blank.bmp
UI_Resource/Steinway/slider11.bmp
UI_Resource/Steinway/splitScreenOff.bmp
UI_Resource/Steinway/majorLineSpacing.bmp
UI_Resource/Steinway/cntrChroma.bmp
UI_Resource/Steinway/h2_matchingControls.bmp
UI_Resource/Steinway/colorStabilizer.bmp
UI_Resource/Steinway/h2_contrastPop.bmp
UI_Resource/Steinway/satLowSoft.bmp
UI_Resource/Steinway/enablePerspective3D.bmp
UI_Resource/Steinway/global_hue.bmp
UI_Resource/Steinway/prune.bmp
UI_Resource/Steinway/scaleControls.bmp
UI_Resource/Steinway/toggle11.bmp
UI_Resource/Steinway/source_red_contrast.bmp
UI_Resource/Steinway/redGreen.bmp
UI_Resource/Steinway/h2_directionalBlur.bmp
UI_Resource/Steinway/selectOutput.bmp
UI_Resource/Steinway/sourceYPosition.bmp
UI_Resource/Steinway/qualifierOffset.bmp
UI_Resource/Steinway/smallTextureSize.bmp
UI_Resource/Steinway/greenClip.bmp
UI_Resource/Steinway/h2_repro.bmp
UI_Resource/Steinway/borderType.bmp
UI_Resource/Steinway/h2_powerCurveWindowAdjustments.bmp
UI_Resource/Steinway/sh1Neg.bmp
UI_Resource/Steinway/curves_hue_sat.bmp
UI_Resource/Steinway/h2_scanEffects.bmp
UI_Resource/Steinway/postRefine.bmp
UI_Resource/Steinway/numberOfIterations.bmp
UI_Resource/Steinway/edgeDetectThr.bmp
UI_Resource/Steinway/foreheadSaturation.bmp
UI_Resource/Steinway/spread.bmp
UI_Resource/Steinway/addOutside.bmp
UI_Resource/Steinway/useBlueChannel.bmp
UI_Resource/Steinway/h2_dark.bmp
UI_Resource/Steinway/nextKeyfrm.bmp
UI_Resource/Steinway/525844.bmp
UI_Resource/Steinway/source_midtone_detail.bmp
UI_Resource/Steinway/source_red_shadow.bmp
UI_Resource/Steinway/lumLowSoft.bmp
UI_Resource/Steinway/h2_ppwControl.bmp
UI_Resource/Steinway/joyballOffset.bmp
UI_Resource/Steinway/stopTrack.bmp
UI_Resource/Steinway/repro.bmp
UI_Resource/Steinway/operatorRadius.bmp
UI_Resource/Steinway/hvRatio.bmp
UI_Resource/Steinway/lumaChromaLink.bmp
UI_Resource/Steinway/repeat.bmp
UI_Resource/Steinway/blurAngle.bmp
UI_Resource/Steinway/tvHSize.bmp
UI_Resource/Steinway/h2_inputSizingAdjustments.bmp
UI_Resource/Steinway/2930.bmp
UI_Resource/Steinway/testPattern.bmp
UI_Resource/Steinway/h2_sharpen.bmp
UI_Resource/Steinway/lpw.bmp
UI_Resource/Steinway/blueSoft.bmp
UI_Resource/Steinway/compressSaturation.bmp
UI_Resource/Steinway/split.bmp
UI_Resource/Steinway/h2_circularPowerWindowAdjustments.bmp
UI_Resource/Steinway/blueRadius.bmp
UI_Resource/Steinway/h2_timelapseDeflicker.bmp
UI_Resource/Steinway/scanlinesOnly.bmp
UI_Resource/Steinway/tempRange.bmp
UI_Resource/Steinway/redBlur.bmp
UI_Resource/Steinway/resetTrim.bmp
UI_Resource/Steinway/h2_curveControls.bmp
UI_Resource/Steinway/showActivePatches.bmp
UI_Resource/Steinway/gangSolo.bmp
UI_Resource/Steinway/h1_stereoscopic.bmp
UI_Resource/Steinway/audio2Source.bmp
UI_Resource/Steinway/EdgeThreshold.bmp
UI_Resource/Steinway/blueYSFX.bmp
UI_Resource/Steinway/cleanWhiteMatte.bmp
UI_Resource/Steinway/presetSelect.bmp
UI_Resource/Steinway/saturation.bmp
UI_Resource/Steinway/blueLowSoft.bmp
UI_Resource/Steinway/outputPreset.bmp
UI_Resource/Steinway/xSize.bmp
UI_Resource/Steinway/blue_sat.bmp
UI_Resource/Steinway/inputBlanking.bmp
UI_Resource/Steinway/cropBorder.bmp
UI_Resource/Steinway/eclipsePosition.bmp
UI_Resource/Steinway/textureOperationMode.bmp
UI_Resource/Steinway/1080i59Hz.bmp
UI_Resource/Steinway/shape.bmp
UI_Resource/Steinway/addMatte.bmp
UI_Resource/Steinway/1125i60Hz.bmp
UI_Resource/Steinway/slider1.bmp
UI_Resource/Steinway/chromaShift.bmp
UI_Resource/Steinway/preserveLum.bmp
UI_Resource/Steinway/cyan.bmp
UI_Resource/Steinway/selectedAndBlend.bmp
UI_Resource/Steinway/ApertureBlades.bmp
UI_Resource/Steinway/pixelFrequency.bmp
UI_Resource/Steinway/lineFrequency.bmp
UI_Resource/Steinway/enableRotation.bmp
UI_Resource/Steinway/yPosition.bmp
UI_Resource/Steinway/rgbMixer.bmp
UI_Resource/Steinway/user2.bmp
UI_Resource/Steinway/trackForwards.bmp
UI_Resource/Steinway/audio1NR.bmp
UI_Resource/Steinway/ghost4Type.bmp
UI_Resource/Steinway/motionScale.bmp
UI_Resource/Steinway/ShowCompFor.bmp
UI_Resource/Steinway/adjustSkinModel.bmp
UI_Resource/Steinway/splitScreenSelected.bmp
UI_Resource/Steinway/flareSoftness.bmp
UI_Resource/Steinway/refSet.bmp
UI_Resource/Steinway/greenGreen.bmp
UI_Resource/Steinway/1080i50Hz.bmp
UI_Resource/Steinway/warpLimits.bmp
UI_Resource/Steinway/slider21.bmp
UI_Resource/Steinway/ppw.bmp
UI_Resource/Steinway/ptrSpeed.bmp
UI_Resource/Steinway/colorCompressor.bmp
UI_Resource/Steinway/stabilizeBlueChannel.bmp
UI_Resource/Steinway/blk_offset.bmp
UI_Resource/Steinway/motionBlur.bmp
UI_Resource/Steinway/waviness.bmp
UI_Resource/Steinway/faceRefinement.bmp
UI_Resource/Steinway/source_red_blackpoint.bmp
UI_Resource/Steinway/clearTrackingBack.bmp
UI_Resource/Steinway/soften.bmp
UI_Resource/Steinway/log.bmp
UI_Resource/Steinway/ySize.bmp
UI_Resource/Steinway/hueShift.bmp
UI_Resource/Steinway/closeZonesGraph.bmp
UI_Resource/Steinway/h2_outputStandard.bmp
UI_Resource/Steinway/convMode.bmp
UI_Resource/Steinway/h2_blue.bmp
UI_Resource/Steinway/h2_testPatternSelect.bmp
UI_Resource/Steinway/pointsInsert.bmp
UI_Resource/Steinway/cntrBand.bmp
UI_Resource/Steinway/inputGamma.bmp
UI_Resource/Steinway/previousScene.bmp
UI_Resource/Steinway/zoomSpeed.bmp
UI_Resource/Steinway/toggle10.bmp
UI_Resource/Steinway/softnessMinus.bmp
UI_Resource/Steinway/matchMove.bmp
UI_Resource/Steinway/repeatOperation.bmp
UI_Resource/Steinway/vignetteSize.bmp
UI_Resource/Steinway/h1_openFX.bmp
UI_Resource/Steinway/vortex.bmp
UI_Resource/Steinway/red_hue.bmp
UI_Resource/Steinway/grid.bmp
UI_Resource/Steinway/minusMaster.bmp
UI_Resource/Steinway/setPoint.bmp
UI_Resource/Steinway/slider24.bmp
UI_Resource/Steinway/y.bmp
UI_Resource/Steinway/magenta_lum.bmp
UI_Resource/Steinway/anamorphism.bmp
UI_Resource/Steinway/fpnNeg.bmp
UI_Resource/Steinway/detailAmount.bmp
UI_Resource/Steinway/frequency.bmp
UI_Resource/Steinway/extKeyBlurHV.bmp
UI_Resource/Steinway/flareIrregularity.bmp
UI_Resource/Steinway/globalTint.bmp
UI_Resource/Steinway/lineSharpness.bmp
UI_Resource/Steinway/cropBottom.bmp
UI_Resource/Steinway/h1_highDynamicRange.bmp
UI_Resource/Steinway/vectors.bmp
UI_Resource/Steinway/h2_colorStabilizer.bmp
UI_Resource/Steinway/outputStandard.bmp
UI_Resource/Steinway/edgeBlur.bmp
UI_Resource/Steinway/cleanBlackMatte.bmp
UI_Resource/Steinway/masking.bmp
UI_Resource/Steinway/green_to_blue.bmp
UI_Resource/Steinway/filmGrain.bmp
UI_Resource/Steinway/pots.bmp
UI_Resource/Steinway/invertMix.bmp
UI_Resource/Steinway/meanLevel.bmp
UI_Resource/Steinway/repeatSizeSeed.bmp
UI_Resource/Steinway/h2_sharpenEdgePlugin.bmp
UI_Resource/Steinway/texture.bmp
UI_Resource/Steinway/tracking.bmp
UI_Resource/Steinway/h1_nodeLinearPowerWindow.bmp
UI_Resource/Steinway/redHiSoft.bmp
UI_Resource/Steinway/h2_colorPalette.bmp
UI_Resource/Steinway/gainAudio2.bmp
UI_Resource/Steinway/toggle12.bmp
UI_Resource/Steinway/h2s_left.bmp
UI_Resource/Steinway/h2_matteSizingControls.bmp
UI_Resource/Steinway/appendNode.bmp
UI_Resource/Steinway/ghost8Type.bmp
UI_Resource/Steinway/resetCorners.bmp
UI_Resource/Steinway/3dOverlay.bmp
UI_Resource/Steinway/vignetteSharpness.bmp
UI_Resource/Steinway/alignTransform.bmp
UI_Resource/Steinway/midtones.bmp
UI_Resource/Steinway/markOut.bmp
UI_Resource/Steinway/lensCenterXPosition.bmp
UI_Resource/Steinway/resetAll.bmp
UI_Resource/Steinway/h2_inputSizing.bmp
UI_Resource/Steinway/aberrationDistance.bmp
UI_Resource/Steinway/targetDisplay.bmp
UI_Resource/Steinway/100PercentLum.bmp
UI_Resource/Steinway/extKeyOffset.bmp
UI_Resource/Steinway/randomnessScale.bmp
UI_Resource/Steinway/x.bmp
UI_Resource/Steinway/slider9.bmp
UI_Resource/Steinway/shiftRed.bmp
UI_Resource/Steinway/toggle7.bmp
UI_Resource/Steinway/splitScreenHighlight.bmp
UI_Resource/Steinway/h1_imageBlur.bmp
UI_Resource/Steinway/zoomToCrop.bmp
UI_Resource/Steinway/perf.bmp
UI_Resource/Steinway/swirl.bmp
UI_Resource/Steinway/h1_nodePolygonPowerWindow.bmp
UI_Resource/Steinway/length.bmp
UI_Resource/Steinway/deleteAllTracks.bmp
UI_Resource/Steinway/satLowClip.bmp
UI_Resource/Steinway/matteMask.bmp
UI_Resource/Steinway/useGreenChannel.bmp
UI_Resource/cursor_rotate.bmp
UI_Resource/qtlogo.bmp
UI_Resource/ASClogo.jpg
UI_Resource/drag.bmp
UI_Resource/DVPImages
UI_Resource/DVPImages/navigation_dot_active.raw
UI_Resource/DVPImages/icon_softness_minus_active.raw
UI_Resource/DVPImages/icon_picker_minus_active.raw
UI_Resource/DVPImages/icon-circle-add.raw
UI_Resource/DVPImages/icon-invert.raw
UI_Resource/DVPImages/icon-linear-add-active.raw
UI_Resource/DVPImages/icon-linear.raw
UI_Resource/DVPImages/palette.raw
UI_Resource/DVPImages/color_indicator_red.raw
UI_Resource/DVPImages/icon-gradient.raw
UI_Resource/DVPImages/icon_vertical.raw
UI_Resource/DVPImages/color_indicator_yellow.raw
UI_Resource/DVPImages/icon_tracker_stop.raw
UI_Resource/DVPImages/color_indicator_white.raw
UI_Resource/DVPImages/icon_softness_minus.raw
UI_Resource/DVPImages/icon-rtog.raw
UI_Resource/DVPImages/icon-gradient-add-active.raw
UI_Resource/DVPImages/icon_picker.raw
UI_Resource/DVPImages/icon-linear-add.raw
UI_Resource/DVPImages/color_indicator_green.raw
UI_Resource/DVPImages/icon-invert-active.raw
UI_Resource/DVPImages/icon-linear-active.raw
UI_Resource/DVPImages/icon-flip_horizontal-active.raw
UI_Resource/DVPImages/icon_softness_plus_active.raw
UI_Resource/DVPImages/icon_picker_invert.raw
UI_Resource/DVPImages/icon_picker_minus.raw
UI_Resource/DVPImages/icon-flip_horizontal.raw
UI_Resource/DVPImages/color_indicator_cyan.raw
UI_Resource/DVPImages/icon-gradient-active.raw
UI_Resource/DVPImages/icon-mask-active.raw
UI_Resource/DVPImages/icon-circle-active.raw
UI_Resource/DVPImages/icon-btor.raw
UI_Resource/DVPImages/icon_picker_plus.raw
UI_Resource/DVPImages/icon_tracker_forward_active.raw
UI_Resource/DVPImages/icon-flip_vertical-active.raw
UI_Resource/DVPImages/icon_horizontal_active.raw
UI_Resource/DVPImages/icon-flip_vertical.raw
UI_Resource/DVPImages/icon-curve-active.raw
UI_Resource/DVPImages/icon_tracker_rewind.raw
UI_Resource/DVPImages/icon-curve-add-active.raw
UI_Resource/DVPImages/icon_vertical_active.raw
UI_Resource/DVPImages/icon_picker_active.raw
UI_Resource/DVPImages/color_indicator_blue.raw
UI_Resource/DVPImages/icon_horizontal.raw
UI_Resource/DVPImages/icon_tracker_forward.raw
UI_Resource/DVPImages/color_indicator_rgb.raw
UI_Resource/DVPImages/icon-curve-add.raw
UI_Resource/DVPImages/icon-curve.raw
UI_Resource/DVPImages/modified_indicator.raw
UI_Resource/DVPImages/icon-circle.raw
UI_Resource/DVPImages/icon-circle-add-active.raw
UI_Resource/DVPImages/navigation_dot.raw
UI_Resource/DVPImages/icon-swap-active.raw
UI_Resource/DVPImages/icon-polygon-add.raw
UI_Resource/DVPImages/icon_tracker_prevframe.raw
UI_Resource/DVPImages/color_indicator_yrgb.raw
UI_Resource/DVPImages/icon-mask.raw
UI_Resource/DVPImages/icon-polygon-active.raw
UI_Resource/DVPImages/icon-gradient-add.raw
UI_Resource/DVPImages/icon_tracker_nextframe.raw
UI_Resource/DVPImages/network_dot.raw
UI_Resource/DVPImages/icon_tracker_rewind_active.raw
UI_Resource/DVPImages/icon-polygon.raw
UI_Resource/DVPImages/icon_tracker_stop_active.raw
UI_Resource/DVPImages/icon_softness_plus.raw
UI_Resource/DVPImages/color_indicator_purple.raw
UI_Resource/DVPImages/icon_picker_invert_active.raw
UI_Resource/DVPImages/icon-polygon-add-active.raw
UI_Resource/DVPImages/icon_picker_plus_active.raw
UI_Resource/DVPImages/icon-gtob.raw
BlackmagicRAWPlayer
BlackmagicRAWPlayer/Third Party Licenses.rtf
BlackmagicRAWPlayer/BlackmagicRAWPlayer
BlackmagicRAWPlayer/qt.conf
BlackmagicRAWPlayer/BlackmagicRawAPI
BlackmagicRAWPlayer/BlackmagicRawAPI/libc++abi.so.1
BlackmagicRAWPlayer/BlackmagicRawAPI/libBlackmagicRawAPI.so
BlackmagicRAWPlayer/BlackmagicRawAPI/libDecoderCUDA.so
BlackmagicRAWPlayer/BlackmagicRawAPI/libc++.so.1
BlackmagicRAWPlayer/BlackmagicRawAPI/libDecoderOpenCL.so
BlackmagicRAWPlayer/BlackmagicRawAPI/libgcc_s.so.1
BlackmagicRAWPlayer/plugins
BlackmagicRAWPlayer/plugins/audio
BlackmagicRAWPlayer/plugins/audio/libqtaudio_alsa.so
BlackmagicRAWPlayer/plugins/bearer
BlackmagicRAWPlayer/plugins/bearer/libqnmbearer.so
BlackmagicRAWPlayer/plugins/bearer/libqconnmanbearer.so
BlackmagicRAWPlayer/plugins/bearer/libqgenericbearer.so
BlackmagicRAWPlayer/plugins/imageformats
BlackmagicRAWPlayer/plugins/imageformats/libqgif.so
BlackmagicRAWPlayer/plugins/imageformats/libqwbmp.so
BlackmagicRAWPlayer/plugins/imageformats/libqjpeg.so
BlackmagicRAWPlayer/plugins/imageformats/libqtiff.so
BlackmagicRAWPlayer/plugins/xcbglintegrations
BlackmagicRAWPlayer/plugins/xcbglintegrations/libqxcb-egl-integration.so
BlackmagicRAWPlayer/plugins/xcbglintegrations/libqxcb-glx-integration.so
BlackmagicRAWPlayer/plugins/mediaservice
BlackmagicRAWPlayer/plugins/mediaservice/libqtmedia_audioengine.so
BlackmagicRAWPlayer/plugins/platforms
BlackmagicRAWPlayer/plugins/platforms/libqxcb.so
BlackmagicRAWPlayer/lib
BlackmagicRAWPlayer/lib/libQt5Network.so.5
BlackmagicRAWPlayer/lib/libQt5Core.so.5
BlackmagicRAWPlayer/lib/fonts
BlackmagicRAWPlayer/lib/fonts/fonts.bin
BlackmagicRAWPlayer/lib/libQt5XcbQpa.so.5
BlackmagicRAWPlayer/lib/libQt5DBus.so.5
BlackmagicRAWPlayer/lib/libQt5Widgets.so.5
BlackmagicRAWPlayer/lib/libQt5Gui.so.5
BlackmagicRAWPlayer/lib/libQt5Multimedia.so.5
bin
bin/DaVinciPanelDaemon
Failed to copy file: bin/libusb-1.0.so
Can anyone help?
Best wishes
Daniel
