M78
1
to reproduce the error:
just clone the repo:
git clone https://gitlab.manjaro.org/profiles-and-settings/iso-profiles.git ~/iso-profiles
and do a fresh build (without changing anything in iso-profiles folder):
buildiso -f -v -b stable -p xfce
here you can find the full errorlog:
http://termbin.com/re0l
could anyone please help me on this or guide me to the correct forum bugtracker?
Thx,
kind regards, Michael
philm
2
Which version of the tools you are using? Currently only works with the latest commits of which there is no release yet.
M78
3
manjaro-tools-base-git r3016.263d640-1
should I build from src?
philm
4
You can simply download 23.1 official XFCE ISO which reflects the current stable branch state.
M78
5
so buildiso is broken at the moment?
I need a custom build, so I will try to get help here:
or do you have a recommendation for me?
philm
6
You can simply use the PKGBUILD and update it to latest master commit.
The simple method to get latest version of the toolbox.
git clone https://gitlab.manjaro.org/tools/development-tools/manjaro-tools
cd manjaro-tools
make
sudo make install
Because /usr/local/bin is first in PATH it will override the package installed.
It appears you are building using linux54 - and the mkinitcpio fails building the init image.
M78
8
Hello Linux-aarhus,
thx for the clear instructions!
I made a new build of the tools, and tested the iso in my virtualbox.
But I got the same error…
what I do not understand is, there is no error in the Log, only warnings…
http://termbin.com/bkfe
Your usage of linux54 may be the reason why you are having an issue.
I just tested linux54 vs linux61 - first fails during install - linux61 doesn’t.
M78
10
Hello Linux-aarhus and philm,
thx a lot!!
I changed my build to linux61, now it works again!!
Kind regards,
you are great guys!
Michael
system
Closed
11
