Installation failed
Boost.Python error in job “bootloader”.
Command ‘grub-install --target=x86_64-efi --efi-directory=/boot/efi --bootloader-id=Manjaro --force’ returned non-zero exit status 1.
Installing for x86_64-efi platform. grub-install: error: /boot/efi doesn’t look like an EFI partition.
Traceback:
File “/usr/lib/calamares/modules/bootloader/main.py”, line 476, in run
prepare_bootloader(fw_type)
File “/usr/lib/calamares/modules/bootloader/main.py”, line 448, in prepare_bootloader
install_grub(efi_directory, fw_type)
File “/usr/lib/calamares/modules/bootloader/main.py”, line 310, in install_grub
check_target_env_call([libcalamares.job.configuration[“grubInstall”],
File “”, line 5, in
Welcome to the forum! :slight_smile:
Did you create an EFI system partition, and with the proper attributes?
  • Size: 512 MiB
  • Filesystem: vfat (FAT32)
  • Marked with boot flag
  • Mountpoint: /boot/efi
first check in UEFI bios option
If this does not help, check boot options in your UEFI firmware and make sure that
  1. no secure boot is enabled
  2. no fast boot is enabled
  3. no csm is enabled
  4. only UEFI is enabled
  5. only AHCI disks is enabled
Then, check return to be sure that
its all EFI and disks appears and are formatted with GPT
do NOT format /boot/efi
test -d /sys/firmware/efi && echo efi || echo bios
sudo efibootmgr -v
sudo parted -l
if all is ok you can install in EFI
