Installation failed creating bootloader
I accidently deleted manjaro efi Partition and now reinstalling it but a error occurs
Installation Failed
Boost.Python error in job “bootloader”.
Command 'grub-install -target-x86_64-efi -efi-directory-/boot/efi -bootloader-id-Manjaro -force
returned non-zero exit status 1.
Installing for x86_64 efi platform. Could not prepare Boot variable: No space left on device grub-install: error. efibootmgr failed to register the boot entry: Input/output error.
Traceback:
File “/usr/lib/calamares/modules/bootloader/main.py”, line 476, in run prepare_bootloader (fw_type)
File “/usr/lib/calamares/modules/bootloader/main.py”, line 448, in prepare_bootloader install_grub(efi_directory, fw_type)
File “/usr/lib/calamares/modules/bootloader/main.py”, line 310, in install_grub
check_target_env_call([libcalamares.job.configuration[“grubInstall”].
File “”, line 6, in
How do I fix this plz help
Try to follow strictly this guide and copy every error message in combination with the commands you used:
https://wiki.manjaro.org/index.php?title=GRUB/Restore_the_GRUB_Bootloader
Ensure you are actually using an EFI based system.
Next is to ensure the firmware is not populated with a lot of useless entries.
Yes I am using efi system I did efibootmgr -v the deleted some with efibootmgr -b XXXX -B
