Installation Error related to hard drive readability (i guess)
i installed manjaro Kde first with bootable pendrive and it worked fine in the first boot . In the second boot , my pc crashed amd then i restarted and i was faced with following error message
"error: failure reading sector ex97002 from `hd1’.
error: disk hd1, gpt2’ not found.
error: no such device: 7c899e38-1927-4559-9561-c8e2c6b027dc.
Press any key to continue…
Failed to boot both default and fallback entries.
Press any key to continue… error: disk hd1.gpt2’ not found.
Press any key to continue… "
i thought i should try reinstalling KDE but then i faced another problem
After failing to reinstall Manjaro
, i thought of installing Fedora but then i was faced with the similar issue
( I have never used linux before and i am pretty much clueless about the os . i just wanted a change from windows so i thought of installing linux )
Maybe you should first try to identify, what went wrong the first time.
Therefore boot with the pen drive into a live manjaro and gather some system information to post here.
Then someone may be able to help you.
In this case it may be necessary to gather information about the partitions you already created, and which of them have valuable data on them and which where from different trials to install something
Please look in the forum for’:
  • how to provide good information
  • how to get help
  • inxi
  • list partitions
I fear your drive is failing. See S.M.A.R.T. - ArchWiki.
i will add more info in an hour as it says on the post .
system info
inxi --full --verbosity=7 --filter --no-host         ✔
System:    Kernel: 5.15.6-2-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0 Desktop: GNOME 41.1 tk: GTK 3.24.30
           wm: gnome-shell dm: GDM 41.0 Distro: Manjaro Linux base: Arch Linux
Machine:   Type: Laptop System: ASUSTeK product: X556UQK v: 1.0 serial: <superuser required>
           Mobo: ASUSTeK model: X556UQK v: 1.0 serial: <superuser required> UEFI: American Megatrends v: X556UQK.315
           date: 01/24/2019
Battery:   ID-1: BAT0 charge: 21.0 Wh (100.0%) condition: 21.0/38.0 Wh (55.2%) volts: 7.6 min: 7.6 model: ASUSTeK ASUS Battery
           type: Li-ion serial: N/A status: Not charging cycles: 702
Memory:    RAM: total: 11.57 GiB used: 2.59 GiB (22.3%)
CPU:       Info: Dual Core model: Intel Core i5-7200U bits: 64 type: MT MCP arch: Amber/Kaby Lake note: check rev: 9 cache:
           L1: 128 KiB L2: 512 KiB L3: 3 MiB bogomips: 21607
           Speed: 543 MHz min/max: 400/3100 MHz Core speeds (MHz): 1: 500 2: 504 3: 500 4: 500
           Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon art avx avx2 bmi1 bmi2 bts clflush
           clflushopt cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c
           flexpriority flush_l1d fma fpu fsgsbase fxsr ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ida intel_pt
           invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe
           pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp rep_good sdbg sep smap
           smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx
           vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Graphics:  Device-1: Intel HD Graphics 620 vendor: ASUSTeK driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:5916
           class-ID: 0300
           Device-2: NVIDIA GM108M [GeForce 940MX] vendor: ASUSTeK driver: nvidia v: 495.44 bus-ID: 01:00.0 chip-ID: 10de:134d
           class-ID: 0302
           Device-3: Chicony USB2.0 VGA UVC WebCam type: USB driver: uvcvideo bus-ID: 1-6:4 chip-ID: 04f2:b52b class-ID: 0e02
           serial: <filter>
           Display: x11 server: X.org 1.21.1.1 compositor: gnome-shell driver: loaded: modesetting,nvidia
           alternate: fbdev,nouveau,nv,vesa resolution: <missing: xdpyinfo>
Audio:     Device-1: Intel Sunrise Point-LP HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 00:1f.3
           chip-ID: 8086:9d71 class-ID: 0403
           Sound Server-1: ALSA v: k5.15.6-2-MANJARO running: yes
           Sound Server-4: PipeWire v: 0.3.40 running: no
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK driver: r8169 v: kernel port: d000
           bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
           Device-2: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter vendor: AzureWave driver: ath10k_pci v: kernel
           bus-ID: 03:00.0 chip-ID: 168c:0042 class-ID: 0280
           IF: wlp3s0 state: down mac: <filter>
           WAN IP: No WAN IP found. Connected to web? SSL issues? Try enabling dig
Bluetooth: Device-1: IMC Networks type: USB driver: btusb v: 0.8 bus-ID: 1-8:5 chip-ID: 13d3:3496 class-ID: e001
Logical:   Message: No logical block device data found.
RAID:      Message: No RAID data found.
Drives:    Local Storage: total: 7.27 GiB used: 0 KiB (0.0%)
           ID-1: /dev/sda type: USB vendor: Kingston model: DataTraveler 2.0 size: 7.27 GiB type: N/A serial: <filter>
           rev: PMAP scheme: MBR
           Optical-1: /dev/sr0 vendor: Slimtype model: DVD A DA8AESH rev: XAA1 dev-links: cdrom
           Features: speed: 24 multisession: yes audio: yes dvd: yes rw: cd-r,cd-rw,dvd-r,dvd-ram state: running
Partition: Message: No partition data found.
Swap:      Alert: No swap data was found.
Unmounted: ID-1: /dev/sda1 size: 3.27 GiB fs: iso9660
           ID-2: /dev/sda2 size: 4 MiB fs: vfat label: MISO_EFI uuid: 8704-2F24
USB:       Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 12 rev: 2.0 speed: 480 Mb/s chip-ID: 1d6b:0002 class-ID: 0900
           Device-1: 1-1:2 info: Toshiba Kingston DataTraveler 102/2.0 / HEMA Flash Drive 2 GB / PNY Attache 4GB Stick
           type: Mass Storage driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 300mA chip-ID: 0930:6545
           class-ID: 0806 serial: <filter>
           Device-2: 1-5:3 info: Realtek RTS5129 Card Reader Controller type: <vendor specific>
           driver: rtsx_usb,rtsx_usb_ms,rtsx_usb_sdmmc interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 500mA chip-ID: 0bda:0129
           class-ID: ff00 serial: <filter>
           Device-3: 1-6:4 info: Chicony USB2.0 VGA UVC WebCam type: Video driver: uvcvideo interfaces: 2 rev: 2.0
           speed: 480 Mb/s power: 500mA chip-ID: 04f2:b52b class-ID: 0e02 serial: <filter>
           Device-4: 1-8:5 info: IMC Networks type: Bluetooth driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s power: 100mA
           Hub-2: 2-0:1 info: Super-speed hub ports: 6 rev: 3.0 speed: 5 Gb/s chip-ID: 1d6b:0003 class-ID: 0900
Sensors:   System Temperatures: cpu: 31.0 C pch: 26.0 C mobo: N/A
           Fan Speeds (RPM): cpu: 2600
Info:      Processes: 225 Uptime: 13m wakeups: 2 Init: systemd v: 249 Compilers: gcc: N/A Packages: pacman: 1189 Shell: Zsh
           v: 5.8 running-in: gnome-terminal inxi: 3.3.09 `Preformatted text`
Hi @TriratnaP,
In the Drives: section of your inxi output,
           ID-1: /dev/sda type: USB vendor: Kingston model: DataTraveler 2.0 size: 7.27 GiB serial: AC220B280C75B0A039B1D93A
I am unable to find a hard drive. The Partition: section seems to confirm this:
And if the drive is connected ass you say, it would seem it has given up the ghost.
Someone is welcome to confirm/prove it wrong, and let’s hope I am, but it looks to me like a hardware problem that can only be fixed by replacing the faulty hardware.
i tried booting ubuntu as well and when i was in it’s live environment , i was able to get the system to recognise it to the bare minimum using this code
this is a ubuntu code
sudo apt-get install ntfs-3g
my hdd was showing up but i was not able to format it or mount it or anything, neither could i install ubuntu desktop .
In ubuntu , the smartctl scan said my hdd is okay but ut had bad sectors.
I don’t like it, personally.
That would explain a lot. Not the no partitions found, I don’t think, though. Neither why the hard drive’s not visible…
Please provide the output to:
fdisk --list
and,
parted --list
Also, if possible, please provide the output of the above two commands from the working Ubuntu.
Disk /dev/loop0: 26.09 MiB, 27353088 bytes, 53424 sectors
Disk /dev/loop1: 473.9 MiB, 496918528 bytes, 970544 sectors
Disk /dev/loop2: 1.11 GiB, 1195339776 bytes, 2334648 sectors
Disk /dev/loop3: 729.63 MiB, 765071360 bytes, 1494280 sectors
Disk /dev/sda: 7.27 GiB, 7807696896 bytes, 15249408 sectors
Disk model: DataTraveler 2.0
Disklabel type: dos
Disk identifier: 0x00000000
Device     Boot   Start     End Sectors  Size Id Type
/dev/sda1  *         64 4981019 4980956  2.4G  0 Empty
/dev/sda2       4981020 4989211    8192    4M ef EFI (FAT-12/16/32)
Model: Kingston DataTraveler 2.0 (scsi)
Disk /dev/sda: 7808MB
Partition Table: msdos
Disk Flags:
Number  Start   End     Size    Type     File system  Flags
 2      2550MB  2554MB  4194kB  primary               esp
My hdd is showing up in BIOS though …
Could you send the Kernel Messages?
sudo dmesg
Anyway… this is the first sign of a faulty HDD/SSD with badblocks:
[    0.028057]   Normal zone: 39872 pages used for memmap
[    0.028058]   Normal zone: 2551808 pages, LIFO batch:63
[    0.061677] Reserving Intel graphics memory at [mem 0x8c000000-0x8fffffff]
[    0.061931] ACPI: PM-Timer IO Port: 0x1808
[    0.061933] ACPI: Local APIC address 0xfee00000
[    0.061938] ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
[    0.061939] ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
[    0.061940] ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
[    0.061940] ACPI: LAPIC_NMI (acpi_id[0x04] high edge lint[0x1])
[    0.061967] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
[    0.061969] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[    0.061970] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[    0.061972] ACPI: IRQ0 used by override.
[    0.061973] ACPI: IRQ9 used by override.
[    0.061974] Using ACPI (MADT) for SMP configuration information
[    0.061976] ACPI: HPET id: 0x8086a201 base: 0xfed00000
[    0.061982] e820: update [mem 0x881bf000-0x881edfff] usable ==> reserved
[    0.061990] TSC deadline timer available
[    0.061991] smpboot: Allowing 4 CPUs, 0 hotplug CPUs
[    0.062011] PM: Registered nosave memory: [mem 0x00000000-0x00000fff]
[    0.062013] PM: Registered nosave memory: [mem 0x00058000-0x00058fff]
[    0.062014] PM: Registered nosave memory: [mem 0x0009e000-0x000fffff]
[    0.062016] PM: Registered nosave memory: [mem 0x8412f000-0x8412ffff]
[    0.062016] PM: Registered nosave memory: [mem 0x84130000-0x84130fff]
[    0.062018] PM: Registered nosave memory: [mem 0x881bf000-0x881edfff]
[    0.062019] PM: Registered nosave memory: [mem 0x8986c000-0x8a596fff]
[    0.062020] PM: Registered nosave memory: [mem 0x8a597000-0x8a5dafff]
[    0.062021] PM: Registered nosave memory: [mem 0x8a5db000-0x8adbffff]
[    0.062021] PM: Registered nosave memory: [mem 0x8adc0000-0x8b208fff]
[    0.062022] PM: Registered nosave memory: [mem 0x8b209000-0x8b27efff]
[    0.062023] PM: Registered nosave memory: [mem 0x8b2ff000-0x8fffffff]
[    0.062024] PM: Registered nosave memory: [mem 0x90000000-0xefffffff]
[    0.062024] PM: Registered nosave memory: [mem 0xf0000000-0xf7ffffff]
[    0.062025] PM: Registered nosave memory: [mem 0xf8000000-0xfdffffff]
[    0.062025] PM: Registered nosave memory: [mem 0xfe000000-0xfe010fff]
[    0.062026] PM: Registered nosave memory: [mem 0xfe011000-0xfebfffff]
[    0.062026] PM: Registered nosave memory: [mem 0xfec00000-0xfec00fff]
[    0.062027] PM: Registered nosave memory: [mem 0xfec01000-0xfedfffff]
[    0.062028] PM: Registered nosave memory: [mem 0xfee00000-0xfee00fff]
[    0.062028] PM: Registered nosave memory: [mem 0xfee01000-0xfeffffff]
[    0.062029] PM: Registered nosave memory: [mem 0xff000000-0xffffffff]
[    0.062030] [mem 0x90000000-0xefffffff] available for PCI devices
[    0.062031] Booting paravirtualized kernel on bare hardware
[    0.062034] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
[    0.171979] setup_percpu: NR_CPUS:320 nr_cpumask_bits:320 nr_cpu_ids:4 nr_node_ids:1
[    0.172169] percpu: Embedded 54 pages/cpu s184320 r8192 d28672 u524288
[    0.172177] pcpu-alloc: s184320 r8192 d28672 u524288 alloc=1*2097152
[    0.172178] pcpu-alloc: [0] 0 1 2 3
[    0.172200] Built 1 zonelists, mobility grouping on.  Total pages: 3066444
[    0.172201] Policy zone: Normal
[    0.172203] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-x86_64 lang=en_US keytable=us tz=UTC misobasedir=manjaro misolabel=MANJARO_KDEM_2107 quiet systemd.show_status=1 apparmor=1 security=apparmor driver=nonfree nouveau.modeset=0 i915.modeset=1 radeon.modeset=1
[    0.173187] Dentry cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[    0.173593] Inode-cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[    0.173642] mem auto-init: stack:off, heap alloc:on, heap free:off
[    0.176813] Calgary: detecting Calgary via BIOS EBDA area
[    0.176814] Calgary: Unable to locate Rio Grande table in EBDA - bailing!
[    0.200018] Memory: 11994380K/12460568K available (12291K kernel code, 1331K rwdata, 4096K rodata, 1640K init, 3404K bss, 466188K reserved, 0K cma-reserved)
[    0.200024] random: get_random_u64 called from __kmem_cache_create+0x3e/0x5f0 with crng_init=0
[    0.200153] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[    0.200174] Kernel/User page tables isolation: enabled
[    0.200188] ftrace: allocating 37586 entries in 147 pages
[    0.214941] rcu: Preemptible hierarchical RCU implementation.
[    0.214942] rcu:     RCU dyntick-idle grace-period acceleration is enabled.
[    0.214943] rcu:     RCU restricting CPUs from NR_CPUS=320 to nr_cpu_ids=4.
[    0.214944] rcu:     RCU priority boosting: priority 1 delay 500 ms.
[    0.214945]  Tasks RCU enabled.
[    0.214945] rcu: RCU calculated value of scheduler-enlistment delay is 30 jiffies.
[    0.214946] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.217446] NR_IRQS: 20736, nr_irqs: 1024, preallocated irqs: 16
[    0.217997] Console: colour dummy device 80x25
[    0.218001] printk: console [tty0] enabled
[    0.218015] ACPI: Core revision 20190816
[    0.218317] clocksource: hpet: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635855245 ns
[    0.218385] APIC: Switch to symmetric I/O mode setup
[    0.218387] DMAR: Host address width 39
[    0.218388] DMAR: DRHD base: 0x000000fed90000 flags: 0x0
[    0.218394] DMAR: dmar0: reg_base_addr fed90000 ver 1:0 cap 1c0000c40660462 ecap 19e2ff0505e
[    0.218395] DMAR: DRHD base: 0x000000fed91000 flags: 0x1
[    0.218398] DMAR: dmar1: reg_base_addr fed91000 ver 1:0 cap d2008c40660462 ecap f050da
[    0.218399] DMAR: RMRR base: 0x00000089d27000 end: 0x00000089d46fff
[    0.218400] DMAR: RMRR base: 0x0000008b800000 end: 0x0000008fffffff
[    0.218401] DMAR: ANDD device: 1 name: \_SB.PCI0.I2C0
[    0.218401] DMAR: ANDD device: 2 name: \_SB.PCI0.I2C1
[    0.218403] DMAR-IR: IOAPIC id 2 under DRHD base  0xfed91000 IOMMU 1
[    0.218404] DMAR-IR: HPET id 0 under DRHD base 0xfed91000
[    0.218404] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
[    0.219915] DMAR-IR: Enabled IRQ remapping in x2apic mode
[    0.219917] x2apic enabled
[    0.219929] Switched APIC routing to cluster x2apic.
[    0.223891] ..TIMER: vector=0x30 apic1=0 pin1=2 apic2=-1 pin2=-1
[    0.238447] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x26eae8729ef, max_idle_ns: 440795235156 ns
[    0.238452] Calibrating delay loop (skipped), value calculated using timer frequency.. 5401.81 BogoMIPS (lpj=8999696)
[    0.238454] pid_max: default: 32768 minimum: 301
[    0.241822] LSM: Security Framework initializing
[    0.241827] Yama: becoming mindful.
[    0.241851] AppArmor: AppArmor initialized
[    0.241887] Mount-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.241909] Mountpoint-cache hash table entries: 32768 (order: 6, 262144 bytes, linear)
[    0.241919] *** VALIDATE tmpfs ***
[    0.242056] *** VALIDATE proc ***
[    0.242099] *** VALIDATE cgroup1 ***
[    0.242100] *** VALIDATE cgroup2 ***
[    0.242170] mce: CPU0: Thermal monitoring enabled (TM1)
[    0.242187] process: using mwait in idle threads
[    0.242189] Last level iTLB entries: 4KB 64, 2MB 8, 4MB 8
[    0.242190] Last level dTLB entries: 4KB 64, 2MB 0, 4MB 0, 1GB 4
[    0.242193] Spectre V1 : Mitigation: usercopy/swapgs barriers and __user pointer sanitization
[    0.242195] Spectre V2 : Mitigation: Full generic retpoline
[    0.242196] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[    0.242196] Spectre V2 : Enabling Restricted Speculation for firmware calls
[    0.242198] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[    0.242199] Spectre V2 : User space: Mitigation: STIBP via seccomp and prctl
[    0.242200] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl and seccomp
[    0.242205] SRBDS: Mitigation: Microcode
[    0.242205] MDS: Mitigation: Clear CPU buffers
[    0.242529] Freeing SMP alternatives memory: 32K
[    0.244233] smpboot: CPU0: Intel(R) Core(TM) i5-7200U CPU @ 2.50GHz (family: 0x6, model: 0x8e, stepping: 0x9)
[    0.244322] Performance Events: PEBS fmt3+, Skylake events, 32-deep LBR, full-width counters, Intel PMU driver.
[    0.244328] ... version:                4
[    0.244329] ... bit width:              48
[    0.244329] ... generic registers:      4
[    0.244330] ... value mask:             0000ffffffffffff
[    0.244330] ... max period:             00007fffffffffff
[    0.244331] ... fixed-purpose events:   3
[    0.244331] ... event mask:             000000070000000f
[    0.244375] rcu: Hierarchical SRCU implementation.
[    0.244998] NMI watchdog: Enabled. Permanently consumes one hw-PMU counter.
[    0.245045] smp: Bringing up secondary CPUs ...
[    0.245116] x86: Booting SMP configuration:
[    0.245116] .... node  #0, CPUs:      #1
[    0.004040] [Firmware Bug]: TSC ADJUST differs within socket(s), fixing all errors
[    0.245646]  #2
[    0.245646] MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
[    0.245646]  #3
[    0.245649] smp: Brought up 1 node, 4 CPUs
[    0.245649] smpboot: Max logical packages: 1
[    0.245649] smpboot: Total of 4 processors activated (21607.24 BogoMIPS)
[    0.248568] devtmpfs: initialized
[    0.248568] x86/mm: Memory block size: 128MB
[    0.249640] PM: Registering ACPI NVS region [mem 0x8412f000-0x8412ffff] (4096 bytes)
[    0.249640] PM: Registering ACPI NVS region [mem 0x8a5db000-0x8adbffff] (8278016 bytes)
[    0.249640] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370867519511994 ns
[    0.249640] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[    0.249640] pinctrl core: initialized pinctrl subsystem
[    0.249640] PM: RTC time: 17:28:02, date: 2021-12-22
[    0.249640] NET: Registered protocol family 16
[    0.249640] audit: initializing netlink subsys (disabled)
[    0.249640] audit: type=2000 audit(1640194082.029:1): state=initialized audit_enabled=0 res=1
[    0.249640] cpuidle: using governor ladder
[    0.249640] cpuidle: using governor menu
[    0.249640] ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
[    0.249640] ACPI: bus type PCI registered
[    0.249640] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[    0.249640] PCI: MMCONFIG for domain 0000 [bus 00-7f] at [mem 0xf0000000-0xf7ffffff] (base 0xf0000000)
[    0.249640] PCI: MMCONFIG at [mem 0xf0000000-0xf7ffffff] reserved in E820
[    0.249640] PCI: Using configuration type 1 for base access
[    0.249640] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[    0.252541] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[    0.252541] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.252541] ACPI: Added _OSI(Module Device)
[    0.252541] ACPI: Added _OSI(Processor Device)
[    0.252541] ACPI: Added _OSI(3.0 _SCP Extensions)
[    0.252541] ACPI: Added _OSI(Processor Aggregator Device)
[    0.252541] ACPI: Added _OSI(Linux-Dell-Video)
[    0.252541] ACPI: Added _OSI(Linux-Lenovo-NV-HDMI-Audio)
[    0.252541] ACPI: Added _OSI(Linux-HPI-Hybrid-Graphics)
[    0.302134] ACPI: 8 ACPI AML tables successfully acquired and loaded
[    0.304365] ACPI: EC: EC started
[    0.304365] ACPI: EC: interrupt blocked
[    0.307109] ACPI: \: Used as first EC
[    0.307111] ACPI: \: GPE=0x50, EC_CMD/EC_SC=0x66, EC_DATA=0x62
[    0.307111] ACPI: EC: Boot ECDT EC used to handle transactions
[    0.308928] ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
[    0.316561] ACPI: Dynamic OEM Table Load:
[    0.316567] ACPI: SSDT 0xFFFF8ADE2073D800 0006B4 (v02 PmRef  Cpu0Ist  00003000 INTL 20160422)
[    0.318687] ACPI: \_PR_.CPU0: _OSC native thermal LVT Acked
[    0.320569] ACPI: Dynamic OEM Table Load:
[    0.320574] ACPI: SSDT 0xFFFF8ADE202D2C00 0003FF (v02 PmRef  Cpu0Cst  00003001 INTL 20160422)
[    0.322595] ACPI: Dynamic OEM Table Load:
[    0.322599] ACPI: SSDT 0xFFFF8ADE203D0600 000115 (v02 PmRef  Cpu0Hwp  00003000 INTL 20160422)
[    0.324447] ACPI: Dynamic OEM Table Load:
[    0.324450] ACPI: SSDT 0xFFFF8ADE203D1C00 0001A4 (v02 PmRef  HwpLvt   00003000 INTL 20160422)
[    0.326739] ACPI: Dynamic OEM Table Load:
[    0.326744] ACPI: SSDT 0xFFFF8ADE2073B000 00065C (v02 PmRef  ApIst    00003000 INTL 20160422)
[    0.329122] ACPI: Dynamic OEM Table Load:
[    0.329126] ACPI: SSDT 0xFFFF8ADE203D0E00 000197 (v02 PmRef  ApHwp    00003000 INTL 20160422)
[    0.331112] ACPI: Dynamic OEM Table Load:
[    0.331115] ACPI: SSDT 0xFFFF8ADE203D0200 00018A (v02 PmRef  ApCst    00003000 INTL 20160422)
[    0.335199] ACPI: Interpreter enabled
[    0.335245] ACPI: (supports S0 S3 S4 S5)
[    0.335247] ACPI: Using IOAPIC for interrupt routing
[    0.335291] PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
[    0.336725] ACPI: Enabled 7 GPEs in block 00 to 7F
[    0.342390] ACPI: Power Resource [WRST] (on)
[    0.342847] ACPI: Power Resource [WRST] (on)
[    0.343307] ACPI: Power Resource [WRST] (on)
[    0.343770] ACPI: Power Resource [WRST] (on)
[    0.344223] ACPI: Power Resource [WRST] (on)
[    0.344287] ACPI: Power Resource [PC09] (on)
[    0.453421] ACPI: Power Resource [WRST] (on)
[    0.453884] ACPI: Power Resource [WRST] (on)
[    0.454339] ACPI: Power Resource [WRST] (on)
[    0.454798] ACPI: Power Resource [WRST] (on)
[    0.455531] ACPI: Power Resource [WRST] (on)
[    0.455986] ACPI: Power Resource [WRST] (on)
[    0.456442] ACPI: Power Resource [WRST] (on)
[    0.456896] ACPI: Power Resource [WRST] (on)
[    0.457352] ACPI: Power Resource [WRST] (on)
[    0.457810] ACPI: Power Resource [WRST] (on)
[    0.458262] ACPI: Power Resource [WRST] (on)
[    0.460007] ACPI: Power Resource [WRST] (on)
[    0.460465] ACPI: Power Resource [WRST] (on)
[    0.460918] ACPI: Power Resource [WRST] (on)
[    0.478080] ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-7e])
[    0.478086] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI HPX-Type3]
[    0.479960] acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug SHPCHotplug PME AER PCIeCapability LTR]
[    0.479961] acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
[    0.480819] PCI host bridge to bus 0000:00
[    0.480821] pci_bus 0000:00: root bus resource [io  0x0000-0x0cf7 window]
[    0.480822] pci_bus 0000:00: root bus resource [io  0x0d00-0xffff window]
[    0.480823] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[    0.480825] pci_bus 0000:00: root bus resource [mem 0x000c0000-0x000c3fff window]
[    0.480825] pci_bus 0000:00: root bus resource [mem 0x000c4000-0x000c7fff window]
[    0.480826] pci_bus 0000:00: root bus resource [mem 0x000c8000-0x000cbfff window]
[    0.480827] pci_bus 0000:00: root bus resource [mem 0x000cc000-0x000cffff window]
[    0.480828] pci_bus 0000:00: root bus resource [mem 0x000d0000-0x000d3fff window]
[    0.480829] pci_bus 0000:00: root bus resource [mem 0x000d4000-0x000d7fff window]
[    0.480830] pci_bus 0000:00: root bus resource [mem 0x000d8000-0x000dbfff window]
[    0.480831] pci_bus 0000:00: root bus resource [mem 0x000dc000-0x000dffff window]
[    0.480832] pci_bus 0000:00: root bus resource [mem 0x000e0000-0x000e3fff window]
[    0.480833] pci_bus 0000:00: root bus resource [mem 0x000e4000-0x000e7fff window]
[    0.480834] pci_bus 0000:00: root bus resource [mem 0x000e8000-0x000ebfff window]
[    0.480835] pci_bus 0000:00: root bus resource [mem 0x000ec000-0x000effff window]
[    0.480836] pci_bus 0000:00: root bus resource [mem 0x000f0000-0x000fffff window]
[    0.480837] pci_bus 0000:00: root bus resource [mem 0x90000000-0xefffffff window]
[    0.480838] pci_bus 0000:00: root bus resource [mem 0xfd000000-0xfe7fffff window]
[    0.480839] pci_bus 0000:00: root bus resource [bus 00-7e]
[    0.480849] pci 0000:00:00.0: [8086:5904] type 00 class 0x060000
[    0.481315] pci 0000:00:02.0: [8086:5916] type 00 class 0x030000
[    0.481327] pci 0000:00:02.0: reg 0x10: [mem 0xed000000-0xedffffff 64bit]
[    0.481333] pci 0000:00:02.0: reg 0x18: [mem 0xc0000000-0xcfffffff 64bit pref]
[    0.481337] pci 0000:00:02.0: reg 0x20: [io  0xf000-0xf03f]
[    0.481354] pci 0000:00:02.0: BAR 2: assigned to efifb
[    0.481539] pci 0000:00:04.0: [8086:1903] type 00 class 0x118000
[    0.481552] pci 0000:00:04.0: reg 0x10: [mem 0xef120000-0xef127fff 64bit]
[    0.481826] pci 0000:00:14.0: [8086:9d2f] type 00 class 0x0c0330
[    0.481851] pci 0000:00:14.0: reg 0x10: [mem 0xef110000-0xef11ffff 64bit]
[    0.481928] pci 0000:00:14.0: PME# supported from D3hot D3cold
[    0.482219] pci 0000:00:14.2: [8086:9d31] type 00 class 0x118000
[    0.482243] pci 0000:00:14.2: reg 0x10: [mem 0xef138000-0xef138fff 64bit]
[    0.482547] pci 0000:00:15.0: [8086:9d60] type 00 class 0x118000
[    0.482811] pci 0000:00:15.0: reg 0x10: [mem 0xef137000-0xef137fff 64bit]
[    0.483935] pci 0000:00:15.1: [8086:9d61] type 00 class 0x118000
[    0.484200] pci 0000:00:15.1: reg 0x10: [mem 0xef136000-0xef136fff 64bit]
[    0.485256] pci 0000:00:16.0: [8086:9d3a] type 00 class 0x078000
[    0.485284] pci 0000:00:16.0: reg 0x10: [mem 0xef135000-0xef135fff 64bit]
[    0.485364] pci 0000:00:16.0: PME# supported from D3hot
[    0.485581] pci 0000:00:17.0: [8086:9d03] type 00 class 0x010601
[    0.485601] pci 0000:00:17.0: reg 0x10: [mem 0xef130000-0xef131fff]
[    0.485609] pci 0000:00:17.0: reg 0x14: [mem 0xef134000-0xef1340ff]
[    0.485617] pci 0000:00:17.0: reg 0x18: [io  0xf090-0xf097]
[    0.485625] pci 0000:00:17.0: reg 0x1c: [io  0xf080-0xf083]
[    0.485633] pci 0000:00:17.0: reg 0x20: [io  0xf060-0xf07f]
[    0.485641] pci 0000:00:17.0: reg 0x24: [mem 0xef133000-0xef1337ff]
[    0.485687] pci 0000:00:17.0: PME# supported from D3hot
[    0.485903] pci 0000:00:1c.0: [8086:9d10] type 01 class 0x060400
[    0.485992] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[    0.486260] pci 0000:00:1c.4: [8086:9d14] type 01 class 0x060400
[    0.486348] pci 0000:00:1c.4: PME# supported from D0 D3hot D3cold
[    0.486598] pci 0000:00:1c.5: [8086:9d15] type 01 class 0x060400
[    0.486686] pci 0000:00:1c.5: PME# supported from D0 D3hot D3cold
[    0.486949] pci 0000:00:1f.0: [8086:9d58] type 00 class 0x060100
[    0.487262] pci 0000:00:1f.2: [8086:9d21] type 00 class 0x058000
[    0.487277] pci 0000:00:1f.2: reg 0x10: [mem 0xef12c000-0xef12ffff]
[    0.487517] pci 0000:00:1f.3: [8086:9d71] type 00 class 0x040300
[    0.487545] pci 0000:00:1f.3: reg 0x10: [mem 0xef128000-0xef12bfff 64bit]
[    0.487572] pci 0000:00:1f.3: reg 0x20: [mem 0xef100000-0xef10ffff 64bit]
[    0.487624] pci 0000:00:1f.3: PME# supported from D3hot D3cold
[    0.487908] pci 0000:00:1f.4: [8086:9d23] type 00 class 0x0c0500
[    0.487970] pci 0000:00:1f.4: reg 0x10: [mem 0xef132000-0xef1320ff 64bit]
[    0.488041] pci 0000:00:1f.4: reg 0x20: [io  0xf040-0xf05f]
[    0.488366] pci 0000:01:00.0: [10de:134d] type 00 class 0x030200
[    0.488392] pci 0000:01:00.0: reg 0x10: [mem 0xee000000-0xeeffffff]
[    0.488405] pci 0000:01:00.0: reg 0x14: [mem 0xd0000000-0xdfffffff 64bit pref]
[    0.488418] pci 0000:01:00.0: reg 0x1c: [mem 0xe0000000-0xe1ffffff 64bit pref]
[    0.488426] pci 0000:01:00.0: reg 0x24: [io  0xe000-0xe07f]
[    0.488435] pci 0000:01:00.0: reg 0x30: [mem 0xef000000-0xef07ffff pref]
[    0.488456] pci 0000:01:00.0: Enabling HDA controller
[    0.488665] pci 0000:00:1c.0: PCI bridge to [bus 01]
[    0.488668] pci 0000:00:1c.0:   bridge window [io  0xe000-0xefff]
[    0.488671] pci 0000:00:1c.0:   bridge window [mem 0xee000000-0xef0fffff]
[    0.488676] pci 0000:00:1c.0:   bridge window [mem 0xd0000000-0xe1ffffff 64bit pref]
[    0.488753] pci 0000:02:00.0: [10ec:8168] type 00 class 0x020000
[    0.488785] pci 0000:02:00.0: reg 0x10: [io  0xd000-0xd0ff]
[    0.488813] pci 0000:02:00.0: reg 0x18: [mem 0xef404000-0xef404fff 64bit]
[    0.488830] pci 0000:02:00.0: reg 0x20: [mem 0xef400000-0xef403fff 64bit]
[    0.488942] pci 0000:02:00.0: supports D1 D2
[    0.488943] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[    0.489161] pci 0000:00:1c.4: PCI bridge to [bus 02]
[    0.489164] pci 0000:00:1c.4:   bridge window [io  0xd000-0xdfff]
[    0.489166] pci 0000:00:1c.4:   bridge window [mem 0xef400000-0xef4fffff]
[    0.489485] pci 0000:03:00.0: [168c:0042] type 00 class 0x028000
[    0.489815] pci 0000:03:00.0: reg 0x10: [mem 0xef200000-0xef3fffff 64bit]
[    0.491124] pci 0000:03:00.0: PME# supported from D0 D3hot D3cold
[    0.492117] pci 0000:00:1c.5: PCI bridge to [bus 03]
[    0.492122] pci 0000:00:1c.5:   bridge window [mem 0xef200000-0xef3fffff]
[    0.495379] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.495450] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 *10 11 12 14 15)
[    0.495518] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.495586] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.495653] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.495719] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.495786] ACPI: PCI Interrupt Link [LNKG] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.495853] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 10 *11 12 14 15)
[    0.496639] ACPI: EC: interrupt unblocked
[    0.496660] ACPI: EC: event unblocked
[    0.496673] ACPI: \_SB_.PCI0.LPCB.EC0_: GPE=0x50, EC_CMD/EC_SC=0x66, EC_DATA=0x62
[    0.496674] ACPI: \_SB_.PCI0.LPCB.EC0_: Boot DSDT EC used to handle transactions and events
[    0.496749] iommu: Default domain type: Translated
[    0.496764] pci 0000:00:02.0: vgaarb: setting as boot VGA device
[    0.496764] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[    0.496764] pci 0000:00:02.0: vgaarb: bridge control possible
[    0.496764] vgaarb: loaded
[    0.496764] ACPI: bus type USB registered
[    0.496764] usbcore: registered new interface driver usbfs
[    0.496764] usbcore: registered new interface driver hub
[    0.496764] usbcore: registered new device driver usb
[    0.496764] pps_core: LinuxPPS API ver. 1 registered
[    0.496764] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.496764] PTP clock support registered
[    0.496764] EDAC MC: Ver: 3.0.0
[    0.498473] Registered efivars operations
[    0.498504] PCI: Using ACPI for IRQ routing
[    0.511522] PCI: pci_cache_line_size set to 64 bytes
[    0.511795] e820: reserve RAM buffer [mem 0x00058000-0x0005ffff]
[    0.511796] e820: reserve RAM buffer [mem 0x0009e000-0x0009ffff]
[    0.511797] e820: reserve RAM buffer [mem 0x8412f000-0x87ffffff]
[    0.511798] e820: reserve RAM buffer [mem 0x881bf000-0x8bffffff]
[    0.511799] e820: reserve RAM buffer [mem 0x8986c000-0x8bffffff]
[    0.511800] e820: reserve RAM buffer [mem 0x8b2ff000-0x8bffffff]
[    0.511801] e820: reserve RAM buffer [mem 0x36f000000-0x36fffffff]
[    0.511886] NetLabel: Initializing
[    0.511887] NetLabel:  domain hash size = 128
[    0.511887] NetLabel:  protocols = UNLABELED CIPSOv4 CALIPSO
[    0.511900] NetLabel:  unlabeled traffic allowed by default
[    0.512569] hpet0: at MMIO 0xfed00000, IRQs 2, 8, 0, 0, 0, 0, 0, 0
[    0.512572] hpet0: 8 comparators, 64-bit 24.000000 MHz counter
[    0.515119] clocksource: Switched to clocksource tsc-early
[    0.525911] *** VALIDATE bpf ***
[    0.525954] VFS: Disk quotas dquot_6.6.0
[    0.525968] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    0.525993] *** VALIDATE ramfs ***
[    0.525996] *** VALIDATE hugetlbfs ***
[    0.526077] AppArmor: AppArmor Filesystem Enabled
[    0.526105] pnp: PnP ACPI init
[    0.526459] system 00:00: [io  0x0680-0x069f] has been reserved
[    0.526461] system 00:00: [io  0xffff] has been reserved
[    0.526462] system 00:00: [io  0xffff] has been reserved
[    0.526463] system 00:00: [io  0xffff] has been reserved
[    0.526465] system 00:00: [io  0x1800-0x18fe] has been reserved
[    0.526466] system 00:00: [io  0x164e-0x164f] has been reserved
[    0.526470] system 00:00: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.526591] pnp 00:01: Plug and Play ACPI device, IDs PNP0b00 (active)
[    0.526636] system 00:02: [io  0x1854-0x1857] has been reserved
[    0.526639] system 00:02: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[    0.526847] pnp 00:03: Plug and Play ACPI device, IDs ATK3001 PNP030b (active)
[    0.527166] system 00:04: [mem 0xfed10000-0xfed17fff] has been reserved
[    0.527168] system 00:04: [mem 0xfed18000-0xfed18fff] has been reserved
[    0.527169] system 00:04: [mem 0xfed19000-0xfed19fff] has been reserved
[    0.527170] system 00:04: [mem 0xf0000000-0xf7ffffff] has been reserved
[    0.527171] system 00:04: [mem 0xfed20000-0xfed3ffff] has been reserved
[    0.527173] system 00:04: [mem 0xfed90000-0xfed93fff] could not be reserved
[    0.527174] system 00:04: [mem 0xfed45000-0xfed8ffff] has been reserved
[    0.527175] system 00:04: [mem 0xff000000-0xffffffff] has been reserved
[    0.527177] system 00:04: [mem 0xfee00000-0xfeefffff] could not be reserved
[    0.527178] system 00:04: [mem 0xeffe0000-0xefffffff] has been reserved
[    0.527181] system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.527233] system 00:05: [mem 0xfd000000-0xfdabffff] has been reserved
[    0.527234] system 00:05: [mem 0xfdad0000-0xfdadffff] has been reserved
[    0.527235] system 00:05: [mem 0xfdb00000-0xfdffffff] has been reserved
[    0.527236] system 00:05: [mem 0xfe000000-0xfe01ffff] could not be reserved
[    0.527238] system 00:05: [mem 0xfe036000-0xfe03bfff] has been reserved
[    0.527239] system 00:05: [mem 0xfe03d000-0xfe3fffff] has been reserved
[    0.527240] system 00:05: [mem 0xfe410000-0xfe7fffff] has been reserved
[    0.527243] system 00:05: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.527624] system 00:06: [io  0xff00-0xfffe] has been reserved
[    0.527627] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.529218] system 00:07: [mem 0xfe029000-0xfe029fff] has been reserved
[    0.529219] system 00:07: [mem 0xfe028000-0xfe028fff] has been reserved
[    0.529220] system 00:07: [mem 0xfdaf0000-0xfdafffff] has been reserved
[    0.529222] system 00:07: [mem 0xfdae0000-0xfdaeffff] has been reserved
[    0.529225] system 00:07: [mem 0xfdac0000-0xfdacffff] has been reserved
[    0.529228] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[    0.530628] pnp: PnP ACPI: found 8 devices
[    0.531756] thermal_sys: Registered thermal governor 'fair_share'
[    0.531756] thermal_sys: Registered thermal governor 'bang_bang'
[    0.531757] thermal_sys: Registered thermal governor 'step_wise'
[    0.531758] thermal_sys: Registered thermal governor 'user_space'
[    0.531759] thermal_sys: Registered thermal governor 'power_allocator'
[    0.536294] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[    0.536327] pci 0000:00:1c.0: PCI bridge to [bus 01]
[    0.536330] pci 0000:00:1c.0:   bridge window [io  0xe000-0xefff]
[    0.536334] pci 0000:00:1c.0:   bridge window [mem 0xee000000-0xef0fffff]
[    0.536337] pci 0000:00:1c.0:   bridge window [mem 0xd0000000-0xe1ffffff 64bit pref]
[    0.536341] pci 0000:00:1c.4: PCI bridge to [bus 02]
[    0.536343] pci 0000:00:1c.4:   bridge window [io  0xd000-0xdfff]
[    0.536346] pci 0000:00:1c.4:   bridge window [mem 0xef400000-0xef4fffff]
[    0.536352] pci 0000:00:1c.5: PCI bridge to [bus 03]
[    0.536356] pci 0000:00:1c.5:   bridge window [mem 0xef200000-0xef3fffff]
[    0.536363] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
[    0.536364] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
[    0.536365] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[    0.536366] pci_bus 0000:00: resource 7 [mem 0x000c0000-0x000c3fff window]
[    0.536367] pci_bus 0000:00: resource 8 [mem 0x000c4000-0x000c7fff window]
[    0.536368] pci_bus 0000:00: resource 9 [mem 0x000c8000-0x000cbfff window]
[    0.536369] pci_bus 0000:00: resource 10 [mem 0x000cc000-0x000cffff window]
[    0.536370] pci_bus 0000:00: resource 11 [mem 0x000d0000-0x000d3fff window]
[    0.536371] pci_bus 0000:00: resource 12 [mem 0x000d4000-0x000d7fff window]
[    0.536372] pci_bus 0000:00: resource 13 [mem 0x000d8000-0x000dbfff window]
[    0.536373] pci_bus 0000:00: resource 14 [mem 0x000dc000-0x000dffff window]
[    0.536374] pci_bus 0000:00: resource 15 [mem 0x000e0000-0x000e3fff window]
[    0.536375] pci_bus 0000:00: resource 16 [mem 0x000e4000-0x000e7fff window]
[    0.536376] pci_bus 0000:00: resource 17 [mem 0x000e8000-0x000ebfff window]
[    0.536377] pci_bus 0000:00: resource 18 [mem 0x000ec000-0x000effff window]
[    0.536378] pci_bus 0000:00: resource 19 [mem 0x000f0000-0x000fffff window]
[    0.536379] pci_bus 0000:00: resource 20 [mem 0x90000000-0xefffffff window]
[    0.536380] pci_bus 0000:00: resource 21 [mem 0xfd000000-0xfe7fffff window]
[    0.536381] pci_bus 0000:01: resource 0 [io  0xe000-0xefff]
[    0.536382] pci_bus 0000:01: resource 1 [mem 0xee000000-0xef0fffff]
[    0.536383] pci_bus 0000:01: resource 2 [mem 0xd0000000-0xe1ffffff 64bit pref]
[    0.536384] pci_bus 0000:02: resource 0 [io  0xd000-0xdfff]
[    0.536385] pci_bus 0000:02: resource 1 [mem 0xef400000-0xef4fffff]
[    0.536386] pci_bus 0000:03: resource 1 [mem 0xef200000-0xef3fffff]
[    0.536603] NET: Registered protocol family 2
[    0.536747] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[    0.538610] tcp_listen_portaddr_hash hash table entries: 8192 (order: 5, 131072 bytes, linear)
[    0.538685] TCP established hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[    0.538858] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[    0.538931] TCP: Hash tables configured (established 131072 bind 65536)
[    0.538972] UDP hash table entries: 8192 (order: 6, 262144 bytes, linear)
[    0.539015] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes, linear)
[    0.539109] NET: Registered protocol family 1
[    0.539117] NET: Registered protocol family 44
[    0.539129] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[    0.539688] PCI: CLS 0 bytes, default 64
[    0.539736] Trying to unpack rootfs image as initramfs...
[    5.055466] Freeing initrd memory: 42508K
[    5.055496] DMAR: ACPI device "device:6e" under DMAR at fed91000 as 00:15.0
[    5.055499] DMAR: ACPI device "device:6f" under DMAR at fed91000 as 00:15.1
[    5.085199] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[    5.085208] software IO TLB: mapped [mem 0x7ef49000-0x82f49000] (64MB)
[    5.085427] check: Scanning for low memory corruption every 60 seconds
[    5.085726] Initialise system trusted keyrings
[    5.085745] Key type blacklist registered
[    5.085795] workingset: timestamp_bits=41 max_order=22 bucket_order=0
[    5.086916] zbud: loaded
[    5.090623] Key type asymmetric registered
[    5.090624] Asymmetric key parser 'x509' registered
[    5.090632] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[    5.090660] io scheduler mq-deadline registered
[    5.090660] io scheduler kyber registered
[    5.090682] io scheduler bfq registered
[    5.091073] pcieport 0000:00:1c.0: PME: Signaling with IRQ 122
[    5.091132] pcieport 0000:00:1c.0: AER: enabled with IRQ 122
[    5.091369] pcieport 0000:00:1c.4: PME: Signaling with IRQ 123
[    5.091583] pcieport 0000:00:1c.5: PME: Signaling with IRQ 124
[    5.091646] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[    5.091720] efifb: probing for efifb
[    5.091742] efifb: Ignoring BGRT: unexpected or invalid BMP data
[    5.091743] efifb: framebuffer at 0xc0000000, using 3072k, total 3072k
[    5.091744] efifb: mode is 1024x768x32, linelength=4096, pages=1
[    5.091745] efifb: scrolling: redraw
[    5.091746] efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
[    5.091781] fbcon: Deferring console take-over
[    5.091788] fb0: EFI VGA frame buffer device
[    5.091797] intel_idle: MWAIT substates: 0x11142120
[    5.091798] intel_idle: v0.4.1 model 0x8E
[    5.092001] intel_idle: lapic_timer_reliable_states 0xffffffff
[    5.092057] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:18/PNP0C09:01/PNP0C0D:00/input/input0
[    5.092074] ACPI: Lid Switch [LID]
[    5.092136] input: Sleep Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0E:00/input/input1
[    5.092150] ACPI: Sleep Button [SLPB]
[    5.092173] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input2
[    5.092185] ACPI: Power Button [PWRB]
[    5.092215] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input3
[    5.095185] ACPI: Power Button [PWRF]
[    5.096863] thermal LNXTHERM:00: registered as thermal_zone0
[    5.096864] ACPI: Thermal Zone [THRM] (48 C)
[    5.097168] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[    5.098050] AMD-Vi: AMD IOMMUv2 driver by Joerg Roedel <jroedel@suse.de>
[    5.098051] AMD-Vi: AMD IOMMUv2 functionality not available on this system
[    5.098482] usbcore: registered new interface driver usbserial_generic
[    5.098485] usbserial: USB Serial support registered for generic
[    5.098510] rtc_cmos 00:01: RTC can wake from S4
[    5.099062] rtc_cmos 00:01: registered as rtc0
[    5.099075] rtc_cmos 00:01: alarms up to one month, y3k, 242 bytes nvram, hpet irqs
[    5.099127] intel_pstate: Intel P-state driver initializing
[    5.099375] intel_pstate: HWP enabled
[    5.099424] ledtrig-cpu: registered to indicate activity on CPUs
[    5.099483] intel_pmc_core INT33A1:00:  initialized
[    5.099537] drop_monitor: Initializing network drop monitor service
[    5.099688] NET: Registered protocol family 10
[    5.105452] Segment Routing with IPv6
[    5.105476] NET: Registered protocol family 17
[    5.105828] RAS: Correctable Errors collector initialized.
[    5.105863] microcode: sig=0x806e9, pf=0x80, revision=0xde
[    5.105994] microcode: Microcode Update Driver: v2.2.
[    5.105998] IPI shorthand broadcast: enabled
[    5.106006] sched_clock: Marking stable (5105284067, 706945)->(5110905962, -4914950)
[    5.106154] registered taskstats version 1
[    5.106161] Loading compiled-in X.509 certificates
[    5.109494] Loaded X.509 cert 'Build time autogenerated kernel key: 3c4346de4ef277ce1b6a837b25841358452bfbe8'
[    5.109525] zswap: loaded using pool lzo/zbud
[    5.109683] Key type ._fscrypt registered
[    5.109684] Key type .fscrypt registered
[    5.115017] Key type big_key registered
[    5.115020] AppArmor: AppArmor sha1 policy hashing enabled
[    5.116451] PM:   Magic number: 1:421:492
[    5.116643] rtc_cmos 00:01: setting system clock to 2021-12-22T17:28:06 UTC (1640194086)
[    5.117742] Freeing unused decrypted memory: 2040K
[    5.118051] Freeing unused kernel image memory: 1640K
[    5.152116] Write protecting the kernel read-only data: 18432k
[    5.153171] Freeing unused kernel image memory: 2008K
[    5.177210] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    5.177212] x86/mm: Checking user space page tables
[    5.193690] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[    5.193692] Run /init as init process
[    5.472803] loop: module loaded
[    5.488745] device-mapper: uevent: version 1.0.3
[    5.489004] device-mapper: ioctl: 4.41.0-ioctl (2019-09-16) initialised: dm-devel@redhat.com
[    5.574434] i8042: PNP: PS/2 Controller [PNP030b:PS2K] at 0x60,0x64 irq 1
[    5.574436] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[    5.575723] serio: i8042 KBD port at 0x60,0x64 irq 1
[    5.586584] battery: ACPI: Battery Slot [BAT0] (battery present)
[    5.595082] Linux agpgart interface v0.103
[    5.602343] SCSI subsystem initialized
[    5.602570] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    5.602578] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[    5.603656] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x100 quirks 0x0000000081109810
[    5.605178] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[    5.605732] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.04
[    5.605734] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    5.605736] usb usb1: Product: xHCI Host Controller
[    5.605737] usb usb1: Manufacturer: Linux 5.4.124-1-MANJARO xhci-hcd
[    5.605738] usb usb1: SerialNumber: 0000:00:14.0
[    5.605856] hub 1-0:1.0: USB hub found
[    5.605872] hub 1-0:1.0: 12 ports detected
[    5.607118] xhci_hcd 0000:00:14.0: xHCI Host Controller
[    5.607121] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[    5.607124] xhci_hcd 0000:00:14.0: Host supports USB 3.0 SuperSpeed
[    5.607164] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.04
[    5.607165] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    5.607166] usb usb2: Product: xHCI Host Controller
[    5.607168] usb usb2: Manufacturer: Linux 5.4.124-1-MANJARO xhci-hcd
[    5.607169] usb usb2: SerialNumber: 0000:00:14.0
[    5.607256] hub 2-0:1.0: USB hub found
[    5.607267] hub 2-0:1.0: 6 ports detected
[    5.626275] cryptd: max_cpu_qlen set to 1000
[    5.632978] r8169 0000:02:00.0: can't disable ASPM; OS doesn't have ASPM control
[    5.638715] AVX2 version of gcm_enc/dec engaged.
[    5.638716] AES CTR mode by8 optimization enabled
[    5.638768] libata version 3.00 loaded.
[    5.642945] ahci 0000:00:17.0: version 3.0
[    5.647536] libphy: r8169: probed
[    5.647752] r8169 0000:02:00.0 eth0: RTL8168gu/8111gu, 70:4d:7b:4a:66:f7, XID 509, IRQ 126
[    5.647754] r8169 0000:02:00.0 eth0: jumbo features [frames: 9200 bytes, tx checksumming: ko]
[    5.653431] ahci 0000:00:17.0: AHCI 0001.0301 32 slots 2 ports 6 Gbps 0x3 impl SATA mode
[    5.653432] ahci 0000:00:17.0: flags: 64bit ncq pm led clo only pio slum part deso sadm sds apst
[    5.653846] scsi host0: ahci
[    5.654002] scsi host1: ahci
[    5.654054] ata1: SATA max UDMA/133 abar m2048@0xef133000 port 0xef133100 irq 127
[    5.654056] ata2: SATA max UDMA/133 abar m2048@0xef133000 port 0xef133180 irq 127
[    5.674083] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input4
[    5.855165] usb 1-2: new high-speed USB device number 2 using xhci_hcd
[    5.873660] checking generic (c0000000 300000) vs hw (c0000000 10000000)
[    5.873661] fb0: switching to inteldrmfb from EFI VGA
[    5.873714] i915 0000:00:02.0: vgaarb: deactivate vga console
[    5.875077] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    5.875077] [drm] Driver supports precise vblank timestamp query.
[    5.876049] i915 0000:00:02.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=io+mem
[    5.876454] [drm] Finished loading DMC firmware i915/kbl_dmc_ver1_04.bin (v1.4)
[    5.893288] i915 0000:00:02.0: Failed to program MOCS registers; expect performance issues.
[    5.893985] [drm] Initialized i915 1.6.0 20190822 for 0000:00:02.0 on minor 0
[    5.896688] ACPI: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
[    5.897113] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input5
[    5.897158] ACPI: Video Device [PEGP] (multi-head: no  rom: yes  post: no)
[    5.897183] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:23/LNXVIDEO:01/input/input6
[    5.969368] ata2: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[    5.973060] ata2.00: ATAPI: SlimtypeDVD A  DA8AESH, XAA1, max UDMA/133
[    5.973853] ata2.00: configured for UDMA/133
[    6.009515] usb 1-2: New USB device found, idVendor=0930, idProduct=6545, bcdDevice= 1.10
[    6.009519] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    6.009522] usb 1-2: Product: DataTraveler 2.0
[    6.009525] usb 1-2: Manufacturer: Kingston
[    6.009527] usb 1-2: SerialNumber: AC220B280C75B0A039B1D93A
[    6.017543] usb-storage 1-2:1.0: USB Mass Storage device detected
[    6.017893] scsi host2: usb-storage 1-2:1.0
[    6.018051] usbcore: registered new interface driver usb-storage
[    6.021470] usbcore: registered new interface driver uas
[    6.082619] fbcon: i915drmfb (fb0) is primary device
[    6.082621] fbcon: Deferring console take-over
[    6.082625] i915 0000:00:02.0: fb0: i915drmfb frame buffer device
[    6.111927] tsc: Refined TSC clocksource calibration: 2711.999 MHz
[    6.111934] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x271785701be, max_idle_ns: 440795203568 ns
[    6.111971] clocksource: Switched to clocksource tsc
[    6.135219] usb 1-5: new high-speed USB device number 3 using xhci_hcd
[    6.275757] usb 1-5: New USB device found, idVendor=0bda, idProduct=0129, bcdDevice=39.60
[    6.275761] usb 1-5: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    6.275764] usb 1-5: Product: USB2.0-CRW
[    6.275767] usb 1-5: Manufacturer: Generic
[    6.275770] usb 1-5: SerialNumber: 20100201396000000
[    6.284675] usbcore: registered new interface driver rtsx_usb
[    6.398548] usb 1-6: new high-speed USB device number 4 using xhci_hcd
[    6.564803] usb 1-6: New USB device found, idVendor=04f2, idProduct=b52b, bcdDevice=95.52
[    6.564808] usb 1-6: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[    6.564811] usb 1-6: Product: USB2.0 VGA UVC WebCam
[    6.564814] usb 1-6: Manufacturer: Chicony Electronics Co.,Ltd.
[    6.564816] usb 1-6: SerialNumber: 0x0001
[    6.688543] usb 1-8: new full-speed USB device number 5 using xhci_hcd
[    6.829667] usb 1-8: New USB device found, idVendor=13d3, idProduct=3496, bcdDevice= 0.01
[    6.829674] usb 1-8: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    7.021334] scsi 2:0:0:0: Direct-Access     Kingston DataTraveler 2.0 PMAP PQ: 0 ANSI: 6
[    7.031052] sd 2:0:0:0: [sda] 15249408 512-byte logical blocks: (7.81 GB/7.27 GiB)
[    7.031462] sd 2:0:0:0: [sda] Write Protect is off
[    7.031469] sd 2:0:0:0: [sda] Mode Sense: 45 00 00 00
[    7.031756] sd 2:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[    7.059134]  sda: sda1 sda2
[    7.061966] sd 2:0:0:0: [sda] Attached SCSI removable disk
[   11.011899] ata1: link is slow to respond, please be patient (ready=0)
[   15.658567] ata1: COMRESET failed (errno=-16)
[   21.011914] ata1: link is slow to respond, please be patient (ready=0)
[   25.715245] ata1: COMRESET failed (errno=-16)
[   31.071905] ata1: link is slow to respond, please be patient (ready=0)
[   60.765180] ata1: COMRESET failed (errno=-16)
[   60.765194] ata1: limiting SATA link speed to 3.0 Gbps
[   65.781906] ata1: COMRESET failed (errno=-16)
[   65.781921] ata1: reset failed, giving up
[   65.786247] scsi 1:0:0:0: CD-ROM            Slimtype DVD A  DA8AESH   XAA1 PQ: 0 ANSI: 5
[   65.857425] random: fast init done
[   65.895280] sr 1:0:0:0: [sr0] scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray
[   65.895288] cdrom: Uniform CD-ROM driver Revision: 3.20
[   65.919526] sr 1:0:0:0: Attached scsi CD-ROM sr0
[   66.770650] ISO 9660 Extensions: Microsoft Joliet Level 3
[   66.785182] ISO 9660 Extensions: RRIP_1991A
[   66.916573] ISO 9660 Extensions: Microsoft Joliet Level 3
[   66.930665] ISO 9660 Extensions: RRIP_1991A
[   67.064632] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[   67.537906] overlayfs: null uuid detected in lower fs '/', falling back to index=off,nfs_export=off.
[   68.388355] cgroup2: Unknown parameter 'memory_recursiveprot'
[   68.401749] systemd[1]: systemd 248.3-2-manjaro running in system mode. (+PAM +AUDIT -SELINUX -APPARMOR -IMA +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT -QRENCODE +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +XKBCOMMON +UTMP -SYSVINIT default-hierarchy=unified)
[   68.418906] systemd[1]: Detected architecture x86-64.
[   68.438687] fbcon: Taking over console
[   68.456023] Console: switching to colour frame buffer device 240x67
[   68.604168] random: crng init done
[   68.882768] systemd[1]: Queued start job for default target Graphical Interface.
[   68.883738] systemd[1]: Created slice system-getty.slice.
[   68.884047] systemd[1]: Created slice system-modprobe.slice.
[   68.884321] systemd[1]: Created slice User and Session Slice.
[   68.884466] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[   68.884589] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[   68.884929] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[   68.885037] systemd[1]: Reached target Local Encrypted Volumes.
[   68.885136] systemd[1]: Reached target Login Prompts.
[   68.885232] systemd[1]: Reached target Paths.
[   68.885313] systemd[1]: Reached target Remote File Systems.
[   68.885396] systemd[1]: Reached target Slices.
[   68.885477] systemd[1]: Reached target Swap.
[   68.885564] systemd[1]: Reached target Local Verity Integrity Protected Volumes.
[   68.885710] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[   68.886136] systemd[1]: Listening on LVM2 poll daemon socket.
[   68.887105] systemd[1]: Listening on Process Core Dump Socket.
[   68.887321] systemd[1]: Listening on Journal Audit Socket.
[   68.887479] systemd[1]: Listening on Journal Socket (/dev/log).
[   68.887642] systemd[1]: Listening on Journal Socket.
[   68.888048] systemd[1]: Listening on udev Control Socket.
[   68.888205] systemd[1]: Listening on udev Kernel Socket.
[   68.888899] systemd[1]: Mounting Huge Pages File System...
[   68.889599] systemd[1]: Mounting POSIX Message Queue File System...
[   68.890525] systemd[1]: Mounting Kernel Debug File System...
[   68.891222] systemd[1]: Mounting Kernel Trace File System...
[   68.892077] systemd[1]: Mounting Temporary Directory (/tmp)...
[   68.892965] systemd[1]: Starting Create list of static device nodes for the current kernel...
[   68.893669] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling...
[   68.894713] systemd[1]: Starting Load Kernel Module configfs...
[   68.895810] systemd[1]: Starting Load Kernel Module drm...
[   68.896912] systemd[1]: Starting Load Kernel Module fuse...
[   68.907922] systemd[1]: Condition check resulted in Set Up Additional Binary Formats being skipped.
[   68.911521] systemd[1]: Starting Load Kernel Modules...
[   68.912256] systemd[1]: Starting Remount Root and Kernel File Systems...
[   68.913069] systemd[1]: Condition check resulted in Repartition Root Disk being skipped.
[   68.913662] systemd[1]: Starting Coldplug All udev Devices...
[   68.915336] systemd[1]: Mounted Huge Pages File System.
[   68.915543] systemd[1]: Mounted POSIX Message Queue File System.
[   68.915705] systemd[1]: Mounted Kernel Debug File System.
[   68.915876] systemd[1]: Mounted Kernel Trace File System.
[   68.916041] systemd[1]: Mounted Temporary Directory (/tmp).
[   68.916325] systemd[1]: Finished Create list of static device nodes for the current kernel.
[   68.916643] systemd[1]: modprobe@drm.service: Deactivated successfully.
[   68.916777] systemd[1]: Finished Load Kernel Module drm.
[   68.920957] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[   68.921513] systemd[1]: Finished Load Kernel Module configfs.
[   68.923822] systemd[1]: Mounting Kernel Configuration File System...
[   68.929287] systemd[1]: Mounted Kernel Configuration File System.
[   68.944375] fuse: init (API version 7.31)
[   68.944426] *** VALIDATE fuse ***
[   68.944430] *** VALIDATE fuse ***
[   68.945169] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[   68.945403] systemd[1]: Finished Load Kernel Module fuse.
[   68.946546] systemd[1]: Mounting FUSE Control File System...
[   68.949847] systemd[1]: Mounted FUSE Control File System.
[   68.980642] systemd[1]: Finished Remount Root and Kernel File Systems.
[   68.981004] systemd[1]: Condition check resulted in First Boot Wizard being skipped.
[   68.982132] systemd[1]: Condition check resulted in Rebuild Hardware Database being skipped.
[   68.982994] systemd[1]: Starting Load/Save Random Seed...
[   68.983297] systemd[1]: Condition check resulted in Create System Users being skipped.
[   68.984440] systemd[1]: Starting Create Static Device Nodes in /dev...
[   68.990023] systemd[1]: Finished Load/Save Random Seed.
[   68.990361] systemd[1]: Condition check resulted in First Boot Complete being skipped.
[   69.046257] spl: loading out-of-tree module taints kernel.
[   69.046338] spl: module verification failed: signature and/or required key missing - tainting kernel
[   69.066744] znvpair: module license 'CDDL' taints kernel.
[   69.066745] Disabling lock debugging due to kernel taint
[   69.106504] systemd[1]: Finished Create Static Device Nodes in /dev.
[   69.107919] systemd[1]: Started Entropy Daemon based on the HAVEGE algorithm.
[   69.109519] systemd[1]: Starting Journal Service...
[   69.111068] systemd[1]: Starting Rule-based Manager for Device Events and Files...
[   69.111511] systemd[1]: Finished Coldplug All udev Devices.
[   69.157799] systemd[1]: Started Journal Service.
[   69.157939] audit: type=1130 audit(1640194150.535:2): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journald comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   69.214383] systemd-journald[316]: Received client request to flush runtime journal.
[   69.218913] audit: type=1130 audit(1640194150.598:3): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-journal-flush comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   69.233688] audit: type=1130 audit(1640194150.612:4): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-udevd comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   69.389375] ZFS: Loaded module v2.0.4-1, ZFS pool version 5000, ZFS filesystem version 5
[   69.393201] audit: type=1130 audit(1640194150.772:5): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-modules-load comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   69.475207] audit: type=1130 audit(1640194150.855:6): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-sysctl comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   69.488890] ACPI: AC Adapter [AC0] (on-line)
[   69.533210] input: Asus Wireless Radio Control as /devices/LNXSYSTM:00/LNXSYBUS:00/ATK4002:00/input/input7
[   69.560079] tpm_crb MSFT0101:00: [Firmware Bug]: ACPI region does not cover the entire command/response buffer. [mem 0xfed40000-0xfed4087f flags 0x200] vs fed40080 f80
[   69.560086] tpm_crb MSFT0101:00: [Firmware Bug]: ACPI region does not cover the entire command/response buffer. [mem 0xfed40000-0xfed4087f flags 0x200] vs fed40080 f80
[   69.581097] proc_thermal 0000:00:04.0: enabling device (0000 -> 0002)
[   69.587669] intel_rapl_common: Found RAPL domain package
[   69.587670] intel_rapl_common: Found RAPL domain dram
[   69.587759] proc_thermal 0000:00:04.0: Creating sysfs group for PROC_THERMAL_PCI
[   69.601286] audit: type=1130 audit(1640194150.978:7): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-backlight@backlight:intel_backlight comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   69.682838] r8169 0000:02:00.0 enp2s0: renamed from eth0
[   69.711650] hidraw: raw HID events driver (C) Jiri Kosina
[   69.782130] input: PC Speaker as /devices/platform/pcspkr/input/input8
[   69.782796] i801_smbus 0000:00:1f.4: SPD Write Disable is set
[   69.782842] i801_smbus 0000:00:1f.4: SMBus using PCI interrupt
[   69.863680] mei_me 0000:00:16.0: enabling device (0000 -> 0002)
[   69.864031] intel-lpss 0000:00:15.0: enabling device (0000 -> 0002)
[   69.864315] idma64 idma64.0: Found Intel integrated DMA 64-bit
[   69.875898] intel-lpss 0000:00:15.1: enabling device (0000 -> 0002)
[   69.876226] idma64 idma64.1: Found Intel integrated DMA 64-bit
[   69.887350] i2c_hid i2c-FTE1001:00: i2c-FTE1001:00 supply vdd not found, using dummy regulator
[   69.887374] i2c_hid i2c-FTE1001:00: i2c-FTE1001:00 supply vddl not found, using dummy regulator
[   69.904397] RAPL PMU: API unit is 2^-32 Joules, 5 fixed counters, 655360 ms ovfl timer
[   69.904398] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[   69.904399] RAPL PMU: hw unit of domain package 2^-14 Joules
[   69.904400] RAPL PMU: hw unit of domain dram 2^-14 Joules
[   69.904400] RAPL PMU: hw unit of domain pp1-gpu 2^-14 Joules
[   69.904401] RAPL PMU: hw unit of domain psys 2^-14 Joules
[   69.904979] asus_wmi: ASUS WMI generic driver loaded
[   69.914519] intel_rapl_common: Found RAPL domain package
[   69.914520] intel_rapl_common: Found RAPL domain core
[   69.914522] intel_rapl_common: Found RAPL domain uncore
[   69.914523] intel_rapl_common: Found RAPL domain dram
[   69.956299] asus_wmi: Initialization: 0x1
[   69.956615] asus_wmi: BIOS WMI version: 9.0
[   69.956829] asus_wmi: SFUN value: 0x21
[   69.956838] asus-nb-wmi asus-nb-wmi: Detected ATK, not ASUSWMI, use DSTS
[   69.956845] asus-nb-wmi asus-nb-wmi: Detected ATK, enable event queue
[   69.964018] input: Asus WMI hotkeys as /devices/platform/asus-nb-wmi/input/input9
[   70.034789] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   70.037506] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   70.069155] mei_hdcp 0000:00:16.0-b638ab7e-94e2-4ea2-a552-d1c54b627f04: bound 0000:00:02.0 (ops i915_hdcp_component_ops [i915])
[   70.145168] iTCO_vendor_support: vendor-support=0
[   70.147345] iTCO_wdt: Intel TCO WatchDog Timer Driver v1.11
[   70.147415] iTCO_wdt: Found a Intel PCH TCO device (Version=4, TCOBASE=0x0400)
[   70.147557] iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
[   70.174614] input: FTE1001:00 0B05:0101 as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-7/i2c-FTE1001:00/0018:0B05:0101.0001/input/input10
[   70.174700] asus 0018:0B05:0101.0001: input,hidraw0: I2C HID v1.00 Mouse [FTE1001:00 0B05:0101] on i2c-FTE1001:00
[   70.196261] mousedev: PS/2 mouse device common for all mice
[   70.221632] snd_hda_intel 0000:00:1f.3: enabling device (0000 -> 0002)
[   70.221822] snd_hda_intel 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [i915])
[   70.335384] snd_hda_codec_realtek hdaudioC0D0: autoconfig for ALC255: line_outs=1 (0x14/0x0/0x0/0x0/0x0) type:speaker
[   70.335386] snd_hda_codec_realtek hdaudioC0D0:    speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[   70.335388] snd_hda_codec_realtek hdaudioC0D0:    hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[   70.335390] snd_hda_codec_realtek hdaudioC0D0:    mono: mono_out=0x0
[   70.335391] snd_hda_codec_realtek hdaudioC0D0:    inputs:
[   70.335392] snd_hda_codec_realtek hdaudioC0D0:      Internal Mic=0x1b
[   70.335394] snd_hda_codec_realtek hdaudioC0D0:      Headset Mic=0x19
[   70.388212] ath10k_pci 0000:03:00.0: enabling device (0000 -> 0002)
[   70.390620] ath10k_pci 0000:03:00.0: pci irq msi oper_irq_mode 2 irq_mode 0 reset_mode 0
[   70.410429] input: HDA Intel PCH Headphone as /devices/pci0000:00/0000:00:1f.3/sound/card0/input11
[   70.410479] input: HDA Intel PCH HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input12
[   70.410529] input: HDA Intel PCH HDMI/DP,pcm=7 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input13
[   70.410576] input: HDA Intel PCH HDMI/DP,pcm=8 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input14
[   70.410627] input: HDA Intel PCH HDMI/DP,pcm=9 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input15
[   70.410676] input: HDA Intel PCH HDMI/DP,pcm=10 as /devices/pci0000:00/0000:00:1f.3/sound/card0/input16
[   70.708679] ath10k_pci 0000:03:00.0: qca9377 hw1.1 target 0x05020001 chip_id 0x003821ff sub 1a3b:2b31
[   70.708685] ath10k_pci 0000:03:00.0: kconfig debug 1 debugfs 1 tracing 1 dfs 0 testmode 0
[   70.710115] ath10k_pci 0000:03:00.0: firmware ver WLAN.TF.2.1-00021-QCARMSWP-1 api 6 features wowlan,ignore-otp crc32 42e41877
[   70.780786] ath10k_pci 0000:03:00.0: board_file api 2 bmi_id N/A crc32 8aedfa4a
[   70.855233] ath10k_pci 0000:03:00.0: unsupported HTC service id: 1536
[   70.873639] ath10k_pci 0000:03:00.0: htt-ver 3.56 wmi-op 4 htt-op 3 cal otp max-sta 32 raw 0 hwcrypto 1
[   70.948897] ath: EEPROM regdomain: 0x6a
[   70.948902] ath: EEPROM indicates we should expect a direct regpair map
[   70.948908] ath: Country alpha2 being used: 00
[   70.948910] ath: Regpair used: 0x6a
[   70.965756] ath10k_pci 0000:03:00.0 wlp3s0: renamed from wlan0
[   70.982783] audit: type=1130 audit(1640194152.362:8): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   71.989546] mc: Linux media interface: v0.10
[   72.038908] videodev: Linux video capture interface: v2.00
[   72.045409] Bluetooth: Core ver 2.22
[   72.045430] NET: Registered protocol family 31
[   72.045432] Bluetooth: HCI device and connection manager initialized
[   72.045435] Bluetooth: HCI socket layer initialized
[   72.045437] Bluetooth: L2CAP socket layer initialized
[   72.045440] Bluetooth: SCO socket layer initialized
[   72.279576] usbcore: registered new interface driver btusb
[   72.301744] uvcvideo: Found UVC 1.00 device USB2.0 VGA UVC WebCam (04f2:b52b)
[   72.307876] Bluetooth: hci0: using rampatch file: qca/rampatch_usb_00000302.bin
[   72.307888] Bluetooth: hci0: QCA: patch rome 0x302 build 0x3e8, firmware rome 0x302 build 0x111
[   72.316744] input: USB2.0 VGA UVC WebCam: USB2.0 V as /devices/pci0000:00/0000:00:14.0/usb1/1-6/1-6:1.0/input/input17
[   72.318553] usbcore: registered new interface driver uvcvideo
[   72.318579] USB Video Class driver (1.1.1)
[   72.383598] Bluetooth: hci0: using NVM file: qca/nvm_usb_00000302.bin
[   72.454780] audit: type=1130 audit(1640194153.832:9): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lvm2-monitor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   72.556416] audit: type=1130 audit(1640194153.935:10): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-setup comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   72.562942] audit: type=1127 audit(1640194153.942:11): pid=681 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg=' comm="systemd-update-utmp" exe="/usr/lib/systemd/systemd-update-utmp" hostname=? addr=? terminal=? res=success'
[   72.613958] proc: Bad value for 'hidepid'
[   73.296891] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   73.296895] Bluetooth: BNEP filters: protocol multicast
[   73.296902] Bluetooth: BNEP socket layer initialized
[   73.320791] NET: Registered protocol family 38
[   73.320896] proc: Bad value for 'hidepid'
[   74.247354] kauditd_printk_skb: 9 callbacks suppressed
[   74.247355] audit: type=1130 audit(1640194155.622:21): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=polkit comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   74.412414] st: Version 20160209, fixed bufsize 32768, s/g segs 256
[   74.645520] sd 2:0:0:0: Attached scsi generic sg0 type 0
[   74.645565] sr 1:0:0:0: Attached scsi generic sg1 type 5
[   74.682403] Generic FE-GE Realtek PHY r8169-200:00: attached PHY driver [Generic FE-GE Realtek PHY] (mii_bus:phy_addr=r8169-200:00, irq=IGNORE)
[   74.772186] audit: type=1130 audit(1640194156.152:22): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=ModemManager comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   74.773560] audit: type=1130 audit(1640194156.152:23): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   74.797908] r8169 0000:02:00.0 enp2s0: Link is Down
[   75.024989] ath10k_pci 0000:03:00.0: unsupported HTC service id: 1536
[   75.379317] ath10k_pci 0000:03:00.0: unsupported HTC service id: 1536
[   75.673464] audit: type=1130 audit(1640194157.052:24): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=wpa_supplicant comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   76.033048] audit: type=1130 audit(1640194157.412:25): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=mirrors-live comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   76.033052] audit: type=1131 audit(1640194157.412:26): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=mirrors-live comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   77.302494] audit: type=1131 audit(1640194158.682:27): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-rfkill comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[   80.807043] audit: type=1116 audit(1640194162.185:28): pid=920 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=adding group acct="manjaro" exe="/usr/bin/useradd" hostname=? addr=? terminal=? res=success'
[   80.807781] audit: type=1114 audit(1640194162.185:29): pid=920 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=adding user id=1000 exe="/usr/bin/useradd" hostname=? addr=? terminal=? res=success'
[   80.807793] audit: type=1114 audit(1640194162.185:30): pid=920 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=adding user to group acct="manjaro" exe="/usr/bin/useradd" hostname=? addr=? terminal=? res=success'
[   80.807815] audit: type=1114 audit(1640194162.185:31): pid=920 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=adding user to group acct="manjaro" exe="/usr/bin/useradd" hostname=? addr=? terminal=? res=success'
[   80.807834] audit: type=1114 audit(1640194162.185:32): pid=920 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=adding user to group acct="manjaro" exe="/usr/bin/useradd" hostname=? addr=? terminal=? res=success'
[   80.807851] audit: type=1114 audit(1640194162.185:33): pid=920 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=adding user to group acct="manjaro" exe="/usr/bin/useradd" hostname=? addr=? terminal=? res=success'
[   80.807868] audit: type=1114 audit(1640194162.185:34): pid=920 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=adding user to group acct="manjaro" exe="/usr/bin/useradd" hostname=? addr=? terminal=? res=success'
[   80.807889] audit: type=1114 audit(1640194162.185:35): pid=920 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=adding user to shadow group acct="manjaro" exe="/usr/bin/useradd" hostname=? addr=? terminal=? res=success'
[   80.807906] audit: type=1114 audit(1640194162.185:36): pid=920 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=adding user to shadow group acct="manjaro" exe="/usr/bin/useradd" hostname=? addr=? terminal=? res=success'
[   80.807925] audit: type=1114 audit(1640194162.185:37): pid=920 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=adding user to shadow group acct="manjaro" exe="/usr/bin/useradd" hostname=? addr=? terminal=? res=success'
[  103.628364] kauditd_printk_skb: 7 callbacks suppressed
[  103.628367] audit: type=1130 audit(1640194185.005:45): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=pacman-init comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  104.166845] audit: type=1131 audit(1640194185.545:46): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  117.760173] nvidia-nvlink: Nvlink Core is being initialized, major device number 237
[  117.760730] nvidia 0000:01:00.0: enabling device (0006 -> 0007)
[  117.876999] NVRM: loading NVIDIA UNIX x86_64 Kernel Module  465.31  Thu May 13 22:24:36 UTC 2021
[  117.898943] nvidia-modeset: Loading NVIDIA Kernel Mode Setting Driver for UNIX platforms  465.31  Thu May 13 22:14:23 UTC 2021
[  117.902135] [drm] [nvidia-drm] [GPU ID 0x00000100] Loading driver
[  117.902137] [drm] Initialized nvidia-drm 0.0.0 20160202 for 0000:01:00.0 on minor 1
[  117.905344] audit: type=1130 audit(1640194199.285:47): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=mhwd-live comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  117.905347] audit: type=1131 audit(1640194199.285:48): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=mhwd-live comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  117.911643] audit: type=1130 audit(1640194199.288:49): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-user-sessions comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  117.914276] audit: type=1130 audit(1640194199.292:50): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=sddm comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  120.491982] ACPI Warning: \_SB.PCI0.RP01.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20190816/nsarguments-59)
[  121.985467] audit: type=1100 audit(1640194203.365:51): pid=3830 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:authentication grantors=pam_faillock,pam_shells,pam_permit,pam_gnome_keyring acct="manjaro" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[  121.986518] audit: type=1101 audit(1640194203.365:52): pid=3830 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="manjaro" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[  121.986815] audit: type=1103 audit(1640194203.365:53): pid=3830 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_shells,pam_permit,pam_gnome_keyring acct="manjaro" exe="/usr/lib/sddm/sddm-helper" hostname=? addr=? terminal=? res=success'
[  121.986859] audit: type=1006 audit(1640194203.365:54): pid=3830 uid=0 subj==unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=1 res=1
[  122.002995] audit: type=1130 audit(1640194203.382:55): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  122.009611] audit: type=1101 audit(1640194203.388:56): pid=3832 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="manjaro" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  125.211610] kauditd_printk_skb: 5 callbacks suppressed
[  125.211611] audit: type=1130 audit(1640194206.588:62): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  125.397340] audit: type=1101 audit(1640194206.775:63): pid=4047 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="manjaro" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=success'
[  125.397582] audit: type=1110 audit(1640194206.775:64): pid=4047 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=success'
[  125.401741] audit: type=1105 audit(1640194206.778:65): pid=4047 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=success'
[  125.413484] audit: type=1130 audit(1640194206.792:66): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  125.413993] audit: type=1106 audit(1640194206.792:67): pid=4047 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=success'
[  125.414146] audit: type=1104 audit(1640194206.792:68): pid=4047 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=success'
[  125.436054] audit: type=1101 audit(1640194206.815:69): pid=4063 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="manjaro" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=success'
[  125.436352] audit: type=1110 audit(1640194206.815:70): pid=4063 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=success'
[  125.441329] audit: type=1105 audit(1640194206.818:71): pid=4063 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=? res=success'
[  125.961993] Bluetooth: RFCOMM TTY layer initialized
[  125.961999] Bluetooth: RFCOMM socket layer initialized
[  125.962004] Bluetooth: RFCOMM ver 1.11
[  225.951397] kauditd_printk_skb: 3 callbacks suppressed
[  225.951400] audit: type=1111 audit(1640194307.328:75): pid=687 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=connection-add-activate uuid=ed1cf7f3-8195-420f-a7b9-698aa8fed6f9 name="note6" pid=3981 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
[  230.840352] wlp3s0: authenticate with 70:bb:e9:18:d2:97
[  230.872722] wlp3s0: send auth to 70:bb:e9:18:d2:97 (try 1/3)
[  230.876360] wlp3s0: authenticated
[  230.878501] wlp3s0: associate with 70:bb:e9:18:d2:97 (try 1/3)
[  230.886953] wlp3s0: RX AssocResp from 70:bb:e9:18:d2:97 (capab=0x1421 status=0 aid=1)
[  230.890218] wlp3s0: associated
[  230.891812] IPv6: ADDRCONF(NETDEV_CHANGE): wlp3s0: link becomes ready
[  230.987677] audit: type=1130 audit(1640194312.365:76): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  231.040269] audit: type=1111 audit(1640194312.418:77): pid=687 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=statistics arg="refresh-rate-ms" pid=3981 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
[  235.351070] audit: type=1111 audit(1640194316.728:78): pid=687 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='op=statistics arg="refresh-rate-ms" pid=3981 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
[  241.011071] audit: type=1131 audit(1640194322.388:79): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  299.175865] audit: type=1101 audit(1640194380.555:80): pid=5007 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="manjaro" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[  299.176617] audit: type=1110 audit(1640194380.555:81): pid=5007 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[  299.182699] audit: type=1105 audit(1640194380.562:82): pid=5007 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[  299.499644] audit: type=1106 audit(1640194380.878:83): pid=5007 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[  299.500228] audit: type=1104 audit(1640194380.878:84): pid=5007 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[  394.273509] audit: type=1101 audit(1640194475.652:85): pid=5100 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="manjaro" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[  394.274220] audit: type=1110 audit(1640194475.652:86): pid=5100 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[  394.275959] audit: type=1105 audit(1640194475.655:87): pid=5100 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[  394.599409] audit: type=1106 audit(1640194475.978:88): pid=5100 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[  394.599825] audit: type=1104 audit(1640194475.978:89): pid=5100 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[  768.625338] audit: type=1101 audit(1640194850.005:90): pid=5876 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="manjaro" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[  768.625531] audit: type=1110 audit(1640194850.005:91): pid=5876 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[  768.628383] audit: type=1105 audit(1640194850.005:92): pid=5876 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[  768.634282] audit: type=1106 audit(1640194850.012:93): pid=5876 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[  768.634411] audit: type=1104 audit(1640194850.012:94): pid=5876 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[  851.331054] audit: type=1101 audit(1640194932.708:95): pid=6031 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="manjaro" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[  857.932344] audit: type=1101 audit(1640194939.312:96): pid=6039 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="manjaro" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[  857.932583] audit: type=1110 audit(1640194939.312:97): pid=6039 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[  857.935797] audit: type=1105 audit(1640194939.315:98): pid=6039 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[  857.943219] audit: type=1106 audit(1640194939.322:99): pid=6039 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[  857.943290] audit: type=1104 audit(1640194939.322:100): pid=6039 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[  887.092799] audit: type=1101 audit(1640194968.471:101): pid=6092 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="manjaro" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[  887.092997] audit: type=1110 audit(1640194968.471:102): pid=6092 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[  887.094909] audit: type=1105 audit(1640194968.471:103): pid=6092 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[  887.100283] audit: type=1106 audit(1640194968.478:104): pid=6092 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[  887.100371] audit: type=1104 audit(1640194968.478:105): pid=6092 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[  894.746359] audit: type=1101 audit(1640194976.125:106): pid=6104 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="manjaro" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[  894.746550] audit: type=1110 audit(1640194976.125:107): pid=6104 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[  894.750187] audit: type=1105 audit(1640194976.128:108): pid=6104 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[  894.756707] audit: type=1106 audit(1640194976.135:109): pid=6104 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[  894.756778] audit: type=1104 audit(1640194976.135:110): pid=6104 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[  905.716878] audit: type=1101 audit(1640194987.095:111): pid=6125 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="manjaro" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[  905.716965] audit: type=1110 audit(1640194987.095:112): pid=6125 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[  905.720031] audit: type=1105 audit(1640194987.098:113): pid=6125 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[  905.728822] audit: type=1106 audit(1640194987.108:114): pid=6125 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[  905.728921] audit: type=1104 audit(1640194987.108:115): pid=6125 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[  905.733528] audit: type=1130 audit(1640194987.111:116): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  905.733532] audit: type=1131 audit(1640194987.111:117): pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-tmpfiles-clean comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
[  910.458832] audit: type=1101 audit(1640194991.838:118): pid=6139 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="manjaro" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[  910.459346] audit: type=1110 audit(1640194991.838:119): pid=6139 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[  910.462261] audit: type=1105 audit(1640194991.841:120): pid=6139 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[  958.981004] kauditd_printk_skb: 2 callbacks suppressed
[  958.981005] audit: type=1101 audit(1640195040.358:123): pid=6207 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="manjaro" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[  958.981319] audit: type=1110 audit(1640195040.358:124): pid=6207 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[  958.983164] audit: type=1105 audit(1640195040.361:125): pid=6207 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[  958.990997] audit: type=1106 audit(1640195040.368:126): pid=6207 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[  958.991135] audit: type=1104 audit(1640195040.368:127): pid=6207 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[  969.979292] audit: type=1101 audit(1640195051.358:128): pid=6222 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="manjaro" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[  969.979296] audit: type=1110 audit(1640195051.358:129): pid=6222 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[  969.981943] audit: type=1105 audit(1640195051.361:130): pid=6222 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[  969.990013] audit: type=1106 audit(1640195051.368:131): pid=6222 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[  969.990080] audit: type=1104 audit(1640195051.368:132): pid=6222 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[ 1422.423097] audit: type=1101 audit(1640195503.801:133): pid=6951 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="manjaro" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[ 1422.423358] audit: type=1110 audit(1640195503.801:134): pid=6951 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[ 1422.425264] audit: type=1105 audit(1640195503.805:135): pid=6951 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[ 1422.441633] audit: type=1106 audit(1640195503.821:136): pid=6951 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_close grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[ 1422.441732] audit: type=1104 audit(1640195503.821:137): pid=6951 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[ 1475.880797] audit: type=1101 audit(1640195557.258:138): pid=7043 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:accounting grantors=pam_unix,pam_permit,pam_time acct="manjaro" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[ 1475.880977] audit: type=1110 audit(1640195557.258:139): pid=7043 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:setcred grantors=pam_faillock,pam_permit,pam_env,pam_faillock acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[ 1475.882957] audit: type=1105 audit(1640195557.261:140): pid=7043 uid=1000 auid=1000 ses=1 subj==unconfined msg='op=PAM:session_open grantors=pam_limits,pam_unix,pam_permit acct="root" exe="/usr/bin/sudo" hostname=? addr=? terminal=/dev/pts/2 res=success'
[manjaro@manjaro ~]$
There are 2 SATA Connections detected:
Your DVD-Drive:
and thats must be the HDD/SSD:
EBUSY 16 Device or resource busy
I would say, the HDD is dead. It tries to connect, but failed, because it takes too long. Probably the HDD starts spinning and crash while connecting? IDK :man_shrugging:
if my hdd is dead then i need to buy a new one ?
if yes then can you please tell me which one …
yes…
See forum rules… Manjaro Forum is not a place for hardware recommendations. Anyway, it must be a 2.5 inch form factor HDD/SSD. SSDs should be preferable.
see for any SSD ( sata )
As @megavolt explained, this is likely to be a faulty HDD; probably your HDD got head crash and destroyed the internal disk (say if perhaps you cut down the PC power while the HDD was running). A faulty HDD from a head crash can be still identified by OS, but you just cannot access it.
Anyway, this is no longer Manjaro issue and you need to buy an HDD/SSD SATA connection type (not USB, SCSI, or SAS connection type).
For a quick advice how to choose:
  • HDD is prone to mechanical failure like this, like if you cut down power to HDD or drop your HDD.
  • SSD doesn’t have this mechanical issue, so it’s not as fragile to physical faults as compared to HDD.
  • But in terms of reliability (in every day use, means if you keep your HDD/SSD in its normal enviroment and not mishandle it like dropping to the floor), HDD has longer life span than SSD; SSD cell wearing by not being able to write to the cells anymore has much shorter lifespan than HDD mechanical component wear and tear.
thank you for the advice , I’ll start looking for ssd now .
