I’m upgrading my HP Z230 SFF from 250 GB to 2 TB. I bought a drive from eBay and booted from a thumb drive. (I downloaded a fresh iso.) At first, the installer crashed shortly after I opened. When I finally got all the options selected in the installer, the installation process failed. Below is the installer log (https://termbin.com/c9xau) . I have a sneaking suspicion that the drive is bad. Any help would be appreciated.
Thanks.
=== START CALAMARES 3.2.61-9
2023-01-25 - 18:59:13 [6]: void CalamaresApplication::init()
Calamares version: 3.2.61-9
2023-01-25 - 18:59:13 [6]: .. languages: "ar, as, ast, az, az_AZ, be, bg, bn, ca, ca@valencia, cs_CZ, da, de, el, en, en_GB, eo, es, es_MX, et, eu, fa, fi_FI, fr, fur, gl, he, hi, hr, hu, id, is, it_IT, ja, ko, lt, ml, mr, nb, nl, oc, pl, pt_BR, pt_PT, ro, ru, si, sk, sl, sq, sr, sr@latin, sv, tg, th, tr_TR, uk, vi, zh_CN, zh_TW"
2023-01-25 - 18:59:13 [6]: bool CalamaresUtils::initQmlModulesDir()
Using Calamares QML directory "/usr/share/calamares/qml"
2023-01-25 - 18:59:13 [6]: Calamares::Branding::Branding(const QString&, QObject*)
Using Calamares branding file at "/usr/share/calamares/branding/manjaro/branding.desc"
2023-01-25 - 18:59:13 [2]: Calamares::Branding::Branding(const QString&, QObject*)
WARNING: the branding component "/usr/share/calamares/branding/manjaro" does not ship translations.
Loaded branding component "manjaro"
2023-01-25 - 18:59:13 [6]: .. No translation for "tz_" "C" using default (en)
2023-01-25 - 18:59:13 [6]: .. No translation for "calamares_" "C" using default (en)
2023-01-25 - 18:59:13 [6]: .. STARTUP: initSettings, initQmlPath, initBranding done
2023-01-25 - 18:59:13 [6]: .. STARTUP: initModuleManager: module init started
2023-01-25 - 18:59:13 [2]: static Calamares::ModuleSystem::Descriptor Calamares::ModuleSystem::Descriptor::fromDescriptorData(const QVariantMap&, const QString&)
WARNING: Descriptor file "/usr/lib/calamares/modules/servicescfg/module.desc"
2023-01-25 - 18:59:13 [2]: WARNING: .. Module descriptor contains extra keys:
"requires"
2023-01-25 - 18:59:13 [6]: void Calamares::ModuleManager::doInit()
Found 57 modules
2023-01-25 - 18:59:13 [6]: void CalamaresApplication::initView()
STARTUP: initModuleManager: all modules init done
STARTUP: initJobQueue done
2023-01-25 - 18:59:13 [6]: CalamaresWindow::CalamaresWindow(QWidget*)
Available desktop QSize(1920, 1048) minimum size QSize(1024, 520)
2023-01-25 - 18:59:13 [6]: .. Proposed window size: 1024 560
2023-01-25 - 18:59:13 [6]: QString CalamaresUtils::searchQmlFile(QmlSearch, const QString&)
Looking for QML for "calamares-sidebar"
2023-01-25 - 18:59:13 [6]: .. Looking at QML file "/usr/share/calamares/branding/manjaro/calamares-sidebar.qml"
STARTUP: CalamaresWindow created; loadModules started
2023-01-25 - 18:59:13 [6]: void Config::initLanguages()
Trying to match locale "C"
Trying to match locale QLocale(C, Default, Default)
2023-01-25 - 18:59:13 [6]: .. Trying to match approximate locale QLocale::C
2023-01-25 - 18:59:13 [6]: .. Trying to match English (US)
2023-01-25 - 18:59:13 [6]: void Config::setLocaleIndex(int)
Index 14 Selected locale "en"
2023-01-25 - 18:59:13 [6]: .. Loaded QRC translation "tz_" "en"
2023-01-25 - 18:59:13 [6]: .. Loaded QRC translation "calamares_" "en"
2023-01-25 - 18:59:14 [6]: virtual void Calamares::ViewModule::loadSelf()
ViewModule "welcome@welcome" loading complete.
2023-01-25 - 18:59:14 [6]: QStringList loadLocales(const QString&)
Loading locales from "/usr/share/i18n/SUPPORTED"
2023-01-25 - 18:59:14 [6]: .. Read 492 lines
2023-01-25 - 18:59:14 [6]: .. After filtering 317 lines
ViewModule "locale@locale" loading complete.
2023-01-25 - 18:59:14 [6]: KeyboardModelsModel::KeyboardModelsModel(QObject*)
Loaded 189 keyboard models
2023-01-25 - 18:59:14 [6]: KeyboardPage::KeyboardPage(Config*, QWidget*)
Variants now total= 0 selected= -1
2023-01-25 - 18:59:14 [6]: .. Loaded QRC translation "kb_" "en"
2023-01-25 - 18:59:14 [6]: void Config::detectCurrentKeyboardLayout()
("pc", "us", "inet(evdev)\"")
ViewModule "keyboard@keyboard" loading complete.
2023-01-25 - 18:59:14 [6]: CalamaresUtils::Partition::InternalManager::InternalManager()
KPMCore backend starting ..
2023-01-25 - 18:59:14 [6]: Loaded backend plugin: "pmsfdiskbackendplugin"
2023-01-25 - 18:59:14 [6]: .. Backend @0x562bfba311a0 "pmsfdiskbackendplugin" "1"
2023-01-25 - 18:59:14 [2]: virtual void PartitionViewStep::setConfigurationMap(const QVariantMap&)
WARNING: Partition-module setting *defaultPartitionTableType* is unset, will use gpt for efi or msdos for bios
ViewModule "partition@partition" loading complete.
2023-01-25 - 18:59:14 [2]: void copyLegacy(const QVariantMap&, const QString&, QVariantMap&, const QString&)
WARNING: Legacy *users* key "userShell" overrides hostname-settings.
ViewModule "users@users" loading complete.
ViewModule "summary@summary" loading complete.
2023-01-25 - 18:59:14 [6]: void Calamares::ModuleManager::loadModules()
Module "partition@partition" already loaded.
2023-01-25 - 18:59:14 [6]: Calamares::SlideshowQML::SlideshowQML(QWidget*)
QML import paths:
"/usr/bin"
"qrc:/qt-project.org/imports"
"/usr/lib/qt/qml"
QML load on startup, API 2.
2023-01-25 - 18:59:14 [2]: QThread::setPriority: Cannot set priority, thread is not running
2023-01-25 - 18:59:14 [2]: virtual void MachineIdJob::setConfigurationMap(const QVariantMap&)
WARNING: MachineId: configuration setting *symlink* is deprecated, use *dbus-symlink*.
2023-01-25 - 18:59:14 [6]: virtual void Calamares::CppJobModule::loadSelf()
CppJobModule "machineid@machineid" loading complete.
Module "locale@locale" already loaded.
Module "keyboard@keyboard" already loaded.
CppJobModule "luksopenswaphookcfg@luksopenswaphookcfg" loading complete.
CppJobModule "luksbootkeyfile@luksbootkeyfile" loading complete.
CppJobModule "initcpio@initcpio" loading complete.
Module "users@users" already loaded.
CppJobModule "umount@umount" loading complete.
2023-01-25 - 18:59:14 [2]: void Config::setConfigurationMap(const QVariantMap&)
WARNING: Configuring the finished module with deprecated restartNowEnabled settings
ViewModule "finished@finished" loading complete.
2023-01-25 - 18:59:14 [6]: setGeoIP(Config*, const QVariantMap&)::<lambda()>
GeoIP result for welcome= "US"
2023-01-25 - 18:59:14 [6]: void setCountry(Config*, const QString&, CalamaresUtils::GeoIP::Handler*)
Unusable country code "US"
2023-01-25 - 18:59:14 [6]: .. Obtained from "https://ipapi.co/json" ( 1 "country" )
2023-01-25 - 18:59:14 [6]: void CalamaresApplication::initViewSteps()
STARTUP: loadModules for all modules done
2023-01-25 - 18:59:14 [6]: void Calamares::ModuleManager::checkRequirements()
Checking module requirements ..
2023-01-25 - 18:59:15 [6]: void CalamaresApplication::initViewSteps()
STARTUP: Window now visible and ProgressTreeView populated
2023-01-25 - 18:59:15 [6]: .. 8 view steps loaded.
2023-01-25 - 18:59:15 [6]: void Calamares::SlideshowQML::loadQmlV2Complete()
QML component complete, API 2
2023-01-25 - 18:59:15 [2]: unknown file system type "dos" on "/dev/sda3"
2023-01-25 - 18:59:15 [6]: smartctl initialization failed for "/dev/sdb" : Success
2023-01-25 - 18:59:15 [6]: error during smart output parsing for "/dev/sdb" : Success
2023-01-25 - 18:59:15 [2]: unknown file system type "" on "/dev/md127"
2023-01-25 - 18:59:15 [6]: QList<Device*> PartUtils::getDevices(DeviceType)
Removing unsuitable devices: 3 candidates.
2023-01-25 - 18:59:15 [6]: .. Running ("blkid", "/dev/sda")
2023-01-25 - 18:59:15 [6]: .. Running ("blkid", "/dev/sda1")
2023-01-25 - 18:59:15 [6]: .. Running ("blkid", "/dev/sda2")
2023-01-25 - 18:59:15 [6]: .. Running ("blkid", "")
2023-01-25 - 18:59:15 [6]: .. Target cmd: ("blkid", "") Exit code: 2 (no output)
2023-01-25 - 18:59:15 [6]: .. Running ("blkid", "/dev/sda3")
2023-01-25 - 18:59:15 [6]: .. Running ("blkid", "/dev/sdb")
2023-01-25 - 18:59:15 [6]: .. Removing device with iso9660 filesystem (probably a CD) on it "/dev/sdb"
2023-01-25 - 18:59:15 [6]: .. Running ("blkid", "/dev/md127")
2023-01-25 - 18:59:15 [6]: .. Target cmd: ("blkid", "/dev/md127") Exit code: 2 (no output)
2023-01-25 - 18:59:15 [6]: .. there are 2 devices left.
2023-01-25 - 18:59:15 [6]: void PartitionCoreModule::doInit()
LIST OF DETECTED DEVICES:
2023-01-25 - 18:59:15 [6]: .. node capacity name prettyName
2023-01-25 - 18:59:15 [6]: .. "/dev/sda" 2000396321280 DevName$7543fbf5 DevNamePretty$8cd9b56d
2023-01-25 - 18:59:15 [6]: .. "/dev/md127" -1 DevName$3652abe0 DevNamePretty$8783ddf1
2023-01-25 - 18:59:15 [6]: .. 2 devices detected.
2023-01-25 - 18:59:16 [6]: .. Loading "/usr/share/calamares/branding/manjaro/slideshow/SlideShow.qml"
2023-01-25 - 18:59:16 [6]: void Config::xkbApply()
xkbmap selection changed to: "us" - ""
2023-01-25 - 18:59:16 [6]: void Calamares::RequirementsChecker::reportProgress()
Remaining modules: 2
"partition"
"welcome"
2023-01-25 - 18:59:16 [6]: bool GeneralRequirements::checkHasPower()
A battery exists, checking for mains power.
2023-01-25 - 18:59:17 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
"welcome"
2023-01-25 - 18:59:17 [6]: Calamares::RequirementsList GeneralRequirements::checkRequirements()
GeneralRequirements output:
storage : 8482560409
enoughStorage : true
RAM : 1073741824
enoughRam : true
hasPower : true
hasInternet : true
isRoot : true
2023-01-25 - 18:59:17 [6]: void Calamares::RequirementsChecker::addCheckedRequirements(Calamares::Module*)
Got 5 requirement results from "welcome"
2023-01-25 - 18:59:18 [6]: void Calamares::RequirementsChecker::reportProgress()
Remaining modules: 1
"partition"
2023-01-25 - 18:59:19 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
2023-01-25 - 18:59:21 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
2023-01-25 - 18:59:22 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
2023-01-25 - 18:59:23 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
2023-01-25 - 18:59:24 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
2023-01-25 - 18:59:25 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
2023-01-25 - 18:59:27 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
2023-01-25 - 18:59:28 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
2023-01-25 - 18:59:29 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
2023-01-25 - 18:59:30 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
2023-01-25 - 18:59:31 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
2023-01-25 - 18:59:33 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
2023-01-25 - 18:59:34 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
2023-01-25 - 18:59:35 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
2023-01-25 - 18:59:36 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
2023-01-25 - 18:59:37 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
2023-01-25 - 18:59:39 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
2023-01-25 - 18:59:40 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
2023-01-25 - 18:59:41 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
2023-01-25 - 18:59:42 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
2023-01-25 - 18:59:43 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
2023-01-25 - 18:59:45 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
2023-01-25 - 18:59:46 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
2023-01-25 - 18:59:47 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
2023-01-25 - 18:59:48 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
2023-01-25 - 18:59:49 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
2023-01-25 - 18:59:51 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
2023-01-25 - 18:59:52 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
2023-01-25 - 18:59:53 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
2023-01-25 - 18:59:54 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
2023-01-25 - 18:59:55 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
2023-01-25 - 18:59:57 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
2023-01-25 - 18:59:58 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
2023-01-25 - 18:59:59 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
2023-01-25 - 19:00:00 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
2023-01-25 - 19:00:01 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
2023-01-25 - 19:00:03 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
2023-01-25 - 19:00:04 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
2023-01-25 - 19:00:05 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
2023-01-25 - 19:00:06 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
2023-01-25 - 19:00:07 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
2023-01-25 - 19:00:09 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
2023-01-25 - 19:00:10 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
2023-01-25 - 19:00:11 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
2023-01-25 - 19:00:12 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
2023-01-25 - 19:00:13 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
2023-01-25 - 19:00:15 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
2023-01-25 - 19:00:15 [1]: OsproberEntryList PartUtils::runOsprober(DeviceModel*)
ERROR: os-prober timed out.
2023-01-25 - 19:00:15 [6]: OsproberEntryList PartUtils::runOsprober(DeviceModel*)
os-prober gave no output.
2023-01-25 - 19:00:15 [2]: QProcess: Destroyed while process ("os-prober") is still running.
2023-01-25 - 19:00:15 [6]: void PartitionCoreModule::doInit()
Ignoring device that is not Disk_Device to bootLoaderDevices list.
2023-01-25 - 19:00:15 [2]: unknown file system type "" on "/dev/md127"
2023-01-25 - 19:00:16 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
2023-01-25 - 19:00:17 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
2023-01-25 - 19:00:18 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
2023-01-25 - 19:00:19 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
2023-01-25 - 19:00:21 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
2023-01-25 - 19:00:22 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
2023-01-25 - 19:00:23 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
2023-01-25 - 19:00:24 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
2023-01-25 - 19:00:25 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
2023-01-25 - 19:00:27 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
2023-01-25 - 19:00:28 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
2023-01-25 - 19:00:29 [6]: void Calamares::RequirementsChecker::reportProgress()
"partition"
2023-01-25 - 19:00:29 [6]: void Calamares::RequirementsChecker::addCheckedRequirements(Calamares::Module*)
Got 1 requirement results from "partition"
2023-01-25 - 19:00:29 [6]: void ChoicePage::updateDeviceStatePreview()
Updating partitioning state widgets.
2023-01-25 - 19:00:29 [6]: void ChoicePage::setupActions()
Setting up actions for "/dev/md127" with 0 entries.
2023-01-25 - 19:00:29 [6]: .. part of an inactive RAID device
2023-01-25 - 19:00:29 [6]: ChoicePage::setupActions()::<lambda()>
Setting texts for 0 osprober entries
No partitions available for replace-action.
No partitions available for resize-action.
No partitions ( any-mounted? false is-raid? true ) for erase-action.
2023-01-25 - 19:00:29 [6]: void ChoicePage::continueApplyDeviceChoice()
Previous device -1 new device 0
2023-01-25 - 19:00:29 [6]: void ChoicePage::applyActionChoice(InstallChoice)
Prev -1 InstallChoice Config::Erase "erase"
2023-01-25 - 19:00:29 [6]: PartitionTable* CreatePartitionTableJob::createTable()
CreatePartitionTableJob::createTable trying to make table for device "/dev/md127"
2023-01-25 - 19:00:29 [6]: void Calamares::RequirementsChecker::finished()
All requirements have been checked.
2023-01-25 - 19:00:29 [6]: void Calamares::RequirementsModel::describe() const
Requirements model has 6 items
2023-01-25 - 19:00:29 [6]: .. requirement 0 "storage" satisfied? true mandatory? true
2023-01-25 - 19:00:29 [6]: .. requirement 1 "ram" satisfied? true mandatory? true
2023-01-25 - 19:00:29 [6]: .. requirement 2 "power" satisfied? true mandatory? false
2023-01-25 - 19:00:29 [6]: .. requirement 3 "internet" satisfied? true mandatory? false
2023-01-25 - 19:00:29 [6]: .. requirement 4 "root" satisfied? true mandatory? true
2023-01-25 - 19:00:29 [6]: .. requirement 5 "partitions" satisfied? true mandatory? true
2023-01-25 - 19:00:29 [2]: unknown file system type "" on "/dev/md127"
2023-01-25 - 19:00:29 [6]: static LocaleConfiguration LocaleConfiguration::fromLanguageAndLocation(const QString&, const QStringList&, const QString&)
Mapping "en" in "US" to locale.
2023-01-25 - 19:00:29 [6]: .. Got best match for "en" as "en_ZW.UTF-8"
2023-01-25 - 19:00:29 [6]: .. Got best match for "en_US" as "en_US.UTF-8"
2023-01-25 - 14:00:29 [6]: static LocaleConfiguration LocaleConfiguration::fromLanguageAndLocation(const QString&, const QStringList&, const QString&)
2023-01-25 - 14:00:29 [6]: .. Got best match for "en" as "en_ZW.UTF-8"
2023-01-25 - 14:00:29 [6]: .. Got best match for "en_US" as "en_US.UTF-8"
2023-01-25 - 14:00:30 [6]: void PartitionCoreModule::dumpQueue() const
# Queue:
2023-01-25 - 14:00:30 [6]: .. ## Device: "/dev/sda"
2023-01-25 - 14:00:30 [6]: .. ## Device: "/dev/md127"
2023-01-25 - 14:00:30 [6]: .. - CreatePartitionTableJob
2023-01-25 - 14:00:30 [6]: .. - CreatePartitionJob
2023-01-25 - 14:00:30 [6]: .. - SetPartFlagsJob
2023-01-25 - 14:00:30 [6]: void ChoicePage::updateActionChoicePreview(InstallChoice)
Updating partitioning preview widgets.
2023-01-25 - 14:00:30 [6]: void Config::guessLocaleKeyboardLayout()
Got locale language "en_US.UTF-8"
2023-01-25 - 14:00:30 [6]: .. looking for locale part "US"
2023-01-25 - 14:00:30 [6]: .. matched "us"
2023-01-25 - 14:00:30 [6]: void guessLayout(const QStringList&, KeyboardLayoutModel*, KeyboardVariantsModel*)
Next level: "en"
2023-01-25 - 14:00:31 [6]: static LocaleConfiguration LocaleConfiguration::fromLanguageAndLocation(const QString&, const QStringList&, const QString&)
Mapping "en_US.UTF-8" in "US" to locale.
2023-01-25 - 14:00:31 [6]: .. Got best match for "en_US.UTF-8" as "en_US.UTF-8"
2023-01-25 - 14:00:41 [6]: void Config::guessLocaleKeyboardLayout()
2023-01-25 - 14:00:41 [6]: .. looking for locale part "US"
2023-01-25 - 14:00:41 [6]: .. matched "us"
2023-01-25 - 14:00:41 [6]: void guessLayout(const QStringList&, KeyboardLayoutModel*, KeyboardVariantsModel*)
Next level: "en"
2023-01-25 - 14:01:05 [2]: unknown file system type "dos" on "/dev/sda3"
2023-01-25 - 14:01:05 [6]: void Calamares::restoreSelectedBootLoader(QComboBox&, const QString&)
No path to restore, choosing default
2023-01-25 - 14:01:05 [6]: void PartitionCoreModule::setBootLoaderInstallPath(const QString&)
PCM::setBootLoaderInstallPath "/dev/sda"
2023-01-25 - 14:01:05 [2]: unknown file system type "" on "/dev/md127"
2023-01-25 - 14:01:22 [6]: void ChoicePage::updateDeviceStatePreview()
2023-01-25 - 14:01:22 [6]: void ChoicePage::setupActions()
Setting up actions for "/dev/sda" with 0 entries.
2023-01-25 - 14:01:22 [6]: .. Can not resize "/dev/sda1" , filesystem "linux_raid_member" does not support resize.
2023-01-25 - 14:01:22 [6]: .. Checking if "/dev/sda1" can be replaced.
2023-01-25 - 14:01:22 [6]: .. NO, insufficient storage
Required storage B: 9019431321 "(7.9GiB)"
Available storage B: 2550005760 "(2GiB)"
2023-01-25 - 14:01:22 [6]: .. Can not resize "/dev/sda2" , filesystem "linux_raid_member" does not support resize.
2023-01-25 - 14:01:22 [6]: .. Checking if "/dev/sda2" can be replaced.
Available storage B: 2147483648 "(2GiB)"
2023-01-25 - 14:01:22 [6]: .. Can not resize "/dev/sda" , filesystem "unknown" does not support resize.
2023-01-25 - 14:01:22 [6]: .. Checking if "/dev/sda" can be replaced.
Available storage B: 133300224 "(0GiB)"
Required storage B: 11166914969 "(10.4GiB)"
Available storage B: 106938368 "(0GiB)" for "/dev/sda3" length: 3897577824 sectorsUsed: 3897368960 fsType: "extended"
2023-01-25 - 14:01:22 [6]: .. Checking if "/dev/sda3" can be replaced.
2023-01-25 - 14:01:22 [6]: .. Partition "/dev/sda3" authorized for replace install.
2023-01-25 - 14:01:22 [6]: .. contains replaceable "/dev/sda3"
Available storage B: 6144000 "(0GiB)"
2023-01-25 - 14:01:22 [6]: .. Can not resize "/dev/sda5" , filesystem "linux_raid_member" does not support resize.
2023-01-25 - 14:01:22 [6]: .. Checking if "/dev/sda5" can be replaced.
2023-01-25 - 14:01:22 [6]: .. Partition "/dev/sda5" authorized for replace install.
2023-01-25 - 14:01:22 [6]: .. contains replaceable "/dev/sda5"
Available storage B: 97648640 "(0GiB)"
Available storage B: 4637184 "(0GiB)"
2023-01-25 - 14:01:22 [6]: ChoicePage::setupActions()::<lambda()>
2023-01-25 - 14:01:22 [6]: void ChoicePage::continueApplyDeviceChoice()
Previous device 0 new device 1
2023-01-25 - 14:01:22 [6]: void ChoicePage::applyActionChoice(InstallChoice)
2023-01-25 - 14:01:22 [6]: PartitionTable* CreatePartitionTableJob::createTable()
CreatePartitionTableJob::createTable trying to make table for device "/dev/sda"
2023-01-25 - 14:01:22 [6]: void PartitionCoreModule::setBootLoaderInstallPath(const QString&)
2023-01-25 - 14:01:22 [2]: unknown file system type "" on "/dev/md127"
2023-01-25 - 14:01:39 [6]: void PartitionCoreModule::setBootLoaderInstallPath(const QString&)
2023-01-25 - 14:01:39 [2]: unknown file system type "" on "/dev/md127"
2023-01-25 - 14:01:39 [6]: void PartitionCoreModule::dumpQueue() const
# Queue:
2023-01-25 - 14:01:39 [6]: .. ## Device: "/dev/sda"
2023-01-25 - 14:01:39 [6]: .. - CreatePartitionTableJob
2023-01-25 - 14:01:39 [6]: .. - CreatePartitionJob
2023-01-25 - 14:01:39 [6]: .. - SetPartFlagsJob
2023-01-25 - 14:01:39 [6]: .. ## Device: "/dev/md127"
2023-01-25 - 14:01:39 [6]: void ChoicePage::updateActionChoicePreview(InstallChoice)
2023-01-25 - 14:02:03 [6]: bool ChoicePage::calculateNextEnabled() const
No partition selected for alongside or replace
2023-01-25 - 14:02:03 [6]: void ChoicePage::applyActionChoice(InstallChoice)
Prev -1 InstallChoice Config::Replace "replace"
2023-01-25 - 14:02:03 [6]: void ChoicePage::updateActionChoicePreview(InstallChoice)
2023-01-25 - 14:02:03 [2]: unknown file system type "dos" on "/dev/sda3"
2023-01-25 - 14:02:03 [6]: void PartitionCoreModule::setBootLoaderInstallPath(const QString&)
2023-01-25 - 14:02:03 [2]: unknown file system type "" on "/dev/md127"
2023-01-25 - 14:02:04 [6]: bool PartUtils::canBeReplaced(Partition*, const Logger::Once&)
2023-01-25 - 14:02:04 [6]: .. Partition "/dev/sda5" authorized for replace install.
2023-01-25 - 14:02:07 [6]: bool PartUtils::canBeReplaced(Partition*, const Logger::Once&)
2023-01-25 - 14:02:07 [6]: .. NO, insufficient storage
2023-01-25 - 14:02:07 [6]: .. Partition "/dev/sda5" authorized for replace install.
2023-01-25 - 14:02:12 [6]: bool PartUtils::canBeReplaced(Partition*, const Logger::Once&)
2023-01-25 - 14:02:12 [6]: .. Partition "/dev/sda5" authorized for replace install.
2023-01-25 - 14:02:14 [6]: bool PartUtils::canBeReplaced(Partition*, const Logger::Once&)
2023-01-25 - 14:02:14 [6]: .. NO, insufficient storage
2023-01-25 - 14:02:14 [6]: .. Partition "/dev/sda5" authorized for replace install.
2023-01-25 - 14:02:15 [6]: void ChoicePage::applyActionChoice(InstallChoice)
2023-01-25 - 14:02:15 [6]: PartitionTable* CreatePartitionTableJob::createTable()
2023-01-25 - 14:02:15 [6]: void PartitionCoreModule::setBootLoaderInstallPath(const QString&)
2023-01-25 - 14:02:15 [2]: unknown file system type "" on "/dev/md127"
2023-01-25 - 14:02:15 [6]: void PartitionCoreModule::dumpQueue() const
# Queue:
2023-01-25 - 14:02:15 [6]: .. ## Device: "/dev/sda"
2023-01-25 - 14:02:15 [6]: .. - CreatePartitionTableJob
2023-01-25 - 14:02:15 [6]: .. - CreatePartitionJob
2023-01-25 - 14:02:15 [6]: .. - SetPartFlagsJob
2023-01-25 - 14:02:15 [6]: .. ## Device: "/dev/md127"
2023-01-25 - 14:02:15 [6]: void ChoicePage::updateActionChoicePreview(InstallChoice)
2023-01-25 - 14:02:20 [6]: void ChoicePage::applyActionChoice(InstallChoice)
2023-01-25 - 14:02:20 [6]: void ChoicePage::updateActionChoicePreview(InstallChoice)
2023-01-25 - 14:02:20 [2]: unknown file system type "dos" on "/dev/sda3"
2023-01-25 - 14:02:20 [6]: void PartitionCoreModule::setBootLoaderInstallPath(const QString&)
2023-01-25 - 14:02:20 [2]: unknown file system type "" on "/dev/md127"
2023-01-25 - 14:02:20 [6]: PartitionTable* CreatePartitionTableJob::createTable()
2023-01-25 - 14:02:20 [6]: qint64 PartitionActions::swapSuggestion(qint64, Config::SwapChoice)
Suggested swap size: 34 GiB
2023-01-25 - 14:02:20 [6]: void PartitionCoreModule::dumpQueue() const
# Queue:
2023-01-25 - 14:02:20 [6]: .. ## Device: "/dev/sda"
2023-01-25 - 14:02:20 [6]: .. - CreatePartitionTableJob
2023-01-25 - 14:02:20 [6]: .. - CreatePartitionJob
2023-01-25 - 14:02:20 [6]: .. - SetPartFlagsJob
2023-01-25 - 14:02:20 [6]: .. ## Device: "/dev/md127"
2023-01-25 - 14:02:47 [6]: bool PartUtils::canBeReplaced(Partition*, const Logger::Once&)
2023-01-25 - 14:02:47 [6]: .. Partition "/dev/sda5" authorized for replace install.
2023-01-25 - 14:02:48 [6]: bool PartUtils::canBeReplaced(Partition*, const Logger::Once&)
2023-01-25 - 14:02:48 [6]: .. NO, insufficient storage
2023-01-25 - 14:02:55 [6]: void PartitionCoreModule::setBootLoaderInstallPath(const QString&)
2023-01-25 - 14:03:17 [2]: QObject::setParent: Cannot set parent, new parent is in a different thread
2023-01-25 - 14:03:17 [6]: virtual QString PartitionViewStep::prettyStatus() const
Summary for Partition 1 Config::Erase
2023-01-25 - 14:03:17 [6]: QStringList findEssentialLVs(const QList<PartitionCoreModule::DeviceInfo*>&)
Checking LVM use on 2 devices
2023-01-25 - 14:03:17 [6]: QVariantList FillGlobalStorageJob::createPartitionList() const
Building partition information map
2023-01-25 - 14:03:17 [6]: .. partitions on "/dev/sda"
2023-01-25 - 14:03:17 [6]: .. mapping for "" "New Partition"
partlabel : "root"
partition-uuid (partuuid) : "PartUUID$418726db"
parttype : ""
partattrs : "0"
mountPoint: : "/"
fs: : "ext4"
fsName : "ext4"
filesystem-uuid (uuid) : "FSUUID$5159fd70"
claimed : "true"
partlabel : ""
parttype : ""
partattrs : "0"
mountPoint: : ""
fs: : "linuxswap"
fsName : "linuxswap"
claimed : "true"
2023-01-25 - 14:03:17 [6]: .. partitions on "/dev/md127"
partlabel : "root"
parttype : ""
partattrs : "0"
mountPoint: : "/"
fs: : "ext4"
fsName : "ext4"
claimed : "true"
partlabel : ""
parttype : ""
partattrs : "0"
mountPoint: : ""
fs: : "linuxswap"
claimed : "true"
2023-01-25 - 14:03:17 [2]: QLayout: Attempting to add QLayout "" to QWidget "", which already has a layout
partlabel : "root"
parttype : ""
partattrs : "0"
mountPoint: : "/"
fs: : "ext4"
fsName : "ext4"
claimed : "true"
partlabel : ""
parttype : ""
partattrs : "0"
mountPoint: : ""
fs: : "linuxswap"
claimed : "true"
partlabel : "root"
parttype : ""
partattrs : "0"
mountPoint: : "/"
fs: : "ext4"
fsName : "ext4"
claimed : "true"
partlabel : ""
parttype : ""
partattrs : "0"
mountPoint: : ""
fs: : "linuxswap"
claimed : "true"
2023-01-25 - 14:03:24 [6]: QStringList findEssentialLVs(const QList<PartitionCoreModule::DeviceInfo*>&)
2023-01-25 - 14:03:24 [6]: void Calamares::JobThread::finalize()
There are 35 jobs, total weight 33
2023-01-25 - 14:03:24 [6]: .. Job 1 "Manage auto-mount settings" +wt 0.111111 tot.wt 0.111111
2023-01-25 - 14:03:24 [6]: .. Job 2 "Clear all temporary mounts." +wt 0.111111 tot.wt 0.222222
2023-01-25 - 14:03:24 [6]: .. Job 3 "Clear mounts for partitioning operations on /dev/sda" +wt 0.111111 tot.wt 0.333333
2023-01-25 - 14:03:24 [6]: .. Job 4 "Create new msdos partition table on /dev/sda." +wt 0.111111 tot.wt 0.444444
2023-01-25 - 14:03:24 [6]: .. Job 5 "Create new 1872682MiB partition on /dev/sda (WDC WD2003FZEX-00Z4SA0) with file system ext4." +wt 0.111111 tot.wt 0.555556
2023-01-25 - 14:03:24 [6]: .. Job 6 "Set flags on 1872682MiB ext4 partition." +wt 0.111111 tot.wt 0.666667
2023-01-25 - 14:03:24 [6]: .. Job 7 "Create new 35043MiB partition on /dev/sda (WDC WD2003FZEX-00Z4SA0) with file system linuxswap." +wt 0.111111 tot.wt 0.777778
2023-01-25 - 14:03:24 [6]: .. Job 8 "Set partition information" +wt 0.111111 tot.wt 0.888889
2023-01-25 - 14:03:24 [6]: .. Job 9 "Manage auto-mount settings" +wt 0.111111 tot.wt 1
2023-01-25 - 14:03:24 [6]: .. Job 10 "mount" +wt 1 tot.wt 2
2023-01-25 - 14:03:24 [6]: .. Job 11 "unpackfs" +wt 12 tot.wt 14
2023-01-25 - 14:03:24 [6]: .. Job 12 "networkcfg" +wt 1 tot.wt 15
2023-01-25 - 14:03:24 [6]: .. Job 13 "Generate machine-id." +wt 1 tot.wt 16
2023-01-25 - 14:03:24 [6]: .. Job 14 "fstab" +wt 1 tot.wt 17
2023-01-25 - 14:03:24 [6]: .. Job 15 "Set timezone to America/Detroit" +wt 1 tot.wt 18
2023-01-25 - 14:03:24 [6]: .. Job 16 "Set keyboard model to pc105, layout to us-" +wt 1 tot.wt 19
2023-01-25 - 14:03:24 [6]: .. Job 17 "localecfg" +wt 1 tot.wt 20
2023-01-25 - 14:03:24 [6]: .. Job 18 "Configuring encrypted swap." +wt 1 tot.wt 21
2023-01-25 - 14:03:24 [6]: .. Job 19 "Configuring LUKS key file." +wt 1 tot.wt 22
2023-01-25 - 14:03:24 [6]: .. Job 20 "initcpiocfg" +wt 1 tot.wt 23
2023-01-25 - 14:03:24 [6]: .. Job 21 "Creating initramfs with mkinitcpio." +wt 1 tot.wt 24
2023-01-25 - 14:03:24 [6]: .. Job 22 "Configure <pre>sudo</pre> users." +wt 0.166667 tot.wt 24.1667
2023-01-25 - 14:03:24 [6]: .. Job 23 "Preparing groups." +wt 0.166667 tot.wt 24.3333
2023-01-25 - 14:03:24 [6]: .. Job 24 "Create user johnblood" +wt 0.166667 tot.wt 24.5
2023-01-25 - 14:03:24 [6]: .. Job 25 "Set password for user johnblood" +wt 0.166667 tot.wt 24.6667
2023-01-25 - 14:03:24 [6]: .. Job 26 "Set password for user root" +wt 0.166667 tot.wt 24.8333
2023-01-25 - 14:03:24 [6]: .. Job 27 "Set hostname zbox" +wt 0.166667 tot.wt 25
2023-01-25 - 14:03:24 [6]: .. Job 28 "displaymanager" +wt 1 tot.wt 26
2023-01-25 - 14:03:24 [6]: .. Job 29 "mhwdcfg" +wt 1 tot.wt 27
2023-01-25 - 14:03:24 [6]: .. Job 30 "hwclock" +wt 1 tot.wt 28
2023-01-25 - 14:03:24 [6]: .. Job 31 "services" +wt 1 tot.wt 29
2023-01-25 - 14:03:24 [6]: .. Job 32 "grubcfg" +wt 1 tot.wt 30
2023-01-25 - 14:03:24 [6]: .. Job 33 "bootloader" +wt 1 tot.wt 31
2023-01-25 - 14:03:24 [6]: .. Job 34 "postcfg" +wt 1 tot.wt 32
2023-01-25 - 14:03:24 [6]: .. Job 35 "Unmount file systems." +wt 1 tot.wt 33
2023-01-25 - 14:03:24 [6]: virtual void Calamares::JobThread::run()
Starting job "Manage auto-mount settings" ( 1 / 35 )
2023-01-25 - 14:03:24 [6]: virtual Calamares::JobResult AutoMountManagementJob::exec()
Set automount to disable
2023-01-25 - 14:03:24 [6]: void CalamaresUtils::Partition::querySolidAutoMount(QDBusConnection&, AutoMountInfo&)
Solid not available: "Not connected to D-Bus server"
Starting job "Clear all temporary mounts." ( 2 / 35 )
Starting job "Clear mounts for partitioning operations on /dev/sda" ( 3 / 35 )
2023-01-25 - 14:03:24 [6]: QStringList getPartitionsForDevice(const QString&)
Reading from "/proc/partitions" looking for "sda"
2023-01-25 - 14:03:24 [6]: virtual Calamares::JobResult ClearMountsJob::exec()
ClearMountsJob finished. Here's what was done:
2023-01-25 - 14:03:24 [6]: .. Running ("udevadm", "settle")
2023-01-25 - 14:03:24 [6]: .. Running ("sync")
Starting job "Create new msdos partition table on /dev/sda." ( 4 / 35 )
2023-01-25 - 14:03:24 [6]: virtual Calamares::JobResult CreatePartitionTableJob::exec()
Creating new partition table of type "msdos" , uncommitted partitions:
2023-01-25 - 14:03:24 [6]: .. "New Partition"
2023-01-25 - 14:03:24 [6]: .. Running ("lsblk")
2023-01-25 - 14:03:24 [6]: .. lsblk output:
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
loop0 7:0 0 142.6M 1 loop /run/miso/sfs/livefs
loop1 7:1 0 1019.7M 1 loop /run/miso/sfs/mhwdfs
loop2 7:2 0 1.6G 1 loop /run/miso/sfs/desktopfs
loop3 7:3 0 756M 1 loop /run/miso/sfs/rootfs
sda 8:0 0 1.8T 0 disk
|-sda1 8:1 0 2.4G 0 part
|-sda2 8:2 0 2G 0 part
|-sda3 8:3 0 1K 0 part
`-sda5 8:5 0 1.8T 0 part
`-md127 9:127 0 0B 0 md
sdb 8:16 1 28.9G 0 disk /run/miso/bootmnt
|-sdb1 8:17 1 3.6G 0 part
`-sdb2 8:18 1 4M 0 part
sr0 11:0 1 7.3G 0 rom /run/media/manjaro/DOC_MARTIN_S8_D2
2023-01-25 - 14:03:24 [6]: .. Running ("mount")
2023-01-25 - 14:03:24 [6]: .. mount output:
proc on /proc type proc (rw,nosuid,nodev,noexec,relatime)
sys on /sys type sysfs (rw,nosuid,nodev,noexec,relatime)
dev on /dev type devtmpfs (rw,nosuid,relatime,size=16281768k,nr_inodes=4070442,mode=755,inode64)
run on /run type tmpfs (rw,nosuid,nodev,relatime,mode=755,inode64)
/dev/sdb on /run/miso/bootmnt type iso9660 (ro,relatime,nojoliet,check=s,map=n,blocksize=2048,iocharset=utf8)
cowspace on /run/miso/cowspace type tmpfs (rw,relatime,size=262144k,mode=755,inode64)
overlay_root on /run/miso/overlay_root type tmpfs (rw,relatime,size=24466632k,mode=755,inode64)
/dev/loop0 on /run/miso/sfs/livefs type squashfs (ro,relatime,errors=continue)
/dev/loop1 on /run/miso/sfs/mhwdfs type squashfs (ro,relatime,errors=continue)
/dev/loop2 on /run/miso/sfs/desktopfs type squashfs (ro,relatime,errors=continue)
/dev/loop3 on /run/miso/sfs/rootfs type squashfs (ro,relatime,errors=continue)
overlay on / type overlay (rw,relatime,lowerdir=/run/miso/sfs/livefs:/run/miso/sfs/mhwdfs:/run/miso/sfs/desktopfs:/run/miso/sfs/rootfs,upperdir=/run/miso/overlay_root/upper,workdir=/run/miso/overlay_root/work,index=off,xino=off)
securityfs on /sys/kernel/security type securityfs (rw,nosuid,nodev,noexec,relatime)
tmpfs on /dev/shm type tmpfs (rw,nosuid,nodev,inode64)
devpts on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000)
cgroup2 on /sys/fs/cgroup type cgroup2 (rw,nosuid,nodev,noexec,relatime,nsdelegate,memory_recursiveprot)
pstore on /sys/fs/pstore type pstore (rw,nosuid,nodev,noexec,relatime)
bpf on /sys/fs/bpf type bpf (rw,nosuid,nodev,noexec,relatime,mode=700)
systemd-1 on /proc/sys/fs/binfmt_misc type autofs (rw,relatime,fd=33,pgrp=1,timeout=0,minproto=5,maxproto=5,direct,pipe_ino=12908)
mqueue on /dev/mqueue type mqueue (rw,nosuid,nodev,noexec,relatime)
hugetlbfs on /dev/hugepages type hugetlbfs (rw,relatime,pagesize=2M)
debugfs on /sys/kernel/debug type debugfs (rw,nosuid,nodev,noexec,relatime)
tracefs on /sys/kernel/tracing type tracefs (rw,nosuid,nodev,noexec,relatime)
tmpfs on /tmp type tmpfs (rw,nosuid,nodev,size=16311088k,nr_inodes=1048576,inode64)
fusectl on /sys/fs/fuse/connections type fusectl (rw,nosuid,nodev,noexec,relatime)
configfs on /sys/kernel/config type configfs (rw,nosuid,nodev,noexec,relatime)
ramfs on /run/credentials/systemd-sysctl.service type ramfs (ro,nosuid,nodev,noexec,relatime,mode=700)
ramfs on /run/credentials/systemd-tmpfiles-setup-dev.service type ramfs (ro,nosuid,nodev,noexec,relatime,mode=700)
tmpfs on /etc/pacman.d/gnupg type tmpfs (rw,relatime,mode=755,inode64)
ramfs on /run/credentials/systemd-tmpfiles-setup.service type ramfs (ro,nosuid,nodev,noexec,relatime,mode=700)
tmpfs on /run/user/1000 type tmpfs (rw,nosuid,nodev,relatime,size=3262216k,nr_inodes=815554,mode=700,uid=1000,gid=1000,inode64)
gvfsd-fuse on /run/user/1000/gvfs type fuse.gvfsd-fuse (rw,nosuid,nodev,relatime,user_id=1000,group_id=1000)
/dev/sr0 on /run/media/manjaro/DOC_MARTIN_S8_D2 type udf (ro,nosuid,nodev,relatime,uid=1000,gid=1000,iocharset=utf8,uhelper=udisks2)
portal on /run/user/1000/doc type fuse.portal (rw,nosuid,nodev,relatime,user_id=1000,group_id=1000)
Skipping non-emergency job "Create new 1872682MiB partition on /dev/sda (WDC WD2003FZEX-00Z4SA0) with file system ext4."
2023-01-25 - 14:03:24 [6]: .. Skipping non-emergency job "Set flags on 1872682MiB ext4 partition."
2023-01-25 - 14:03:24 [6]: .. Skipping non-emergency job "Create new 35043MiB partition on /dev/sda (WDC WD2003FZEX-00Z4SA0) with file system linuxswap."
2023-01-25 - 14:03:24 [6]: .. Skipping non-emergency job "Set partition information"
2023-01-25 - 14:03:24 [6]: .. Skipping non-emergency job "Manage auto-mount settings"
2023-01-25 - 14:03:24 [6]: .. Skipping non-emergency job "mount"
2023-01-25 - 14:03:24 [6]: .. Skipping non-emergency job "unpackfs"
2023-01-25 - 14:03:24 [6]: .. Skipping non-emergency job "networkcfg"
2023-01-25 - 14:03:24 [6]: .. Skipping non-emergency job "Generate machine-id."
2023-01-25 - 14:03:24 [6]: .. Skipping non-emergency job "fstab"
2023-01-25 - 14:03:24 [6]: .. Skipping non-emergency job "Set timezone to America/Detroit"
2023-01-25 - 14:03:24 [6]: .. Skipping non-emergency job "Set keyboard model to pc105, layout to us-"
2023-01-25 - 14:03:24 [6]: .. Skipping non-emergency job "localecfg"
2023-01-25 - 14:03:24 [6]: .. Skipping non-emergency job "Configuring encrypted swap."
2023-01-25 - 14:03:24 [6]: .. Skipping non-emergency job "Configuring LUKS key file."
2023-01-25 - 14:03:24 [6]: .. Skipping non-emergency job "initcpiocfg"
2023-01-25 - 14:03:24 [6]: .. Skipping non-emergency job "Creating initramfs with mkinitcpio."
2023-01-25 - 14:03:24 [6]: .. Skipping non-emergency job "Configure <pre>sudo</pre> users."
2023-01-25 - 14:03:24 [6]: .. Skipping non-emergency job "Preparing groups."
2023-01-25 - 14:03:24 [6]: .. Skipping non-emergency job "Create user johnblood"
2023-01-25 - 14:03:24 [6]: .. Skipping non-emergency job "Set password for user johnblood"
2023-01-25 - 14:03:24 [6]: .. Skipping non-emergency job "Set password for user root"
2023-01-25 - 14:03:24 [6]: .. Skipping non-emergency job "Set hostname zbox"
2023-01-25 - 14:03:24 [6]: .. Skipping non-emergency job "displaymanager"
2023-01-25 - 14:03:24 [6]: .. Skipping non-emergency job "mhwdcfg"
2023-01-25 - 14:03:24 [6]: .. Skipping non-emergency job "hwclock"
2023-01-25 - 14:03:24 [6]: .. Skipping non-emergency job "services"
2023-01-25 - 14:03:24 [6]: .. Skipping non-emergency job "grubcfg"
2023-01-25 - 14:03:24 [6]: .. Skipping non-emergency job "bootloader"
2023-01-25 - 14:03:24 [6]: .. Skipping non-emergency job "postcfg"
2023-01-25 - 14:03:24 [6]: .. Skipping non-emergency job "Unmount file systems."
2023-01-25 - 14:03:24 [1]: void Calamares::ViewManager::onInstallationFailed(const QString&, const QString&)
ERROR: Installation failed: "The installer failed to create a partition table on WDC WD2003FZEX-00Z4SA0."
2023-01-25 - 14:03:24 [6]: .. - message: "The installer failed to create a partition table on WDC WD2003FZEX-00Z4SA0."
2023-01-25 - 14:03:24 [6]: .. - details:
Create a new partition table (type: msdos) on ‘/dev/sda’
Job: Create new partition table on device ‘/dev/sda’
Command: sfdisk --wipe=always /dev/sda
2023-01-25 - 14:03:24 [6]: void Calamares::ViewManager::onInstallationFailed(const QString&, const QString&)
Calamares will quit when the dialog closes.
2023-01-25 - 14:03:24 [6]: void Config::doNotify(bool, bool)
Notification not sent; completi
