I have found ventoy
as an installable package in the repos. Is there any advantage to installing ventoy
directly with pacman or is it sufficient to download ventoy
as before and start it from the unpacked folder?
Installing from the official Manjaro repo allows Ventoy to be updated automatically, through the usual update system. The advantage is that Ventoy will always be available when you need it, and it will be the latest version. I find it very convenient; it just makes sense.
Cheers.
It always bears preference to use the version from the repositories. That way, it’ll also automatically get updated whenever there’s a system update.
You do of course also have to individually update all of your USB sticks with a bootable Ventoy installation on them, but that is easily done through the Ventoy GUI.
sounds good, thank you
In fact, it’s easy with the CLI aswell, at least, according to the manual.
Yes, that’s how I’ve done it so far. But the idea that it is also updated from the repos is tempting. Saves a bit of work …
This is the command-line that I might normally use, in case it’s useful:
sudo sh ventoy -i -r 100 -S -g -L VOLUME /dev/sdX
- Substitute
VOLUME
for a volume label name to use. - Substitute
/dev/sdX
for the location of your USB device. - Preserve some space on the target device (example allows 100mb).
Cheers.
