As stated above you already have the driver in the kernel.
No other package should be needed.
But you can try rtl88x2bu-dkms-git
if you want.
ok, it wouldn’t work so I installed the dkms git from the AUR. still doesn’t work but shows up in inxi with driver as NA. then shows module r8169 .
[mikaloi@mikaloi ~]$ inxi -Nazy
Device-1: Realtek RTL8125 2.5GbE vendor: ASUSTeK driver: N/A modules: r8169
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 07:00.0
Device-2: ASUSTek USB-N13 802.11n Network Adapter (rev. B1) [Realtek
RTL8192CU] driver: rtl8192cu type: USB rev: 2.0 speed: 480 Mb/s lanes: 1
mode: 2.0 bus-ID: 5-1:3 chip-ID: 0b05:17ab class-ID: 0000 serial:
‘’’ still doesn’t work
I remember something about having to blacklist r8169
I’d like to continue to try and install the drivers for my newest adapter and see if the wifi speed improves . I installed r8125-dkms (9.011.01-1) , but after looking back at some old posts and threads I think it was unneccesary ; but I don’t know how to check to see if I have the right kernel modules and headers installed - I think that is what I need to find out and a good place to start ???
thanks
it is not working - both adapters are plugged in . what info do you need ??
[mikaloi@mikaloi ~]$ lsmod | grep 81
rtl8192cu 110592 0
rtl_usb 24576 1 rtl8192cu
rtl8192c_common 77824 1 rtl8192cu
rtlwifi 155648 3 rtl8192c_common,rtl_usb,rtl8192cu
mac80211 1527808 4 rtl_usb,rtl8192cu,rtlwifi,rtl8xxxu
r8169 114688 0
mdio_devres 12288 1 r8169
libphy 212992 3 r8169,mdio_devres,realtek
Device-1: Realtek RTL8125 2.5GbE driver: r8169
IF: enp7s0 state: down mac: d4:5d:64:b4:d5:6b
IF: wlp10s0f3u1 state: up mac: 10:bf:48:4b:a6:28
Try to install rtl88x2bu-dkms-git
from AUR.
rtl88x2bu-cilynx-dkms-git
was not updated since January of the last year.
Xephon thanks
Did you mean, Thanks, @Xephon
yes. I did.
Thanks @Xephon
However , I’ve tried everything I know and it still only works with the older adapter. I can’t get the newer one to work
Did dkms module compile without errors?
If it did, did you do sudo modprobe 88x2bu
It seemed to compile w/out errors and add/remove shows it installed- but - modprobe: FATAL: Module 88x2bu not found in directory /lib/modules/6.4.9-1-MANJARO
Can you provide output of lsmod | grep 88
[mikaloi@mikaloi ~]$ lsmod | grep 88
cmac 12288 1
libarc4 12288 1 mac80211
irqbypass 12288 1 kvm
crct10dif_pclmul 12288 1
crc32_pclmul 12288 0
polyval_clmulni 12288 0
polyval_generic 12288 1 polyval_clmulni
eeepc_wmi 12288 0
mxm_wmi 12288 1 nouveau
ledtrig_audio 12288 2 snd_hda_codec_generic,asus_wmi
drm_ttm_helper 12288 1 nouveau
sparse_keymap 12288 1 asus_wmi
platform_profile 12288 1 asus_wmi
r8169 114688 0
wmi_bmof 12288 0
pcspkr 12288 0
i2c_nvidia_gpu 12288 0
mac_hid 12288 0
dm_mod 217088 0
crc32c_generic 12288 0
crc16 12288 1 ext4
jbd2 208896 1 ext4
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
And also output of ls /lib/modules/6.4.9-1-MANJARO/updates/dkms
[mikaloi@mikaloi ~]$ ls /lib/modules/6.4.9-1-MANJARO/updates/dkms
ls: cannot access '/lib/modules/6.4.9-1-MANJARO/updates/dkms': No such file or directory
You did install dkms first, did you?
It seems that dkms module failed to compile
how do I fix that ?
Can you remove it from pamac, then rebuild it and post a build log here?
I guess what you mean is remove it/uninstall it from add/remove. I can do that but have no idea how to rebuild it
I removed it .
Now push “Build” button again
Log will be accessible from an arrow button in the lower-right corner of pamac (it’s the real name of Add/Remove Software)
