Recently I’ve noticed that Input while using the headset doesn’t work on my Manajaro PC. I am using a Bluetooth headset, so in the past, I was simply changing the settings from High Fidelity (Stereo) to Headset(Mono) in order to use the microphone of the headset, but now it doesn’t work, I mean I don’t see any microphone action when I select the headset input.
P.S. My headset microphone works perfectly on my laptop whenever I used it.
Does anyone have any idea what can possibly be wrong?
thanks
Please give more information, it will really help us:
How to give system info:
sudo pacman -S inxi
←(installs Inxi
inxi
←(Tells Inxi
to give basic info)
inxi -A
← (Tells Inxi
to give audio info)
You can try using PulseAudio
Install PulseAudio:
sudo pacman -S pavucontrol
(If) Remove PulseAudio
sudo pacman -R pavucontrol
Try tinkering around with the settings in PulseAudio
, may fix your problem. I can’t give detailed guide because I don’t have enough info.
Device-1: NVIDIA GP104 High Definition Audio
vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
bus-ID: 1c:00.1 chip-ID: 10de:10f0 class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 1e:00.3
chip-ID: 1022:1457 class-ID: 0403
Sound Server-1: ALSA v: k5.13.13-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.34 running: yes
