Per a prior question: Gladiator NXT joystick not registered on AntiMicroX?
my input flight sticks wouldn’t work throught my PCI USB extension card (this is kernel independant), but work if plugged directly into the motherboard (which is very strange as I use an XBONE controller hooked through the exact same PCI USB extension card).
Is this a bug or am I missing packages to facilitate the usage of the USB card? If it is a bug, how can I report it?
These are the PCI cards: Card 1, Card 2
Kernel: 6.1.7-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.1-x86_64
root=UUID=f11386cf-342d-47ac-84e6-484b7b2f377d rw rootflags=subvol=@
radeon.modeset=1 nvdia-drm.modeset=1 quiet
cryptdevice=UUID=059df4b4-5be4-44d6-a23a-de81135eb5b4:luks-disk
root=/dev/mapper/luks-disk apparmor=1 security=apparmor
resume=/dev/mapper/luks-swap udev.log_priority=3
Desktop: KDE Plasma v: 5.26.5 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASUSTeK model: PRIME X570-PRO v: Rev X.0x
serial: <superuser required> UEFI: American Megatrends v: 4408
date: 10/27/2022
RAM: total: 62.71 GiB used: 25.75 GiB (41.1%)
Info: model: AMD Ryzen 9 5950X bits: 64 type: MT MCP arch: Zen 3 gen: 4
level: v3 note: check built: 2021-22 process: TSMC n7 (7nm) family: 0x19 (25)
model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
Topology: cpus: 1x cores: 16 tpc: 2 threads: 32 smt: enabled cache:
L1: 1024 KiB desc: d-16x32 KiB; i-16x32 KiB L2: 8 MiB desc: 16x512 KiB
L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 3861 high: 4105 min/max: 2200/6358 boost: disabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 4096 2: 4100
3: 4100 4: 4099 5: 4098 6: 4100 7: 4099 8: 4100 9: 4099 10: 4099 11: 4099
12: 4099 13: 4100 14: 4099 15: 4100 16: 4098 17: 4100 18: 4096 19: 2200
20: 4100 21: 2200 22: 4098 23: 4099 24: 4099 25: 4100 26: 2200 27: 4105
28: 2200 29: 4097 30: 4095 31: 4098 32: 4098 bogomips: 262527
cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms extapic
extd_apicid f16c flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht
hw_pstate ibpb ibrs ibs invpcid irperf lahf_lm lbrv lm mba mca mce
pdpe1gb perfctr_core perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt
pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor
svm svm_lock syscall tce topoext tsc tsc_scale umip v_spec_ctrl
v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall vpclmulqdq wbnoinvd wdt
x2apic xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
STIBP: always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GA104 [GeForce RTX 3070] vendor: ASUSTeK driver: nvidia
v: 525.85.05 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2022-12) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 8
link-max: lanes: 16 bus-ID: 0b:00.0 chip-ID: 10de:2484 class-ID: 0300
Device-2: AMD Cape Verde PRO [Radeon HD 7750/8740 / R7 250E]
vendor: VISIONTEK driver: radeon v: kernel alternate: amdgpu arch: GCN-1
code: Southern Islands process: TSMC 28nm built: 2011-20 pcie: gen: 3
speed: 8 GT/s lanes: 8 link-max: lanes: 16 ports: active: DP-3,DP-4
empty: DP-1, DP-2, DP-5, DP-6 bus-ID: 0c:00.0 chip-ID: 1002:683f
class-ID: 0300 temp: 52.0 C
Device-3: Microdia USB 2.0 Camera type: USB driver: snd-usb-audio,uvcvideo
bus-ID: 9-2:9 chip-ID: 0c45:6367 class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.6 with: Xwayland v: 22.1.7
compositor: kwin_x11 driver: X: loaded: modesetting,nvidia dri: radeonsi
gpu: radeon display-ID: :0 screens: 1
Screen-1: 0 s-res: 5760x2160 s-dpi: 80 s-size: 1829x686mm (72.01x27.01")
s-diag: 1953mm (76.91")
Monitor-1: DP-1 pos: 1-2 res: 1920x1080 dpi: 93
size: 527x296mm (20.75x11.65") diag: 604mm (23.8") modes: N/A
Monitor-2: DP-1-3 pos: 2-1 res: 1920x1080 dpi: 82
size: 598x336mm (23.54x13.23") diag: 686mm (27.01") modes: N/A
Monitor-3: DP-1-4 pos: 1-1 res: 1920x1080 dpi: 93
Monitor-4: DP-3 pos: primary,2-2 res: 1920x1080 dpi: 82
Monitor-5: DP-4 pos: 2-4 res: 1920x1080 dpi: 82
Monitor-6: HDMI-0 pos: 1-3 res: 1920x1080 dpi: 93
API: OpenGL v: 4.6.0 NVIDIA 525.85.05 renderer: NVIDIA GeForce RTX
3070/PCIe/SSE2 direct render: Yes
Device-1: NVIDIA GA104 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 5-1:2 chip-ID: 30be:1019 pcie:
class-ID: 0102 gen: 4 speed: 16 GT/s lanes: 8 link-max: lanes: 16
bus-ID: 0b:00.1 chip-ID: 10de:228b class-ID: 0403
Device-2: AMD Oland/Hainan/Cape Verde/Pitcairn HDMI Audio [Radeon HD 7000
Series] vendor: VISIONTEK driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 0c:00.1
chip-ID: 1002:aab0 class-ID: 0403
Device-3: AMD Starship/Matisse HD Audio vendor: ASUSTeK
bus-ID: 0e:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-4: Schiit Audio Unison Universal Dac type: USB driver: snd-usb-audio
Device-5: JMTek LLC. Plugable USB Audio Device type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 5-2:3 chip-ID: 0c76:120b
class-ID: 0300 serial: <filter>
Device-6: ASUSTek ASUS AI Noise-Cancelling Mic Adapter type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 5-4:4 chip-ID: 0b05:194e
Device-7: Microdia USB 2.0 Camera type: USB driver: snd-usb-audio,uvcvideo
Sound API: ALSA v: k6.1.7-1-MANJARO running: yes
Sound Interface: sndio v: N/A running: no
Sound Server-1: PulseAudio v: 16.1 running: no
Sound Server-2: PipeWire v: 0.3.64 running: yes
Device-1: Intel I211 Gigabit Network vendor: ASUSTeK driver: igb v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: f000 bus-ID: 07:00.0
IF: enp7s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: docker0 state: down mac: <filter>
IF-ID-2: nordlynx state: unknown speed: N/A duplex: N/A mac: N/A
IP v4: <filter> scope: global
driver: btusb v: 0.8 bus-ID: 5-5.3:7 chip-ID: 0a12:0001 class-ID: e001
Device-1: luks-c847cf9f-c6b5-4624-a25e-4531e318851a maj-min: 254:2
type: LUKS dm: dm-2 size: 3.64 TiB
Components:
p-1: sda1 maj-min: 8:1 size: 3.64 TiB
Device-2: luks-swap maj-min: 254:1 type: LUKS dm: dm-1 size: 12 GiB
Components:
p-1: nvme0n1p2 maj-min: 259:2 size: 12 GiB
Device-3: luks-disk maj-min: 254:0 type: LUKS dm: dm-0 size: 919.01 GiB
Components:
p-1: nvme0n1p3 maj-min: 259:3 size: 919.01 GiB
Local Storage: total: 9.13 TiB used: 2.84 TiB (31.1%)
model: WDS100T3X0C-00SJG0 size: 931.51 GiB block-size: physical: 512 B
rev: 111110WD temp: 55.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:4 vendor: Western Digital
model: WDS100T2B0C-00PXH0 size: 931.51 GiB block-size: physical: 512 B
rev: 211070WD temp: 46.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Western Digital
model: WD4005FZBX-00K5WB0 size: 3.64 TiB block-size: physical: 4096 B
logical: 512 B speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter>
rev: 1A01 scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Western Digital
ID-5: /dev/sdc maj-min: 8:32 type: USB vendor: SanDisk
model: Gaming Xbox 360 size: 7.48 GiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: 8.02 scheme: MBR
ID-6: /dev/sdd maj-min: 8:48 type: USB vendor: ASolid model: USB
size: 29.3 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 0000 scheme: MBR
ID-1: / raw-size: 919.01 GiB size: 919.01 GiB (100.00%)
used: 851.58 GiB (92.7%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-disk label: N/A uuid: N/A
used: 40.1 MiB (7.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1 label: EFI
uuid: 8922-E04D
ID-3: /home raw-size: 919.01 GiB size: 919.01 GiB (100.00%)
ID-4: /run/media/sarah/ConvergentRefuge raw-size: 3.64 TiB
size: 3.64 TiB (100.00%) used: 2 TiB (55.1%) fs: btrfs dev: /dev/dm-2
maj-min: 254:2 mapped: luks-c847cf9f-c6b5-4624-a25e-4531e318851a
label: ConvergentRefuge uuid: 7d295e73-4143-4eb1-9d22-75a06b1d2984
ID-5: /run/media/sarah/MSS_EXtended raw-size: 475.51 GiB
size: 475.51 GiB (100.00%) used: 4.33 GiB (0.9%) fs: btrfs
dev: /dev/nvme1n1p1 maj-min: 259:5 label: MSS EXtended
uuid: f98b3a12-e0e4-48c7-91c2-6e3aa6dcd32c
ID-1: swap-1 type: partition size: 12 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/dm-1 maj-min: 254:1 mapped: luks-swap label: SWAP
uuid: c8991364-85a7-4e6c-8380-49cd5bd7a873
ID-1: /dev/nvme1n1p2 maj-min: 259:6 size: 456 GiB fs: ntfs label: N/A
uuid: 5ECA358FCA356485
ID-2: /dev/sdb1 maj-min: 8:17 size: 3.64 TiB fs: ntfs
label: JerichoVariance uuid: 1AB22D5664889CBD
ID-3: /dev/sdc1 maj-min: 8:33 size: 3.57 GiB fs: iso9660
ID-4: /dev/sdc2 maj-min: 8:34 size: 4 MiB fs: vfat label: MISO_EFI
uuid: 5C67-4BF8
ID-5: /dev/sdd1 maj-min: 8:49 size: 29.29 GiB fs: vfat label: Windows USB
uuid: DCD4-73A9
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-2: 1-2:2 info: Hitachi ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 045b:0209 class-ID: 0900
Device-1: 1-2.4:3 info: Microsoft Xbox One Controller (Firmware 2015)
type: <vendor specific> driver: xpad interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 500mA chip-ID: 045e:02dd class-ID: ff00 serial: <filter>
Hub-3: 2-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
Hub-4: 2-2:2 info: Hitachi ports: 4 rev: 3.0 speed: 5 Gb/s
chip-ID: 045b:0210 class-ID: 0900
Hub-5: 3-0:1 info: Hi-speed hub with single TT ports: 1 rev: 2.0
Hub-6: 4-0:1 info: Super-speed hub ports: 4 rev: 3.0 speed: 5 Gb/s
Hub-7: 5-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
Device-1: 5-1:2 info: Schiit Audio Unison Universal Dac type: Audio
driver: snd-usb-audio interfaces: 2 rev: 2.0 speed: 480 Mb/s power: 500mA
chip-ID: 30be:1019 class-ID: 0102
Device-2: 5-2:3 info: JMTek LLC. Plugable USB Audio Device type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
speed: 12 Mb/s power: 100mA chip-ID: 0c76:120b class-ID: 0300
serial: <filter>
Device-3: 5-4:4 info: ASUSTek ASUS AI Noise-Cancelling Mic Adapter
type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 0b05:194e class-ID: 0300
serial: <filter>
Hub-8: 5-5:5 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Device-1: 5-5.3:7 info: Cambridge Silicon Radio Bluetooth Dongle (HCI mode)
type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 0a12:0001 class-ID: e001
Hub-9: 5-6:6 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
Hub-10: 6-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-11: 7-0:1 info: Hi-speed hub with single TT ports: 6 rev: 2.0
Device-1: 7-2:2 info: SanDisk Cruzer Micro Flash Drive type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.0 speed: 480 Mb/s power: 200mA
chip-ID: 0781:5151 class-ID: 0806 serial: <filter>
Device-2: 7-4:3 info: ASUSTek AURA LED Controller type: HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 16mA
chip-ID: 0b05:18f3 class-ID: 0300 serial: <filter>
Hub-12: 8-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Device-1: 8-1:2 info: ASolid USB_0114 type: Mass Storage
driver: usb-storage interfaces: 1 rev: 3.1 speed: 5 Gb/s power: 144mA
chip-ID: 24a9:205a class-ID: 0806 serial: <filter>
Hub-13: 9-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-14: 9-1:2 info: Terminus FE 2.1 7-port Hub ports: 7 rev: 2.0
speed: 480 Mb/s power: 100mA chip-ID: 1a40:0201 class-ID: 0900
Device-1: 9-1.1:4 info: Sunplus Innovation Gaming mouse [Philips SPK9304]
type: Mouse driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 98mA chip-ID: 1bcf:08a0 class-ID: 0301
Device-2: 9-1.5:5 info: Microdia Backlit Gaming Keyboard
type: Keyboard,Mouse driver: hid-generic,usbhid interfaces: 2 rev: 2.0
speed: 12 Mb/s power: 400mA chip-ID: 0c45:652f class-ID: 0301
Device-3: 9-1.6:6 info: HUION H420 type: Mouse,HID driver: uclogic,usbhid
interfaces: 3 rev: 1.1 speed: 12 Mb/s power: 100mA chip-ID: 256c:006e
class-ID: 0300
Hub-15: 9-1.7:7 info: Terminus Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 1a40:0101 class-ID: 0900
Device-1: 9-1.7.4:8 info: Texas Instruments TI-Nspire Calculator
type: <vendor specific> driver: N/A interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 500mA chip-ID: 0451:e012 class-ID: 0000
Device-2: 9-2:9 info: Microdia USB 2.0 Camera type: Video,Audio
power: 500mA chip-ID: 0c45:6367 class-ID: 0102 serial: <filter>
Device-3: 9-3:10 info: VKB-Sim © Alex Oz 2021 VKBsim Gladiator EVO R
type: HID driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s
power: 500mA chip-ID: 231d:0200 class-ID: 0300
Device-4: 9-4:11 info: VKB-Sim © Alex Oz 2021 VKBsim Gladiator EVO L
power: 500mA chip-ID: 231d:0201 class-ID: 0300
Hub-16: 10-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 36.0 C mobo: 42.0 C
Fan Speeds (RPM): fan-1: 690 fan-2: 748 fan-3: 869 fan-4: 829 fan-5: 3125
fan-6: 0 fan-7: 0
GPU: device: nvidia screen: :0.0 temp: 54 C fan: 0% device: radeon
temp: 52.0 C
Processes: 803 Uptime: 3h 33m wakeups: 0 Init: systemd v: 252
default: graphical tool: systemctl Compilers: gcc: 12.2.1 alt: 10/11
clang: 15.0.7 Packages: 2164 pm: pacman pkgs: 2123 libs: 498 tools: pamac,yay
pm: flatpak pkgs: 24 pm: snap pkgs: 17 Shell: Bash v: 5.1.16
running-in: yakuake inxi: 3.3.24
