Hi, I try to use pdflatex on inkscape (First time user of inkscape) but I get the following errors after applying latex input:
/usr/share/inkscape/extensions/inkex/command.py:73: DeprecationWarning: The distutils package is deprecated and slated for removal in Python 3.12. Use setuptools or check PEP 632 for potential alternatives
from distutils.spawn import find_executable
File “/usr/share/inkscape/extensions/pdflatex.py”, line 89, in
PdfLatex().run()
File “/usr/share/inkscape/extensions/inkex/base.py”, line 131, in run
self.save_raw(self.effect())
File “/usr/share/inkscape/extensions/inkex/extensions.py”, line 193, in effect
for child in fragment:
File “/usr/share/inkscape/extensions/pdflatex.py”, line 49, in generate
call(‘pdflatex’, tex_file,
File “/usr/share/inkscape/extensions/inkex/command.py”, line 207, in call
stdout = call(program, *args, **kwargs)
File “/usr/share/inkscape/extensions/inkex/command.py”, line 191, in call
raise ProgramRunError(f"Return Code: {process.returncode}: {stderr}\n{stdout}\nargs: {args}")
inkex.command.ProgramRunError: Return Code: 1: b’’
b"This is pdfTeX, Version 3.141592653-2.6-1.40.23 (TeX Live 2021/Arch Linux) (preloaded format=pdflatex)\n restricted \write18 enabled.\nentering extended mode\n(/tmp/inktmpfmwvajl/input.tex\nLaTeX2e <2021-11-15> patch level 1\nL3 programming layer <2021-11-22>\n(/usr/share/texmf-dist/tex/latex/base/minimal.cls\nDocument Class: minimal 2001/05/25 Standard LaTeX minimal class\n) (/usr/share/texmf-dist/tex/latex/amsmath/amsmath.sty\nFor additional information on amsmath, use the `?’ option.\n(/usr/share/texmf-dist/tex/latex/amsmath/amstext.sty\n(/usr/share/texmf-dist/tex/latex/amsmath/amsgen.sty))\n(/usr/share/texmf-dist/tex/latex/amsmath/amsbsy.sty)\n(/usr/share/texmf-dist/tex/latex/amsmath/amsopn.sty))\n(/usr/share/texmf-dist/tex/latex/amsfonts/amssymb.sty\n(/usr/share/texmf-dist/tex/latex/amsfonts/amsfonts.sty))\n(/usr/share/texmf-dist/tex/latex/l3backend/l3backend-pdftex.def)\nNo file input.aux.\n\n! Package amsmath Error: \vec allowed only in math mode.\n\nSee the amsmath package documentation for explanation.\nType H for immediate help.\n … \n \nl.8 \vec [\n F] =ma\n! ==> Fatal error occurred, no output PDF file produced!\nTranscript written on /tmp/inktmpfmwvajl/input.log.\n"
args: [’/usr/bin/pdflatex’, ‘-output-directory=/tmp/inktmpfmwvajl_’, ‘-halt-on-error’, ‘/tmp/inktmpfmwvajl_/input.tex’]
Hello,
Please read the announcement
You have to rebuild the pdflatex package as is from AUR.
