Inkscape crashes on large projects and gives "dark spots"
Inkscape crashes on large projects and gives “dark spots”. Do you have the same symptoms, help me because it is a software that I use a lot
Inkscape 1.3.2 (091e20ef0f, 2023-11-25, custom)
KDE Plasma Version: 6.0.5
KDE Frameworks Version: 6.5.0
Qt Version: 6.7.2
Kernel Version: 6.10.6-10-MANJARO (64-bit)
Graphics Platform: X11
Processors: 4 × Intel® Core™ i5-5300U CPU @ 2.30GHz
Memory: 15.5 Gio of RAM
Graphics Processor: Mesa Intel® HD Graphics 5500
Manufacturer: Dell Inc.
Product Name: Latitude E5450
I’m not a big user of Inkscape but I’ve not noticed any problems with my small-scale use. If the problem is only with large projects it might be worth checking you have some swap turned on, for instance with swapon --show.
Have you tried to check memory use (with top maybe) when dealing with your large project?
You could also paste the output of inxi -zv8 to give some more detail of your system in case that helps anyone.
Usually, we need more information than is provided by neofetch (and similar). Please provide the output of:
inxi --admin --verbosity=8 --filter --no-host --width
Also, please tell us what you have done to find the problem yourself. What are the results of your forum search to find similar issues?
Under what specific conditions do these crashes occur?
Is Inkscape the package from the official Manjaro repo (recommended) or installed from elsewhere (Flatpak/ AUR)?
Some actionable information is more useful than vague descriptions.
Cheers.
Try the appimage. Inkscape 1.3.2 - GNU/Linux | Inkscape
I am currently performing the system update that is available today, it also includes an update of Inkscape (1.3.2-9 to 1.3.2-11), I hope this will resolve my issue. Here is the inxi result you asked me for in the meantime, I hope it helps:
    ~  inxi --admin --verbosity=8 --filter --no-host --width         ✔
  Kernel: 6.10.6-10-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: BOOT_IMAGE=/@/boot/vmlinuz-6.10-x86_64
    root=UUID=0f56c06d-43ab-462d-a6f0-b84f9c8aec11 rw rootflags=subvol=@ quiet
    splash resume=UUID=f0936bbf-7c5a-4276-aa83-1a2f3b948fa4
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.5.0
  Type: Laptop System: Dell product: Latitude E5450 v: N/A
    serial: <superuser required> Chassis: type: 9 serial: <superuser required>
  Mobo: Dell model: N/A serial: <superuser required> part-nu: 062B
    uuid: <superuser required> UEFI: Dell v: A13 date: 05/17/2016
  ID-1: BAT0 charge: 35.2 Wh (100.0%) condition: 35.2/51.7 Wh (68.1%)
    volts: 8.4 min: 7.6 model: Samsung SDI DELL 7FR5JD9 type: Li-poly
    serial: <filter> status: full
  System RAM: total: 16 GiB available: 15.49 GiB used: 7.82 GiB (50.5%)
  Array-1: capacity: 16 GiB slots: 2 modules: 2 EC: None
  Device-1: DIMM A type: DDR3 detail: synchronous size: 8 GiB
    speed: 1600 MT/s volts: N/A width (bits): data: 64 total: 64
    manufacturer: Hynix/Hyundai part-no: HMT41GS6BFR8A-PB serial: <filter>
  Device-2: DIMM B type: DDR3 detail: synchronous size: 8 GiB
    manufacturer: Crucial part-no: CT102464BF160B.C16 serial: <filter>
  Info: model: Intel Core i5-5300U bits: 64 type: MT MCP arch: Broadwell
    gen: core 5 level: v3 note: check built: 2015-18 process: Intel 14nm
    family: 6 model-id: 0x3D (61) stepping: 4 microcode: 0x2F
  Topology: cpus: 1x dies: 1 clusters: 2 cores: 2 threads: 4 tpc: 2
    smt: enabled cache: L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB
    desc: 2x256 KiB L3: 3 MiB desc: 1x3 MiB
  Speed (MHz): avg: 2835 min/max: 500/2900 scaling: driver: intel_cpufreq
    governor: schedutil cores: 1: 2835 2: 2835 3: 2835 4: 2835 bogomips: 18361
  Flags: 3dnowprefetch abm acpi adx aes aperfmperf apic arat arch_perfmon
    avx avx2 bmi1 bmi2 bts clflush cmov constant_tsc cpuid cpuid_fault cx16
    cx8 de ds_cpl dtes64 dtherm dts epb ept ept_ad erms est f16c flexpriority
    flush_l1d fma fpu fsgsbase fxsr hle ht ibpb ibrs ida intel_pt invpcid
    lahf_lm lm mca mce md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx
    pae pat pbe pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36
    pti pts rdrand rdseed rdtscp rep_good rtm sdbg sep smap smep smx ss ssbd
    sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2 tpr_shadow tsc
    tsc_adjust tsc_deadline_timer vme vmx vnmi vpid x2apic xsave xsaveopt
    xtopology xtpr
    vulnerable
    STIBP: conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
    affected
  Type: tsx_async_abort mitigation: Clear CPU buffers; SMT vulnerable
  Device-1: Intel HD Graphics 5500 vendor: Dell driver: i915 v: kernel
    arch: Gen-8 process: Intel 14nm built: 2014-15 ports: active: eDP-1
    empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:1616
    class-ID: 0300
  Device-2: Silicon Motion - Taiwan (formerly Feiya ) 300k Pixel Camera
    driver: uvcvideo type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0
    bus-ID: 2-4:3 chip-ID: 090c:037c class-ID: 0e02
  Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.2
    compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
    dri: iris gpu: i915 display-ID: :0 screens: 1
  Screen-1: 0 s-res: 1366x768 s-dpi: 96 s-size: 361x203mm (14.21x7.99")
    s-diag: 414mm (16.31") monitors: <missing: xrandr>
  Monitor-1: eDP-1 model: ChiMei InnoLux 0x1490 built: 2014 res: 1366x768
    dpi: 112 gamma: 1.2 chroma: red: x: 0.576 y: 0.333 green: x: 0.325 y: 0.580
    blue: x: 0.157 y: 0.137 white: x: 0.314 y: 0.329
    size: 309x173mm (12.17x6.81") diag: 354mm (13.9") ratio: 16:9
    modes: 1366x768
    device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
    inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.1.6-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 5500 (BDW GT2)
    device-ID: 8086:1616 memory: 7.57 GiB unified: yes
  API: Vulkan v: 1.3.279 layers: N/A device: 0 type: integrated-gpu
    name: Intel HD Graphics 5500 (BDW GT2) driver: mesa intel v: 24.1.6-arch1.1
    device-ID: 8086:1616 surfaces: xcb,xlib
  Device-1: Intel Broadwell-U Audio vendor: Dell driver: snd_hda_intel
    v: kernel bus-ID: 00:03.0 chip-ID: 8086:160c class-ID: 0403
  Device-2: Intel Wildcat Point-LP High Definition Audio vendor: Dell
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9ca0
    class-ID: 0403
  API: ALSA v: k6.10.6-10-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.3 status: active with: 1: pipewire-pulse
  Device-1: Intel Ethernet I218-LM vendor: Dell driver: e1000e v: kernel
    port: f080 bus-ID: 00:19.0 chip-ID: 8086:15a2 class-ID: 0200
  Device-2: Intel Wireless 7265 driver: iwlwifi v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 8086:095a class-ID: 0280
  Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-1.3:3 chip-ID: 8087:0a2a
    class-ID: e001
  Hardware-1: Intel 82801 Mobile SATA Controller [RAID mode] driver: ahci
    v: 3.0 port: f060 bus-ID: 00:1f.2 chip-ID: 8086:282a rev: N/A class-ID: 0104
  Local Storage: total: 465.76 GiB used: 139.07 GiB (29.9%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST500LM000-1EJ162
    size: 465.76 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
    tech: HDD rpm: 5400 serial: <filter> fw-rev: DEMD scheme: GPT
  ID-1: / raw-size: 448.42 GiB size: 448.42 GiB (100.00%)
    used: 139.07 GiB (31.0%) fs: btrfs dev: /dev/sda2 maj-min: 8:2 label: LINUX
    uuid: 0f56c06d-43ab-462d-a6f0-b84f9c8aec11
    used: 584 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: 3415-EAA0
  ID-3: /home raw-size: 448.42 GiB size: 448.42 GiB (100.00%)
  ID-4: /var/cache raw-size: 448.42 GiB size: 448.42 GiB (100.00%)
  ID-5: /var/log raw-size: 448.42 GiB size: 448.42 GiB (100.00%)
  Kernel: swappiness: 5 (default 60) cache-pressure: 55 (default 100)
    zswap: yes compressor: zstd max-pool: 20%
  ID-1: swap-1 type: partition size: 17.04 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/sda3 maj-min: 8:3 label: swap
    uuid: f0936bbf-7c5a-4276-aa83-1a2f3b948fa4
  Hub-1: 1-0:1 info: full speed or root hub ports: 3 rev: 2.0
  Hub-2: 1-1:2 info: Intel Integrated Hub ports: 8 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:8001
  Device-1: 1-1.3:3 info: Intel Bluetooth wireless interface type: bluetooth
    mode: 1.1 power: 100mA chip-ID: 8087:0a2a class-ID: e001
  Device-2: 1-1.7:4 info: Broadcom BCM5880 Secure Applications Processor
    type: smart card driver: N/A interfaces: 2 rev: 1.1
    chip-ID: 0a5c:5800 class-ID: 0b00 serial: <filter>
  Hub-3: 2-0:1 info: hi-speed hub with single TT ports: 11 rev: 2.0
  Device-1: 2-1:2 info: SHARKOON GmbH 2.4GHz Wireless rechargeable vertical
    mouse [More&Better] type: mouse driver: hid-generic,usbhid interfaces: 1
    rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA
    chip-ID: 1ea7:0064 class-ID: 0301
  Device-2: 2-4:3 info: Silicon Motion - Taiwan (formerly Feiya ) 300k Pixel
    Camera type: video driver: uvcvideo interfaces: 2 rev: 2.0
  Hub-4: 3-0:1 info: super-speed hub ports: 4 rev: 3.0
  System Temperatures: cpu: 54.0 C mobo: 48.0 C sodimm: SODIMM C
  Fan Speeds (rpm): cpu: 2876
  Packages: pm: pacman pkgs: 1465 libs: 386 tools: pamac
    1: https://mirrors2.manjaro.org/stable/$repo/$arch
    2: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
    3: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
    4: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
    5: https://mirror.it4i.cz/manjaro/stable/$repo/$arch
    6: https://mirror.vinehost.net/manjaro/stable/$repo/$arch
    7: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
    8: https://ba.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    9: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
    10: https://ftp.linux.org.tr/manjaro/stable/$repo/$arch
    11: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    12: https://fosszone.csd.auth.gr/manjaro/stable/$repo/$arch
    13: https://manjaro.kurdy.org/stable/$repo/$arch
    14: https://mirrors.up.pt/pub/manjaro/stable/$repo/$arch
    15: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
    16: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
    17: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    18: http://manjaro.grena.ge/stable/$repo/$arch
    19: http://ftp.riken.jp/Linux/manjaro/stable/$repo/$arch
    20: https://mirror.leitecastro.com/manjaro/stable/$repo/$arch
    21: https://mirror.kku.ac.th/manjaro/stable/$repo/$arch
    22: https://mirror.dc.uz/manjaro/stable/$repo/$arch
    23: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
    24: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    25: https://mirrors.ft.uam.es/manjaro/stable/$repo/$arch
    26: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    27: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
    28: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    29: http://mirror.datacenter.by/pub/mirrors/manjaro/stable/$repo/$arch
    30: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    31: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
    32: https://mirrors.xtom.de/manjaro/stable/$repo/$arch
    33: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
    34: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
    35: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    36: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
    37: https://mirror.nyist.edu.cn/manjaro/stable/$repo/$arch
    38: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    39: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
    40: https://mirror.init7.net/manjaro/stable/$repo/$arch
    41: https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable/$repo/$arch
    42: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    43: https://mirror.funami.tech/manjaro/stable/$repo/$arch
    44: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
    45: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
    46: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    47: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
    48: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    49: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    50: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
    51: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
    52: http://ftp.free.org/mirrors/repo.manjaro.org/repos/stable/$repo/$arch
    53: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    54: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
    55: https://mirrors.xtom.ee/manjaro/stable/$repo/$arch
    56: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    57: http://mirror.fcix.net/manjaro/stable/$repo/$arch
    58: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
    59: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
    60: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
    61: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
    62: https://manjaro.mirror.garr.it/manjaro/stable/$repo/$arch
    63: https://ct.mirror.garr.it/mirrors/manjaro/stable/$repo/$arch
    64: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
    65: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
    66: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
    67: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    68: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
    69: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
    70: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
    71: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
    72: http://manjaro.mirror.ac.za/stable/$repo/$arch
    73: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
    74: http://mirror.terrahost.no/linux/manjaro/stable/$repo/$arch
    75: https://fastmirror.pp.ua/manjaro/stable/$repo/$arch
    76: https://linorg.usp.br/manjaro/stable/$repo/$arch
    77: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
    78: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
    79: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
    80: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
    81: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    82: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    83: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
    84: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
    85: http://ftp.dei.uc.pt/pub/linux/manjaro/stable/$repo/$arch
    86: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
    87: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
    88: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    89: https://mirror.zetup.net/manjaro/stable/$repo/$arch
    90: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    91: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
    92: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
    93: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
    94: https://mirrors.gigenet.com/manjaro/stable/$repo/$arch
    95: https://manjaro.mirror.liquidtelecom.com/stable/$repo/$arch
    96: https://manjaro.ynh.ovh/stable/$repo/$arch
    97: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
    98: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
    99: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    100: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
    101: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
    102: https://mirror.ufro.cl/manjaro/stable/$repo/$arch
    103: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    104: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
    105: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    106: https://mirror.alwyzon.net/manjaro/stable/$repo/$arch
    107: https://repo.iut.ac.ir/repo/manjaro/stable/$repo/$arch
    108: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
    109: https://muug.ca/mirror/manjaro/stable/$repo/$arch
    110: http://kartolo.sby.datautama.net.id/manjaro/stable/$repo/$arch
    111: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
    112: https://mirror.albony.xyz/manjaro/stable/$repo/$arch
    113: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    114: https://mirror.koddos.net/manjaro/stable/$repo/$arch
    115: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
    116: https://mirror.23m.com/manjaro/stable/$repo/$arch
    117: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    118: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
    119: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 245
  1: cpu: 52.7% command: firefox pid: 1270 mem: 751.4 MiB (4.7%)
  2: cpu: 43.5% command: firefox pid: 1668 mem: 279.9 MiB (1.7%)
  3: cpu: 7.3% command: firefox pid: 1645 mem: 769.6 MiB (4.8%)
  4: cpu: 6.1% command: firefox pid: 1869 mem: 274.2 MiB (1.7%)
  5: cpu: 5.7% command: zsh pid: 13143 mem: 10.2 MiB (0.0%)
  Memory top: 5 of 245
  1: mem: 818.3 MiB (5.1%) command: qbittorrent pid: 11424 cpu: 5.3%
  2: mem: 769.6 MiB (4.8%) command: firefox pid: 1645 cpu: 7.3%
  3: mem: 751.4 MiB (4.7%) command: firefox pid: 1270 cpu: 52.7%
  4: mem: 698.2 MiB (4.4%) command: pamac pid: 1891 cpu: 4.5%
  5: mem: 677.2 MiB (4.2%) command: firefox pid: 1580 cpu: 4.4%
  Processes: 245 Power: uptime: 1h 11m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.18 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
    tool: systemctl
  Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.2.32 running-in: yakuake inxi: 3.3.36
Ah I forgot to specify that the crash occurs during rendering (export in PNG, JPEG format), and this is especially for heavy files (>25 MB)
Merci !
I might have suspected lack of swap being the culprit, but from your system information it seems at least sufficient.
Aside:- Adding zram at a future time may enhance performance to some extent (See: Add a backing SWAP device to zram (and enable hibernation)); but this is unrelated.
Another potential culprit is lack of available space. Usage seems fair at ~30% overall, but temporary files generated by graphic applications can at times be excessive.
A quick Internet search revealed the crashes you describe have been reported for several years, without any definitive solution. One suggestion I found was to avoid saving to removable USB media; or any non-pool volume on other disks; this doesn’t seem applicable in your case.
You might consider checking the destination file system for consistency. I’m not familiar enough with BTRFS to make any recommendations regarding appropriate tools to use.
And then, there is this:
Although the issue is three years old, and in a Windows environment, the similarity is obvious. This might be indicative of a bug in Inkscape that has prevailed for some time.
There was also a note about GIO (the GtkFileChooser).
I interpreted that as suggesting the cause of the crash might have been attributed to the save dialog as opposed Inkscape itself.
Unfortunately, all this equates to a huge :person_shrugging: on my part. You might take some consolation from the fact that you’re apparently not alone:
There appears to be nothing specifically pointing to Manjaro (or Arch-based distributions) as being a contributor. However, allow time for others to respond in case anything else comes to light.
Otherwise, I’d suggest opening a new issue upstream:
Cheers.
You are very meticulous in your research for solutions, I really appreciate it. I will wait, in the hope that a solution will be quickly resolved by the developers
In that case you’ll want to monitor the Inkscape GitLab site, which will no doubt become tedious. Creating a new issue might prompt some renewed interest in finding the cause and a solution.
Remember, Manjaro doesn’t develop Inkscape; many applications are simply inherited from ArchLinux, who in turn receive code directly from the respective developers; Inkscape, in this case.
I hope you find a solution.
Cheers.
Years ago I was looking for a replacement for Inkscape because of the memory issues you describe. It is very sluggish when you have huge projects. The program I found was outstanding in terms of memory management and gobbled up projects Inkscape almost could not open. What I found was http://www.xaraxtreme.org/
Unfortunately, Inkscape won in popularity and xaraextreme was more or less forgotten, hasn’t been updated since 2008, the site says. I suspect it might be troublesome trying to get it to run on a modern Linux, it also does things differently from other editors, as I recall, but I got my project out the door using it. I used to run it on LinuxMint 9, many years ago.
But if you like to experiment, perhaps some virtual machine or something could run it? Or go find some old computer and get an older distro. Who knows? It might work. 8)
The good news is that it is in the AUR: AUR (en) - xaralx-bin
There are no comments on the AUR page since since 2017, so hopefully it should still build okay. I couldn’t test it on my own machine as it has 32-bit dependencies, and I don’t have the multilib repo active on my mini-PC as I don’t use any apps requiring 32-bit libraries.
I did download the source from the Xara Xtreme site & all the files are dated August 11, 2006. However, the version in the AUR says that it is a development release, so it may be more up-to-date. Nevertheless, its compatibility with a modern GNU/Linux system probably can’t be guaranteed.
Karbon is an alternative to Inkscape. Perhaps the export functionality will suffice as a substitute until a workaround (or fix) is found for Inkscape.
Karbon is part of KDE’s Calligra suite of applications, and fairly lightweight. It’s the only worthwhile alternative I can think of that’s still being developed.
sudo pacman -Syu calligra
Cheers.
