Hello!
I use Clementine for playing music on Manjaro. It’s the best player but a bit outdated so it doesn’t prevent Manjaro going to sleep when music is playing. I have a script i found on Linux Mint forum that inhibited suspend as long as audio is playing, and it worked great for Mint and Cinnamon but it doesn’t work on KDE.
#!/bin/sh
# Audiocaffeine - Pulseaudio
# Works in Linux Mint 19 - Cinnamon, Linux Mint 19 - Mate, Ubuntu 18.04 - Gnome
# Script to temporarily set suspend timout for AC and battery to "Never"
# while audio is playing. It then reverts the settings when audio is no longer detected.
# Determine if a valid desktop environment is running and exit if it doesn't.
echo "Reported desktop environment: ""$XDG_CURRENT_DESKTOP"
if [ "$XDG_CURRENT_DESKTOP" = "X-Cinnamon" ]; then
actimeoutid="org.cinnamon.settings-daemon.plugins.power sleep-inactive-ac-timeout"
batttimeoutid="org.cinnamon.settings-daemon.plugins.power sleep-inactive-battery-timeout"
disablevalue=0
elif [ "$XDG_CURRENT_DESKTOP" = "MATE" ]; then
actimeoutid="org.mate.power-manager sleep-computer-ac"
batttimeoutid="org.mate.power-manager sleep-computer-battery"
disablevalue=0
elif [ "$XDG_CURRENT_DESKTOP" = "ubuntu:GNOME" ]; then
actimeoutid="org.gnome.settings-daemon.plugins.power sleep-inactive-ac-type"
batttimeoutid="org.gnome.settings-daemon.plugins.power sleep-inactive-battery-type"
disablevalue="nothing"
else
echo "No valid desktop environment is running"
exit 1
fi
# Create .config directory to store settings if it doesn't exist.
if [ ! -d ~/.config ]; then
echo ".config directory not found!"
echo "Creating ~/.config"
mkdir ~/.config
fi
# Create audiocaffeine directory to store settings if it doesn't exist.
if [ ! -d ~/.config/audiocaffeine ]; then
echo "Configuration directory not found!"
echo "Creating ~/.config/audiocaffeine"
mkdir ~/.config/audiocaffeine
fi
# Restore previous value for AC suspend timeout if script
# was interrupted.
if [ -f ~/.config/audiocaffeine/acsuspend ]; then
echo "Restoring previous AC suspend timeout."
read acsuspendtime < ~/.config/audiocaffeine/acsuspend
gsettings set $actimeoutid $acsuspendtime
echo "Removing temporary file ~/.config/audiocaffeine/acsuspend"
rm ~/.config/audiocaffeine/acsuspend
fi
# Restore previous value for battery suspend timeout if script
# was interrupted.
if [ -f ~/.config/audiocaffeine/battsuspend ]; then
echo "Restoring previous battery suspend timeout."
read battsuspendtime < ~/.config/audiocaffeine/battsuspend
gsettings set $batttimeoutid $battsuspendtime
echo "Removing temporary file ~/.config/audiocaffeine/battsuspend"
rm ~/.config/audiocaffeine/battsuspend
fi
# Start main loop to check if audio is playing
while true; do
# Use pactl to detect if there are any running audio sources.
if pactl list | grep -q "State: RUNNING"; then
echo "Audio detected."
# If AC timeout was not previously saved, then save it.
if [ ! -f ~/.config/audiocaffeine/acsuspend ]; then
echo "Saving current AC suspend timeout."
gsettings get $actimeoutid > ~/.config/audiocaffeine/acsuspend
fi
# If battery timeout was not previously saved, then save it.
if [ ! -f ~/.config/audiocaffeine/battsuspend ]; then
echo "Saving current battery suspend timeout."
gsettings get $batttimeoutid > ~/.config/audiocaffeine/battsuspend
fi
# Set the suspend timouts to Never using gsettings.
echo "Changing suspend timeouts."
gsettings set $actimeoutid $disablevalue
gsettings set $batttimeoutid $disablevalue
else
echo "No audio detected."
# Restore previous value for AC suspend timeout and delete the
# temporary file storing it.
fi
# Restore previous value for battery suspend timeout and delete the
fi
fi
# Pause the script for 60 seconds before doing the loop again.
sleep 60s
done
I don’t know how to alter this code so it works on KDE? Can anyone help?
Hi @sinisab89,
According to this page on the classic Forum:
one possibility to prevent the suspend is to use caffeine (Caffeine in Launchpad). it should be also available in the aur
And from the Caffeine website:
A status bar application able to temporarily prevent the activation of both the screensaver and the “sleep” powersaving mode.
So it sounds like it might work.
I’m guessing it can also be done with qdbus.
I found caffeine today and I’ll try it to see how it works.
I don’t know what to do with qdbus, I am a total dummy for this kind of things
Hi @sinisab89,
For some reason this was intriguing to me. So I looked at the script a bit more carefully, noticing that, while it has support for many Desktop Environments, it doesn’t have for KDE.
So, with my limited knowledge I added support for KDE. Unfortunately there’s no way for me to test it. (I have a hearing problem, so there’s literally no way.)
So here is the changed script. I have absolutely no way of knowing if this will work. Test it and see if it does.
If it doesn’t, try Caffeine again, as I suggested.
#!/bin/sh
disablevalue=0
disablevalue=0
elif [ "$XDG_CURRENT_DESKTOP" = "KDE" ]; then
systemctl stop sleep.target suspend.target
else
exit 1
fi
mkdir ~/.config
fi
fi
# was interrupted.
fi
# was interrupted.
fi
while true; do
fi
fi
else
fi
fi
fi
sleep 60s
done
Edit:
You might want to add a sudoers
entry so that your user can use those commands without a password.
Hope this helps!
Hey @Mirdarthos ! Thanks for help!
Unfortunately, this doesn’t work. Script now reports that DE is KDE but does nothing. I think it needs something like this
instead of this
cause later it calls for $actimeoutid etc.
Sorry it’s not working. I’ll have a look again tomorrow. (It’s 19:57 here, and I’m nowhere near a PC.)
I tried to modify a service I use for suspend inhibition when Samba is serving files.
[Unit]
Description=Inhibit suspend if Clementine is playing music
Before=sleep.target
[Service]
Type=oneshot
ExecStart=/usr/bin/sh -c "! pactl list sink-inputs | grep clementine"
[Install]
RequiredBy=sleep.target
This doesnt work as expected. I get this error:
pa_context_connect() failed: connection refused
Service fails to connect with PulseAudio and PC goes to sleep. Why is that so?
