Good morning fellow Manjaro users, I am here again to ask for your help with a piece of software that I am unable to install.
At the university I am currently attending, the statistical program Infostat is used. When downloading the program I found that it’s an .exe file, which I understand prevents me from using it on Linux. Would there be any solution to be able to use Infostat in Manjaro?
Any help would be really apreciated
Edit: VM isn’t an option, because I have a potato for laptop , my machine has an Intel Core i3-2350M @ 2.30GHz, 4gb DDR3 ram, and a 240G SSD
Actually Infostat is Proprietary Software, Red Hat Linux is Commercial Software.
well yes Infostat is also Commercial Software.
::End Mild Rant::
Your choices for running Windows Software, as that is what Infostat is for (it’s a .exe therefore Windows), is WINE or Play On Linux or some similar compatibility Layer, or to install a copy of Windows in a Virtual Machine. That’s what I did for several years, so I could run MS Visual Studio to program in VB and C#.
That way you have the stability of Linux, as your base.
What specifically is your need to be using Infostat? Is it that this is supposed to help you with analytics or are you supposed to provide Infostat results, that the lecturer/Tutor can plug in to their computer. .
If it’s just a tool to get results, then there are plenty of FOSS Analytics tools that integrate with R.
for example: I did this search ‘Linux Statistical Analysis Software with R’
Tracyanne, I will try to run it via Wine. Thanks for the help!
The purpose of using this software is that we learn to use it to calculate statistics, in addition, the way in which the program can be used in partial exams will be evaluated.
I would jump straight to recommending BOTTLES now. I had some issues keeping up running LINE.exe for my son’s online schooling, and in WINE the thing complained it can’t run on Windows 7, upgrade to Windows 10 now…
However, in Bottles it just works, stays logged in too…
Option 2 is to look at Virtualbox - install Windows and then install your software on Windows. It can work nicely, and you can have two desktops to switch ‘OS’ running Windows fullscreen on Desktop 2, or maybe it will run in ‘seamless’ mode.
Option 3 - guaranteed to work - dual booting is a pain, because it tears you away from your Linux desktop.
But for sure, what you’re experiencing now is #1 Bug.
Mac software runs on a Mac, Windows software on Windows, and for the most part - nobody gives a toss if it runs on Linux.
Sadly the ‘fixed’ version sucked. I didn’t wanna build the -git (but maybe will do) but the one flagged out of date with +81 votes did the job - so I’m not in a hurry to fix it.
