To keep the forum running as smoothly as possible it is necessary to do a major overhaul in the engine room.
There are some maintenance tasks which has been postponed for far too long and the engine desperately need a checkup.
We will do all we can to minimise the effects of this overhaul. We will create a lot of backups during which you will experience downtime, read-only mode or you will be presented with the maintenance page.
@ManjaroDevOps, if you’re going to make this into a banner, then you should also sign off with your name — real name or forum name. Otherwise the viewer won’t know who the “I” is who’s addressing them.
It’s a very common misperception among the members, but Aarhus is not his name. It’s where he lives.
