Infinix inbook x3 XL422, no sound on the speakers
Hi, I am new to Manjaro.
After installing the system, there is no sound, although the driver is installed and the system allows you to adjust the sound.
I provide the inxi -Faz output
  Kernel: 6.6.26-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
    root=UUID=c5df5201-c676-4c6e-b3bb-1e7e32a2a598 rw quiet splash
    resume=UUID=ac7b6541-e355-48e2-b110-ddaf82429fe1 udev.log_priority=3
  Desktop: KDE Plasma v: 5.27.11 tk: Qt v: 5.15.12 info: frameworks
    v: 5.115.0 wm: kwin_wayland vt: 1 dm: SDDM Distro: Manjaro base: Arch Linux
  Type: Laptop System: Infinix product: INBOOK X3
    v: XL422_BIOS_IDL325_200B_V1.0_1.05 serial: <superuser required>
  Mobo: N/A model: EM_IDL325_200B_V1.0 serial: <superuser required>
    uuid: <superuser required> UEFI: American Megatrends LLC.
    v: XL422_BIOS_IDL325_200B_V1.0_1.05 date: 05/24/2023
  ID-1: BAT0 charge: 41.5 Wh (83.0%) condition: 50.0/50.0 Wh (100.0%)
    power: 15.8 W volts: 11.6 min: N/A model: Intel SR 1 SR Real Battery
    type: Unknown serial: <filter> status: charging
  Info: model: 12th Gen Intel Core i5-1235U bits: 64 type: MST AMCP
    arch: Alder Lake level: v3 note: check built: 2021+
    process: Intel 7 (10nm ESF) family: 6 model-id: 0x9A (154) stepping: 4
    microcode: 0x430
  Topology: cpus: 1x cores: 10 mt: 2 tpc: 2 st: 8 threads: 12 smt: enabled
    cache: L1: 928 KiB desc: d-8x32 KiB, 2x48 KiB; i-2x32 KiB, 8x64 KiB
    L2: 6.5 MiB desc: 2x1.2 MiB, 2x2 MiB L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 634 high: 2538 min/max: 400/1300:900 scaling:
    driver: intel_pstate governor: powersave cores: 1: 400 2: 400 3: 400 4: 400
    5: 400 6: 2538 7: 400 8: 400 9: 412 10: 1065 11: 400 12: 400
    bogomips: 59916
  Type: reg_file_data_sampling status: Vulnerable: No microcode
    conditional; RSB filling; PBRSB-eIBRS: SW sequence; BHI: BHI_DIS_S
  Device-1: Intel Alder Lake-UP3 GT2 [Iris Xe Graphics]
    vendor: nCipher Security driver: i915 v: kernel arch: Gen-12.2
    process: Intel 10nm built: 2021-22+ ports: active: eDP-1
    empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:46a8
    class-ID: 0300
  Device-2: Microdia USB 2.0 Camera driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:2 chip-ID: 0c45:636b
  Display: wayland server: X.org v: 1.21.1.12 with: Xwayland v: 23.2.6
    alternate: fbdev,vesa dri: iris gpu: i915 display-ID: 0
  Monitor-1: eDP-1 res: 1920x1080 size: N/A modes: N/A
    device: 1 drv: swrast surfaceless: drv: iris wayland: drv: iris x11:
    drv: iris inactive: gbm
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.2-manjaro1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (ADL GT2)
    device-ID: 8086:46a8 memory: 15 GiB unified: yes display-ID: :1.0
  API: Vulkan v: 1.3.279 layers: 4 device: 0 type: integrated-gpu name: Intel
    Graphics (ADL GT2) driver: mesa intel v: 24.0.2-manjaro1.1
    device-ID: 8086:46a8 surfaces: xcb,xlib,wayland
  Device-1: Intel Alder Lake PCH-P High Definition Audio
    vendor: Emdoor Digital driver: snd_hda_intel v: kernel
    alternate: snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:51c8
    class-ID: 0403
  Device-2: C-Media SADES Dazzle driver: hid-generic,snd-usb-audio,usbhid
    type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-9:5
    chip-ID: 0d8c:0012 class-ID: 0300 serial: <filter>
  API: ALSA v: k6.6.26-1-MANJARO status: kernel-api with: aoss
  Server-2: JACK v: 1.9.22 status: off with: nsmd status: off
    tools: jack_mixer
  Server-3: PipeWire v: 1.0.3 status: active with: 1: pipewire-pulse
  Device-1: Intel Alder Lake-P PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:51f0 class-ID: 0280
  Info: services: NetworkManager,wpa_supplicant
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-10:4 chip-ID: 8087:0026
    class-ID: e001
  Local Storage: total: 476.94 GiB used: 111.19 GiB (23.3%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Foresee model: VP1000F512G
    lanes: 4 tech: SSD serial: <filter> fw-rev: V1.25 temp: 32.9 C scheme: GPT
  ID-1: / raw-size: 332.08 GiB size: 325.8 GiB (98.11%)
    used: 111.19 GiB (34.1%) fs: ext4 dev: /dev/nvme0n1p3 maj-min: 259:3
  ID-2: /boot/efi raw-size: 1024 MiB size: 1022 MiB (99.80%)
    used: 296 KiB (0.0%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-1: swap-1 type: partition size: 32.23 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p1 maj-min: 259:1
  System Temperatures: cpu: 51.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Memory: total: 16 GiB note: est. available: 15.36 GiB used: 5.94 GiB (38.7%)
  Processes: 305 Power: uptime: 27m states: freeze,mem,disk suspend: s2idle
    avail: deep wakeups: 0 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 6.13 GiB services: org_kde_powerdevil,
    tool: systemctl
  Packages: 1448 pm: dpkg pkgs: 0 pm: pacman pkgs: 1427 libs: 454
    tools: pamac,yay pm: flatpak pkgs: 21 Compilers: clang: 16.0.6 gcc: 13.2.1
    Shell: Zsh v: 5.9 default: Bash v: 5.2.26 running-in: konsole inxi: 3.3.34
aplay -l output
**** List of PLAYBACK Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC269VB Analog [ALC269VB Analog]
  Subdevices: 1/1
  Subdevice #0: subdevice #0
card 0: PCH [HDA Intel PCH], device 3: HDMI 0 [HDMI 0]
  Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 7: HDMI 1 [HDMI 1]
  Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 8: HDMI 2 [HDMI 2]
  Subdevices: 1/1
card 0: PCH [HDA Intel PCH], device 9: HDMI 3 [HDMI 3]
  Subdevices: 1/1
cat /proc/asound/cards output
 0 [PCH            ]: HDA-Intel - HDA Intel PCH
                      HDA Intel PCH at 0x6001128000 irq 150
output cat /proc/asound/card*/codec* | grep Codec
Codec: Realtek ALC269VB
Codec: Intel Alderlake-P HDMI
http://alsa-project.org/db/?f=03ecd8e0641c8075dd7b41a15a4368a4b1f2b8aa
How do I fix this?
The problem is solved. After reading many more forums, I came to the conclusion that I need to edit the outputs again.
I turned off the sound with a command.
systemctl --user disable --now pipewire.socket
In the hdajackretask program, I transferred all possible non-connected outputs to the “internal speaker”.
I applied the settings and turned on the sound.
systemctl --user enable --now pipe wire.socket
In the sound settings, set
analog stereo duplex
After making sure that everything works, I created an empty file
/etc/modprobe.d/hda-jack-retask.conf
In the program, I clicked hdajackretask “install boot override” and rebooted the system. After the restart, everything works.
