Hello! First of all, I am a new Linux user, and I have tried many of the things that were suggested as solutions in a similar situation - it did not help.
After several updates I encountered problems:
When loading Manjaro everything gets stuck on infinite loading (the inscription “Manjaro” and animation of three dots). I was able to bypass this by removing “quiet and splash” from the loading settings. But the system as a whole began to slow down. Specifically, it very often does not respond to clicks on the “Taskbar” - only restarting the taskbar helps.
In addition, (I’m not sure how much this is related), some games stopped launching through PortProton, which is not very important, but annoying.
Most of all, the problem of loading and freezes needs to be solved.
I don’t know what exactly broke the system. And it’s unlikely that we’ll be able to find out which update did it - everything broke about a month ago, after which there were other updates…
inxi -Fza
Kernel: 6.12.21-4-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=82954681-ebe2-4e7e-93fc-ef5c46ad336f rw
cryptdevice=UUID=6b7282d8-a02a-4152-897c-6034abef1b55:luks-6b7282d8-a02a-4152-897c-6034abef1b55
root=/dev/mapper/luks-6b7282d8-a02a-4152-897c-6034abef1b55
udev.log_priority=3
Desktop: KDE Plasma v: 6.3.4 tk: Qt v: N/A info: frameworks v: 6.12.0
Type: Desktop Mobo: Micro-Star model: B450M-A PRO MAX (MS-7C52) v: 1.0
serial: <superuser required> uuid: <superuser required> UEFI: American
Megatrends LLC. v: 3.B0 date: 02/03/2021
Info: model: AMD Ryzen 5 PRO 2400G with Radeon Vega Graphics bits: 64
type: MT MCP arch: Zen level: v3 note: check built: 2017-19 process: GF 14nm
family: 0x17 (23) model-id: 0x11 (17) stepping: 0 microcode: 0x8101016
Topology: cpus: 1x dies: 1 clusters: 1 cores: 4 threads: 8 tpc: 2
smt: enabled cache: L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB
desc: 4x512 KiB L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 1600 min/max: 1600/3600 boost: enabled scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 1600 2: 1600 3: 1600
4: 1600 5: 1600 6: 1600 7: 1600 8: 1600 bogomips: 57519
Type: retbleed mitigation: untrained return thunk; SMT vulnerable
Device-1: NVIDIA GA104 [GeForce RTX 3060 Ti Lite Hash Rate] vendor: Gigabyte
driver: nvidia v: 570.133.07 alternate: nouveau,nvidia_drm
non-free: 550-570.xx+ status: current (as of 2025-04; EOL~2026-12-xx)
arch: Ampere code: GAxxx process: TSMC n7 (7nm) built: 2020-2023 pcie:
gen: 2 speed: 5 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16
ports: active: none off: HDMI-A-2 empty: DP-1,DP-2,HDMI-A-1
bus-ID: 10:00.0 chip-ID: 10de:2489 class-ID: 0300
Device-2: Advanced Micro Devices [AMD/ATI] Raven Ridge [Radeon Vega
Series / Radeon Mobile Series] driver: N/A alternate: amdgpu arch: GCN-5
code: Vega process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 2a:00.0 chip-ID: 1002:15dd class-ID: 0300
Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6
compositor: kwin_x11 driver: X: loaded: nvidia gpu: nvidia,nvidia-nvswitch
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 81 s-size: 602x343mm (23.70x13.50")
s-diag: 693mm (27.28")
Monitor-1: HDMI-A-2 mapped: HDMI-1 note: disabled model: Samsung
serial: <filter> built: 2020 res: mode: 1920x1080 hz: 60 scale: 100% (1)
dpi: 40 gamma: 1.2 size: 1210x680mm (47.64x26.77") diag: 690mm (27.2")
ratio: 16:9 modes: max: 1920x1080 min: 640x480
API: EGL v: 1.5 hw: drv: nvidia nouveau drv: nvidia platforms: device: 0
drv: nvidia device: 1 drv: nouveau device: 2 drv: swrast gbm: drv: nvidia
surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 570.133.07
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3060 Ti/PCIe/SSE2
memory: 7.81 GiB
API: Vulkan v: 1.4.309 layers: 9 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 3060 Ti driver: nvidia v: 570.133.07 device-ID: 10de:2489
surfaces: xcb,xlib
Device-1: NVIDIA GA104 High Definition Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 10:00.1
chip-ID: 10de:228b class-ID: 0403
Device-2: Advanced Micro Devices [AMD/ATI] Raven/Raven2/Fenghuang HDMI/DP
Audio vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 3
speed: 8 GT/s lanes: 16 bus-ID: 2a:00.1 chip-ID: 1002:15de class-ID: 0403
speed: 8 GT/s lanes: 16 bus-ID: 2a:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: Logitech H390 headset with microphone
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-6:2 chip-ID: 046d:0a8f class-ID: 0300
API: ALSA v: k6.12.21-4-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.1 status: off with: wireplumber status: active
tools: pw-cli,wpctl
Server-3: PulseAudio v: 17.0-43-g3e2bb status: active
with: pulseaudio-alsa type: plugin tools: pacat,pactl
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: e000 bus-ID: 25:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp37s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Ralink MT7601U Wireless Adapter driver: mt7601u type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-7:3 chip-ID: 148f:7601
class-ID: 0000 serial: <filter>
IF: wlp18s0f0u7 state: down mac: <filter>
IF-ID-1: docker0 state: down mac: <filter>
Local Storage: total: 1.35 TiB used: 1.12 TiB (82.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: MSI model: M390 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: EHFM32.1 temp: 41.9 C
scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: TeamGroup model: T253X5480G
size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 0A0 scheme: GPT
ID-1: / raw-size: 931.21 GiB size: 930.76 GiB (99.95%)
used: 848.76 GiB (91.2%) fs: xfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-6b7282d8-a02a-4152-897c-6034abef1b55
used: 448 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: file size: 8 GiB used: 89.9 MiB (1.1%) priority: -2
file: /swapfile
System Temperatures: cpu: 43.2 C mobo: N/A gpu: nvidia temp: 42 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 45%
Memory: total: 16 GiB note: est. available: 13.58 GiB used: 6.82 GiB (50.2%)
Processes: 386 Power: uptime: 15m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 5.4 GiB services: org_kde_powerdevil,
tool: systemctl
Packages: 1907 pm: pacman pkgs: 1887 libs: 513 tools: pamac,yay
pm: flatpak pkgs: 20 Compilers: clang: 19.1.7 gcc: 14.2.1 alt: 13 Shell: Zsh
v: 5.9 default: Bash v: 5.2.37 running-in: konsole inxi: 3.3.38
journalctl --boot=-1 --priority=3 --catalog --no-pager
апр 12 19:08:59 pmmainpink kernel: amdgpu 0000:2a:00.0: amdgpu: Unable to locate a BIOS ROM
апр 12 19:08:59 pmmainpink kernel: amdgpu 0000:2a:00.0: amdgpu: Fatal error during GPU init
апр 12 19:08:59 pmmainpink kernel: amdgpu 0000:2a:00.0: probe with driver amdgpu failed with error -22
апр 12 19:08:59 pmmainpink systemd-modules-load[403]: Failed to find module 'v4l2loopback-dc'
апр 12 19:09:01 pmmainpink kernel:
апр 12 19:09:05 pmmainpink csc_vpnagent[864]: Function: startParser File: ../../vpn/Common/Xml/CVCSaxParser.cpp Line: 172 Invoked Function: xmlCreateFileParserCtxt Return Code: -33554427 (0xFE000005) Description: GLOBAL_ERROR_NULL_POINTER
апр 12 19:09:05 pmmainpink csc_vpnagent[864]: Function: LoadSettingsFromXmlFile File: ../../vpn/PhoneHome/PhoneHomeAgent.cpp Line: 626 Invoked Function: XmlParser::parseFile Return Code: -33554423 (0xFE000009) Description: GLOBAL_ERROR_UNEXPECTED
апр 12 19:09:05 pmmainpink csc_vpnagent[864]: Function: InitPhoneHomeAgent File: ../../vpn/PhoneHome/PhoneHomeAgent.cpp Line: 542 Illegal last reported time, using default value (0)
апр 12 19:09:08 pmmainpink csc_vpnagent[864]: Function: applyHostConfigForNoVpn File: ../../vpn/Agent/MainThread.cpp Line: 13940 Invoked Function: CHostConfigMgr::DeterminePublicInterface Return Code: -28770288 (0xFE490010) Description: HOSTCONFIGMGR_ERROR_PUBLIC_ADDRESS_UNAVAILABLE
апр 12 19:09:08 pmmainpink csc_vpnagent[864]: Function: OnTimerExpired File: ../../vpn/Agent/MainThread.cpp Line: 7604 Invoked Function: CMainThread::applyHostConfigForNoVpn Return Code: -28770288 (0xFE490010) Description: HOSTCONFIGMGR_ERROR_PUBLIC_ADDRESS_UNAVAILABLE
апр 12 19:09:08 pmmainpink csc_vpnagent[864]: Function: testNetwork File: ../../vpn/Agent/NetEnvironment.cpp Line: 939 Invoked Function: CHostConfigMgr::DeterminePublicInterface Return Code: -28770288 (0xFE490010) Description: HOSTCONFIGMGR_ERROR_PUBLIC_ADDRESS_UNAVAILABLE
апр 12 19:09:08 pmmainpink csc_vpnagent[864]: Function: TestNetEnv File: ../../vpn/Agent/NetEnvironment.cpp Line: 409 Invoked Function: CNetEnvironment::testNetwork Return Code: -28770288 (0xFE490010) Description: HOSTCONFIGMGR_ERROR_PUBLIC_ADDRESS_UNAVAILABLE
апр 12 19:09:08 pmmainpink csc_vpnagent[864]: Function: genericNoticeCategoryHandler File: ../../vpn/Agent/MainThread.cpp Line: 9507 Invoked Function: CMainThread::applyHostConfigForNoVpn Return Code: -28770288 (0xFE490010) Description: HOSTCONFIGMGR_ERROR_PUBLIC_ADDRESS_UNAVAILABLE
апр 12 19:09:08 pmmainpink csc_vpnagent[864]: Function: processNotice File: ../../vpn/Agent/MainThread.cpp Line: 8958 Invoked Function: CMainThread::genericNoticeCategoryHandler Return Code: -28770288 (0xFE490010) Description: HOSTCONFIGMGR_ERROR_PUBLIC_ADDRESS_UNAVAILABLE
апр 12 19:09:08 pmmainpink csc_vpnagent[864]: Function: noticeHandler File: ../../vpn/Agent/MainThread.cpp Line: 8912 Invoked Function: CMainThread::processNotice Return Code: -28770288 (0xFE490010) Description: HOSTCONFIGMGR_ERROR_PUBLIC_ADDRESS_UNAVAILABLE
апр 12 19:09:08 pmmainpink csc_vpnagent[864]: Function: OnEventSignaled File: ../../vpn/Agent/MainThread.cpp Line: 8628 Invoked Function: CMainThread::noticeHandler Return Code: -28770288 (0xFE490010) Description: HOSTCONFIGMGR_ERROR_PUBLIC_ADDRESS_UNAVAILABLE
апр 12 19:09:11 pmmainpink csc_vpnagent[864]: Function: testNetwork File: ../../vpn/Agent/NetEnvironment.cpp Line: 939 Invoked Function: CHostConfigMgr::DeterminePublicInterface Return Code: -28770288 (0xFE490010) Description: HOSTCONFIGMGR_ERROR_PUBLIC_ADDRESS_UNAVAILABLE
апр 12 19:09:11 pmmainpink csc_vpnagent[864]: Function: TestNetEnv File: ../../vpn/Agent/NetEnvironment.cpp Line: 409 Invoked Function: CNetEnvironment::testNetwork Return Code: -28770288 (0xFE490010) Description: HOSTCONFIGMGR_ERROR_PUBLIC_ADDRESS_UNAVAILABLE
апр 12 19:09:13 pmmainpink csc_vpnagent[864]: Function: InitNSS File: ../../vpn/CommonCrypt/Certificates/NSSCertUtils.cpp Line: 344 Invoked Function: CNSSCertUtils::getCertDBPath Return Code: -31457278 (0xFE200002) Description: CERTSTORE_ERROR_BAD_PARAMETER
апр 12 19:09:13 pmmainpink csc_vpnagent[864]: Function: CNSSCertStore File: ../../vpn/CommonCrypt/Certificates/NSSCertStore.cpp Line: 52 Invoked Function: CNSSCertUtils::InitNSS Return Code: -31457278 (0xFE200002) Description: CERTSTORE_ERROR_BAD_PARAMETER
апр 12 19:09:13 pmmainpink csc_vpnagent[864]: Function: addNSSStore File: ../../vpn/CommonCrypt/Certificates/CollectiveCertStore.cpp Line: 1923 Invoked Function: CNSSCertStore::CNSSCertStore Return Code: -31457278 (0xFE200002) Description: CERTSTORE_ERROR_BAD_PARAMETER
апр 12 19:09:13 pmmainpink csc_vpnagent[864]: Function: VerifyCertName File: ../../vpn/CommonCrypt/Certificates/VerifyServerName.cpp Line: 150 Certificate name verification has failed. Server Name: 195.189.123.97 Common Name(s): ASA Temporary Self Signed Certificate
апр 12 19:09:13 pmmainpink csc_vpnagent[864]: Function: VerifyCertName File: ../../vpn/CommonCrypt/Certificates/OpenSSLCertUtils.cpp Line: 1678 Invoked Function: CVerifyServerName::VerifyCertName Return Code: -31391725 (0xFE210013) Description: CERTIFICATE_ERROR_VERIFY_NAME_FAILED
апр 12 19:09:13 pmmainpink csc_vpnagent[864]: Function: VerifyServerCertificate File: ../../vpn/CommonCrypt/Certificates/CertHelper.cpp Line: 497 Invoked Function: CCertHelper::VerifyServerCertificate Return Code: -31391725 (0xFE210013) Description: CERTIFICATE_ERROR_VERIFY_NAME_FAILED
апр 12 19:09:13 pmmainpink csc_vpnagent[864]: Function: analyzeHttpResponse File: ../../vpn/Agent/NetEnvironment.cpp Line: 1921 Invoked Function: CCertHelper::VerifyServerCertificate Return Code: -31391725 (0xFE210013) Description: CERTIFICATE_ERROR_VERIFY_NAME_FAILED server name: 195.189.123.97
апр 12 19:09:15 pmmainpink csc_vpnagent[864]: Function: OnOpenRequestComplete File: ../../vpn/Common/IP/HttpProbeAsync.cpp Line: 287 Invoked Function: CHttpSessionAsync::OnOpenRequestComplete Return Code: -31588307 (0xFE1E002D) Description: SOCKETTRANSPORT_ERROR_CONNECT_CANCELED:An asynchronous connection has been canceled during its initiation.
апр 12 19:09:15 pmmainpink csc_vpnagent[864]: Function: TestAccessToSG File: ../../vpn/Agent/NetEnvironment.cpp Line: 1678 Invoked Function: CNetEnvironment::analyzeHttpResponse Return Code: -28901363 (0xFE47000D) Description: NETENVIRONMENT_ERROR_PROBE_INCOMPLETE:Network Probe could not contact target
апр 12 19:09:15 pmmainpink csc_vpnagent[864]: Function: testNetwork File: ../../vpn/Agent/NetEnvironment.cpp Line: 1029 Invoked Function: CNetEnvironment::IsSGAccessible Return Code: -28901363 (0xFE47000D) Description: NETENVIRONMENT_ERROR_PROBE_INCOMPLETE:Network Probe could not contact target
апр 12 19:09:24 pmmainpink systemd[1]: Failed to start Terminate Plymouth Boot Screen.
░░ Subject: Ошибка юнита plymouth-quit.service
░░ Defined-By: systemd
░░ Произошел сбой юнита plymouth-quit.service.
░░ Результат: failed.
апр 12 19:09:24 pmmainpink sddm[1403]: Failed to read display number from pipe
апр 12 19:09:25 pmmainpink csc_vpnagent[864]: Function: InitNSS File: ../../vpn/CommonCrypt/Certificates/NSSCertUtils.cpp Line: 344 Invoked Function: CNSSCertUtils::getCertDBPath Return Code: -31457278 (0xFE200002) Description: CERTSTORE_ERROR_BAD_PARAMETER
апр 12 19:09:25 pmmainpink csc_vpnagent[864]: Function: CNSSCertStore File: ../../vpn/CommonCrypt/Certificates/NSSCertStore.cpp Line: 52 Invoked Function: CNSSCertUtils::InitNSS Return Code: -31457278 (0xFE200002) Description: CERTSTORE_ERROR_BAD_PARAMETER
апр 12 19:09:25 pmmainpink csc_vpnagent[864]: Function: addNSSStore File: ../../vpn/CommonCrypt/Certificates/CollectiveCertStore.cpp Line: 1923 Invoked Function: CNSSCertStore::CNSSCertStore Return Code: -31457278 (0xFE200002) Description: CERTSTORE_ERROR_BAD_PARAMETER
апр 12 19:09:25 pmmainpink csc_vpnagent[864]: Function: VerifyCertName File: ../../vpn/CommonCrypt/Certificates/VerifyServerName.cpp Line: 150 Certificate name verification has failed. Server Name: 195.189.123.97 Common Name(s): ASA Temporary Self Signed Certificate
апр 12 19:09:25 pmmainpink csc_vpnagent[864]: Function: VerifyCertName File: ../../vpn/CommonCrypt/Certificates/OpenSSLCertUtils.cpp Line: 1678 Invoked Function: CVerifyServerName::VerifyCertName Return Code: -31391725 (0xFE210013) Description: CERTIFICATE_ERROR_VERIFY_NAME_FAILED
апр 12 19:09:25 pmmainpink csc_vpnagent[864]: Function: VerifyServerCertificate File: ../../vpn/CommonCrypt/Certificates/CertHelper.cpp Line: 497 Invoked Function: CCertHelper::VerifyServerCertificate Return Code: -31391725 (0xFE210013) Description: CERTIFICATE_ERROR_VERIFY_NAME_FAILED
апр 12 19:09:25 pmmainpink csc_vpnagent[864]: Function: analyzeHttpResponse File: ../../vpn/Agent/NetEnvironment.cpp Line: 1921 Invoked Function: CCertHelper::VerifyServerCertificate Return Code: -31391725 (0xFE210013) Description: CERTIFICATE_ERROR_VERIFY_NAME_FAILED server name: 195.189.123.97
апр 12 19:09:26 pmmainpink sddm[1403]: Failed to read display number from pipe
апр 12 19:09:27 pmmainpink csc_vpnagent[864]: Function: OnOpenRequestComplete File: ../../vpn/Common/IP/HttpProbeAsync.cpp Line: 287 Invoked Function: CHttpSessionAsync::OnOpenRequestComplete Return Code: -31588307 (0xFE1E002D) Description: SOCKETTRANSPORT_ERROR_CONNECT_CANCELED:An asynchronous connection has been canceled during its initiation.
апр 12 19:09:27 pmmainpink csc_vpnagent[864]: Function: TestAccessToSG File: ../../vpn/Agent/NetEnvironment.cpp Line: 1678 Invoked Function: CNetEnvironment::analyzeHttpResponse Return Code: -28901363 (0xFE47000D) Description: NETENVIRONMENT_ERROR_PROBE_INCOMPLETE:Network Probe could not contact target
апр 12 19:09:27 pmmainpink csc_vpnagent[864]: Function: testNetwork File: ../../vpn/Agent/NetEnvironment.cpp Line: 1029 Invoked Function: CNetEnvironment::IsSGAccessible Return Code: -28901363 (0xFE47000D) Description: NETENVIRONMENT_ERROR_PROBE_INCOMPLETE:Network Probe could not contact target
апр 12 19:09:27 pmmainpink csc_vpnagent[864]: Function: TestNetEnv File: ../../vpn/Agent/NetEnvironment.cpp Line: 409 Invoked Function: CNetEnvironment::testNetwork Return Code: -28901363 (0xFE47000D) Description: NETENVIRONMENT_ERROR_PROBE_INCOMPLETE:Network Probe could not contact target
апр 12 19:09:28 pmmainpink sddm[1403]: Failed to read display number from pipe
апр 12 19:09:28 pmmainpink sddm[1403]: Could not start Display server on vt 2
апр 12 19:09:48 pmmainpink csc_vpnagent[864]: Function: InitNSS File: ../../vpn/CommonCrypt/Certificates/NSSCertUtils.cpp Line: 344 Invoked Function: CNSSCertUtils::getCertDBPath Return Code: -31457278 (0xFE200002) Description: CERTSTORE_ERROR_BAD_PARAMETER
апр 12 19:09:48 pmmainpink csc_vpnagent[864]: Function: CNSSCertStore File: ../../vpn/CommonCrypt/Certificates/NSSCertStore.cpp Line: 52 Invoked Function: CNSSCertUtils::InitNSS Return Code: -31457278 (0xFE200002) Description: CERTSTORE_ERROR_BAD_PARAMETER
апр 12 19:09:48 pmmainpink csc_vpnagent[864]: Function: addNSSStore File: ../../vpn/CommonCrypt/Certificates/CollectiveCertStore.cpp Line: 1923 Invoked Function: CNSSCertStore::CNSSCertStore Return Code: -31457278 (0xFE200002) Description: CERTSTORE_ERROR_BAD_PARAMETER
апр 12 19:09:48 pmmainpink csc_vpnagent[864]: Function: VerifyCertName File: ../../vpn/CommonCrypt/Certificates/VerifyServerName.cpp Line: 150 Certificate name verification has failed. Server Name: 195.189.123.97 Common Name(s): ASA Temporary Self Signed Certificate
апр 12 19:09:48 pmmainpink csc_vpnagent[864]: Function: VerifyCertName File: ../../vpn/CommonCrypt/Certificates/OpenSSLCertUtils.cpp Line: 1678 Invoked Function: CVerifyServerName::VerifyCertName Return Code: -31391725 (0xFE210013) Description: CERTIFICATE_ERROR_VERIFY_NAME_FAILED
апр 12 19:09:48 pmmainpink csc_vpnagent[864]: Function: VerifyServerCertificate File: ../../vpn/CommonCrypt/Certificates/CertHelper.cpp Line: 497 Invoked Function: CCertHelper::VerifyServerCertificate Return Code: -31391725 (0xFE210013) Description: CERTIFICATE_ERROR_VERIFY_NAME_FAILED
апр 12 19:09:48 pmmainpink csc_vpnagent[864]: Function: analyzeHttpResponse File: ../../vpn/Agent/NetEnvironment.cpp Line: 1921 Invoked Function: CCertHelper::VerifyServerCertificate Return Code: -31391725 (0xFE210013) Description: CERTIFICATE_ERROR_VERIFY_NAME_FAILED server name: 195.189.123.97
апр 12 19:09:50 pmmainpink csc_vpnagent[864]: Function: OnOpenRequestComplete File: ../../vpn/Common/IP/HttpProbeAsync.cpp Line: 287 Invoked Function: CHttpSessionAsync::OnOpenRequestComplete Return Code: -31588307 (0xFE1E002D) Description: SOCKETTRANSPORT_ERROR_CONNECT_CANCELED:An asynchronous connection has been canceled during its initiation.
апр 12 19:09:50 pmmainpink csc_vpnagent[864]: Function: TestAccessToSG File: ../../vpn/Agent/NetEnvironment.cpp Line: 1678 Invoked Function: CNetEnvironment::analyzeHttpResponse Return Code: -28901363 (0xFE47000D) Description: NETENVIRONMENT_ERROR_PROBE_INCOMPLETE:Network Probe could not contact target
апр 12 19:09:50 pmmainpink csc_vpnagent[864]: Function: testNetwork File: ../../vpn/Agent/NetEnvironment.cpp Line: 1029 Invoked Function: CNetEnvironment::IsSGAccessible Return Code: -28901363 (0xFE47000D) Description: NETENVIRONMENT_ERROR_PROBE_INCOMPLETE:Network Probe could not contact target
апр 12 19:10:20 pmmainpink csc_vpnagent[864]: Function: InitNSS File: ../../vpn/CommonCrypt/Certificates/NSSCertUtils.cpp Line: 344 Invoked Function: CNSSCertUtils::getCertDBPath Return Code: -31457278 (0xFE200002) Description: CERTSTORE_ERROR_BAD_PARAMETER
апр 12 19:10:20 pmmainpink csc_vpnagent[864]: Function: CNSSCertStore File: ../../vpn/CommonCrypt/Certificates/NSSCertStore.cpp Line: 52 Invoked Function: CNSSCertUtils::InitNSS Return Code: -31457278 (0xFE200002) Description: CERTSTORE_ERROR_BAD_PARAMETER
апр 12 19:10:20 pmmainpink csc_vpnagent[864]: Function: addNSSStore File: ../../vpn/CommonCrypt/Certificates/CollectiveCertStore.cpp Line: 1923 Invoked Function: CNSSCertStore::CNSSCertStore Return Code: -31457278 (0xFE200002) Description: CERTSTORE_ERROR_BAD_PARAMETER
апр 12 19:10:20 pmmainpink csc_vpnagent[864]: Function: VerifyCertName File: ../../vpn/CommonCrypt/Certificates/VerifyServerName.cpp Line: 150 Certificate name verification has failed. Server Name: 195.189.123.97 Common Name(s): ASA Temporary Self Signed Certificate
апр 12 19:10:20 pmmainpink csc_vpnagent[864]: Function: VerifyCertName File: ../../vpn/CommonCrypt/Certificates/OpenSSLCertUtils.cpp Line: 1678 Invoked Function: CVerifyServerName::VerifyCertName Return Code: -31391725 (0xFE210013) Description: CERTIFICATE_ERROR_VERIFY_NAME_FAILED
апр 12 19:10:20 pmmainpink csc_vpnagent[864]: Function: VerifyServerCertificate File: ../../vpn/CommonCrypt/Certificates/CertHelper.cpp Line: 497 Invoked Function: CCertHelper::VerifyServerCertificate Return Code: -31391725 (0xFE210013) Description: CERTIFICATE_ERROR_VERIFY_NAME_FAILED
апр 12 19:10:20 pmmainpink csc_vpnagent[864]: Function: analyzeHttpResponse File: ../../vpn/Agent/NetEnvironment.cpp Line: 1921 Invoked Function: CCertHelper::VerifyServerCertificate Return Code: -31391725 (0xFE210013) Description: CERTIFICATE_ERROR_VERIFY_NAME_FAILED server name: 195.189.123.97
апр 12 19:10:22 pmmainpink csc_vpnagent[864]: Function: OnOpenRequestComplete File: ../../vpn/Common/IP/HttpProbeAsync.cpp Line: 287 Invoked Function: CHttpSessionAsync::OnOpenRequestComplete Return Code: -31588307 (0xFE1E002D) Description: SOCKETTRANSPORT_ERROR_CONNECT_CANCELED:An asynchronous connection has been canceled during its initiation.
апр 12 19:10:22 pmmainpink csc_vpnagent[864]: Function: TestAccessToSG File: ../../vpn/Agent/NetEnvironment.cpp Line: 1678 Invoked Function: CNetEnvironment::analyzeHttpResponse Return Code: -28901363 (0xFE47000D) Description: NETENVIRONMENT_ERROR_PROBE_INCOMPLETE:Network Probe could not contact target
апр 12 19:10:22 pmmainpink csc_vpnagent[864]: Function: testNetwork File: ../../vpn/Agent/NetEnvironment.cpp Line: 1029 Invoked Function: CNetEnvironment::IsSGAccessible Return Code: -28901363 (0xFE47000D) Description: NETENVIRONMENT_ERROR_PROBE_INCOMPLETE:Network Probe could not contact target
апр 12 19:14:05 pmmainpink csc_vpnagent[864]: Function: GetSettings File: ../../vpn/Agent/ServicePluginMgr.cpp Line: 292 m_pIServicePlugin is NULL
апр 12 19:14:05 pmmainpink csc_vpnagent[864]: Function: HandleError File: ../../vpn/Common/Utility/HttpSession_curl.cpp Line: 832 Invoked Function: CHttpSessionCurl::HandleError Return Code: 6 (0x00000006) Description: unknown
апр 12 19:14:05 pmmainpink csc_vpnagent[864]: Function: PostDataGetResponse File: ../../vpn/PhoneHome/FileUploader.cpp Line: 375 Invoked Function: CFileUploader::SendHttpRequest Return Code: -28966887 (0xFE460019) Description: HTTP_SESSION_ERROR_DNS_RESOLUTION
If you need any more information, I will provide it.
Please help!
