$ sudo inxi --admin --verbosity=7 --filter --no-host --width
[sudo] password for andy:
Kernel: 6.1.53-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=d54307a5-ea7d-455d-a83d-6ee4e8a3d18e rw quiet apparmor=1
security=apparmor resume=UUID=be3ab29e-a8cc-418b-aa85-ef2d16217075
udev.log_priority=3
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.10 wm: kwin_x11 dm: SDDM
Type: Desktop System: Gigabyte product: B365M H v: N/A serial: N/A
Mobo: Gigabyte model: B365M H v: x.x serial: N/A UEFI: American Megatrends
v: F4a date: 11/28/2019
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M280/320/275
status: discharging
System RAM: total: 8 GiB available: 7.64 GiB used: 6.52 GiB (85.3%)
igpu: 64 MiB
Array-1: capacity: 64 GiB slots: 4 modules: 1 EC: None
Device-1: ChannelA-DIMM0 type: DDR4 detail: synchronous unbuffered
(unregistered) size: 8 GiB speed: 2666 MT/s volts: curr: 1.2 min: 1.2
max: 1.2 width (bits): data: 64 total: 64 manufacturer: Crucial
part-no: CT8G4DFS8266.M8FD serial: <filter>
Device-2: ChannelA-DIMM1 type: no module installed
Device-3: ChannelB-DIMM0 type: no module installed
Device-4: ChannelB-DIMM1 type: no module installed
Info: model: Intel Core i5-9400 socket: LGA1151 (U3E1) note: check bits: 64
type: MCP arch: Coffee Lake gen: core 9 level: v3 note: check built: 2018
process: Intel 14nm family: 6 model-id: 0x9E (158) stepping: 0xA (10)
microcode: 0xF4
Topology: cpus: 1x cores: 6 smt: <unsupported> cache: L1: 384 KiB
desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB L3: 9 MiB
desc: 1x9 MiB
Speed (MHz): avg: 800 min/max: 800/4100 base/boost: 3900/8300 scaling:
driver: intel_pstate governor: powersave volts: 1.0 V ext-clock: 100 MHz
cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 bogomips: 34814
dtherm dts ept ept_ad erms est f16c flexpriority flush_l1d fma fpu
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq pdcm
pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdseed rdtscp
rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp
vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
disabled
Type: spectre_v2 mitigation: IBRS, IBPB: conditional, STIBP: disabled, RSB
filling, PBRSB-eIBRS: Not affected
Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630] vendor: Gigabyte
ports: active: DP-1 empty: HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:3e92 class-ID: 0300
Device-2: Microsoft LifeCam HD-3000 driver: snd-usb-audio,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5.3.3:7
chip-ID: 045e:0779 class-ID: 0102
Display: server: X.Org v: 21.1.8 compositor: kwin_x11 driver: X:
loaded: modesetting alternate: fbdev,vesa dri: iris gpu: i915 display-ID: :0
screens: 1
s-diag: 582mm (22.93") monitors: <missing: xrandr>
Monitor-1: DP-1 model: LG (GoldStar) E2341 serial: <filter> built: 2011
res: 1920x1080 dpi: 96 gamma: 1.2 size: 510x290mm (20.08x11.42")
diag: 587mm (23.1") ratio: 16:9 modes: max: 1920x1080 min: 720x400
API: OpenGL v: 4.6 Mesa 23.1.7-1 renderer: Mesa Intel UHD Graphics 630
(CFL GT2) direct-render: Yes
Device-1: Intel 200 Series PCH HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:a2f0
class-ID: 0403
API: ALSA v: k6.1.53-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.80 status: n/a (root, process)
with: pipewire-media-session status: active tools: pw-cli
Server-3: PulseAudio v: 16.1 status: active (root, process) with:
tools: pacat,pactl
lanes: 1 port: e000 bus-ID: 06:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp6s0 state: up speed: 10 Mbps duplex: full mac: <filter>
Device-2: Realtek RTL8192EE PCIe Wireless Network Adapter driver: N/A
modules: rtl8192ee pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d000
bus-ID: 09:00.0 chip-ID: 10ec:818b class-ID: 0280
IF-ID-1: nordtun state: unknown speed: 10 Mbps duplex: full mac: N/A
IP v4: <filter> scope: global
Local Storage: total: 125.87 PiB used: 468.38 GiB (0.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 860 QVO 1TB
tech: SSD serial: <filter> fw-rev: 1B6Q scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 model: 0 O6 0 r3 S C 5 pg : s :6 s
size: 125.87 PiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: HDD rpm: 5400
serial: <filter>
Optical-1: /dev/sr0 vendor: HL-DT-ST model: DVDRAM GH24NSD1 rev: LW00
dev-links: cdrom
Features: speed: 12 multisession: yes audio: yes dvd: yes
ID-1: / raw-size: 39.06 GiB size: 38.28 GiB (97.99%) used: 27.32 GiB (71.4%)
fs: ext4 block-size: 4096 B dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: d54307a5-ea7d-455d-a83d-6ee4e8a3d18e
ID-2: /boot/efi raw-size: 1000 MiB size: 998 MiB (99.80%)
used: 280 KiB (0.0%) fs: vfat block-size: 512 B dev: /dev/sda1 maj-min: 8:1
label: N/A uuid: 844A-062C
ID-3: /home raw-size: 883.66 GiB size: 868.72 GiB (98.31%)
used: 438.87 GiB (50.5%) fs: ext4 block-size: 4096 B dev: /dev/sda4
maj-min: 8:4 label: N/A uuid: ce017356-0015-4aa3-9f56-cfc2e191fb87
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default) zswap: yes
ID-1: swap-1 type: partition size: 7.81 GiB used: 2.19 GiB (28.0%)
priority: -2 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: be3ab29e-a8cc-418b-aa85-ef2d16217075
ID-1: /dev/sdb1 maj-min: 8:17 size: 462.19 GiB fs: ext4
label: Toshiba External uuid: c9b1d9d7-169c-47fa-aac6-80a664c64f49
ID-2: /dev/sdb2 maj-min: 8:18 size: 4 MiB fs: vfat label: MISO_EFI
uuid: 8D59-F16D
Device-1: 1-1:2 info: Brother Industries HL-3170CDW series type: printer
driver: usblp interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
mode: 2.0 power: 2mA chip-ID: 04f9:0053 class-ID: 0701 serial: <filter>
Device-2: 1-2:3 info: Lite-On USB Keyboard type: keyboard,HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 1.5 Mb/s (183 KiB/s)
lanes: 1 mode: 1.0 power: 100mA chip-ID: 04ca:009c class-ID: 0300
Hub-2: 1-5:4 info: Terminus Hub ports: 4 rev: 2.0
chip-ID: 1a40:0101 class-ID: 0900
Hub-3: 1-5.3:5 info: Super Top Hub [Super Top] ports: 4 rev: 2.0
chip-ID: 14cd:8608 class-ID: 0900
Device-1: 1-5.3.2:6 info: Logitech Unifying Receiver type: mouse,HID
driver: logitech-djreceiver,usbhid interfaces: 2 rev: 2.0
chip-ID: 046d:c52f class-ID: 0300
Device-2: 1-5.3.3:7 info: Microsoft LifeCam HD-3000 type: video,audio
Hub-4: 2-0:1 info: super-speed hub ports: 8 rev: 3.0
Device-1: 2-5:2 info: Toshiba America External Disk type: mass storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s)
lanes: 1 mode: 3.2 gen-1x1 power: 896mA chip-ID: 0480:0200 class-ID: 0806
serial: <filter>
System Temperatures: cpu: 29.0 C mobo: N/A
Fan Speeds (rpm): N/A
Processes: 298 Uptime: 4h 9m wakeups: 10 Init: systemd v: 254
Packages: 1906 pm: pacman pkgs: 1876 libs: 461 tools: pamac,yay pm: rpm
pkgs: 0 pm: flatpak pkgs: 19 pm: snap pkgs: 11 Shell: Sudo (sudo) v: 1.9.14p3
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.29
Boot is slow, a message briefly appears. Initially there is no taskbar and KSysGuard shows several CPUs at 104%.
Alt/Tab can be used to move between loaded programs.
Eventually the taskbar appears and fills.
Starting any program, VCL, Dolphin, Gwenview, etc, takes time and causes a CPU to max out.
Meanwhile, KSysGuard’s Process Table shows no sign of significant activity for that program.
I am not familiar with htop, but it does not seem to be showing anything dramatic.
The hibernate button does not work.
On shutdown I had:
“Watchdog did not stop!” once
“[FAILED] Failed to start virtual console setup” subsequently
baloo is disabled
today’s log - first few minutes:
# journalctl -p 4 --since today
-- Boot b8f629da2f9e433786e7ff9da391491c --
Sep 27 08:50:59 andy-manjaro kernel: x86/cpu: SGX disabled by BIOS.
Sep 27 08:51:00 andy-manjaro kernel: resource sanity check: requesting [mem 0xfdffe800-0xfe0007ff], which spans more than pnp 00:08 [mem 0xfdb00000-0xfdffffff]
Sep 27 08:51:00 andy-manjaro kernel: caller pmc_core_probe+0xb7/0x6b0 mapping multiple BARs
Sep 27 08:51:00 andy-manjaro kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.PRT3._GTF.DSSP], AE_NOT_FOUND (20220331/psargs-330)
Sep 27 08:51:00 andy-manjaro kernel: ACPI Error: Aborting method \_SB.PCI0.SAT0.PRT3._GTF due to previous error (AE_NOT_FOUND) (20220331/psparse-529)
Sep 27 08:51:00 andy-manjaro kernel: ata4.00: supports DRM functions and may not be fully accessible
Sep 27 08:51:00 andy-manjaro kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.PRT2._GTF.DSSP], AE_NOT_FOUND (20220331/psargs-330)
Sep 27 08:51:00 andy-manjaro kernel: ACPI Error: Aborting method \_SB.PCI0.SAT0.PRT2._GTF due to previous error (AE_NOT_FOUND) (20220331/psparse-529)
Sep 27 08:51:00 andy-manjaro kernel: critical target error, dev sdb, sector 276793011827072 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 2
Sep 27 08:51:00 andy-manjaro kernel: critical target error, dev sdb, sector 276793011827072 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2
Sep 27 08:51:00 andy-manjaro kernel: Buffer I/O error on dev sdb, logical block 276793011827072, async page read
Sep 27 08:51:00 andy-manjaro kernel: critical target error, dev sdb, sector 276793011827073 op 0x0:(READ) flags 0x0 phys_seg 7 prio class 2
Sep 27 08:51:00 andy-manjaro kernel: Buffer I/O error on dev sdb, logical block 276793011827073, async page read
Sep 27 08:51:00 andy-manjaro kernel: Buffer I/O error on dev sdb, logical block 276793011827074, async page read
Sep 27 08:51:00 andy-manjaro kernel: Buffer I/O error on dev sdb, logical block 276793011827075, async page read
Sep 27 08:51:00 andy-manjaro kernel: Buffer I/O error on dev sdb, logical block 276793011827076, async page read
Sep 27 08:51:00 andy-manjaro kernel: Buffer I/O error on dev sdb, logical block 276793011827077, async page read
Sep 27 08:51:00 andy-manjaro kernel: Buffer I/O error on dev sdb, logical block 276793011827078, async page read
Sep 27 08:51:00 andy-manjaro kernel: Buffer I/O error on dev sdb, logical block 276793011827079, async page read
Sep 27 08:51:00 andy-manjaro kernel: r8169 0000:06:00.0: can't disable ASPM; OS doesn't have ASPM control
Sep 27 08:51:00 andy-manjaro systemd-vconsole-setup[578]: /usr/bin/loadkeys failed with exit status 1.
Sep 27 08:51:00 andy-manjaro systemd[1]: systemd-vconsole-setup.service: Failed with result 'exit-code'.
Sep 27 08:51:00 andy-manjaro systemd[1]: Failed to start Virtual Console Setup.
Sep 27 08:51:00 andy-manjaro systemd-vconsole-setup[605]: /usr/bin/loadkeys failed with exit status 1.
Sep 27 08:51:00 andy-manjaro systemd[1]: nordvpnd.socket: TCP_NODELAY failed: Operation not supported
Sep 27 08:51:01 andy-manjaro systemd[1]: Cannot find unit for notify message of PID 707, ignoring.
Sep 27 08:51:01 andy-manjaro systemd[1]: Cannot find unit for notify message of PID 717, ignoring.
Sep 27 08:51:01 andy-manjaro systemd[1]: snapd.service: Got notification message from PID 797, but reception only permitted for main PID 627
Sep 27 08:51:01 andy-manjaro systemd[1]: snapd.service: Got notification message from PID 804, but reception only permitted for main PID 627
Sep 27 08:51:04 andy-manjaro sddm-greeter[1032]: QObject: Cannot create children for a parent that is in a different thread.
(Parent is QGuiApplication(0x7ffd8e7fb100), parent's thread is QThread(0x55f9bf1f3e40), current thread is QThread(0x55f9bf356220)
Sep 27 08:51:04 andy-manjaro sddm-greeter[1032]: QObject::installEventFilter(): Cannot filter events for objects in a different thread.
Sep 27 08:51:07 andy-manjaro hp[1078]: io/hpmud/pp.c 627: unable to read device-id ret=-1
Sep 27 08:51:07 andy-manjaro colord-sane[1063]: io/hpmud/pp.c 627: unable to read device-id ret=-1
Sep 27 08:51:08 andy-manjaro python[1073]: io/hpmud/pp.c 627: unable to read device-id ret=-1
Sep 27 08:51:14 andy-manjaro nmbd[1097]: [2023/09/27 08:51:14.538051, 0] ../../source3/nmbd/nmbd.c:901(main)
Sep 27 08:51:14 andy-manjaro nmbd[1097]: main: nmbd version 4.19.0 started.
Sep 27 08:51:14 andy-manjaro nmbd[1097]: Copyright Andrew Tridgell and the Samba Team 1992-2023
Sep 27 08:51:14 andy-manjaro nmbd[1097]: [2023/09/27 08:51:14.546432, 0] ../../source3/nmbd/nmbd_become_dmb.c:339(become_domain_master_browser_wins)
Sep 27 08:51:14 andy-manjaro nmbd[1097]: become_domain_master_browser_wins:
Sep 27 08:51:14 andy-manjaro nmbd[1097]: Attempting to become domain master browser on workgroup WORKGROUP, subnet UNICAST_SUBNET.
Sep 27 08:51:14 andy-manjaro nmbd[1097]: [2023/09/27 08:51:14.546803, 0] ../../source3/nmbd/nmbd_become_dmb.c:351(become_domain_master_browser_wins)
Sep 27 08:51:14 andy-manjaro nmbd[1097]: become_domain_master_browser_wins: querying WINS server from IP 192.168.1.72 for domain master browser name WORKGROUP<1b> on workgroup WORKGROUP
Sep 27 08:51:14 andy-manjaro smbd[1112]: [2023/09/27 08:51:14.656723, 0] ../../source3/smbd/server.c:1746(main)
Sep 27 08:51:14 andy-manjaro smbd[1112]: smbd version 4.19.0 started.
Sep 27 08:51:14 andy-manjaro smbd[1112]: Copyright Andrew Tridgell and the Samba Team 1992-2023
Sep 27 08:51:20 andy-manjaro nmbd[1097]: [2023/09/27 08:51:20.564620, 0] ../../source3/nmbd/nmbd_become_dmb.c:112(become_domain_master_stage2)
Sep 27 08:51:20 andy-manjaro nmbd[1097]: *****
Sep 27 08:51:20 andy-manjaro nmbd[1097]: Samba server ANDY-MANJARO is now a domain master browser for workgroup WORKGROUP on subnet UNICAST_SUBNET
Sep 27 08:51:20 andy-manjaro nmbd[1097]: [2023/09/27 08:51:20.564851, 0] ../../source3/nmbd/nmbd_become_dmb.c:294(become_domain_master_browser_bcast)
Sep 27 08:51:20 andy-manjaro nmbd[1097]: become_domain_master_browser_bcast:
Sep 27 08:51:20 andy-manjaro nmbd[1097]: Attempting to become domain master browser on workgroup WORKGROUP on subnet 192.168.1.72
Sep 27 08:51:20 andy-manjaro nmbd[1097]: [2023/09/27 08:51:20.564932, 0] ../../source3/nmbd/nmbd_become_dmb.c:306(become_domain_master_browser_bcast)
Sep 27 08:51:20 andy-manjaro nmbd[1097]: become_domain_master_browser_bcast: querying subnet 192.168.1.72 for domain master browser on workgroup WORKGROUP
Sep 27 08:51:28 andy-manjaro nmbd[1097]: [2023/09/27 08:51:28.577206, 0] ../../source3/nmbd/nmbd_become_dmb.c:112(become_domain_master_stage2)
Sep 27 08:51:28 andy-manjaro nmbd[1097]: *****
Sep 27 08:51:28 andy-manjaro nmbd[1097]: Samba server ANDY-MANJARO is now a domain master browser for workgroup WORKGROUP on subnet 192.168.1.72
Sep 27 08:51:30 andy-manjaro sddm-greeter[1032]: file:///usr/share/sddm/themes/Northern-Lights-16-SDDM/Main.qml:452:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Sep 27 08:51:30 andy-manjaro sddm-greeter[1032]: file:///usr/share/sddm/themes/Northern-Lights-16-SDDM/components/VirtualKeyboard.qml:22:1: Type InputPanel unavailable
Sep 27 08:51:30 andy-manjaro sddm-greeter[1032]: qrc:/QtQuick/VirtualKeyboard/content/InputPanel.qml:138:5: Type Keyboard unavailable
Sep 27 08:51:30 andy-manjaro sddm-greeter[1032]: qrc:/QtQuick/VirtualKeyboard/content/components/Keyboard.qml:38:1: module "QtQuick.VirtualKeyboard.Plugins" is not installed
Sep 27 08:51:30 andy-manjaro sddm-greeter[1032]: file:///usr/share/sddm/themes/Northern-Lights-16-SDDM/Login.qml:103:13: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo(<arguments>) { ... }
Sep 27 08:51:30 andy-manjaro sddm-greeter[1032]: file:///usr/share/sddm/themes/Northern-Lights-16-SDDM/Main.qml:65:17: Unable to assign [undefined] to QColor
Sep 27 08:51:30 andy-manjaro sddm-greeter[1032]: QDBusConnection: name 'org.freedesktop.UPower' had owner '' but we thought it was ':1.30'
Sep 27 08:51:36 andy-manjaro sddm-greeter[1032]: file:///usr/share/sddm/themes/Northern-Lights-16-SDDM/Main.qml:420: TypeError: Cannot read property 'smallSpacing' of null
Sep 27 08:51:36 andy-manjaro sddm-greeter[1032]: file:///usr/share/sddm/themes/Northern-Lights-16-SDDM/components/Battery.qml:27: TypeError: Cannot read property 'smallSpacing' of null
Sep 27 08:51:36 andy-manjaro sddm-greeter[1032]: file:///usr/share/sddm/themes/Northern-Lights-16-SDDM/Main.qml:158: TypeError: Cannot read property 'gridUnit' of null
Sep 27 08:51:36 andy-manjaro sddm-greeter[1032]: file:///usr/share/sddm/themes/Northern-Lights-16-SDDM/components/ActionButton.qml:102: TypeError: Cannot read property 'smallSpacing' of null
Sep 27 08:51:36 andy-manjaro sddm-greeter[1032]: file:///usr/share/sddm/themes/Northern-Lights-16-SDDM/components/ActionButton.qml:39: TypeError: Cannot read property 'gridUnit' of null
Sep 27 08:51:36 andy-manjaro sddm-greeter[1032]: file:///usr/share/sddm/themes/Northern-Lights-16-SDDM/components/ActionButton.qml:55: TypeError: Cannot read property 'smallSpacing' of null
Sep 27 08:51:36 andy-manjaro sddm-greeter[1032]: file:///usr/share/sddm/themes/Northern-Lights-16-SDDM/components/ActionButton.qml:41: TypeError: Cannot read property 'largeSpacing' of null
Sep 27 08:51:36 andy-manjaro sddm-greeter[1032]: file:///usr/share/sddm/themes/Northern-Lights-16-SDDM/components/ActionButton.qml:42: TypeError: Cannot read property 'smallSpacing' of null
Sep 27 08:51:36 andy-manjaro sddm-greeter[1032]: file:///usr/share/sddm/themes/Northern-Lights-16-SDDM/Login.qml:120: TypeError: Cannot read property 'smallSpacing' of null
Sep 27 08:51:36 andy-manjaro sddm-greeter[1032]: file:///usr/share/sddm/themes/Northern-Lights-16-SDDM/Login.qml:115: TypeError: Cannot read property 'smallSpacing' of null
Sep 27 08:51:36 andy-manjaro sddm-greeter[1032]: file:///usr/share/sddm/themes/Northern-Lights-16-SDDM/components/SessionManagementScreen.qml:84: TypeError: Cannot read property 'gridUnit' of null
Sep 27 08:51:36 andy-manjaro sddm-greeter[1032]: file:///usr/share/sddm/themes/Northern-Lights-16-SDDM/components/SessionManagementScreen.qml:114: TypeError: Cannot read property 'largeSpacing' of null
Sep 27 08:51:36 andy-manjaro sddm-greeter[1032]: file:///usr/share/sddm/themes/Northern-Lights-16-SDDM/components/SessionManagementScreen.qml:100: TypeError: Cannot read property 'gridUnit' of null
Sep 27 08:51:36 andy-manjaro sddm-greeter[1032]: file:///usr/share/sddm/themes/Northern-Lights-16-SDDM/components/SessionManagementScreen.qml:101: TypeError: Cannot read property 'gridUnit' of null
Sep 27 08:51:36 andy-manjaro sddm-greeter[1032]: file:///usr/share/sddm/themes/Northern-Lights-16-SDDM/components/SessionManagementScreen.qml:91: TypeError: Cannot read property 'gridUnit' of null
Sep 27 08:51:36 andy-manjaro sddm-greeter[1032]: file:///usr/share/sddm/themes/Northern-Lights-16-SDDM/components/UserList.qml:25: TypeError: Cannot read property 'gridUnit' of null
Sep 27 08:51:36 andy-manjaro sddm-greeter[1032]: file:///usr/share/sddm/themes/Northern-Lights-16-SDDM/components/UserList.qml:26: TypeError: Cannot read property 'gridUnit' of null
Sep 27 08:51:36 andy-manjaro sddm-greeter[1032]: file:///usr/share/sddm/themes/Northern-Lights-16-SDDM/components/UserDelegate.qml:103: TypeError: Cannot read property 'largeSpacing' of null
Sep 27 08:51:36 andy-manjaro sddm-greeter[1032]: file:///usr/share/sddm/themes/Northern-Lights-16-SDDM/components/UserDelegate.qml:44: TypeError: Cannot read property 'smallSpacing' of null
Sep 27 08:51:36 andy-manjaro sddm-greeter[1032]: file:///usr/share/sddm/themes/Northern-Lights-16-SDDM/components/UserDelegate.qml:69: TypeError: Cannot read property 'largeSpacing' of null
Sep 27 08:51:36 andy-manjaro sddm-greeter[1032]: file:///usr/share/sddm/themes/Northern-Lights-16-SDDM/components/UserDelegate.qml:95: TypeError: Cannot read property 'gridUnit' of null
Sep 27 08:51:36 andy-manjaro sddm-greeter[1032]: file:///usr/share/sddm/themes/Northern-Lights-16-SDDM/components/UserDelegate.qml:75: TypeError: Cannot read property 'longDuration' of null
Sep 27 08:51:36 andy-manjaro sddm-greeter[1032]: file:///usr/share/sddm/themes/Northern-Lights-16-SDDM/components/UserDelegate.qml:50: TypeError: Cannot read property 'longDuration' of null
Sep 27 08:51:36 andy-manjaro sddm-greeter[1032]: file:///usr/share/sddm/themes/Northern-Lights-16-SDDM/components/UserDelegate.qml:78: TypeError: Cannot read property 'largeSpacing' of null
Sep 27 08:51:36 andy-manjaro sddm-greeter[1032]: file:///usr/share/sddm/themes/Northern-Lights-16-SDDM/Main.qml:239: TypeError: Cannot read property 'longDuration' of null
Sep 27 08:51:36 andy-manjaro sddm-greeter[1032]: file:///usr/share/sddm/themes/Northern-Lights-16-SDDM/Main.qml:425: TypeError: Cannot read property 'longDuration' of null
Sep 27 08:51:36 andy-manjaro systemd-xdg-autostart-generator[1302]: Configuration file /home/andy/.config/autostart/org.kde.kontact.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Sep 27 08:51:36 andy-manjaro systemd-xdg-autostart-generator[1302]: Configuration file /home/andy/.config/autostart/org.kde.yakuake.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Sep 27 08:51:36 andy-manjaro systemd-xdg-autostart-generator[1302]: Configuration file /home/andy/.config/autostart/overgrive-autostart.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Sep 27 08:51:36 andy-manjaro systemd-xdg-autostart-generator[1302]: /home/andy/.config/autostart/overgrive-autostart.desktop: not generating unit, error parsing Exec= line: No such file or directory
Sep 27 08:51:37 andy-manjaro systemd-xdg-autostart-generator[1345]: Configuration file /home/andy/.config/autostart/org.kde.kontact.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Sep 27 08:51:37 andy-manjaro systemd-xdg-autostart-generator[1345]: Configuration file /home/andy/.config/autostart/org.kde.yakuake.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Sep 27 08:51:37 andy-manjaro systemd-xdg-autostart-generator[1345]: Configuration file /home/andy/.config/autostart/overgrive-autostart.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
Sep 27 08:51:37 andy-manjaro systemd-xdg-autostart-generator[1345]: /home/andy/.config/autostart/overgrive-autostart.desktop: not generating unit, error parsing Exec= line: No such file or directory
Sep 27 08:51:37 andy-manjaro systemd[1296]: /run/user/1000/systemd/generator.late/app-session_start_batch.sh@autostart.service:18: WorkingDirectory= path is not absolute, ignoring:
Sep 27 08:51:37 andy-manjaro systemd[1296]: /run/user/1000/systemd/generator.late/app-run_wip.sh@autostart.service:18: WorkingDirectory= path is not absolute, ignoring:
Sep 27 08:51:37 andy-manjaro systemd[1296]: /run/user/1000/systemd/generator.late/app-org.kde.kontact@autostart.service:18: WorkingDirectory= path is not absolute, ignoring:
Sep 27 08:51:37 andy-manjaro systemd[1296]: /run/user/1000/systemd/generator.late/app-logon_sound_0.sh@autostart.service:18: WorkingDirectory= path is not absolute, ignoring:
Sep 27 08:51:38 andy-manjaro ksmserver[1386]: Qt: Session management error: networkIdsList argument is NULL
Sep 27 08:51:38 andy-manjaro kglobalaccel5[1427]: kf.globalaccel.kglobalacceld: No desktop file found for service ".desktop"
Sep 27 08:51:38 andy-manjaro kwin_x11[1389]: kwin_xkbcommon: XKB: inet:323:58: unrecognized keysym "XF86EmojiPicker"
Sep 27 08:51:38 andy-manjaro kwin_x11[1389]: kwin_xkbcommon: XKB: inet:324:58: unrecognized keysym "XF86Dictate"
Sep 27 08:51:38 andy-manjaro ksmserver[1386]: QDBusConnection: name 'org.kde.kglobalaccel' had owner '' but we thought it was ':1.13'
Sep 27 08:51:38 andy-manjaro plasmashell[1444]: Checking screens: available: (QScreen(0x556a503034c0, name="DP-1")) redundant: QHash() fake: QSet() all: (QScreen(0x556a503034c0, name="DP-1"))
Sep 27 08:51:38 andy-manjaro backlighthelper[1556]: org.kde.powerdevil: no kernel backlight interface found
Sep 27 08:51:38 andy-manjaro org_kde_powerdevil[1489]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Sep 27 08:51:38 andy-manjaro plasmashell[1444]: Aborting shell load: The activity manager daemon (kactivitymanagerd) is not running.
Sep 27 08:51:38 andy-manjaro plasmashell[1444]: If this Plasma has been installed into a custom prefix, verify that its D-Bus services dir is known to the system for the daemon to be activatable.
Sep 27 08:51:38 andy-manjaro org_kde_powerdevil[1489]: org.kde.powerdevil: org.kde.powerdevil.backlighthelper.brightness failed
Sep 27 08:51:39 andy-manjaro kded5[1388]: kf.coreaddons: "Could not load plugin from apperd: The shared library was not found."
Sep 27 08:51:39 andy-manjaro kded5[1388]: kf.kded: found kded module "apperd" by prepending 'kded_' to the library path, please fix your metadata.
Sep 27 08:51:39 andy-manjaro plasmashell[1444]: file:///usr/lib/qt/qml/org/kde/kirigami.2/templates/InlineMessage.qml:265:13: QML SelectableLabel: Binding loop detected for property "implicitWidth"
Sep 27 08:51:39 andy-manjaro plasmashell[1444]: org.kde.plasma.containmentlayoutmanager: Error: cannot change the containment to AppletsLayout
Sep 27 08:51:40 andy-manjaro plasmashell[1444]: org.kde.plasma.kicker: DragHelper is deprecated and will be removed in Plasma 6. Use Qt Quick Drag instead.
Sep 27 08:51:40 andy-manjaro plasmashell[1444]: org.kde.plasma.kicker: Kicker.WindowSystem is deprecated and will be removed in Plasma 6. Use KWindowSystem/KX11Extras instead.
Sep 27 08:51:40 andy-manjaro plasmashell[1444]: org.kde.plasma.kicker: DashboardWindow is deprecated and will be removed in Plasma 6. Use Qt Quick Window instead.
Sep 27 08:51:41 andy-manjaro pulseaudio[1608]: stat('/etc/pulse/default.pa.d'): No such file or directory
Sep 27 08:51:43 andy-manjaro systemd[1296]: plasma-powerdevil.service: start operation timed out. Terminating.
Sep 27 08:51:43 andy-manjaro systemd[1296]: plasma-powerdevil.service: Failed with result 'timeout'.
Sep 27 08:51:43 andy-manjaro systemd[1296]: Failed to start Powerdevil.
Sep 27 08:51:44 andy-manjaro kwin_x11[1389]: kf.config.core: "\"fsrestore1\" - conversion of \"0,0,0,0\" to QRect failed"
Sep 27 08:51:44 andy-manjaro kwin_x11[1389]: kf.config.core: "\"fsrestore2\" - conversion of \"0,0,0,0\" to QRect failed"
Sep 27 08:51:44 andy-manjaro kwin_x11[1389]: kf.config.core: "\"fsrestore3\" - conversion of \"0,0,0,0\" to QRect failed"
Sep 27 08:51:44 andy-manjaro kwin_x11[1389]: kf.config.core: "\"fsrestore4\" - conversion of \"0,0,0,0\" to QRect failed"
Sep 27 08:51:44 andy-manjaro kwin_x11[1389]: kf.config.core: "\"fsrestore5\" - conversion of \"0,0,0,0\" to QRect failed"
Sep 27 08:51:44 andy-manjaro kwin_x11[1389]: kf.config.core: "\"restore6\" - conversion of \"0,0,0,0\" to QRect failed"
Sep 27 08:51:44 andy-manjaro kwin_x11[1389]: kf.config.core: "\"fsrestore6\" - conversion of \"0,0,0,0\" to QRect failed"
Sep 27 08:51:44 andy-manjaro kwin_x11[1389]: kf.config.core: "\"fsrestore7\" - conversion of \"0,0,0,0\" to QRect failed"
Sep 27 08:51:44 andy-manjaro kwin_x11[1389]: kf.config.core: "\"fsrestore8\" - conversion of \"0,0,0,0\" to QRect failed"
Sep 27 08:51:44 andy-manjaro kwin_x11[1389]: kf.config.core: "\"fsrestore9\" - conversion of \"0,0,0,0\" to QRect failed"
Sep 27 08:51:44 andy-manjaro kwin_x11[1389]: kf.config.core: "\"fsrestore10\" - conversion of \"0,0,0,0\" to QRect failed"
Sep 27 08:51:44 andy-manjaro kwin_x11[1389]: kf.config.core: "\"fsrestore11\" - conversion of \"0,0,0,0\" to QRect failed"
Sep 27 08:51:44 andy-manjaro kwin_x11[1389]: kf.config.core: "\"fsrestore12\" - conversion of \"0,0,0,0\" to QRect failed"
Sep 27 08:51:44 andy-manjaro kwin_x11[1389]: kf.config.core: "\"fsrestore13\" - conversion of \"0,0,0,0\" to QRect failed"
Sep 27 08:51:44 andy-manjaro kwin_x11[1389]: kf.config.core: "\"fsrestore14\" - conversion of \"0,0,0,0\" to QRect failed"
Sep 27 08:51:44 andy-manjaro kwin_x11[1389]: kf.config.core: "\"restore15\" - conversion of \"0,0,0,0\" to QRect failed"
Sep 27 08:51:44 andy-manjaro kwin_x11[1389]: kf.config.core: "\"fsrestore15\" - conversion of \"0,0,0,0\" to QRect failed"
Sep 27 08:51:44 andy-manjaro kwin_x11[1389]: kwin_core: XCB error: 152 (BadDamage), sequence: 3421, resource id: 16777253, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Sep 27 08:51:44 andy-manjaro kmixctrl[1722]: org.kde.kmix: no mix devices and not dynamic
Sep 27 08:51:44 andy-manjaro org_kde_powerdevil[1697]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Sep 27 08:51:44 andy-manjaro org_kde_powerdevil[1697]: org.kde.powerdevil: org.kde.powerdevil.backlighthelper.brightness failed
Sep 27 08:51:44 andy-manjaro kmix[1708]: org.kde.kmix: no mix devices and not dynamic
Sep 27 08:51:44 andy-manjaro kmix[1708]: org.kde.kmix: Cannot load profile "PulseAudio.Playback_Devices.1.default"
Sep 27 08:51:44 andy-manjaro kmix[1708]: org.kde.kmix: No such icon "audio-card-pci"
Sep 27 08:51:44 andy-manjaro kmix[1708]: org.kde.kmix: Cannot load profile "PulseAudio.Capture_Devices.1.default"
Sep 27 08:51:44 andy-manjaro kmix[1708]: org.kde.kmix: No such icon "camera-web-usb"
Sep 27 08:51:44 andy-manjaro kmix[1708]: org.kde.kmix: Cannot load profile "PulseAudio.Playback_Streams.1.default"
Sep 27 08:51:44 andy-manjaro kmix[1708]: org.kde.kmix: Cannot load profile "PulseAudio.Capture_Streams.1.default"
Sep 27 08:51:44 andy-manjaro akonadi_control[1898]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Sep 27 08:51:45 andy-manjaro python[1661]: libpng warning: iCCP: known incorrect sRGB profile
Sep 27 08:51:45 andy-manjaro pcloud[1647]: Theme parsing error: gtk.css:73:46: The style property GtkScrolledWindow:scrollbars-within-bevel is deprecated and shouldn't be used anymore. It will be removed in a future version
Sep 27 08:51:45 andy-manjaro kernel: kauditd_printk_skb: 69 callbacks suppressed
Sep 27 08:51:45 andy-manjaro kwin_x11[1389]: Module 'org.kde.kwin.decoration' does not contain a module identifier directive - it cannot be protected from external registrations.
Sep 27 08:51:46 andy-manjaro akonadiserver[1941]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
Sep 27 08:51:49 andy-manjaro systemd[1296]: plasma-powerdevil.service: start operation timed out. Terminating.
Sep 27 08:51:49 andy-manjaro systemd[1296]: plasma-powerdevil.service: Failed with result 'timeout'.
Sep 27 08:51:49 andy-manjaro systemd[1296]: Failed to start Powerdevil.
Sep 27 08:51:49 andy-manjaro org_kde_powerdevil[2891]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Sep 27 08:51:49 andy-manjaro org_kde_powerdevil[2891]: org.kde.powerdevil: org.kde.powerdevil.backlighthelper.brightness failed
Sep 27 08:51:54 andy-manjaro systemd[1296]: plasma-powerdevil.service: start operation timed out. Terminating.
Sep 27 08:51:54 andy-manjaro systemd[1296]: plasma-powerdevil.service: Failed with result 'timeout'.
Sep 27 08:51:54 andy-manjaro systemd[1296]: Failed to start Powerdevil.
Sep 27 08:51:54 andy-manjaro org_kde_powerdevil[3215]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Sep 27 08:51:54 andy-manjaro org_kde_powerdevil[3215]: org.kde.powerdevil: org.kde.powerdevil.backlighthelper.brightness failed
Sep 27 08:51:59 andy-manjaro systemd[1296]: plasma-powerdevil.service: start operation timed out. Terminating.
Sep 27 08:51:59 andy-manjaro systemd[1296]: plasma-powerdevil.service: Failed with result 'timeout'.
Sep 27 08:51:59 andy-manjaro systemd[1296]: Failed to start Powerdevil.
Sep 27 08:52:00 andy-manjaro org_kde_powerdevil[3275]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Sep 27 08:52:00 andy-manjaro org_kde_powerdevil[3275]: org.kde.powerdevil: org.kde.powerdevil.backlighthelper.brightness failed
Sep 27 08:52:04 andy-manjaro org_kde_powerdevil[3275]: org.kde.powerdevil: Handle button events action could not check for screen configuration
Sep 27 08:52:04 andy-manjaro org_kde_powerdevil[3275]: org.kde.powerdevil: The profile "AC" tried to activate "DimDisplay" a non-existent action. This is usually due to an installation problem, a configuration problem, or because the action is not supported
Sep 27 08:52:04 andy-manjaro org_kde_powerdevil[3275]: org.kde.powerdevil: org.kde.powerdevil.chargethresholdhelper.getthreshold failed "Charge thresholds are not supported by the kernel for this hardware"
Sep 27 08:52:05 andy-manjaro kioslave5[1601]: QObject::connect: No such slot DesktopProtocol::_k_slotRedirection(KIO::Job *, QUrl)
Sep 27 08:52:05 andy-manjaro plasmashell[1444]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
Sep 27 08:52:06 andy-manjaro pulseaudio[1608]: GetManagedObjects() failed: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
Sep 27 08:52:09 andy-manjaro msm_kde_notifier[1696]: kf.notifications: env says KDE is running but SNI unavailable -- check KDE_FULL_SESSION and XDG_CURRENT_DESKTOP
Sep 27 08:52:09 andy-manjaro yakuake[1644]: kf.notifications: env says KDE is running but SNI unavailable -- check KDE_FULL_SESSION and XDG_CURRENT_DESKTOP
Sep 27 08:52:09 andy-manjaro kdeconnectd[1640]: kdeconnect.core: Could not query capabilities from notifications server
Sep 27 08:52:10 andy-manjaro kteatime[1991]: kf.notifications: env says KDE is running but SNI unavailable -- check KDE_FULL_SESSION and XDG_CURRENT_DESKTOP
Sep 27 08:52:14 andy-manjaro kontact[1643]: kf.notifications: env says KDE is running but SNI unavailable -- check KDE_FULL_SESSION and XDG_CURRENT_DESKTOP
Sep 27 08:52:27 andy-manjaro kwin_x11[1389]: qml: PlasmaExtras.ScrollArea is deprecated. Use PlasmaComponents3.ScrollView instead.
Sep 27 08:52:29 andy-manjaro kded5[1388]: kf.solid.backends.udisks2: Failed enumerating UDisks2 objects: "org.freedesktop.DBus.Error.TimedOut"
"Failed to activate service 'org.freedesktop.UDisks2': timed out (service_start_timeout=25000ms)"
Sep 27 08:52:29 andy-manjaro plasmashell[1444]: kf.solid.backends.udisks2: Failed enumerating UDisks2 objects: "org.freedesktop.DBus.Error.TimedOut"
Sep 27 08:52:29 andy-manjaro kate[2039]: kf.solid.backends.udisks2: Failed enumerating UDisks2 objects: "org.freedesktop.DBus.Error.TimedOut"
Sep 27 08:52:29 andy-manjaro dolphin[2818]: kf.solid.backends.udisks2: Failed enumerating UDisks2 objects: "org.freedesktop.DBus.Error.TimedOut"
Sep 27 08:52:29 andy-manjaro systemd[1]: mnt-ext\x2ddrive\x2d0.mount: Mounting timed out. Terminating.
Sep 27 08:52:34 andy-manjaro systemd[1]: udisks2.service: start operation timed out. Terminating.
Sep 27 08:52:35 andy-manjaro kmix[1708]: kf.notifications: env says KDE is running but SNI unavailable -- check KDE_FULL_SESSION and XDG_CURRENT_DESKTOP
Sep 27 08:52:35 andy-manjaro kmix[1708]: org.kde.kmix: No such icon "audio-card-pci"
Sep 27 08:52:35 andy-manjaro kmix[1708]: org.kde.kmix: No such icon "camera-web-usb"
Sep 27 08:52:41 andy-manjaro xembedsniproxy[1491]: kde.xembedsniproxy: could not register SNI: "Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken."
Sep 27 08:52:49 andy-manjaro kwin_x11[1389]: kwin_core: XCB error: 152 (BadDamage), sequence: 24863, resource id: 16779492, major code: 143 (DAMAGE), minor code: 3 (Subtract)
Sep 27 08:52:51 andy-manjaro NetworkManager[685]: <warn> [1695801171.1103] platform-linux: do-add-ip6-address[2: fe80::642f:3ba8:98b3:8e52]: failure 13 (Permission denied)
Sep 27 08:52:51 andy-manjaro NetworkManager[685]: <warn> [1695801171.1108] l3cfg[c87dd25ded75e854,ifindex=2]: unable to configure IPv6 route: type unicast fe80::/64 dev 2 metric 1024 mss 0 rt-src ipv6ll
Sep 27 08:52:53 andy-manjaro NetworkManager[685]: <warn> [1695801173.1064] platform-linux: do-add-ip6-address[2: fe80::7ef:a55b:ded5:16e2]: failure 13 (Permission denied)
Sep 27 08:52:54 andy-manjaro kded5[1388]: kf.solid.backends.udisks2: Failed enumerating UDisks2 objects: "org.freedesktop.DBus.Error.TimedOut"
Sep 27 08:52:54 andy-manjaro kate[2039]: kf.solid.backends.udisks2: Failed enumerating UDisks2 objects: "org.freedesktop.DBus.Error.TimedOut"
Sep 27 08:52:54 andy-manjaro dolphin[2818]: kf.solid.backends.udisks2: Failed enumerating UDisks2 objects: "org.freedesktop.DBus.Error.TimedOut"
Sep 27 08:52:54 andy-manjaro plasmashell[1444]: kf.solid.backends.udisks2: Failed enumerating UDisks2 objects: "org.freedesktop.DBus.Error.TimedOut"
Sep 27 08:52:54 andy-manjaro kded5[1388]: kf.coreaddons: "Could not load plugin from /usr/lib/qt/plugins/plasma/geolocationprovider/plasma-geolocation-gps.so: Cannot load library /usr/lib/qt/plugins/plasma/geolocationprovider/plasma-geolocation-gps.so: (libgps.so.30: cannot open shared object file: No such file or directory)"
Sep 27 08:52:54 andy-manjaro kded5[1388]: kf.networkmanagerqt: void NetworkManager::ConnectionPrivate::onPropertiesChanged(const QVariantMap&) Unhandled property "VersionId"
Sep 27 08:52:54 andy-manjaro kded5[1388]: QDBusAbstractAdaptor: Cannot relay signal KDEDModule::moduleDeleted(KDEDModule*): Pointers are not supported: KDEDModule*
Sep 27 08:52:55 andy-manjaro NetworkManager[685]: <warn> [1695801175.1079] platform-linux: do-add-ip6-address[2: fe80::e334:53e8:b3d6:c2d5]: failure 13 (Permission denied)
Sep 27 08:52:57 andy-manjaro NetworkManager[685]: <warn> [1695801177.1079] platform-linux: do-add-ip6-address[2: fe80::d873:12d5:f433:8025]: failure 13 (Permission denied)
Sep 27 08:52:59 andy-manjaro NetworkManager[685]: <warn> [1695801179.1093] platform-linux: do-add-ip6-address[2: fe80::dd95:8c84:23e6:f9f9]: failure 13 (Permission denied)
Sep 27 08:52:59 andy-manjaro kmix[1708]: org.kde.kmix: No such icon "audio-card-pci"
Sep 27 08:52:59 andy-manjaro kmix[1708]: org.kde.kmix: No such icon "camera-web-usb"
Sep 27 08:53:01 andy-manjaro NetworkManager[685]: <warn> [1695801181.1109] platform-linux: do-add-ip6-address[2: fe80::b912:66fa:3448:12e7]: failure 13 (Permission denied)
Sep 27 08:53:03 andy-manjaro NetworkManager[685]: <warn> [1695801183.1132] ipv6ll[631369ad7e314811,ifindex=2]: changed: no IPv6 link local address to retry after Duplicate Address Detection failures (back off)
Sep 27 08:53:07 andy-manjaro NetworkManager[685]: <warn> [1695801187.0467] ndisc[0x55f6155df7c0,"enp6s0"]: solicit: failure sending router solicitation: Cannot assign requested address (99)
Sep 27 08:53:13 andy-manjaro NetworkManager[685]: <warn> [1695801193.1177] platform-linux: do-add-ip6-address[2: fe80::642f:3ba8:98b3:8e52]: failure 13 (Permission denied)
Sep 27 08:53:13 andy-manjaro NetworkManager[685]: <warn> [1695801193.1178] l3cfg[c87dd25ded75e854,ifindex=2]: unable to configure IPv6 route: type unicast fe80::/64 dev 2 metric 1024 mss 0 rt-src ipv6ll
Sep 27 08:53:15 andy-manjaro NetworkManager[685]: <warn> [1695801195.1202] platform-linux: do-add-ip6-address[2: fe80::7ef:a55b:ded5:16e2]: failure 13 (Permission denied)
Sep 27 08:53:17 andy-manjaro NetworkManager[685]: <warn> [1695801197.1209] platform-linux: do-add-ip6-address[2: fe80::e334:53e8:b3d6:c2d5]: failure 13 (Permission denied)
Sep 27 08:53:19 andy-manjaro dolphin[2818]: kf.solid.backends.udisks2: Failed enumerating UDisks2 objects: "org.freedesktop.DBus.Error.TimedOut"
Sep 27 08:53:19 andy-manjaro plasmashell[1444]: kf.solid.backends.udisks2: Failed enumerating UDisks2 objects: "org.freedesktop.DBus.Error.TimedOut"
Sep 27 08:53:19 andy-manjaro kate[2039]: kf.solid.backends.udisks2: Failed enumerating UDisks2 objects: "org.freedesktop.DBus.Error.TimedOut"
Sep 27 08:53:19 andy-manjaro NetworkManager[685]: <warn> [1695801199.1233] platform-linux: do-add-ip6-address[2: fe80::d873:12d5:f433:8025]: failure 13 (Permission denied)
Sep 27 08:53:21 andy-manjaro NetworkManager[685]: <warn> [1695801201.1241] platform-linux: do-add-ip6-address[2: fe80::dd95:8c84:23e6:f9f9]: failure 13 (Permission denied)
Sep 27 08:53:23 andy-manjaro NetworkManager[685]: <warn> [1695801203.1250] platform-linux: do-add-ip6-address[2: fe80::b912:66fa:3448:12e7]: failure 13 (Permission denied)
Sep 27 08:53:25 andy-manjaro NetworkManager[685]: <warn> [1695801205.1272] ipv6ll[631369ad7e314811,ifindex=2]: changed: no IPv6 link local address to retry after Duplicate Address Detection failures (back off)
Sep 27 08:53:35 andy-manjaro NetworkManager[685]: <warn> [1695801215.1309] platform-linux: do-add-ip6-address[2: fe80::642f:3ba8:98b3:8e52]: failure 13 (Permission denied)
Sep 27 08:53:35 andy-manjaro NetworkManager[685]: <warn> [1695801215.1310] l3cfg[c87dd25ded75e854,ifindex=2]: unable to configure IPv6 route: type unicast fe80::/64 dev 2 metric 1024 mss 0 rt-src ipv6ll
Sep 27 08:53:37 andy-manjaro NetworkManager[685]: <warn> [1695801217.1336] platform-linux: do-add-ip6-address[2: fe80::7ef:a55b:ded5:16e2]: failure 13 (Permission denied)
Sep 27 08:53:39 andy-manjaro NetworkManager[685]: <warn> [1695801219.1364] platform-linux: do-add-ip6-address[2: fe80::e334:53e8:b3d6:c2d5]: failure 13 (Permission denied)
Sep 27 08:53:41 andy-manjaro NetworkManager[685]: <warn> [1695801221.1375] platform-linux: do-add-ip6-address[2: fe80::d873:12d5:f433:8025]: failure 13 (Permission denied)
Sep 27 08:53:43 andy-manjaro NetworkManager[685]: <warn> [1695801223.1402] platform-linux: do-add-ip6-address[2: fe80::dd95:8c84:23e6:f9f9]: failure 13 (Permission denied)
Sep 27 08:53:44 andy-manjaro kate[2039]: kf.solid.backends.udisks2: Failed enumerating UDisks2 objects: "org.freedesktop.DBus.Error.TimedOut"
Sep 27 08:53:44 andy-manjaro plasmashell[1444]: kf.solid.backends.udisks2: Failed enumerating UDisks2 objects: "org.freedesktop.DBus.Error.TimedOut"
Sep 27 08:53:44 andy-manjaro dolphin[2818]: kf.solid.backends.udisks2: Failed enumerating UDisks2 objects: "org.freedesktop.DBus.Error.TimedOut"
Sep 27 08:53:45 andy-manjaro NetworkManager[685]: <warn> [1695801225.1430] platform-linux: do-add-ip6-address[2: fe80::b912:66fa:3448:12e7]: failure 13 (Permission denied)
Sep 27 08:53:46 andy-manjaro nmbd[1097]: [2023/09/27 08:53:46.917277, 0] ../../source3/libsmb/nmblib.c:923(send_udp)
Sep 27 08:53:46 andy-manjaro nmbd[1097]: Packet send failed to 192.168.1.255(138) ERRNO=Operation not permitted
Sep 27 08:53:46 andy-manjaro nmbd[1097]: [2023/09/27 08:53:46.917707, 0] ../../source3/libsmb/nmblib.c:923(send_udp)
Sep 27 08:53:47 andy-manjaro NetworkManager[685]: <warn> [1695801227.1439] ipv6ll[631369ad7e314811,ifindex=2]: changed: no IPv6 link local address to retry after Duplicate Address Detection failures (back off)
Sep 27 08:53:57 andy-manjaro NetworkManager[685]: <warn> [1695801237.1453] platform-linux: do-add-ip6-address[2: fe80::642f:3ba8:98b3:8e52]: failure 13 (Permission denied)
Sep 27 08:53:57 andy-manjaro NetworkManager[685]: <warn> [1695801237.1455] l3cfg[c87dd25ded75e854,ifindex=2]: unable to configure IPv6 route: type unicast fe80::/64 dev 2 metric 1024 mss 0 rt-src ipv6ll
Sep 27 08:53:59 andy-manjaro NetworkManager[685]: <warn> [1695801239.1475] platform-linux: do-add-ip6-address[2: fe80::7ef:a55b:ded5:16e2]: failure 13 (Permission denied)
Sep 27 08:54:00 andy-manjaro systemd[1]: mnt-ext\x2ddrive\x2d0.mount: Mount process timed out. Killing.
Sep 27 08:54:01 andy-manjaro NetworkManager[685]: <warn> [1695801241.1502] platform-linux: do-add-ip6-address[2: fe80::e334:53e8:b3d6:c2d5]: failure 13 (Permission denied)
Sep 27 08:54:02 andy-manjaro systemd-udevd[379]: sdb: Worker [456] processing SEQNUM=2567 killed
Sep 27 08:54:03 andy-manjaro NetworkManager[685]: <warn> [1695801243.1527] platform-linux: do-add-ip6-address[2: fe80::d873:12d5:f433:8025]: failure 13 (Permission denied)
Sep 27 08:54:04 andy-manjaro systemd[1]: udisks2.service: State 'stop-sigterm' timed out. Killing.
Sep 27 08:54:05 andy-manjaro NetworkManager[685]: <warn> [1695801245.1542] platform-linux: do-add-ip6-address[2: fe80::dd95:8c84:23e6:f9f9]: failure 13 (Permission denied)
Sep 27 08:54:06 andy-manjaro systemd-coredump[3667]: Process 3556 (packagekitd) of user 0 dumped core.
Stack trace of thread 3556:
#0 0x00007f8d5188e83c n/a (libc.so.6 + 0x8e83c)
#1 0x00007f8d5183e668 raise (libc.so.6 + 0x3e668)
#2 0x00007f8d518264b8 abort (libc.so.6 + 0x264b8)
#3 0x00007f8d520890ee n/a (libglib-2.0.so.0 + 0x1e0ee)
#4 0x00007f8d520ea180 g_assertion_message_expr (libglib-2.0.so.0 + 0x7f180)
#5 0x00005606267cf7fe n/a (packagekitd + 0x277fe)
#6 0x00007f8d5202b7e3 g_object_unref (libgobject-2.0.so.0 + 0x227e3)
#7 0x00007f8d520485b1 g_value_unset (libgobject-2.0.so.0 + 0x3f5b1)
#8 0x00007f8d5203c4af n/a (libgobject-2.0.so.0 + 0x334af)
#9 0x00007f8d5203cc77 g_signal_emit_valist (libgobject-2.0.so.0 + 0x33c77)
#10 0x00007f8d5203cd34 g_signal_emit (libgobject-2.0.so.0 + 0x33d34)
#11 0x00005606267bbfdc pk_transaction_set_state (packagekitd + 0x13fdc)
#12 0x00005606267c45c8 n/a (packagekitd + 0x1c5c8)
#13 0x00007f8d51f33198 n/a (libgio-2.0.so.0 + 0x103198)
#14 0x00007f8d520c4f19 n/a (libglib-2.0.so.0 + 0x59f19)
#15 0x00007f8d521232b7 n/a (libglib-2.0.so.0 + 0xb82b7)
#16 0x00007f8d520c5b47 g_main_loop_run (libglib-2.0.so.0 + 0x5ab47)
#17 0x00005606267b6b85 main (packagekitd + 0xeb85)
#18 0x00007f8d51827cd0 n/a (libc.so.6 + 0x27cd0)
#19 0x00007f8d51827d8a __libc_start_main (libc.so.6 + 0x27d8a)
#20 0x00005606267b6e25 _start (packagekitd + 0xee25)
Stack trace of thread 3665:
#0 0x00007f8d51e73947 g_buffered_input_stream_fill (libgio-2.0.so.0 + 0x43947)
#1 0x00007f8d51e7cfe7 g_data_input_stream_read_line (libgio-2.0.so.0 + 0x4cfe7)
#2 0x00007f8d51453af8 n/a (libpk_backend_alpm.so + 0x8af8)
#3 0x00007f8d51453efd n/a (libpk_backend_alpm.so + 0x8efd)
#4 0x00007f8d51453efd n/a (libpk_backend_alpm.so + 0x8efd)
#5 0x00007f8d5145477b pk_alpm_configure (libpk_backend_alpm.so + 0x977b)
#6 0x00007f8d5145a5f2 n/a (libpk_backend_alpm.so + 0xf5f2)
#7 0x00005606267cf40e n/a (packagekitd + 0x2740e)
#8 0x00007f8d520f69a5 n/a (libglib-2.0.so.0 + 0x8b9a5)
#9 0x00007f8d5188c9eb n/a (libc.so.6 + 0x8c9eb)
#10 0x00007f8d51910dfc n/a (libc.so.6 + 0x110dfc)
Stack trace of thread 3558:
#0 0x00007f8d5190359f __poll (libc.so.6 + 0x10359f)
#1 0x00007f8d52123206 n/a (libglib-2.0.so.0 + 0xb8206)
#2 0x00007f8d520c3112 g_main_context_iteration (libglib-2.0.so.0 + 0x58112)
#3 0x00007f8d520c3162 n/a (libglib-2.0.so.0 + 0x58162)
#4 0x00007f8d520f69a5 n/a (libglib-2.0.so.0 + 0x8b9a5)
#5 0x00007f8d5188c9eb n/a (libc.so.6 + 0x8c9eb)
#6 0x00007f8d51910dfc n/a (libc.so.6 + 0x110dfc)
Stack trace of thread 3557:
#0 0x00007f8d5190ed6d syscall (libc.so.6 + 0x10ed6d)
#1 0x00007f8d5211e247 g_cond_wait (libglib-2.0.so.0 + 0xb3247)
#2 0x00007f8d520901b4 n/a (libglib-2.0.so.0 + 0x251b4)
#3 0x00007f8d520f8a2e n/a (libglib-2.0.so.0 + 0x8da2e)
Stack trace of thread 3559:
#2 0x00007f8d520c5b47 g_main_loop_run (libglib-2.0.so.0 + 0x5ab47)
#3 0x00007f8d51f420bc n/a (libgio-2.0.so.0 + 0x1120bc)
Stack trace of thread 3664:
#1 0x00007f8d5211ec23 g_cond_wait_until (libglib-2.0.so.0 + 0xb3c23)
#2 0x00007f8d52090185 n/a (libglib-2.0.so.0 + 0x25185)
#3 0x00007f8d520f94db n/a (libglib-2.0.so.0 + 0x8e4db)
Sep 27 08:54:06 andy-manjaro systemd[1]: packagekit.service: Main process exited, code=dumped, status=6/ABRT
Sep 27 08:54:06 andy-manjaro systemd[1]: packagekit.service: Failed with result 'core-dump'.
dmesg --level emerg,alert,crit,err,warn output
# dmesg --level emerg,alert,crit,err,warn
[ 0.087721] x86/cpu: SGX disabled by BIOS.
[ 3.594269] resource sanity check: requesting [mem 0xfdffe800-0xfe0007ff], which spans more than pnp 00:08 [mem 0xfdb00000-0xfdffffff]
[ 3.594271] caller pmc_core_probe+0xb7/0x6b0 mapping multiple BARs
[ 3.904945] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.PRT3._GTF.DSSP], AE_NOT_FOUND (20220331/psargs-330)
[ 3.904972] ACPI Error: Aborting method \_SB.PCI0.SAT0.PRT3._GTF due to previous error (AE_NOT_FOUND) (20220331/psparse-529)
[ 3.905107] ata4.00: supports DRM functions and may not be fully accessible
[ 3.905787] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.PRT2._GTF.DSSP], AE_NOT_FOUND (20220331/psargs-330)
[ 3.905815] ACPI Error: Aborting method \_SB.PCI0.SAT0.PRT2._GTF due to previous error (AE_NOT_FOUND) (20220331/psparse-529)
[ 3.907415] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.PRT2._GTF.DSSP], AE_NOT_FOUND (20220331/psargs-330)
[ 3.907443] ACPI Error: Aborting method \_SB.PCI0.SAT0.PRT2._GTF due to previous error (AE_NOT_FOUND) (20220331/psparse-529)
[ 3.909147] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.SAT0.PRT3._GTF.DSSP], AE_NOT_FOUND (20220331/psargs-330)
[ 3.909174] ACPI Error: Aborting method \_SB.PCI0.SAT0.PRT3._GTF due to previous error (AE_NOT_FOUND) (20220331/psparse-529)
[ 3.909297] ata4.00: supports DRM functions and may not be fully accessible
[ 7.329632] critical target error, dev sdb, sector 276793011827072 op 0x0:(READ) flags 0x80700 phys_seg 1 prio class 2
[ 7.330060] critical target error, dev sdb, sector 276793011827072 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 2
[ 7.330062] Buffer I/O error on dev sdb, logical block 276793011827072, async page read
[ 7.330639] critical target error, dev sdb, sector 276793011827073 op 0x0:(READ) flags 0x0 phys_seg 7 prio class 2
[ 7.330641] Buffer I/O error on dev sdb, logical block 276793011827073, async page read
[ 7.330643] Buffer I/O error on dev sdb, logical block 276793011827074, async page read
[ 7.330644] Buffer I/O error on dev sdb, logical block 276793011827075, async page read
[ 7.330644] Buffer I/O error on dev sdb, logical block 276793011827076, async page read
[ 7.330645] Buffer I/O error on dev sdb, logical block 276793011827077, async page read
[ 7.330646] Buffer I/O error on dev sdb, logical block 276793011827078, async page read
[ 7.330647] Buffer I/O error on dev sdb, logical block 276793011827079, async page read
[ 7.504878] r8169 0000:06:00.0: can't disable ASPM; OS doesn't have ASPM control
[ 53.140154] kauditd_printk_skb: 69 callbacks suppressed
[ 245.474537] INFO: task mount:585 blocked for more than 122 seconds.
[ 245.474549] Not tainted 6.1.53-1-MANJARO #1
[ 245.474554] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 245.475386] INFO: task udisksd:1046 blocked for more than 122 seconds.
[ 245.475392] Not tainted 6.1.53-1-MANJARO #1
[ 245.475396] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 367.679651] sd 6:0:0:0: [sdb] tag#0 timing out command, waited 360s
[ 367.679704] I/O error, dev sdb, sector 7479296 op 0x1:(WRITE) flags 0x800 phys_seg 1 prio class 2
[ 367.679718] Buffer I/O error on dev sdb1, logical block 0, lost sync page write
[ 367.679790] EXT4-fs (sdb1): I/O error while writing superblock
[ 367.679822] EXT4-fs (sdb1): mount failed
[ 368.354777] INFO: task (udev-worker):467 blocked for more than 122 seconds.
[ 368.354789] Not tainted 6.1.53-1-MANJARO #1
[ 368.354794] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 368.355284] INFO: task (udev-worker):468 blocked for more than 122 seconds.
[ 368.355289] Not tainted 6.1.53-1-MANJARO #1
[ 368.355293] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 732.596874] sd 6:0:0:0: [sdb] tag#0 timing out command, waited 360s
[ 732.596925] I/O error, dev sdb, sector 0 op 0x1:(WRITE) flags 0x800 phys_seg 0 prio class 2
[ 1109.498708] sd 6:0:0:0: [sdb] tag#0 timing out command, waited 360s
[ 1109.498755] I/O error, dev sdb, sector 0 op 0x1:(WRITE) flags 0x800 phys_seg 0 prio class 2
[ 4199.200940] sd 6:0:0:0: [sdb] tag#0 timing out command, waited 360s
[ 4199.200997] I/O error, dev sdb, sector 0 op 0x1:(WRITE) flags 0x800 phys_seg 0 prio class 2
[ 5860.818175] sd 6:0:0:0: [sdb] tag#0 timing out command, waited 360s
[ 5860.818225] I/O error, dev sdb, sector 0 op 0x1:(WRITE) flags 0x800 phys_seg 0 prio class 2
[ 9806.859001] sd 6:0:0:0: [sdb] tag#0 timing out command, waited 360s
[ 9806.859049] I/O error, dev sdb, sector 0 op 0x1:(WRITE) flags 0x800 phys_seg 0 prio class 2
[10499.848822] sd 6:0:0:0: [sdb] tag#0 timing out command, waited 360s
[10499.848871] I/O error, dev sdb, sector 0 op 0x1:(WRITE) flags 0x800 phys_seg 0 prio class 2
[10733.835798] Freezing of tasks failed after 20.005 seconds (1 tasks refusing to freeze, wq_busy=0):
[10753.951990] Freezing of tasks failed after 20.000 seconds (1 tasks refusing to freeze, wq_busy=0):
[10874.887676] sd 6:0:0:0: [sdb] tag#0 timing out command, waited 360s
[10874.887725] I/O error, dev sdb, sector 0 op 0x1:(WRITE) flags 0x800 phys_seg 0 prio class 2
[13368.990891] sd 6:0:0:0: [sdb] tag#0 timing out command, waited 360s
[13368.990939] I/O error, dev sdb, sector 0 op 0x1:(WRITE) flags 0x800 phys_seg 0 prio class 2
[14029.863219] sd 6:0:0:0: [sdb] tag#0 timing out command, waited 360s
[14029.863253] I/O error, dev sdb, sector 0 op 0x1:(WRITE) flags 0x800 phys_seg 0 prio class 2
[17268.315295] sd 6:0:0:0: [sdb] tag#0 timing out command, waited 360s
[17268.315343] I/O error, dev sdb, sector 0 op 0x1:(WRITE) flags 0x800 phys_seg 0 prio class 2
[18744.655809] sd 6:0:0:0: [sdb] tag#0 timing out command, waited 360s
[18744.655857] I/O error, dev sdb, sector 0 op 0x1:(WRITE) flags 0x800 phys_seg 0 prio class 2
[19252.287559] sd 6:0:0:0: [sdb] tag#0 timing out command, waited 360s
[19252.287608] I/O error, dev sdb, sector 0 op 0x1:(WRITE) flags 0x800 phys_seg 0 prio class 2
[19612.989904] sd 6:0:0:0: [sdb] tag#0 timing out command, waited 360s
[19612.989953] I/O error, dev sdb, sector 0 op 0x1:(WRITE) flags 0x800 phys_seg 0 prio class 2
[20158.929463] sd 6:0:0:0: [sdb] tag#0 timing out command, waited 360s
[20158.929515] I/O error, dev sdb, sector 0 op 0x1:(WRITE) flags 0x800 phys_seg 0 prio class 2
[20832.236384] sd 6:0:0:0: [sdb] tag#0 timing out command, waited 360s
[20832.236432] I/O error, dev sdb, sector 0 op 0x1:(WRITE) flags 0x800 phys_seg 0 prio class 2
[21538.058331] sd 6:0:0:0: [sdb] tag#0 timing out command, waited 360s
[21538.058382] I/O error, dev sdb, sector 0 op 0x1:(WRITE) flags 0x800 phys_seg 0 prio class 2
[24482.039207] sd 6:0:0:0: [sdb] tag#0 timing out command, waited 360s
[24482.039254] I/O error, dev sdb, sector 0 op 0x1:(WRITE) flags 0x800 phys_seg 0 prio class 2
[24857.163247] sd 6:0:0:0: [sdb] tag#0 timing out command, waited 360s
[24857.163306] I/O error, dev sdb, sector 0 op 0x1:(WRITE) flags 0x800 phys_seg 0 prio class 2
[25426.470725] Freezing of tasks failed after 20.009 seconds (1 tasks refusing to freeze, wq_busy=0):
[25446.538408] Freezing of tasks failed after 20.006 seconds (1 tasks refusing to freeze, wq_busy=0):
[25762.388598] sd 6:0:0:0: [sdb] tag#0 timing out command, waited 360s
[25762.388646] I/O error, dev sdb, sector 0 op 0x1:(WRITE) flags 0x800 phys_seg 0 prio class 2
[26643.917168] sd 6:0:0:0: [sdb] tag#0 timing out command, waited 360s
[26643.917204] I/O error, dev sdb, sector 0 op 0x1:(WRITE) flags 0x800 phys_seg 0 prio class 2
[27788.455583] sd 6:0:0:0: [sdb] tag#0 timing out command, waited 360s
[27788.455630] I/O error, dev sdb, sector 0 op 0x1:(WRITE) flags 0x800 phys_seg 0 prio class 2
Possibly related is Dolphin not showing all folder expansion icons:
I do not know enough to interpret the data, any help appreciated.
