Indexing the Folder's content for research purpose
Hello, I looked in the forum but I haven’t found anything treating this specifically:
I often find myself needing to sort folders containing videos by the video length.
I found out with some research that this is possible using the sort by → audio → duration. It’s a bit tricky but actually it works, because obviously the audio track is the same as the video one.
If it was not that audio duration is not displayed as info by default, but I learnt that you have to INDEX a certain folder in order to make the system know about the details of the files.
My question are: why is it like this? Performance purpose?
Do you guys set Manjaro to Index all your drives or just some specific folders?
Just wanted some light on this topic.
Perhaps because indexing is an option - not a requirement.
I disable indexing all-together - I don’t need the indexer to hog my system - of course if you need it - they you enabled it.
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or :heart: or :+1: if you agree)
:innocent:
P.S. In the future, please don’t forget to come back to your question after your issue has been solved and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
Solution
