Ok so I’m coming from windows and I want to up my colour saturation. That usually happens in the radeon settings which are not available for manjaro. For Nvidia the same setting is called “digital vibrance”. If anyone could suggest an alternative way to manipulate this setting I’d really appreciate it.
Howdy!
There is a gamma adjustment in plasma’s settings!
Use the setting’s search feature and search for gamma!
Have a sweet day!
Hey, thanks for the quick reply, but it doesn’t work the same way. INcreasing the gamma just makes it more “bleached” / white-ish while the saturation makes the colours deeper, if you understand what I mean.
Have a great day too!
Oh, might need to lower the gamma to have desired effect.
Thank you!
maybe changing color profile?
