~ inxi -Aazy ✔
Device-1: Intel Alder Lake-S HD Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel alternate: snd_sof_pci_intel_tgl
bus-ID: 00:1f.3 chip-ID: 8086:7ad0 class-ID: 0403
Device-2: NVIDIA GA102 High Definition Audio driver: snd_hda_intel
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 01:00.1 chip-ID: 10de:1aef class-ID: 0403
Device-3: Micro Star USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-11:6
chip-ID: 0db0:1feb class-ID: 0300
API: ALSA v: k6.3.0-1-MANJARO status: kernel-api with: aoss
Server-3: PipeWire v: 0.3.70 status: active with: 1: pipewire-pulse
status: active 2: pipewire-media-session status: active 3: pipewire-alsa
type: plugin tools: pactl,pw-cat,pw-cli
~ pactl list sinks ✔
Sink #43
State: SUSPENDED
Description: GA102 High Definition Audio Controller Digital Stereo (HDMI)
Driver: PipeWire
Sample Specification: s32le 2ch 48000Hz
Channel Map: front-left,front-right
Owner Module: 4294967295
Mute: no
Volume: front-left: 48287 / 74% / -7.96 dB, front-right: 48287 / 74% / -7.96 dB
balance 0.00
Base Volume: 65536 / 100% / 0.00 dB
Monitor Source: alsa_output.pci-0000_01_00.1.hdmi-stereo.monitor
Latency: 0 usec, configured 0 usec
Flags: HARDWARE DECIBEL_VOLUME LATENCY SET_FORMATS
Properties:
object.path = "alsa:pcm:1:hdmi:1:playback"
api.alsa.path = "hdmi:1"
api.alsa.pcm.card = "1"
api.alsa.pcm.stream = "playback"
audio.channels = "2"
audio.position = "FL,FR"
device.routes = "1"
alsa.resolution_bits = "16"
device.api = "alsa"
device.class = "sound"
alsa.class = "generic"
alsa.subclass = "generic-mix"
alsa.name = "Beyond TV"
alsa.id = "HDMI 0"
alsa.subdevice = "0"
alsa.subdevice_name = "subdevice #0"
alsa.device = "3"
alsa.card = "1"
alsa.card_name = "HDA NVidia"
alsa.long_card_name = "HDA NVidia at 0x82080000 irq 17"
device.profile.name = "hdmi-stereo"
device.profile.description = "Digital Stereo (HDMI)"
card.profile.device = "4"
device.id = "39"
factory.name = "api.alsa.pcm.sink"
priority.driver = "632"
priority.session = "632"
media.class = "Audio/Sink"
node.nick = "HDA NVidia"
node.name = "alsa_output.pci-0000_01_00.1.hdmi-stereo"
device.description = "GA102 High Definition Audio Controller"
device.icon_name = "audio-card-hdmi"
device.bus = "pci"
device.bus_path = "pci-0000:01:00.1"
node.pause-on-idle = "false"
factory.id = "18"
clock.quantum-limit = "8192"
client.id = "33"
node.driver = "true"
factory.mode = "merge"
audio.adapt.follower = ""
library.name = "audioconvert/libspa-audioconvert"
object.id = "43"
object.serial = "43"
device.enum.api = "udev"
api.alsa.card = "1"
api.alsa.card.name = "HDA NVidia"
api.alsa.card.longname = "HDA NVidia at 0x82080000 irq 17"
device.plugged.usec = "3018849"
sysfs.path = "/devices/pci0000:00/0000:00:01.0/0000:01:00.1/sound/card1"
device.subsystem = "sound"
device.vendor.id = "0x10de"
device.vendor.name = "NVIDIA Corporation"
device.product.id = "0x1aef"
device.product.name = "GA102 High Definition Audio Controller"
device.name = "alsa_card.pci-0000_01_00.1"
device.nick = "HDA NVidia"
api.alsa.use-acp = "true"
api.acp.auto-port = "false"
api.dbus.ReserveDevice1 = "Audio1"
device.string = "1"
Ports:
hdmi-output-0: HDMI / DisplayPort (type: HDMI, priority: 5900, availability group: Legacy 1, available)
Active Port: hdmi-output-0
Formats:
pcm
Sink #44
State: SUSPENDED
Description: USB Audio S/PDIF Output
Driver: PipeWire
Sample Specification: s24le 2ch 48000Hz
Mute: no
balance 0.00
Monitor Source: alsa_output.usb-Generic_USB_Audio-00.HiFi_5_1__hw_Audio_2__sink.monitor
Properties:
object.path = "alsa:pcm:2:hw:Audio,2:playback"
api.alsa.path = "hw:Audio,2"
api.alsa.open.ucm = "true"
api.alsa.pcm.card = "2"
device.routes = "1"
alsa.mixer_device = "_ucm0003.hw:Audio"
device.api = "alsa"
alsa.name = "USB Audio #2"
alsa.id = "USB Audio"
alsa.device = "2"
alsa.card = "2"
alsa.card_name = "USB Audio"
alsa.long_card_name = "Generic USB Audio at usb-0000:00:14.0-11, high speed"
alsa.driver_name = "snd_usb_audio"
device.profile.name = "HiFi 5+1: hw:Audio,2: sink"
device.profile.description = "S/PDIF Output"
card.profile.device = "5"
device.id = "42"
priority.driver = "584"
priority.session = "584"
node.nick = "USB Audio"
node.name = "alsa_output.usb-Generic_USB_Audio-00.HiFi_5_1__hw_Audio_2__sink"
device.description = "USB Audio"
device.icon_name = "audio-card"
device.bus = "usb"
device.bus_path = "pci-0000:00:14.0-usb-0:11:1.0"
factory.id = "18"
client.id = "33"
object.id = "41"
object.serial = "44"
api.alsa.card = "2"
api.alsa.card.name = "USB Audio"
api.alsa.card.longname = "Generic USB Audio at usb-0000:00:14.0-11, high speed"
device.plugged.usec = "9390605"
sysfs.path = "/devices/pci0000:00/0000:00:14.0/usb1/1-11/1-11:1.0/sound/card2"
device.bus-id = "usb-Generic_USB_Audio-00"
device.vendor.id = "0x0db0"
device.vendor.name = "Micro Star International"
device.product.id = "0x1feb"
device.product.name = "USB Audio"
device.serial = "Generic_USB_Audio"
device.name = "alsa_card.usb-Generic_USB_Audio-00"
device.nick = "USB Audio"
api.dbus.ReserveDevice1 = "Audio2"
device.string = "2"
Ports:
[Out] SPDIF: S/PDIF Output (type: SPDIF, priority: 100, availability unknown)
Active Port: [Out] SPDIF
Formats:
pcm
Sink #45
State: SUSPENDED
Description: USB Audio Front Headphones
Driver: PipeWire
Mute: no
Volume: front-left: 65536 / 100% / 0.00 dB, front-right: 65536 / 100% / 0.00 dB
balance 0.00
Monitor Source: alsa_output.usb-Generic_USB_Audio-00.HiFi_5_1__hw_Audio_1__sink.monitor
Properties:
object.path = "alsa:pcm:2:hw:Audio,1:playback"
api.alsa.path = "hw:Audio,1"
device.routes = "1"
device.api = "alsa"
alsa.name = "USB Audio #1"
alsa.device = "1"
alsa.card = "2"
device.profile.name = "HiFi 5+1: hw:Audio,1: sink"
device.profile.description = "Front Headphones"
card.profile.device = "6"
device.id = "42"
priority.driver = "600"
priority.session = "600"
node.name = "alsa_output.usb-Generic_USB_Audio-00.HiFi_5_1__hw_Audio_1__sink"
device.bus = "usb"
factory.id = "18"
client.id = "33"
object.id = "44"
object.serial = "45"
api.alsa.card = "2"
device.string = "2"
Ports:
[Out] Headphones: Front Headphones (type: Headphones, priority: 300, availability group: Headphone - Output, not available)
Active Port: [Out] Headphones
Formats:
pcm
Sink #46
State: SUSPENDED
Description: USB Audio Speakers
Driver: PipeWire
Sample Specification: s32le 6ch 48000Hz
Channel Map: front-left,front-right,rear-left,rear-right,front-center,lfe
Mute: no
Volume: front-left: 52429 / 80% / -5.81 dB, front-right: 52429 / 80% / -5.81 dB, rear-left: 52429 / 80% / -5.81 dB, rear-right: 52429 / 80% / -5.81 dB, front-center: 52429 / 80% / -5.81 dB, lfe: 52429 / 80% / -5.81 dB
balance 0.00
Monitor Source: alsa_output.usb-Generic_USB_Audio-00.HiFi_5_1__hw_Audio__sink.monitor
Properties:
object.path = "alsa:pcm:2:hw:Audio:playback"
api.alsa.path = "hw:Audio"
audio.channels = "6"
audio.position = "FL,FR,RL,RR,FC,LFE"
device.routes = "1"
device.api = "alsa"
alsa.name = "USB Audio"
alsa.device = "0"
alsa.card = "2"
device.profile.name = "HiFi 5+1: hw:Audio: sink"
device.profile.description = "Speakers"
card.profile.device = "7"
device.id = "42"
priority.driver = "616"
priority.session = "616"
node.name = "alsa_output.usb-Generic_USB_Audio-00.HiFi_5_1__hw_Audio__sink"
device.bus = "usb"
factory.id = "18"
client.id = "33"
object.id = "45"
object.serial = "46"
node.max-latency = "16384/48000"
api.alsa.period-size = "512"
api.alsa.period-num = "64"
api.alsa.headroom = "512"
api.alsa.card = "2"
device.string = "2"
Ports:
[Out] Speaker: Speakers (type: Speaker, priority: 200, availability group: Speaker - Output, available)
Active Port: [Out] Speaker
Formats:
pcm
Moderator edit: In the future, please use proper formatting: [HowTo] Post command output and file content as formatted text
